Hello mates!
I had a problem: I had a 4090 paired with an Epyc 7532 as MoBo has an MZ32-AR0 V1.0 with 64GB of RAM ECC DDR4 2666Mhz
Samsung with NVMe drive, SSD drive, and an AIO TT Water3.0. It’s on Linux (Ubuntu 22.04) and the latest NVIDIA CUDA and CUDNN driver. Also, it had two PSUs, one RM750 for the CPU and MoBo and an RM850 for the GPU.
The issue is the next: this PC is used for research (Deep Learning). However, it seems slower than my previous 3090. Maybe I sound paranoid, but the 4090 does every epoch of ResNET-18 in 29s, while with the 3090, the time per epoch is 17s.
If you had any thoughts on what could be the issue, would be appreciated.
In addition, I use TF, Pytorch and Pycuda development frameworks. I have attached a lot of info on Windows and Linux, pictures.zip are the pictures of logs and workstation config, logs.zip are the results of several benchmarking tests on Linux and windows.
nvidia-bug-report.log.gz (381.3 KB)
3090_nvidia-bug-report.log.gz (390.8 KB)
pictures.zip (12.5 MB)
logs.zip (180.3 KB)
