When I run ./simpleMemcpy, the result is as follows:(without Unified Memory)
xavier@xavier-desktop:~/cuda_demo/cuda-benchmarks-master$ ./simpleMemcpy 40000000
host: MallocHost: 0.017753
host: init arrays: 0.359125
device: malloc+copy+compute: 0.052061
host: access all arrays: 0.216636
host: access all arrays a second time: 0.053593
host: free: 0.033321
total: 0.732845
When I run ./simpleManaged, the result is as follows:(witht Unified Memory)
xavier@xavier-desktop:~/cuda_demo/cuda-benchmarks-master$ ./simpleManaged 40000000
host: MallocManaged: 0.015639
host: init arrays: 0.385382
device: uvm+compute+synchronize: 0.001809
host: access all arrays: 0.613202
host: access all arrays a second time: 0.054150
host: free: 0.033925
total: 1.104471
why the time of “host: access all array” in simpleManaged.cu is longer than that of “host: access all array” in simpleMemcpy.cu???
the Xavier is in the highest performance mode (nvpmodel –m 0 jetson_clocks)
Code of simpleMemcpy.cu:
include
include
include
include <cuda_runtime.h>
include “common.hh”
static global void
f(const uint64_t a, const uint64_t b, uint64_t c, int64_t N)
int64_t index = threadIdx.x + blockIdx.x * blockDim.x;
int64_t stride = blockDim.x * gridDim.x;
for (int64_t i = index; i < N; i += stride) {
c[i] = a[i] * b[i];
static void
doit(const uint64_t a, const uint64_t b, uint64_t c, int64_t N)
int blockSize = 256;
int64_t numBlocks = (N + blockSize - 1) / blockSize;
f<<<numBlocks, blockSize>>>(a, b, c, N);
int
main(int argc, char *argv)
size_t N = 10000000;
clock_t start_program, end_program;
clock_t start, end;
uint64_t *a, *b, *c;
uint64_t *da, *db, *dc;
size_t count;
if (argc == 2) {
N = checked_strtosize(argv[1]);
count = checked_mul(N, sizeof(uint64_t));
/* Initialize context */
check(cudaMallocHost(&a, 128));
check(cudaDeviceSynchronize());
check(cudaFreeHost(a));
start_program = clock();
start = clock();
check(cudaMallocHost(&a, count));
check(cudaMallocHost(&b, count));
check(cudaMallocHost(&c, count));
end = clock();
log("host: MallocHost", start, end);
start = clock();
for (size_t i = 0; i < N; i++) {
a[i] = 3;
b[i] = 5;
end = clock();
log("host: init arrays", start, end);
start = clock();
check(cudaMalloc(&da, count));
check(cudaMalloc(&db, count));
check(cudaMalloc(&dc, count));
check(cudaMemcpy(da, a, count, cudaMemcpyHostToDevice));
check(cudaMemcpy(db, b, count, cudaMemcpyHostToDevice));
doit(da, db, dc, N);
check(cudaMemcpy(c, dc, count, cudaMemcpyDeviceToHost));
check(cudaFree(da));
check(cudaFree(db));
check(cudaFree(dc));
end = clock();
log("device: malloc+copy+compute", start, end);
start = clock();
if (a[i] != 3 || b[i] != 5 || c[i] != 15) {
fprintf(stderr, "unexpected result a: %lu b: %lu c: %lu\n",
a[i], b[i], c[i]);
exit(1);
end = clock();
log("host: access all arrays", start, end);
start = clock();
a[i], b[i], c[i]);
exit(1);
end = clock();
log("host: access all arrays a second time", start, end);
start = clock();
check(cudaFreeHost(b));
check(cudaFreeHost(c));
end = clock();
log("host: free", start, end);
end_program = clock();
log("total", start_program, end_program);
return 0;
include
include
include “common.hh”
static global void
c[i] = a[i] * b[i];
static void
int
clock_t start, end;
size_t count;
if (argc == 2) {
check(cudaMallocManaged(&a, 128));
check(cudaFree(a));
start = clock();
check(cudaMallocManaged(&a, count));
check(cudaMallocManaged(&b, count));
check(cudaMallocManaged(&c, count));
end = clock();
log("host: MallocManaged", start, end);
start = clock();
a[i] = 3;
b[i] = 5;
end = clock();
start = clock();
doit(a, b, c, N);
end = clock();
log("device: uvm+compute+synchronize", start, end);
start = clock();
a[i], b[i], c[i]);
exit(1);
end = clock();
start = clock();
a[i], b[i], c[i]);
exit(1);
end = clock();
start = clock();
check(cudaFree(a));
check(cudaFree(b));
check(cudaFree(c));
end = clock();
return 0;
