i have trained model with tao tool kit and saved etlt and engine and cache files for inference but when i use in python module ( taken from deepstream-python-app ) it fail.
i used tlt-encoded-model parameter instead of model-file it solve deserialization but got other error.
/Desktop/farid/O/Object-Detection-Deepstream$ sudo python3 deepstream_test_1.py /opt/nvidia/deepstream/deepstream-6.1/samples/streams/camera-1_video_26.mp4
Creating Pipeline
Creating Source
creating caps_filter
Creating H264Parser
Creating Decoder
Creating EGLSink
Playing file /opt/nvidia/deepstream/deepstream-6.1/samples/streams/camera-1_video_26.mp4
Adding elements to Pipeline
Linking elements in the Pipeline
Starting pipeline
0:00:00.159538914 504171 0x37e3120 WARN nvinfer gstnvinfer.cpp:643:gst_nvinfer_logger:<primary-inference> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::initialize() <nvdsinfer_context_impl.cpp:1170> [UID = 1]: Warning, OpenCV has been deprecated. Using NMS for clustering instead of cv::groupRectangles with topK = 20 and NMS Threshold = 0.5
0:00:00.159641791 504171 0x37e3120 INFO nvinfer gstnvinfer.cpp:646:gst_nvinfer_logger:<primary-inference> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1923> [UID = 1]: Trying to create engine from model files
WARNING: [TRT]: onnx2trt_utils.cpp:369: Your ONNX model has been generated with INT64 weights, while TensorRT does not natively support INT64. Attempting to cast down to INT32.
WARNING: [TRT]: onnx2trt_utils.cpp:395: One or more weights outside the range of INT32 was clamped
WARNING: [TRT]: builtin_op_importers.cpp:4716: Attribute caffeSemantics not found in plugin node! Ensure that the plugin creator has a default value defined or the engine may fail to build.
WARNING: [TRT]: The getMaxBatchSize() function should not be used with an engine built from a network created with NetworkDefinitionCreationFlag::kEXPLICIT_BATCH flag. This function will always return 1.
0:02:05.141006352 504171 0x37e3120 INFO nvinfer gstnvinfer.cpp:646:gst_nvinfer_logger:<primary-inference> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1955> [UID = 1]: serialize cuda engine to file: /home/experts-vision/Desktop/farid/O/Primary_Detector/export_retrain/yolov4_resnet18_epoch_080.etlt_b1_gpu0_fp32.engine successfully
INFO: ../nvdsinfer/nvdsinfer_model_builder.cpp:610 [Implicit Engine Info]: layers num: 5
0 INPUT kFLOAT Input 3x384x1248
1 OUTPUT kINT32 BatchedNMS 1
2 OUTPUT kFLOAT BatchedNMS_1 200x4
3 OUTPUT kFLOAT BatchedNMS_2 200
4 OUTPUT kFLOAT BatchedNMS_3 200
ERROR: [TRT]: 3: Cannot find binding of given name: conv2d_bbox
0:02:05.145256102 504171 0x37e3120 WARN nvinfer gstnvinfer.cpp:643:gst_nvinfer_logger:<primary-inference> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::checkBackendParams() <nvdsinfer_context_impl.cpp:1876> [UID = 1]: Could not find output layer 'conv2d_bbox' in engine
ERROR: [TRT]: 3: Cannot find binding of given name: conv2d_cov/Sigmoid
0:02:05.145273353 504171 0x37e3120 WARN nvinfer gstnvinfer.cpp:643:gst_nvinfer_logger:<primary-inference> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::checkBackendParams() <nvdsinfer_context_impl.cpp:1876> [UID = 1]: Could not find output layer 'conv2d_cov/Sigmoid' in engine
0:02:05.206911633 504171 0x37e3120 INFO nvinfer gstnvinfer_impl.cpp:328:notifyLoadModelStatus:<primary-inference> [UID 1]: Load new model:dstest1_pgie_config.txt sucessfully
Error: gst-stream-error-quark: Failed to parse stream (7): gstbaseparse.c(2998): gst_base_parse_check_sync (): /GstPipeline:pipeline0/GstH264Parse:h264-parser
i also removed the capsfilter plugin but still got same error
