I observe ~10% variation run-to-run in the reported time of that sortingNetworks example code without any UM addition:
$ ./sortingNetworks
./sortingNetworks Starting...
Starting up CUDA context...
GPU Device 0: "Tesla V100-PCIE-32GB" with compute capability 7.0
Allocating and initializing host arrays...
Allocating and initializing CUDA arrays...
Running GPU bitonic sort (10000 identical iterations)...
Testing array length 64 (16384 arrays per batch)...
Average time: 0.067686 ms
Testing array length 1048576 (1 arrays per batch)...
Average time: 1.658396 ms
sortingNetworks-bitonic, Throughput = 632.2834 MElements/s, Time = 0.00166 s, Size = 1048576 elements, NumDevsUsed = 1, Workgroup = 512
Validating the results...
...reading back GPU results
...inspecting keys array: OK
...inspecting keys and values array: OK
...stability property: NOT stable
Shutting down...
$ ./sortingNetworks
Average time: 0.066287 ms
Average time: 1.802872 ms
sortingNetworks-bitonic, Throughput = 581.6143 MElements/s, Time = 0.00180 s, Size = 1048576 elements, NumDevsUsed = 1, Workgroup = 512
Shutting down...
At the low end of the above range we see 1.65ms average kernel runtime for the 1048576 test case, and 1.80ms average run time for the same test in the second run. 10000 iterations.
I’m not sure what a 10% difference tells you in that test.
Then, when I recompiled and ran with the UM mod you suggested at the beginning of main.cpp, I got a result that was at the low end of the above range:
$ nvcc -I/usr/local/cuda/samples/common/inc -arch=sm_70 -o sortingNetworks *.cu *.cpp -DUSE_TEST
$ ./sortingNetworks
Average time: 0.067579 ms
Average time: 1.656511 ms
sortingNetworks-bitonic, Throughput = 633.0026 MElements/s, Time = 0.00166 s, Size = 1048576 elements, NumDevsUsed = 1, Workgroup = 512
Shutting down...
So I can’t see any difference based on the test you suggested.
Here’s my modified main.cpp, the only mods were for numIterations and the use of USE_TEST
$ cat main.cpp
* Copyright 1993-2015 NVIDIA Corporation. All rights reserved.
* Please refer to the NVIDIA end user license agreement (EULA) associated
* with this source code for terms and conditions that govern your use of
* this software. Any use, reproduction, disclosure, or distribution of
* this software and related documentation outside the terms of the EULA
* is strictly prohibited.
* This sample implements bitonic sort and odd-even merge sort, algorithms
* belonging to the class of sorting networks.
* While generally subefficient on large sequences
* compared to algorithms with better asymptotic algorithmic complexity
* (i.e. merge sort or radix sort), may be the algorithms of choice for sorting
* batches of short- or mid-sized arrays.
* Refer to the excellent tutorial by H. W. Lang:
* http://www.iti.fh-flensburg.de/lang/algorithmen/sortieren/networks/indexen.htm
* Victor Podlozhnyuk, 07/09/2009
// CUDA Runtime
#include <cuda_runtime.h>
// Utilities and system includes
#include <helper_cuda.h>
#include <helper_timer.h>
#include "sortingNetworks_common.h"
// Test driver
int main(int argc, char **argv)
cudaError_t error;
printf("%s Starting...\n\n", argv[0]);
printf("Starting up CUDA context...\n");
int dev = findCudaDevice(argc, (const char **)argv);
uint *h_InputKey, *h_InputVal, *h_OutputKeyGPU, *h_OutputValGPU;
uint *d_InputKey, *d_InputVal, *d_OutputKey, *d_OutputVal;
StopWatchInterface *hTimer = NULL;
const uint N = 1048576;
const uint DIR = 0;
const uint numValues = 65536;
const uint numIterations = 10000;
printf("Allocating and initializing host arrays...\n\n");
sdkCreateTimer(&hTimer);
h_InputKey = (uint *)malloc(N * sizeof(uint));
h_InputVal = (uint *)malloc(N * sizeof(uint));
h_OutputKeyGPU = (uint *)malloc(N * sizeof(uint));
h_OutputValGPU = (uint *)malloc(N * sizeof(uint));
srand(2001);
#ifdef USE_TEST
uint *test;
error = cudaMallocManaged(&test, N*sizeof(uint));
checkCudaErrors(error);
#endif
for (uint i = 0; i < N; i++)
h_InputKey[i] = rand() % numValues;
h_InputVal[i] = i;
printf("Allocating and initializing CUDA arrays...\n\n");
error = cudaMalloc((void **)&d_InputKey, N * sizeof(uint));
error = cudaMalloc((void **)&d_InputVal, N * sizeof(uint));
error = cudaMalloc((void **)&d_OutputKey, N * sizeof(uint));
error = cudaMalloc((void **)&d_OutputVal, N * sizeof(uint));
error = cudaMemcpy(d_InputKey, h_InputKey, N * sizeof(uint), cudaMemcpyHostToDevice);
error = cudaMemcpy(d_InputVal, h_InputVal, N * sizeof(uint), cudaMemcpyHostToDevice);
int flag = 1;
printf("Running GPU bitonic sort (%u identical iterations)...\n\n", numIterations);
for (uint arrayLength = 64; arrayLength <= N; arrayLength *= 2)
printf("Testing array length %u (%u arrays per batch)...\n", arrayLength, N / arrayLength);
error = cudaDeviceSynchronize();
sdkResetTimer(&hTimer);
sdkStartTimer(&hTimer);
uint threadCount = 0;
for (uint i = 0; i < numIterations; i++)
threadCount = bitonicSort(
d_OutputKey,
d_OutputVal,
d_InputKey,
d_InputVal,
N / arrayLength,
arrayLength,
DIR
sdkStopTimer(&hTimer);
printf("Average time: %f ms\n\n", sdkGetTimerValue(&hTimer) / numIterations);
if (arrayLength == N)
double dTimeSecs = 1.0e-3 * sdkGetTimerValue(&hTimer) / numIterations;
printf("sortingNetworks-bitonic, Throughput = %.4f MElements/s, Time = %.5f s, Size = %u elements, NumDevsUsed = %u, Workgroup = %u\n",
(1.0e-6 * (double)arrayLength/dTimeSecs), dTimeSecs, arrayLength, 1, threadCount);
printf("\nValidating the results...\n");
printf("...reading back GPU results\n");
error = cudaMemcpy(h_OutputKeyGPU, d_OutputKey, N * sizeof(uint), cudaMemcpyDeviceToHost);
error = cudaMemcpy(h_OutputValGPU, d_OutputVal, N * sizeof(uint), cudaMemcpyDeviceToHost);
int keysFlag = validateSortedKeys(h_OutputKeyGPU, h_InputKey, N / arrayLength, arrayLength, numValues, DIR);
int valuesFlag = validateValues(h_OutputKeyGPU, h_OutputValGPU, h_InputKey, N / arrayLength, arrayLength);
flag = flag && keysFlag && valuesFlag;
printf("\n");
printf("Shutting down...\n");
sdkDeleteTimer(&hTimer);
cudaFree(d_OutputVal);
cudaFree(d_OutputKey);
cudaFree(d_InputVal);
cudaFree(d_InputKey);
free(h_OutputValGPU);
free(h_OutputKeyGPU);
free(h_InputVal);
free(h_InputKey);
exit(flag ? EXIT_SUCCESS : EXIT_FAILURE);
