I have a problem with CUDA kernel shared memory bank conflicts when using the LDG.128 optimization.
When I store data from shared memory to global memory, I notice that within the same warp, the access pattern is fixed. However, as the number of thread blocks varies, the occurrence of bank conflicts fluctuates from none to some.
Here is some code using the broadcasting mechanism and LDG.128
.The number of thread blocks here varies with the matrix size M.
The device used is an RTX 4060, and the compilation was done with -arch=sm_80
#include <stdio.h>
#include <mma.h>
#include <cuda_fp16.h>
#include <cuda_profiler_api.h>
#include <stdint.h>
#include <cuda_runtime.h>
#include "assert.h"
#include "include/ldmatrix.cuh"
#include<iostream>
template<int VectorLength, int Block_M, int Block_K, int Block_N, int Warp_M, int Warp_K, int Warp_N, int Mma_M, int Mma_K, int Mma_N>
void __global__ OutPutPad(half *output_matrix, int m, int k, int n){
int m_index = blockIdx.x * Block_M;
int n_index = blockIdx.y * Block_N;
int warp_id = threadIdx.x / 32;
int warp_lane_id = threadIdx.x % 32;
int warp_lane_id_8 = warp_lane_id % 8;
int warp_group_id_8 = warp_lane_id / 8;
// int num_warp = blockDim.x / 32;
// const int warp_pad_row = 0;
// constexpr int pad_row = 0;
constexpr int c_tile_size = Block_M * Block_N;
__shared__ half C_tile[c_tile_size];
half *c_tile_ptr = C_tile;
const int c_num_reg = (Warp_N / Mma_N) * (Warp_M / Mma_M) * 2;
uint c_fragment[c_num_reg];
const int num_iter = Warp_N / Mma_N;
#pragma unroll
for(int i = 0; i < num_iter; i++){
uint4 *src = reinterpret_cast<uint4*>(c_tile_ptr + warp_id * Warp_M * Block_N);
uint4 *dst = reinterpret_cast<uint4*>(output_matrix + warp_lane_id * 8);
*dst = *src;
void Main(){
const int M = 128;
const int K = 32;
const int N = 4096;
half *matrix_h = new half[M * K];
for(int i = 0; i < M * K; i++){matrix_h[i] = i;}
half *matrix_d;
cudaMalloc(&matrix_d, M * K * sizeof(half));
cudaMemcpy(matrix_d, matrix_h, M * K * sizeof(half), cudaMemcpyHostToDevice);
const int V = 64;
const int BM = 64;
const int BK = 32;
const int BN = 64;
const int WM = 32;
const int WK = 32;
const int WN = 64;
const int MM = 16;
const int MK = 16;
const int MN = 8;
dim3 gridsize(M / BM, N / BN, 1);
dim3 blocksize(32 * (BM / WM) * (BN / WN), 1, 1);
printf("Matrix:(M, K, N)=(%d, %d, %d)\n", M, K, N);
printf("Grid:(X, Y, Z)=(%d, %d, %d)\n", gridsize.x, gridsize.y, gridsize.z);
printf("Block:(X, Y, Z)=(%d, %d, %d)\n", blocksize.x, blocksize.y, blocksize.z);
OutPutPad<V, BM, BK, BN, WM, WK, WN, MM, MK, MN><<<gridsize, blocksize>>>(matrix_d, M, K, N);
cudaDeviceSynchronize();
int main() {
Main();
return 0;
CMakeLists.txt:
cmake_minimum_required(VERSION 3.18)
project(SPATHA CUDA CXX C)
find_package(CUDA REQUIRED)
set(CMAKE_CUDA_ARCHITECTURES 80)
set(CMAKE_BUILD_TYPE Debug)
set(CMAKE_CUDA_FLAGS "-G -g")
set(CUDA_SOURCE_FILES_OUTPUTPAD OutptTile.cu)
add_executable(outputpad ${CUDA_SOURCE_FILES_OUTPUTPAD})
When M =128
, no bank conflict occurs, but when M = 256
, bank conflict occurs.
Here are the results from NCU.
sudo ncu --metric l1tex__average_t_sectors_per_request_pipe_lsu_mem_global_op_st.ratio,l1tex__average_t_sectors_per_request_pipe_lsu_mem_global_op_ld.ratio,smsp__sass_average_data_bytes_per_sector_mem_global_op_ld.pct,sm__cycles_elapsed.avg,l1tex__data_bank_conflicts_pipe_lsu_mem_shared_op_ld.sum,l1tex__data_bank_conflicts_pipe_lsu_mem_shared_op_ld.avg,l1tex__data_bank_conflicts_pipe_lsu_mem_shared_op_st.sum,l1tex__data_bank_conflicts_pipe_lsu_mem_shared_op_st.avg ./outputpad
M=128:
==PROF== Connected to process 73304 (/home/buwf/code/bank/build/outputpad)
==PROF== Profiling "OutPutPad" - 0: 0%....50%....100% - 6 passes
Matrix:(M, K, N)=(128, 32, 4096)
Grid:(X, Y, Z)=(2, 64, 1)
Block:(X, Y, Z)=(64, 1, 1)
==PROF== Disconnected from process 73304
[73304] outputpad@127.0.0.1
void OutPutPad<(int)64, (int)64, (int)32, (int)64, (int)32, (int)32, (int)64, (int)16, (int)16, (int)8>(__half *, int, int, int) (2, 64, 1)x(64, 1, 1), Context 1, Stream 7, Device 0, CC 8.9
Section: Command line profiler metrics
Metric Name Metric Unit Metric Value
l1tex__average_t_sectors_per_request_pipe_lsu_mem_global_op_ld.ratio sector/request 0
l1tex__average_t_sectors_per_request_pipe_lsu_mem_global_op_st.ratio sector/request 16.00
l1tex__data_bank_conflicts_pipe_lsu_mem_shared_op_ld.avg 0
l1tex__data_bank_conflicts_pipe_lsu_mem_shared_op_ld.sum 0
l1tex__data_bank_conflicts_pipe_lsu_mem_shared_op_st.avg 0
l1tex__data_bank_conflicts_pipe_lsu_mem_shared_op_st.sum 0
sm__cycles_elapsed.avg cycle 18,237.33
smsp__sass_average_data_bytes_per_sector_mem_global_op_ld.pct % inf
M=256
==PROF== Connected to process 73707 (/home/buwf/code/bank/build/outputpad)
Matrix:(M, K, N)=(256, 32, 4096)
Grid:(X, Y, Z)=(4, 64, 1)
==PROF== Disconnected from process 73707
[73707] outputpad@127.0.0.1
void OutPutPad<(int)64, (int)64, (int)32, (int)64, (int)32, (int)32, (int)64, (int)16, (int)16, (int)8>(__half *, int, int, int) (4, 64, 1)x(64, 1, 1), Context 1, Stream 7, Device 0, CC 8.9
l1tex__data_bank_conflicts_pipe_lsu_mem_shared_op_ld.avg 6.08
l1tex__data_bank_conflicts_pipe_lsu_mem_shared_op_ld.sum 146
sm__cycles_elapsed.avg cycle 19,635
I’m not sure if the issue is with my access pattern or something else. Is there a method or tool that can help me identify the cause of the bank conflicts?
