Hi!
I think this error means from /neck/fpn_convs.0/fpn_convs.0.0/conv/Conv to /seg_result/resize cannot work on DLA
the details are shown in the next:
[05/31/2024-03:09:20] [TRT] [W] {ForeignNode[/neck/fpn_convs.0/fpn_convs.0.0/conv/Conv…/seg_result/resize]} cannot be compiled by DLA, falling back to GPU.
[05/31/2024-03:09:20] [TRT] [V] DLA Memory Consumption Summary:
[05/31/2024-03:09:20] [TRT] [V] Number of DLA node candidates offloaded : 0 out of 1
[05/31/2024-03:09:20] [TRT] [V] Total memory required by accepted candidates : Managed SRAM = 0 MiB, Local DRAM = 0 MiB, Global DRAM = 0 MiB
[05/31/2024-03:09:20] [TRT] [V] After DLA optimization: 8 layers
[05/31/2024-03:09:20] [TRT] [V] Applying ScaleNodes fusions.
[05/31/2024-03:09:20] [TRT] [V] After scale fusion: 8 layers
[05/31/2024-03:09:20] [TRT] [V] Running: ConvReluFusion on /convs/convs.0/conv/Conv
[05/31/2024-03:09:20] [TRT] [V] ConvReluFusion: Fusing /convs/convs.0/conv/Conv with /convs/convs.0/activate/Relu
[05/31/2024-03:09:20] [TRT] [V] After dupe layer removal: 7 layers
[05/31/2024-03:09:20] [TRT] [V] After final dead-layer removal: 7 layers
[05/31/2024-03:09:20] [TRT] [V] After tensor merging: 7 layers
[05/31/2024-03:09:20] [TRT] [V] After vertical fusions: 7 layers
[05/31/2024-03:09:20] [TRT] [V] After slice removal: 7 layers
[05/31/2024-03:09:20] [TRT] [V] After concat removal: 7 layers
[05/31/2024-03:09:20] [TRT] [V] Trying to split Reshape and strided tensor
[05/31/2024-03:09:20] [TRT] [V] Graph construction and optimization completed in 0.1482 seconds.
[05/31/2024-03:09:20] [TRT] [I] ---------- Layers Running on DLA ----------
[05/31/2024-03:09:20] [TRT] [I] ---------- Layers Running on GPU ----------
[05/31/2024-03:09:20] [TRT] [I] [GpuLayer] CONVOLUTION: /neck/fpn_convs.0/fpn_convs.0.0/conv/Conv
[05/31/2024-03:09:20] [TRT] [I] [GpuLayer] CONVOLUTION: /neck/fpn_convs.0/fpn_convs.0.1/conv/Conv
[05/31/2024-03:09:20] [TRT] [I] [GpuLayer] CONVOLUTION: /convs/convs.0/conv/Conv + /convs/convs.0/activate/Relu
[05/31/2024-03:09:20] [TRT] [I] [GpuLayer] CONVOLUTION: /conv_seg/Conv
[05/31/2024-03:09:20] [TRT] [I] [GpuLayer] RESIZE: /seg_result/resize
[05/31/2024-03:09:20] [TRT] [I] [GpuLayer] TOPK: /seg_result/argmax
[05/31/2024-03:09:20] [TRT] [I] [GpuLayer] SHUFFLE: (Unnamed Layer* 7) [Shuffle]
Furthermore, I tried to remove the resize layer,and model is like this:
I found that these convolutional layers can work on DLA in
fp16 mode:
[06/05/2024-03:41:38] [TRT] [V] {ForeignNode[/neck/fpn_convs.0/fpn_convs.0.1/conv/Conv…/conv_seg/Conv]} successfully offloaded to DLA.
[06/05/2024-03:41:38] [TRT] [V] Memory consumption details:
[06/05/2024-03:41:38] [TRT] [V] Pool Sizes: Managed SRAM = 0.5 MiB, Local DRAM = 1024 MiB, Global DRAM = 512 MiB
[06/05/2024-03:41:38] [TRT] [V] Required: Managed SRAM = 0.5 MiB, Local DRAM = 128 MiB, Global DRAM = 4 MiB
[06/05/2024-03:41:38] [TRT] [V] DLA Memory Consumption Summary:
[06/05/2024-03:41:38] [TRT] [V] Number of DLA node candidates offloaded : 1 out of 1
[06/05/2024-03:41:38] [TRT] [V] Total memory required by accepted candidates : Managed SRAM = 0.5 MiB, Local DRAM = 128 MiB, Global DRAM = 4 MiB
[06/05/2024-03:41:38] [TRT] [V] After DLA optimization: 2 layers
[06/05/2024-03:41:38] [TRT] [V] Applying ScaleNodes fusions.
[06/05/2024-03:41:38] [TRT] [V] After scale fusion: 2 layers
[06/05/2024-03:41:38] [TRT] [V] After dupe layer removal: 2 layers
[06/05/2024-03:41:38] [TRT] [V] After final dead-layer removal: 2 layers
[06/05/2024-03:41:38] [TRT] [V] After tensor merging: 2 layers
[06/05/2024-03:41:38] [TRT] [V] After vertical fusions: 2 layers
[06/05/2024-03:41:38] [TRT] [V] After slice removal: 2 layers
[06/05/2024-03:41:38] [TRT] [V] After concat removal: 2 layers
[06/05/2024-03:41:38] [TRT] [V] Trying to split Reshape and strided tensor
[06/05/2024-03:41:38] [TRT] [V] Graph construction and optimization completed in 0.899575 seconds.
[06/05/2024-03:41:38] [TRT] [I] ---------- Layers Running on DLA ----------
[06/05/2024-03:41:38] [TRT] [I] [DlaLayer] {ForeignNode[/neck/fpn_convs.0/fpn_convs.0.1/conv/Conv…/conv_seg/Conv]}
[06/05/2024-03:41:38] [TRT] [I] ---------- Layers Running on GPU ----------
[06/05/2024-03:41:38] [TRT] [I] [GpuLayer] CONVOLUTION: /neck/fpn_convs.0/fpn_convs.0.0/conv/Conv
However, they cannot work on DLA in int8 mode:
[06/05/2024-03:42:30] [TRT] [W] {ForeignNode[/neck/fpn_convs.0/fpn_convs.0.0/conv/Conv…/conv_seg/Conv]} cannot be compiled by DLA, falling back to GPU.
[06/05/2024-03:42:30] [TRT] [V] DLA Memory Consumption Summary:
[06/05/2024-03:42:30] [TRT] [V] Number of DLA node candidates offloaded : 0 out of 1
[06/05/2024-03:42:30] [TRT] [V] Total memory required by accepted candidates : Managed SRAM = 0 MiB, Local DRAM = 0 MiB, Global DRAM = 0 MiB
[06/05/2024-03:42:30] [TRT] [V] After DLA optimization: 5 layers
[06/05/2024-03:42:30] [TRT] [V] Applying ScaleNodes fusions.
[06/05/2024-03:42:30] [TRT] [V] After scale fusion: 5 layers
[06/05/2024-03:42:30] [TRT] [V] Running: ConvReluFusion on /convs/convs.0/conv/Conv
[06/05/2024-03:42:30] [TRT] [V] ConvReluFusion: Fusing /convs/convs.0/conv/Conv with /convs/convs.0/activate/Relu
[06/05/2024-03:42:30] [TRT] [V] After dupe layer removal: 4 layers
[06/05/2024-03:42:30] [TRT] [V] After final dead-layer removal: 4 layers
[06/05/2024-03:42:30] [TRT] [V] After tensor merging: 4 layers
[06/05/2024-03:42:30] [TRT] [V] After vertical fusions: 4 layers
[06/05/2024-03:42:30] [TRT] [V] After slice removal: 4 layers
[06/05/2024-03:42:30] [TRT] [V] After concat removal: 4 layers
[06/05/2024-03:42:30] [TRT] [V] Trying to split Reshape and strided tensor
[06/05/2024-03:42:30] [TRT] [V] Graph construction and optimization completed in 0.129133 seconds.
[06/05/2024-03:42:30] [TRT] [I] ---------- Layers Running on DLA ----------
[06/05/2024-03:42:30] [TRT] [I] ---------- Layers Running on GPU ----------
[06/05/2024-03:42:30] [TRT] [I] [GpuLayer] CONVOLUTION: /neck/fpn_convs.0/fpn_convs.0.0/conv/Conv
[06/05/2024-03:42:30] [TRT] [I] [GpuLayer] CONVOLUTION: /neck/fpn_convs.0/fpn_convs.0.1/conv/Conv
[06/05/2024-03:42:30] [TRT] [I] [GpuLayer] CONVOLUTION: /convs/convs.0/conv/Conv + /convs/convs.0/activate/Relu
[06/05/2024-03:42:30] [TRT] [I] [GpuLayer] CONVOLUTION: /conv_seg/Conv
I want to know why this is happening
