Why RTX4090 performs at a level much lower than officially claimed?
If you are reporting a bug or error, consider submitting a Support Bundle to aiworkbench-ea@nvidia.com. This will help us solve your issue more quickly.
I’m running a performance test on RTX4090 using gpu_burn, the result shows that the computing power of my RTX4090 is merely 54TFLOPs (for FP32), which is way lower than corresponding 82TFLOPs claimed on Nvidia official website (NVIDIA GeForce RTX 4090 Graphics Cards)
And my case is not alone, I also asked another party to do the test on their 4090, the result is the same just 50TFLOPs.
Also in both our cases, it shows that 4090 can merely run at P2 level (as known P0 is the highest performance level). Wonder if that correlates and why is it running just at p2 instead of p0?
It shouldn’t be due to hardware configuration reason like cpu or motherboard. The detail is as below:
CPU: Intel Xeon 8368Q
Motherboard: Supermicro X12SPA-TF (PICe4.0 x16)
RAM:128G DDR4 RECC3200
See attachment for the test results:
Looking forward for reply soon, thanks!
Please describe your issue or request: (tick the boxes after creating this topic):
Please tick the appropriate box to help us categorize your post
Bug or Error
Feature Request
Documentation Issue
Other
Hi. This is the forum for AI Workbench, not 4090 GPUs. I don’t think you’re going to get a good answer to your question in this forum.
Also, the link you posted is to the H100, not the 4090. I’m not sure that comparing the 4090 to an H100 is sensible.
Can you find the appropriate forum to get your question answered?
Thanks for quick reply, which forum should I post this question? I looked around for a while and couldn’t find one that matches so I post it here
