why shift is slower than integer multiply shift ,integer multiply
we know integer multiply by 2^n can be replaced by shift operation, which is faster.
As version 1 & 2 shown, I replace tid*4 by tid<<2(I think it can speedup). But the actual result shows version 1 is faster than version 2. I have tested many times.
I was confused.
why shift is slower than integer multiply? my GPU is G260
uint tid
version 1
des[tid * 4 + 0] = …;
des[tid * 4 + 1] = …;
des[tid * 4 + 2] = …;
des[tid * 4 + 3] = …;
__syncthreads();
__syncthreads();
float4 d;
d.x = __fdividef(des[tid * 4 + 0], len[0]);
d.y = __fdividef(des[tid * 4 + 1], len[0]);
d.z = __fdividef(des[tid * 4 + 2], len[0]);
d.w= __fdividef(des[tid * 4 + 3], len[0]);
d_des[idx * 16 + tid] = d;
version 2
des[(tid<<2)] = …;
des[(tid<<2) + 1] = …;
des[(tid<<2) + 2] = …;
des[(tid<<2) + 3] = …;
__syncthreads();
__syncthreads();
float4 d;
d.x = __fdividef(des[(tid<<2)], len[0]);
d.y = __fdividef(des[(tid<<2) + 1], len[0]);
d.z = __fdividef(des[(tid<<2) + 2], len[0]);
d.w = __fdividef(des[(tid<<2) + 3], len[0]);
d_des[(idx<<4) + tid] = d;
There should be no difference at all as the compiler does this substitution for you anyway. How are you timing your code?
I use “cudaEvent_t start, stop” for timing as followed
cudaEventRecord(start, 0);
cudaEventRecord(stop, 0);
cudaEventSynchronize(stop);
cudaEventElapsedTime(&time, start, stop);
and If i use __mul24(tid,4) instead of tid * 4, whether thay are also no difference?
You might want to look at the assembly generated with decuda.
Three things to consider:
  • There is a MAD instruction which can compute a * b + c (multiply is 24x24-bit only on SM 1.x devices), but the instruction doing a >> b + c only exists on SM 2.0 devices (Fermi).
  • SM 1.x devices have special registers and instructions to deal with addresses.
  • At the hardware level, addresses are in bytes.
So the compiler has to multiply your addresses by 4 (or shift by 2) anyways.
It is likely that in the first case,
is first turned into a store at byte [des + (tid * 4 + 3) * 4],
then optimized as [des + tid * 16 + 12],
then finally as [des + tid << 4 + 12].
I suspect what happens is: by using an unusual idiom, you prevent the compiler from inferring what you mean, and applying distributivity to fuse both mulitplications/shifts together.
So just stick with multiplication…
Be sure that if a simple and widely-known optimization can be applied safely and has a benefit in every case, then the compiler will use it…
See TABLE III of Demystifying GPU Microarchitecture through Microbenchmarking
The throughput of shl/shr is 7.9 with 24 cycles of latency while integer mul’s is 1.7 and 96 cycles latency - there’s no way a mul is faster. It had to be optimized by compiler anyway as Sylvain said.
(Also note the paradox: floating point mul’s throughput is 11.2 so float mul IS kind of faster than bitwise functions)
It can be faster, but only under the following conditions:
  • The compiler can ensure that both operands fit into 24 bits.
  • The mul is followed by an add.
  • We’re running on a SM 1.x device.
Strangely enough, they all seem to apply in the OP case.
Float mul being faster than 32-bit int mul (on SM 1.x) makes sense: a float multiplication only requires a 24x24-bit multiplier, which is roughly twice as small as a 32x32-bit multiplier…
You’re right, I totally forgot about mad24.
here’s the benchmark:
[codebox]mov.b32 $r62, %clock
mad24.lo.u32.u16.u16.u32 $r1, $r0.hi, $r0.lo, $r0
add.b32 $r3,$r0,$r0 //kill forwarding
add.b32 $r2,$r1,$1 //cause RAW stall
mov.b32 $r63, %clock[/codebox]
It executes 40 cycles, which reveals true mad24 latency of 40-8-8=24 cycles, believe it or not.
Also true with floating mul.
If I use “__mul24( a, b ) - c”, whether it also can be optimized by compiler? int a,b,c
whether the speed of __mul24( a, b ) +c and a*b+c are equal, as compiler optimize? int a,b,c
I don’t think there’s a good answer to that. The part of the compiler which does that is proprietary and nobody outside NVIDIA knows how it exactly works. I could make a dummy kernel with that single operation and see if it optimizes, but that’s hardly a clue - compiler may decide otherwise in other cases.
Thx
Thx
“mad24” is multiply-add instruction for integer on CUDA?
there are lots of “a*b+c”(int a,b,c) in my code. but why I can’t find “mad24” on its ptx?
my Gpu is G260.
How can I employ multiply-add operation of integer on CUDA to speedup my app?
