Will printf inside a kernel work on other language/compilers ? Possible replacement ?
I think the real “HelloWorld” for cuda would be:
global kernel()
printf(“Hello World !\n”);
However according to the manual, the formatting of printf depends on the host compiler/operating system.
So I now wonder if this printf will work on for example another compiler/language like Delphi ?!?
If not then a replacement could be designed for CUDA Driver API which would work something like this:
printf would be replaced with
OutputString( “Hello World !\n” );
Plus perhaps any other version of this function that you can conceive that might have parameter support as well, perhaps by a list of memory which can contain integers or floats or even more strings.
And then every data structure would have the following fieldS:
OutputStringParameterStructure:
OutputStringParameterType (enum)   osp_float / osp_integer / osp_ansi_character / osp_double
OutputStringParameterSize (int)            4 /           4 /                  1 /          8
OutputStringParameterCount(int)            1 /           1 /           Variable /          1
Example:
TOutputStringParameterTypeEnum =
 osp_float,
 osp_integer,
 osp_ansi_character,
 osp_double
struct TOutputStringParameterStructure
  TOutputStringParameterTypeEnum mType;
  int mSize;
  int mCount;
usage example:
TOutputStringParameterStructure mParameter[10];
// or
TOutputStringParameterStructure *mParameter;
mParameter[0].mType = osp_float;
  mParameter[0].mSize = 4;
  mParameter[0].mCount = 1;
Count could also be used as an array size.
This parameter structure would be proceeded by:
OutputStringParameterArray // array of OutputStringParameterStructurePointers
OutputStringParameterArraySize // size of array
So such an advanced function (variable) would look like:
OutputString( ParaMainString, the rest );
or to prevent this weird inconsistencies it would instead directly go to the data structure:
OutputString( OutputStringParameterArray *ParameterArray, OutputStringParameterArraySize ParameterArraySize );
This is not how the kernel user would use it…
The kernel user would simply write:
printf(“whatever”, whatever);
The cuda compiler would then convert this call to a call to OutputString function variable above.
Other languages can now call the following functions to set the output string function variable/callback.
SetOutputStringVariable( @OutputStringFunctionVariable );
Then the host user can simply implement OutputStringFunction himself and provide a variable/callback towards it.
Then the host user can simply use the language’s/compiler’s string printing functions to do the rest ! External Image =D
(This posting was writing by listening to music lol, which might or might not have affected this posting LOL External Image :) I think it’s ok External Image External Image
(Ok I think this is enough… this should give you some idea of what I’m looking for External Image External Image
Bye,
Sky-music-buck.
