Hi,all.
On the Xavier, JP4.4, DS5.0.
I had 2 sources,and 2 sinks, linked by nvstreammux and nvstreamdemux,.
On the sink0 linked by demux.src0 I always could found video frames cames from mux.sink1, why ?
It can be hit by the pipeline as bellow in probability.
gst-launch-1.0
nvstreammux name=streammux width=1920 height=1080 batch-size=1 live-source=1 batched-push-timeout=40000
nvstreamdemux name=streamdemux
streammux. ! queue ! streamdemux.
videotestsrc pattern=0 ! nvvideoconvert ! “video/x-raw(memory:NVMM),format=NV12” ! streammux.sink_0
videotestsrc pattern=1 ! nvvideoconvert ! “video/x-raw(memory:NVMM),format=NV12” ! streammux.sink_1
streamdemux.src_0 ! queue ! nvvideoconvert ! “video/x-raw(memory:NVMM),format=I420” ! nvoverlaysink sync=false
streamdemux.src_1 ! queue ! fakesink sync=false
gst-launch-1.0
nvstreammux name=streammux width=1920 height=1080 batch-size=1 live-source=1 batched-push-timeout=0
streamdemux.src_0 ! queue ! nvoverlaysink sync=false
Amycao
June 10, 2020, 9:28am
3
Hi
Please change batch-size=1 in streammux to 2.
Hi,amycao.
It’s not working, just the same.
Amycao
June 11, 2020, 3:37am
5
Here is the command used, it’s working on my side.
gst-launch-1.0 nvstreammux name=streammux width=1920 height=1080 batch-size=2 live-source=1 batched-push-timeout=40000 nvstreamdemux name=streamdemux streammux. ! queue ! streamdemux. videotestsrc pattern=0 ! nvvideoconvert ! “video/x-raw(memory:NVMM),format=NV12” ! streammux.sink_0 videotestsrc pattern=1 ! nvvideoconvert ! “video/x-raw(memory:NVMM),format=NV12” ! streammux.sink_1 streamdemux.src_0 ! queue ! nvvideoconvert ! “video/x-raw(memory:NVMM),format=I420” ! nvegltransform ! nveglglessink sync=false streamdemux.src_1 ! queue ! fakesink sync=false
133a22ff6857665a.zip (291.8 KB)
Hi, amycao.
The same command do not work on my side.
I can still find frames from sink_1, at the first few frames when the command is started.
by the way, How to upload compressed file or video file.
Amycao
June 16, 2020, 1:51am
7
you can compress it into zip extension file, and size limited to 4MB, I remembered. you can cut the clip which have the issue from original video.
Hi, amycao.
the compressed file can’t be upload.
Amycao
June 16, 2020, 1:32pm
9
Oh, then you could add extension which supported after the file name.
Hi,amycao.
Here is the command used, I found frames from sink_1, at the first few frames when the command is started.
test.mp4.cpp (670.8 KB)
Amycao
June 30, 2020, 9:11am
13
Hi
I extract the mp4 file into a series of frames, as attached as pics.zip, except the first 5 frames, should be your working server screen, after these frames, until the final frame OTxxx_0000000014.jpg, it all from videotestsrc pattern 0. please let me know where your issue lies.
pics.zip (1.0 MB)
Hi,amycao.
The pipeline is just for test.
In the pipeline we used the issue can be hit at all time.
Maybe the patch can hit the issue better. It’s based on deepstream_sdk_v5.0.0_jetson.tbz2.
deepstream-5.0.patch.cpp (6.4 KB)
0.00.00.283240361-ds-app-playing.dot.cpp (76.4 KB)
Amycao
July 15, 2020, 2:39am
17
Have reproed your issue, will update to you once have progress.
Amycao
July 28, 2020, 2:26pm
18
Please try with attached config, issue gone with this config.
source1_usb_dec_infer_resnet_int8.txt (2.9 KB)
All cames from videotestsrc pattern 1 except the first few frames.
But if change all the batch-size to 1, or the batched-push-timeout to 10000 (maybe need to change all to container to 2 to fix an error “ERROR from sink_sub_bin_mux3: Could not multiplex stream.”), there’s a few frames from videotestsrc pattern 1 every once in a while .
Amycao
August 7, 2020, 5:14am
20
2251582984:
→ please see folders
Dropbox
Dropbox
→ either do not have frames from another source. using the config i shared and test code you shared.
→ Do you mean if change streammux batch size to 1 in the config i shared will cause the error “ERROR from sink_sub_bin_mux3: Could not multiplex stream.” ? even if i change streammux batch size to 1, i do not have this issue.
Please see inline. seems we still have some difference. please specify detaied.
Hi,amycao.
We had found the same problem on the nano, TX2, Xavier NX.
All the devices are flashed by JP4.4 and run on our own custom board
the sources , videos and executable program compiled on TX2 attached.
deepstream-5.0.tar.gz (2.6 MB)
640ef7aab8a8425cd999ac08de8315b0.mp4.cpp (838.2 KB)
deepstream-app.tar.gz (220 KB)
the test command is :
./deepstream-app -c …/…/…/…/samples/configs/deepstream-app/source1_usb_dec_infer_resnet_int8_2.txt
./deepstream-app -c …/…/…/…/samples/configs/deepstream-app/source1_usb_dec_infer_resnet_int8_1.txt
I face this issue too, anyone have new update?
Link issue to two post similar.
I run deepstream app with input multiple streams and output split multiple sinks for each streams (multifilesink). The problem is that sometime frame of stream 2 place over stream 1 but still keep objects was draw of stream 1 on it. With deepstream version 4 everything is ok, but after deepstream 5 release and I move project on then the problem above happen, and I assume nvstreamdemux plugin maybe have some change, isnt’t it?. Please check.
Please provide complete information as applicable to …
and
• Hardware Platform (jetson xavier nx devkit)
• DeepStream Version5.0
• JetPack Version (valid for Jetson only)4.4
• TensorRT Version7.1
hello everyone,I have some problems when I using pipeling for multiple streams output.
here is my pipeline [mypipeline_no]
two streams into streammux → streamdemux → two queues → two geltransform+gelsink, it’s a simple test.
and I got something strange:
1. I can see one or two frame from …
Amycao
August 25, 2020, 4:55am
23
HI,
I can repro your issue using the config source1_usb_dec_infer_resnet_int8_2.txt in your package deepstream-5.0.tar.gz
but after comment out sink0 group, change sink1 to sink0 and sink2 to sink1,
the issue will gone. you can use attached config to give a try.
source1_usb_dec_infer_resnet_int8.txt (3.0 KB)
Hi,amycao.
It’s just a test to repro the issue. And comment the sink which use the nvoverlaysink don’t work in our formal projects.
Amycao
September 2, 2020, 6:33am
25
Hi
Since I can not repro your issue using your provided test code and config modified, it’s hart to tell why it’s not working in your formal project, you need to debug first to narrow down the issue, if related with nvidia, we will look into it.
