Why l1 cache always hit at the first access
I run the following code on Orin-X with Jetpack version 6.2.1
In kernel, the time_record should be the latency of gpu accessing global memory from index 0 to iterations/2 and the latency of gpu accessing l1 cache from index iterations/2 to the end.
__global__ void l1_cache_size_test_kernel(unsigned int * my_array, unsigned int * time_record, unsigned int * index_record,
                            int iterations, int * sum)
    int i;
    volatile int j = 0;
    int tmp = 0;
    *sum = 0;
    j = 0;
    for (i = 0; i < iterations/2; i++) {
        unsigned int start_time = clock();
        j = my_array[j];
        // s_index[i % 100] = j;
        tmp += j;
        unsigned int end_time = clock();
        // __threadfence();
        time_record[i] = end_time - start_time;
        // index_record[i] = j;
        // __threadfence();
    __threadfence();
    j = 0;
    for (i = iterations/2; i < iterations; i++) {
        j = my_array[j];
        tmp += j;
        // __threadfence();
        // __threadfence();
    *sum = tmp;
int main()
    int i;
    int stride = 1;
    int array_size = 36870;
    size_t Value;
    cudaDeviceGetLimit(&Value, cudaLimitMaxL2FetchGranularity);
    printf("L2 fetch granularity before set: %lu\n", Value);
    cudaDeviceSetLimit(cudaLimitMaxL2FetchGranularity, 32);
    printf("L2 fetch granularity after set: %lu\n", Value);
    int * sum_d;
    int * sum_h = (int *)malloc(1 * sizeof(unsigned int));
    unsigned int * A_h = (unsigned int *)malloc(array_size * sizeof(unsigned int));
    unsigned int * A_d;
    cudaMalloc(&A_d, array_size * sizeof(unsigned int));
    cudaMalloc(&sum_d, 1 * sizeof(unsigned int));
    for (i = 0; i < array_size; i++) {
        A_h[i] = (i + stride) % array_size;
    cudaMemcpy(A_d, A_h, array_size * sizeof(unsigned int), cudaMemcpyHostToDevice);
    unsigned int * time_record_h = (unsigned int *)malloc(array_size * sizeof(unsigned int));
    unsigned int * index_record_h = (unsigned int *)malloc(array_size * sizeof(unsigned int));
    unsigned int * time_record_d;
    unsigned int * index_record_d;
    cudaMalloc(&time_record_d, array_size * sizeof(unsigned int));
    cudaMalloc(&index_record_d, array_size * sizeof(unsigned int));
    // execute l1 cache size test
    l1_cache_size_test_kernel<<<1, 1>>>(A_d, time_record_d, index_record_d, array_size, sum_d);
    cudaDeviceSynchronize();
    cudaMemcpy(time_record_h, time_record_d, array_size * sizeof(unsigned int), cudaMemcpyDeviceToHost);
    cudaMemcpy(index_record_h, index_record_d, array_size * sizeof(unsigned int), cudaMemcpyDeviceToHost);
    cudaMemcpy(sum_h, sum_d, 1 * sizeof(unsigned int), cudaMemcpyDeviceToHost);
    int max_time = 0, max_time_index = 0;
        if (time_record_h[i] > max_time) {
            max_time = time_record_h[i];
            max_time_index = i;
        if (time_record_h[i] > 0) {
            printf("%d: index %u, time %u\n", i, index_record_h[i], time_record_h[i]);
    printf("max_time: %d, index %d\n", max_time, max_time_index);
    printf("sum_h: %d\n", *sum_h);
    free(sum_h);
    free(A_h);
    free(time_record_h);
    cudaFree(A_d);
    cudaFree(time_record_d);
    cudaFree(sum_d);
    return 0;
But, the result shows below(The index can be ignored). The first value of time_record is 30 which means the sm access l1 cache. So I have two questions:
  1. What happened at the first access ?
  2. Why does the time access L1 cache differ ? They are always be 19 or 42
  3. As far as I know, the size of L1 cache is 144KB in orin-X. From log can conclude that sm access L2 cache in the second for loop in kernel. Why doesn’t it access the l1 cache?
Furthermore, when I uncomment the index_record(kernel code shows below),
    int i;
    volatile int j = 0;
    int tmp = 0;
    *sum = 0;
    j = 0;
        j = my_array[j];
        tmp += j;
        // __threadfence();
        // __threadfence();
    __threadfence();
    j = 0;
        j = my_array[j];
        tmp += j;
        // __threadfence();
        // __threadfence();
    *sum = tmp;
the result becomes different. From log can conclude that sm access l1-cache in the first for loop in kernel and access l2-cache in the second loop. Why does the l1-cache hit in the first loop when there is no preheat operation ?
there is no guarantee that the compiler has not moved instructions around, into or out of the timing region, so it is necessary to study the SASS to have confident understanding of what is actually happening.
The generated SASS is not measuring what you expect and there is no method in the compiler today to force it to do what you want.
I simplified the kernel to the first loop and output the SASS for sm_80.
    int i;
    volatile int j = 0;
    int tmp = 0;
    *sum = 0;
    j = 0;
    for (i = 0; i < 2; i++) {
        j = my_array[j];
        tmp += j;
        // __threadfence();
        // __threadfence();
    *sum = tmp;
The two timing ranges have numerous issues.
For some reason the start_time = clock() is being converted to a S2UR which is a variable latency instruction. The DEPBAR.LE verifies the S2UR has returned. Additional instructions are included for the address calculation and LDG. The CS2R after the LDG is reading the timestamp after the LDG is issued but with no dependency that the LDG has completed. See the R0 read to use bar on the right.
    MOV R1, c[0x0][0x28]
    MOV R2, c[0x0][0x180]
    ULDC.64 UR4, c[0x0][0x118]
    MOV R3, c[0x0][0x184]
    STG.E desc[UR4][R2.64], RZ
 -> S2UR UR6, SR_CLOCKLO
|   DEPBAR.LE SB1, 0x0
|   HFMA2.MMA R9, -RZ, RZ, 0, 2.384185791015625e-07
|   IMAD.WIDE R4, RZ, R9, c[0x0][0x160]
|   LDG.E R0, desc[UR4][R4.64]                          R0 read
 -> CS2R.32 R7, SR_CLOCKLO                              |
    IADD3 R7, R7, -UR6, RZ                              |
    IMAD.MOV.U32 R4, RZ, RZ, c[0x0][0x168]              |
    MOV R5, c[0x0][0x16c]                               |
    STG.E desc[UR4][R4.64], R7                          |
 -> S2UR UR6, SR_CLOCKLO                                |
|   DEPBAR.LE SB2, 0x0                                  |
|   IMAD.WIDE R6, R0, R9, c[0x0][0x160]                 R0 used
|   LDG.E R7, desc[UR4][R6.64]
|   IADD3 R9, R0, R7, RZ
    STG.E desc[UR4][R4.64+0x4], R7
    STG.E desc[UR4][R2.64], R9
    EXIT
If #pragma unroll 1 is added before the loop then the timing makes more sense; however, S2UR is still in use.
l1_cache_size_test_kernel(unsigned int*, unsigned int*, unsigned int*, int, int*):
        HFMA2.MMA R0, -RZ, RZ, 0, 0
        CS2R R6, SRZ
.L_x_0:
|       DEPBAR.LE SB1, 0x0
|       MOV R11, 0x4
|       IMAD.WIDE R4, R6, R11, c[0x0][0x160]
|       LDG.E R6, desc[UR4][R4.64]                      R6 read
|       IADD3 R7, R6, R7, RZ                            R6 use
 ->     CS2R.32 R9, SR_CLOCKLO
        IMAD.WIDE R4, R0.reuse, R11, c[0x0][0x168]
        IADD3 R0, R0, 0x1, RZ
        IADD3 R9, R9, -UR6, RZ
        ISETP.GE.U32.AND P0, PT, R0, 0x2, PT
        IMAD.MOV.U32 R0, RZ, RZ, 0x1
        STG.E desc[UR4][R4.64], R9
   @!P0 BRA `(.L_x_0)
        STG.E desc[UR4][R2.64], R7
        EXIT
.L_x_1:
        BRA `(.L_x_1)
        NOP
        NOP
        NOP
        NOP
        NOP
        NOP
        NOP
        NOP
.L_x_2:
The ideal code generation would look like
-> CS2R R10, SR_CLOCKLO | LDG.E R6, desc[UR4][R4.64] R6 read | IADD3 R7, R6, R7, RZ R6 use -> CS2R.32 R9, SR_CLOCKLO
This moves the address calculation to a separate statement before the clock.
This tries to use inline PTX in place of S2UR.
static __device__ inline uint32_t __rd_clock()
    uint32_t clock;
    asm volatile("mov.u32 %0, %%clock;" : "=r"(clock) );
    return clock;
    int i;
    volatile int j = 0;
    int tmp = 0;
    *sum = 0;
    j = 0;
#pragma unroll 1
        unsigned int* pj = &my_array[j];
        unsigned int start_time = __rd_clock();
        j = *pj;
        tmp += j;
        unsigned int end_time = __rd_clock();
    *sum = tmp;
Moving the address calculation out did remove a few instructions; however, even using inline PTX does not stop the compiler from using the S2UR.
        CS2R R6, SRZ
.L_x_0:
        MOV R11, 0x4
        DEPBAR.LE SB1, 0x0
@!P0 BRA `(.L_x_0)
        EXIT
The S2UR instruction can only read 32-bit special register. The CS2R can read 32-bit or 64-bit.
Please note I changed several locations to use fixed width types.
#include <stdint.h>
static __device__ inline uint64_t __rd_clock64()
    uint64_t clock;
    asm volatile("mov.u64 %0, %%clock64;" : "=l"(clock) );
    return clock;
__global__ void l1_cache_size_test_kernel(unsigned int * my_array, uint64_t * time_record, unsigned int * index_record, int iterations, int * sum)
    int i;
    volatile int j = 0;
    int tmp = 0;
    *sum = 0;
    j = 0;
#pragma unroll 1
        uint64_t start_time = __rd_clock64();
        j = *pj;
        tmp += j;
        uint64_t end_time = __rd_clock64();
    *sum = tmp;
Using 64-bit clock read fixes the code generation. I would recommend filing a compiler bug.
    l1_cache_size_test_kernel(unsigned int*, unsigned long*, unsigned int*, int, int*):
            CS2R R8, SRZ
    .L_x_0:
            MOV R5, 0x4
            IMAD.WIDE R4, R8, R5, c[0x0][0x160]
 ->         CS2R R6, SR_CLOCKLO
|           LDG.E R8, desc[UR4][R4.64]
|           IADD3 R9, R8, R9, RZ
 ->         CS2R R4, SR_CLOCKLO
            IADD3 R6, P0, -R6, R4, RZ
            IMAD.MOV.U32 R11, RZ, RZ, 0x8
            IADD3.X R7, ~R7, R5, RZ, P0, !PT
            STG.E.64 desc[UR4][R4.64], R6
    @!P0 BRA `(.L_x_0)
            EXIT
    .L_x_1:
Thank you for replying.
I use the “nvcc -ptx“ to get ptx code of l1_cache_size_test_kernel.
The result shows with index_record[i]=j uncommented:
// Generated by NVIDIA NVVM Compiler
// Compiler Build ID: CL-34714021
// Cuda compilation tools, release 12.6, V12.6.68
// Based on NVVM 7.0.1
.version 8.5
.target sm_52
.address_size 64
	// .globl	_Z25l1_cache_size_test_kernelPjS_S_iPi
.visible .entry _Z25l1_cache_size_test_kernelPjS_S_iPi(
	.param .u64 _Z25l1_cache_size_test_kernelPjS_S_iPi_param_0,
	.param .u64 _Z25l1_cache_size_test_kernelPjS_S_iPi_param_1,
	.param .u64 _Z25l1_cache_size_test_kernelPjS_S_iPi_param_2,
	.param .u32 _Z25l1_cache_size_test_kernelPjS_S_iPi_param_3,
	.param .u64 _Z25l1_cache_size_test_kernelPjS_S_iPi_param_4
	.reg .pred 	%p<11>;
	.reg .b32 	%r<143>;
	.reg .b64 	%rd<85>;
	ld.param.u64 	%rd28, [_Z25l1_cache_size_test_kernelPjS_S_iPi_param_0];
	ld.param.u64 	%rd29, [_Z25l1_cache_size_test_kernelPjS_S_iPi_param_1];
	ld.param.u64 	%rd30, [_Z25l1_cache_size_test_kernelPjS_S_iPi_param_2];
	ld.param.u64 	%rd31, [_Z25l1_cache_size_test_kernelPjS_S_iPi_param_4];
	ld.param.u32 	%r33, [_Z25l1_cache_size_test_kernelPjS_S_iPi_param_3];
	cvta.to.global.u64 	%rd1, %rd30;
	cvta.to.global.u64 	%rd2, %rd29;
	cvta.to.global.u64 	%rd3, %rd28;
	mov.u32 	%r34, 0;
	mov.u32 	%r142, %r34;
	cvta.to.global.u64 	%rd5, %rd31;
	st.global.u32 	[%rd5], %r34;
	shr.u32 	%r35, %r33, 31;
	add.s32 	%r36, %r33, %r35;
	shr.s32 	%r1, %r36, 1;
	setp.lt.s32 	%p1, %r33, 2;
	mov.u32 	%r141, %r34;
	@%p1 bra 	$L__BB0_7;
	add.s32 	%r40, %r1, -1;
	and.b32  	%r131, %r1, 3;
	setp.lt.u32 	%p2, %r40, 3;
	mov.u32 	%r141, 0;
	mov.u32 	%r129, %r141;
	@%p2 bra 	$L__BB0_4;
	sub.s32 	%r126, %r1, %r131;
	mov.u32 	%r141, 0;
	mov.u64 	%rd77, %rd1;
	mov.u64 	%rd78, %rd2;
$L__BB0_3:
	// begin inline asm
	mov.u64 	%rd33, %clock64;
	// end inline asm
	cvt.u32.u64 	%r43, %rd33;
	mov.u32 	%r44, %r142;
	mul.wide.s32 	%rd41, %r44, 4;
	add.s64 	%rd42, %rd3, %rd41;
	ld.global.u32 	%r45, [%rd42];
	mov.u32 	%r142, %r45;
	mov.u32 	%r46, %r142;
	add.s32 	%r47, %r46, %r141;
	// begin inline asm
	mov.u64 	%rd34, %clock64;
	// end inline asm
	cvt.u32.u64 	%r48, %rd34;
	sub.s32 	%r49, %r48, %r43;
	st.global.u32 	[%rd78], %r49;
	mov.u32 	%r50, %r142;
	st.global.u32 	[%rd77], %r50;
	// begin inline asm
	mov.u64 	%rd35, %clock64;
	// end inline asm
	cvt.u32.u64 	%r51, %rd35;
	mov.u32 	%r52, %r142;
	mul.wide.s32 	%rd43, %r52, 4;
	add.s64 	%rd44, %rd3, %rd43;
	ld.global.u32 	%r53, [%rd44];
	mov.u32 	%r142, %r53;
	mov.u32 	%r54, %r142;
	add.s32 	%r55, %r54, %r47;
	// begin inline asm
	mov.u64 	%rd36, %clock64;
	// end inline asm
	cvt.u32.u64 	%r56, %rd36;
	sub.s32 	%r57, %r56, %r51;
	st.global.u32 	[%rd78+4], %r57;
	mov.u32 	%r58, %r142;
	st.global.u32 	[%rd77+4], %r58;
	// begin inline asm
	mov.u64 	%rd37, %clock64;
	// end inline asm
	cvt.u32.u64 	%r59, %rd37;
	mov.u32 	%r60, %r142;
	mul.wide.s32 	%rd45, %r60, 4;
	add.s64 	%rd46, %rd3, %rd45;
	ld.global.u32 	%r61, [%rd46];
	mov.u32 	%r142, %r61;
	mov.u32 	%r62, %r142;
	add.s32 	%r63, %r62, %r55;
	// begin inline asm
	mov.u64 	%rd38, %clock64;
	// end inline asm
	cvt.u32.u64 	%r64, %rd38;
	sub.s32 	%r65, %r64, %r59;
	st.global.u32 	[%rd78+8], %r65;
	mov.u32 	%r66, %r142;
	st.global.u32 	[%rd77+8], %r66;
	// begin inline asm
	mov.u64 	%rd39, %clock64;
	// end inline asm
	cvt.u32.u64 	%r67, %rd39;
	mov.u32 	%r68, %r142;
	mul.wide.s32 	%rd47, %r68, 4;
	add.s64 	%rd48, %rd3, %rd47;
	ld.global.u32 	%r69, [%rd48];
	mov.u32 	%r142, %r69;
	mov.u32 	%r70, %r142;
	add.s32 	%r141, %r70, %r63;
	// begin inline asm
	mov.u64 	%rd40, %clock64;
	// end inline asm
	cvt.u32.u64 	%r71, %rd40;
	sub.s32 	%r72, %r71, %r67;
	st.global.u32 	[%rd78+12], %r72;
	mov.u32 	%r73, %r142;
	st.global.u32 	[%rd77+12], %r73;
	add.s32 	%r129, %r129, 4;
	add.s64 	%rd78, %rd78, 16;
	add.s64 	%rd77, %rd77, 16;
	add.s32 	%r126, %r126, -4;
	setp.ne.s32 	%p3, %r126, 0;
	@%p3 bra 	$L__BB0_3;
$L__BB0_4:
	setp.eq.s32 	%p4, %r131, 0;
	@%p4 bra 	$L__BB0_7;
	mul.wide.s32 	%rd49, %r129, 4;
	add.s64 	%rd80, %rd1, %rd49;
	add.s64 	%rd79, %rd2, %rd49;
$L__BB0_6:
	.pragma "nounroll";
	// begin inline asm
	mov.u64 	%rd50, %clock64;
	// end inline asm
	cvt.u32.u64 	%r74, %rd50;
	mov.u32 	%r75, %r142;
	mul.wide.s32 	%rd52, %r75, 4;
	add.s64 	%rd53, %rd3, %rd52;
	ld.global.u32 	%r76, [%rd53];
	mov.u32 	%r142, %r76;
	mov.u32 	%r77, %r142;
	add.s32 	%r141, %r77, %r141;
	// begin inline asm
	mov.u64 	%rd51, %clock64;
	// end inline asm
	cvt.u32.u64 	%r78, %rd51;
	sub.s32 	%r79, %r78, %r74;
	st.global.u32 	[%rd79], %r79;
	mov.u32 	%r80, %r142;
	st.global.u32 	[%rd80], %r80;
	add.s64 	%rd80, %rd80, 4;
	add.s64 	%rd79, %rd79, 4;
	add.s32 	%r131, %r131, -1;
	setp.ne.s32 	%p5, %r131, 0;
	@%p5 bra 	$L__BB0_6;
$L__BB0_7:
	membar.gl;
	setp.ge.s32 	%p6, %r1, %r33;
	@%p6 bra 	$L__BB0_14;
	sub.s32 	%r83, %r33, %r1;
	and.b32  	%r135, %r83, 3;
	setp.eq.s32 	%p7, %r135, 0;
	mov.u32 	%r137, %r1;
	@%p7 bra 	$L__BB0_11;
	mul.wide.s32 	%rd54, %r1, 4;
	add.s64 	%rd82, %rd1, %rd54;
	add.s64 	%rd81, %rd2, %rd54;
	mov.u32 	%r137, %r1;
$L__BB0_10:
	.pragma "nounroll";
	// begin inline asm
	mov.u64 	%rd55, %clock64;
	// end inline asm
	cvt.u32.u64 	%r84, %rd55;
	mov.u32 	%r85, %r142;
	mul.wide.s32 	%rd57, %r85, 4;
	add.s64 	%rd58, %rd3, %rd57;
	ld.global.u32 	%r86, [%rd58];
	mov.u32 	%r142, %r86;
	mov.u32 	%r87, %r142;
	add.s32 	%r141, %r87, %r141;
	// begin inline asm
	mov.u64 	%rd56, %clock64;
	// end inline asm
	cvt.u32.u64 	%r88, %rd56;
	sub.s32 	%r89, %r88, %r84;
	st.global.u32 	[%rd81], %r89;
	mov.u32 	%r90, %r142;
	st.global.u32 	[%rd82], %r90;
	add.s32 	%r137, %r137, 1;
	add.s64 	%rd82, %rd82, 4;
	add.s64 	%rd81, %rd81, 4;
	add.s32 	%r135, %r135, -1;
	setp.ne.s32 	%p8, %r135, 0;
	@%p8 bra 	$L__BB0_10;
$L__BB0_11:
	not.b32 	%r91, %r1;
	add.s32 	%r92, %r91, %r33;
	setp.lt.u32 	%p9, %r92, 3;
	@%p9 bra 	$L__BB0_14;
	mul.wide.s32 	%rd59, %r137, 4;
	add.s64 	%rd60, %rd59, 8;
	add.s64 	%rd84, %rd2, %rd60;
	add.s64 	%rd83, %rd1, %rd60;
$L__BB0_13:
	// begin inline asm
	mov.u64 	%rd61, %clock64;
	// end inline asm
	cvt.u32.u64 	%r93, %rd61;
	mov.u32 	%r94, %r142;
	mul.wide.s32 	%rd69, %r94, 4;
	add.s64 	%rd70, %rd3, %rd69;
	ld.global.u32 	%r95, [%rd70];
	mov.u32 	%r142, %r95;
	mov.u32 	%r96, %r142;
	add.s32 	%r97, %r96, %r141;
	// begin inline asm
	mov.u64 	%rd62, %clock64;
	// end inline asm
	cvt.u32.u64 	%r98, %rd62;
	sub.s32 	%r99, %r98, %r93;
	st.global.u32 	[%rd84+-8], %r99;
	mov.u32 	%r100, %r142;
	st.global.u32 	[%rd83+-8], %r100;
	// begin inline asm
	mov.u64 	%rd63, %clock64;
	// end inline asm
	cvt.u32.u64 	%r101, %rd63;
	mov.u32 	%r102, %r142;
	mul.wide.s32 	%rd71, %r102, 4;
	add.s64 	%rd72, %rd3, %rd71;
	ld.global.u32 	%r103, [%rd72];
	mov.u32 	%r142, %r103;
	mov.u32 	%r104, %r142;
	add.s32 	%r105, %r104, %r97;
	// begin inline asm
	mov.u64 	%rd64, %clock64;
	// end inline asm
	cvt.u32.u64 	%r106, %rd64;
	sub.s32 	%r107, %r106, %r101;
	st.global.u32 	[%rd84+-4], %r107;
	mov.u32 	%r108, %r142;
	st.global.u32 	[%rd83+-4], %r108;
	// begin inline asm
	mov.u64 	%rd65, %clock64;
	// end inline asm
	cvt.u32.u64 	%r109, %rd65;
	mov.u32 	%r110, %r142;
	mul.wide.s32 	%rd73, %r110, 4;
	add.s64 	%rd74, %rd3, %rd73;
	ld.global.u32 	%r111, [%rd74];
	mov.u32 	%r142, %r111;
	mov.u32 	%r112, %r142;
	add.s32 	%r113, %r112, %r105;
	// begin inline asm
	mov.u64 	%rd66, %clock64;
	// end inline asm
	cvt.u32.u64 	%r114, %rd66;
	sub.s32 	%r115, %r114, %r109;
	st.global.u32 	[%rd84], %r115;
	mov.u32 	%r116, %r142;
	st.global.u32 	[%rd83], %r116;
	// begin inline asm
	mov.u64 	%rd67, %clock64;
	// end inline asm
	cvt.u32.u64 	%r117, %rd67;
	mov.u32 	%r118, %r142;
	mul.wide.s32 	%rd75, %r118, 4;
	add.s64 	%rd76, %rd3, %rd75;
	ld.global.u32 	%r119, [%rd76];
	mov.u32 	%r142, %r119;
	mov.u32 	%r120, %r142;
	add.s32 	%r141, %r120, %r113;
	// begin inline asm
	mov.u64 	%rd68, %clock64;
	// end inline asm
	cvt.u32.u64 	%r121, %rd68;
	sub.s32 	%r122, %r121, %r117;
	st.global.u32 	[%rd84+4], %r122;
	mov.u32 	%r123, %r142;
	st.global.u32 	[%rd83+4], %r123;
	add.s64 	%rd84, %rd84, 16;
	add.s64 	%rd83, %rd83, 16;
	add.s32 	%r137, %r137, 4;
	setp.lt.s32 	%p10, %r137, %r33;
	@%p10 bra 	$L__BB0_13;
$L__BB0_14:
	st.global.u32 	[%rd5], %r141;
	ret;
And result shows with index_record[i]=j commented:
.version 8.5
.target sm_52
.address_size 64
	.reg .pred 	%p<11>;
	.reg .b32 	%r<133>;
	.reg .b64 	%rd<68>;
	ld.param.u64 	%rd16, [_Z25l1_cache_size_test_kernelPjS_S_iPi_param_0];
	ld.param.u64 	%rd17, [_Z25l1_cache_size_test_kernelPjS_S_iPi_param_1];
	ld.param.u64 	%rd18, [_Z25l1_cache_size_test_kernelPjS_S_iPi_param_4];
	cvta.to.global.u64 	%rd1, %rd17;
	cvta.to.global.u64 	%rd2, %rd16;
	mov.u32 	%r34, 0;
	mov.u32 	%r132, %r34;
	cvta.to.global.u64 	%rd4, %rd18;
	st.global.u32 	[%rd4], %r34;
	mov.u32 	%r131, %r34;
	@%p1 bra 	$L__BB0_7;
	and.b32  	%r121, %r1, 3;
	mov.u32 	%r131, 0;
	mov.u32 	%r119, %r131;
	@%p2 bra 	$L__BB0_4;
	sub.s32 	%r116, %r1, %r121;
	mov.u32 	%r131, 0;
	mov.u64 	%rd64, %rd1;
$L__BB0_3:
	// begin inline asm
	mov.u64 	%rd20, %clock64;
	// end inline asm
	cvt.u32.u64 	%r43, %rd20;
	mov.u32 	%r44, %r132;
	mul.wide.s32 	%rd28, %r44, 4;
	add.s64 	%rd29, %rd2, %rd28;
	ld.global.u32 	%r45, [%rd29];
	mov.u32 	%r132, %r45;
	mov.u32 	%r46, %r132;
	add.s32 	%r47, %r46, %r131;
	// begin inline asm
	mov.u64 	%rd21, %clock64;
	// end inline asm
	cvt.u32.u64 	%r48, %rd21;
	st.global.u32 	[%rd64], %r49;
	// begin inline asm
	mov.u64 	%rd22, %clock64;
	// end inline asm
	cvt.u32.u64 	%r50, %rd22;
	mov.u32 	%r51, %r132;
	mul.wide.s32 	%rd30, %r51, 4;
	add.s64 	%rd31, %rd2, %rd30;
	ld.global.u32 	%r52, [%rd31];
	mov.u32 	%r132, %r52;
	mov.u32 	%r53, %r132;
	add.s32 	%r54, %r53, %r47;
	// begin inline asm
	mov.u64 	%rd23, %clock64;
	// end inline asm
	cvt.u32.u64 	%r55, %rd23;
	sub.s32 	%r56, %r55, %r50;
	st.global.u32 	[%rd64+4], %r56;
	// begin inline asm
	mov.u64 	%rd24, %clock64;
	// end inline asm
	cvt.u32.u64 	%r57, %rd24;
	mov.u32 	%r58, %r132;
	mul.wide.s32 	%rd32, %r58, 4;
	add.s64 	%rd33, %rd2, %rd32;
	ld.global.u32 	%r59, [%rd33];
	mov.u32 	%r132, %r59;
	mov.u32 	%r60, %r132;
	add.s32 	%r61, %r60, %r54;
	// begin inline asm
	mov.u64 	%rd25, %clock64;
	// end inline asm
	cvt.u32.u64 	%r62, %rd25;
	sub.s32 	%r63, %r62, %r57;
	st.global.u32 	[%rd64+8], %r63;
	// begin inline asm
	mov.u64 	%rd26, %clock64;
	// end inline asm
	cvt.u32.u64 	%r64, %rd26;
	mov.u32 	%r65, %r132;
	mul.wide.s32 	%rd34, %r65, 4;
	add.s64 	%rd35, %rd2, %rd34;
	ld.global.u32 	%r66, [%rd35];
	mov.u32 	%r132, %r66;
	mov.u32 	%r67, %r132;
	add.s32 	%r131, %r67, %r61;
	// begin inline asm
	mov.u64 	%rd27, %clock64;
	// end inline asm
	cvt.u32.u64 	%r68, %rd27;
	sub.s32 	%r69, %r68, %r64;
	st.global.u32 	[%rd64+12], %r69;
	add.s32 	%r119, %r119, 4;
	add.s64 	%rd64, %rd64, 16;
	add.s32 	%r116, %r116, -4;
	setp.ne.s32 	%p3, %r116, 0;
	@%p3 bra 	$L__BB0_3;
$L__BB0_4:
	setp.eq.s32 	%p4, %r121, 0;
	@%p4 bra 	$L__BB0_7;
	mul.wide.s32 	%rd36, %r119, 4;
	add.s64 	%rd65, %rd1, %rd36;
$L__BB0_6:
	.pragma "nounroll";
	// begin inline asm
	// end inline asm
	cvt.u32.u64 	%r70, %rd37;
	mov.u32 	%r71, %r132;
	mul.wide.s32 	%rd39, %r71, 4;
	add.s64 	%rd40, %rd2, %rd39;
	ld.global.u32 	%r72, [%rd40];
	mov.u32 	%r132, %r72;
	mov.u32 	%r73, %r132;
	add.s32 	%r131, %r73, %r131;
	// begin inline asm
	// end inline asm
	cvt.u32.u64 	%r74, %rd38;
	sub.s32 	%r75, %r74, %r70;
	st.global.u32 	[%rd65], %r75;
	add.s64 	%rd65, %rd65, 4;
	add.s32 	%r121, %r121, -1;
	setp.ne.s32 	%p5, %r121, 0;
	@%p5 bra 	$L__BB0_6;
$L__BB0_7:
	membar.gl;
	sub.s32 	%r78, %r33, %r1;
	and.b32  	%r125, %r78, 3;
	setp.eq.s32 	%p7, %r125, 0;
	mov.u32 	%r127, %r1;
	mul.wide.s32 	%rd41, %r1, 4;
	add.s64 	%rd66, %rd1, %rd41;
	mov.u32 	%r127, %r1;
$L__BB0_10:
	.pragma "nounroll";
	// begin inline asm
	mov.u64 	%rd42, %clock64;
	// end inline asm
	cvt.u32.u64 	%r79, %rd42;
	mov.u32 	%r80, %r132;
	mul.wide.s32 	%rd44, %r80, 4;
	add.s64 	%rd45, %rd2, %rd44;
	ld.global.u32 	%r81, [%rd45];
	mov.u32 	%r132, %r81;
	mov.u32 	%r82, %r132;
	add.s32 	%r131, %r82, %r131;
	// begin inline asm
	mov.u64 	%rd43, %clock64;
	// end inline asm
	cvt.u32.u64 	%r83, %rd43;
	sub.s32 	%r84, %r83, %r79;
	st.global.u32 	[%rd66], %r84;
	add.s32 	%r127, %r127, 1;
	add.s64 	%rd66, %rd66, 4;
	add.s32 	%r125, %r125, -1;
	setp.ne.s32 	%p8, %r125, 0;
$L__BB0_11:
	not.b32 	%r85, %r1;
	add.s32 	%r86, %r85, %r33;
	setp.lt.u32 	%p9, %r86, 3;
	mul.wide.s32 	%rd46, %r127, 4;
	add.s64 	%rd47, %rd1, %rd46;
	add.s64 	%rd67, %rd47, 8;
$L__BB0_13:
	// begin inline asm
	mov.u64 	%rd48, %clock64;
	// end inline asm
	cvt.u32.u64 	%r87, %rd48;
	mov.u32 	%r88, %r132;
	mul.wide.s32 	%rd56, %r88, 4;
	add.s64 	%rd57, %rd2, %rd56;
	ld.global.u32 	%r89, [%rd57];
	mov.u32 	%r132, %r89;
	mov.u32 	%r90, %r132;
	add.s32 	%r91, %r90, %r131;
	// begin inline asm
	mov.u64 	%rd49, %clock64;
	// end inline asm
	cvt.u32.u64 	%r92, %rd49;
	sub.s32 	%r93, %r92, %r87;
	st.global.u32 	[%rd67+-8], %r93;
	// begin inline asm
	// end inline asm
	cvt.u32.u64 	%r94, %rd50;
	mov.u32 	%r95, %r132;
	mul.wide.s32 	%rd58, %r95, 4;
	add.s64 	%rd59, %rd2, %rd58;
	ld.global.u32 	%r96, [%rd59];
	mov.u32 	%r132, %r96;
	mov.u32 	%r97, %r132;
	add.s32 	%r98, %r97, %r91;
	// begin inline asm
	// end inline asm
	cvt.u32.u64 	%r99, %rd51;
	sub.s32 	%r100, %r99, %r94;
	st.global.u32 	[%rd67+-4], %r100;
	// begin inline asm
	mov.u64 	%rd52, %clock64;
	// end inline asm
	cvt.u32.u64 	%r101, %rd52;
	mov.u32 	%r102, %r132;
	mul.wide.s32 	%rd60, %r102, 4;
	add.s64 	%rd61, %rd2, %rd60;
	ld.global.u32 	%r103, [%rd61];
	mov.u32 	%r132, %r103;
	mov.u32 	%r104, %r132;
	add.s32 	%r105, %r104, %r98;
	// begin inline asm
	mov.u64 	%rd53, %clock64;
	// end inline asm
	cvt.u32.u64 	%r106, %rd53;
	st.global.u32 	[%rd67], %r107;
	// begin inline asm
	mov.u64 	%rd54, %clock64;
	// end inline asm
	cvt.u32.u64 	%r108, %rd54;
	mov.u32 	%r109, %r132;
	mul.wide.s32 	%rd62, %r109, 4;
	add.s64 	%rd63, %rd2, %rd62;
	ld.global.u32 	%r110, [%rd63];
	mov.u32 	%r132, %r110;
	mov.u32 	%r111, %r132;
	add.s32 	%r131, %r111, %r105;
	// begin inline asm
	// end inline asm
	cvt.u32.u64 	%r112, %rd55;
	sub.s32 	%r113, %r112, %r108;
	st.global.u32 	[%rd67+4], %r113;
	add.s64 	%rd67, %rd67, 16;
	add.s32 	%r127, %r127, 4;
	setp.lt.s32 	%p10, %r127, %r33;
$L__BB0_14:
	st.global.u32 	[%rd4], %r131;
	ret;
There is no S2UR in those two ptx code.
Morever, the ptx code of uncommented index_record is just add mov and st.global.u32 for each loop. Why do these two operations make result different? From your explain, is the reason timestamp read after LDG also not barried before using the data LDG get ?
Things go well when I put #pragma unroll 1 before the for loop.
I use your kernel and the result is not affected by index_record :
It looks like the latency of sm accessing global memory is 400+ cycles. Is it expectful ?
There is another question. I change the kernel as below:
    int i;
    volatile int j = 0;
    int tmp = 0;
    *sum = 0;
#elif 1
#pragma unroll 1
        j = *pj;
        tmp += j;
        time_record[i] = (uint32_t)(end_time - start_time);
    j = 0;
    __threadfence();
        j = *pj;
        tmp += j;
#endif
    *sum = tmp;
And the ptx code generated by “nvcc -arch=sm_87 -ptx“ is
.version 8.5
.target sm_87
.address_size 64
	.reg .pred 	%p<8>;
	.reg .b32 	%r<73>;
	.reg .b64 	%rd<66>;
	ld.param.u64 	%rd22, [_Z25l1_cache_size_test_kernelPjS_S_iPi_param_0];
	ld.param.u64 	%rd23, [_Z25l1_cache_size_test_kernelPjS_S_iPi_param_1];
	ld.param.u64 	%rd24, [_Z25l1_cache_size_test_kernelPjS_S_iPi_param_2];
	ld.param.u64 	%rd25, [_Z25l1_cache_size_test_kernelPjS_S_iPi_param_4];
	ld.param.u32 	%r22, [_Z25l1_cache_size_test_kernelPjS_S_iPi_param_3];
	cvta.to.global.u64 	%rd1, %rd24;
	cvta.to.global.u64 	%rd2, %rd23;
	cvta.to.global.u64 	%rd3, %rd22;
	mov.u32 	%r23, 0;
	mov.u32 	%r72, %r23;
	cvta.to.global.u64 	%rd5, %rd25;
	st.global.u32 	[%rd5], %r23;
	mov.u32 	%r72, %r23;
	shr.u32 	%r24, %r22, 31;
	add.s32 	%r25, %r22, %r24;
	shr.s32 	%r1, %r25, 1;
	setp.lt.s32 	%p1, %r22, 2;
	mov.u32 	%r71, %r23;
	@%p1 bra 	$L__BB0_3;
	mov.u32 	%r71, 0;
	mov.u64 	%rd60, %rd2;
	mov.u64 	%rd61, %rd1;
	mov.u32 	%r61, %r71;
$L__BB0_2:
	.pragma "nounroll";
	mov.u32 	%r28, %r72;
	mul.wide.s32 	%rd29, %r28, 4;
	add.s64 	%rd30, %rd3, %rd29;
	// begin inline asm
	// end inline asm
	ld.global.u32 	%r29, [%rd30];
	mov.u32 	%r72, %r29;
	mov.u32 	%r30, %r72;
	add.s32 	%r71, %r30, %r71;
	// begin inline asm
	mov.u64 %rd28, %clock64;
	// end inline asm
	sub.s64 	%rd31, %rd28, %rd27;
	st.global.u32 	[%rd60], %rd31;
	mov.u32 	%r31, %r72;
	st.global.u32 	[%rd61], %r31;
	add.s64 	%rd61, %rd61, 4;
	add.s64 	%rd60, %rd60, 4;
	add.s32 	%r61, %r61, 1;
	setp.lt.s32 	%p2, %r61, %r1;
	@%p2 bra 	$L__BB0_2;
$L__BB0_3:
	mov.u32 	%r72, %r23;
	membar.gl;
	setp.ge.s32 	%p3, %r1, %r22;
	@%p3 bra 	$L__BB0_10;
	sub.s32 	%r34, %r22, %r1;
	and.b32  	%r65, %r34, 3;
	setp.eq.s32 	%p4, %r65, 0;
	mov.u32 	%r67, %r1;
	@%p4 bra 	$L__BB0_7;
	mul.wide.s32 	%rd32, %r1, 4;
	add.s64 	%rd63, %rd1, %rd32;
	add.s64 	%rd62, %rd2, %rd32;
	mov.u32 	%r67, %r1;
$L__BB0_6:
	.pragma "nounroll";
	mov.u32 	%r35, %r72;
	mul.wide.s32 	%rd35, %r35, 4;
	add.s64 	%rd36, %rd3, %rd35;
	// begin inline asm
	// end inline asm
	ld.global.u32 	%r36, [%rd36];
	mov.u32 	%r72, %r36;
	mov.u32 	%r37, %r72;
	add.s32 	%r71, %r37, %r71;
	// begin inline asm
	// end inline asm
	sub.s64 	%rd37, %rd34, %rd33;
	st.global.u32 	[%rd62], %rd37;
	mov.u32 	%r38, %r72;
	st.global.u32 	[%rd63], %r38;
	add.s32 	%r67, %r67, 1;
	add.s64 	%rd63, %rd63, 4;
	add.s64 	%rd62, %rd62, 4;
	add.s32 	%r65, %r65, -1;
	setp.ne.s32 	%p5, %r65, 0;
	@%p5 bra 	$L__BB0_6;
$L__BB0_7:
	not.b32 	%r39, %r1;
	add.s32 	%r40, %r39, %r22;
	setp.lt.u32 	%p6, %r40, 3;
	@%p6 bra 	$L__BB0_10;
	mul.wide.s32 	%rd38, %r67, 4;
	add.s64 	%rd39, %rd38, 8;
	add.s64 	%rd65, %rd2, %rd39;
	add.s64 	%rd64, %rd1, %rd39;
$L__BB0_9:
	mov.u32 	%r41, %r72;
	mul.wide.s32 	%rd48, %r41, 4;
	add.s64 	%rd49, %rd3, %rd48;
	// begin inline asm
	// end inline asm
	ld.global.u32 	%r42, [%rd49];
	mov.u32 	%r72, %r42;
	mov.u32 	%r43, %r72;
	add.s32 	%r44, %r43, %r71;
	// begin inline asm
	mov.u64 %rd41, %clock64;
	// end inline asm
	sub.s64 	%rd50, %rd41, %rd40;
	st.global.u32 	[%rd65+-8], %rd50;
	mov.u32 	%r45, %r72;
	st.global.u32 	[%rd64+-8], %r45;
	mov.u32 	%r46, %r72;
	mul.wide.s32 	%rd51, %r46, 4;
	add.s64 	%rd52, %rd3, %rd51;
	// begin inline asm
	// end inline asm
	ld.global.u32 	%r47, [%rd52];
	mov.u32 	%r72, %r47;
	mov.u32 	%r48, %r72;
	add.s32 	%r49, %r48, %r44;
	// begin inline asm
	// end inline asm
	sub.s64 	%rd53, %rd43, %rd42;
	st.global.u32 	[%rd65+-4], %rd53;
	mov.u32 	%r50, %r72;
	st.global.u32 	[%rd64+-4], %r50;
	mov.u32 	%r51, %r72;
	mul.wide.s32 	%rd54, %r51, 4;
	add.s64 	%rd55, %rd3, %rd54;
	// begin inline asm
	mov.u64 %rd44, %clock64;
	// end inline asm
	ld.global.u32 	%r52, [%rd55];
	mov.u32 	%r72, %r52;
	mov.u32 	%r53, %r72;
	add.s32 	%r54, %r53, %r49;
	// begin inline asm
	mov.u64 %rd45, %clock64;
	// end inline asm
	sub.s64 	%rd56, %rd45, %rd44;
	st.global.u32 	[%rd65], %rd56;
	mov.u32 	%r55, %r72;
	st.global.u32 	[%rd64], %r55;
	mov.u32 	%r56, %r72;
	mul.wide.s32 	%rd57, %r56, 4;
	// begin inline asm
	mov.u64 %rd46, %clock64;
	// end inline asm
	ld.global.u32 	%r57, [%rd58];
	mov.u32 	%r72, %r57;
	mov.u32 	%r58, %r72;
	add.s32 	%r71, %r58, %r54;
	// begin inline asm
	mov.u64 %rd47, %clock64;
	// end inline asm
	sub.s64 	%rd59, %rd47, %rd46;
	st.global.u32 	[%rd65+4], %rd59;
	mov.u32 	%r59, %r72;
	st.global.u32 	[%rd64+4], %r59;
	add.s64 	%rd65, %rd65, 16;
	add.s32 	%r67, %r67, 4;
	setp.lt.s32 	%p7, %r67, %r22;
	@%p7 bra 	$L__BB0_9;
$L__BB0_10:
	st.global.u32 	[%rd5], %r71;
	ret;
Result of the first loop is expectful. But the second loop shows below, why the latency various rather than stable 36 ?
