# nvcc --version
Copyright (c) 2005-2018 NVIDIA Corporation
Built on Sat_Aug_25_21:08:01_CDT_2018
Cuda compilation tools, release 10.0, V10.0.130
Does this mean the version is 10.0?
However, nvidia-smi shows it is 10.1:
# nvidia-smi
Sat Nov 28 16:53:05 2020
| NVIDIA-SMI 418.87.01 Driver Version: 418.87.01 CUDA Version: 10.1 |
| 0 Tesla P100-PCIE... On | 00000000:00:0D.0 Off | 0 |
| N/A 34C P0 25W / 250W | 0MiB / 16280MiB | 0% Default |
| 1 Tesla P100-PCIE... On | 00000000:00:0E.0 Off | 0 |
| N/A 67C P0 175W / 250W | 15601MiB / 16280MiB | 96% Default |
| 2 Tesla P100-PCIE... On | 00000000:00:0F.0 Off | 0 |
| N/A 30C P0 27W / 250W | 0MiB / 16280MiB | 0% Default |
| 3 Tesla P100-PCIE... On | 00000000:00:10.0 Off | 0 |
| N/A 32C P0 27W / 250W | 0MiB / 16280MiB | 0% Default |
Then, I did this:
# pip install cupy-cuda100
And test it:
In [1]: import cupy
...: a = cupy.zeros((5, 5))
ImportError Traceback (most recent call last)
~/.venv/wbnlu/lib/python3.7/site-packages/cupy/__init__.py in <module>
19 message='can\'t resolve package from __spec__')
---> 20 from cupy import core # NOQA
21 except ImportError as e:
~/.venv/wbnlu/lib/python3.7/site-packages/cupy/core/__init__.py in <module>
----> 1 from cupy.core import core # NOQA
2 from cupy.core import internal # NOQA
3
ImportError: libnvrtc.so.10.0: cannot open shared object file: No such file or directory
The above exception was the direct cause of the following exception:
<ipython-input-1-13f62b8eee5e> in <module>
----> 1 import cupy
2 a = cupy.zeros((5, 5))
39 original error: {}'''.format(_exc_info[1])) # NOQA
40
---> 41 raise ImportError(_msg) from e
42
43
ImportError: CuPy is not correctly installed.
If you are using wheel distribution (cupy-cudaXX), make sure that the version of CuPy you installed matches with the version of CUDA on your host.
Also, confirm that only one CuPy package is installed:
$ pip freeze
If you are building CuPy from source, please check your environment, uninstall CuPy and reinstall it with:
$ pip install cupy --no-cache-dir -vvvv
Check the Installation Guide for details:
https://docs.cupy.dev/en/latest/install.html
So what’t the problem of installing cupy here?
