Will Ubuntu 16.04 crash after the GPU crashes?
Immediately after my operating system crashed, my operating system is ubuntu16.04, the nvidia driver version is 390.87, and the NVCC version is V9.0.176.
The following is my error log:
ov 27 21:39:03 ubuntu kernel: [163905.193192] NVRM: GPU at PCI:0000:85:00: GPU-4115e6b5-b712-feac-9f2d-a39422cfc7fe
Nov 27 21:39:03 ubuntu kernel: [163905.193201] NVRM: GPU Board Serial Number:
Nov 27 21:39:03 ubuntu kernel: [163905.193207] NVRM: Xid (PCI:0000:85:00): 79, GPU has fallen off the bus.
Nov 27 21:39:03 ubuntu kernel: [163905.193210] NVRM: GPU at 0000:85:00.0 has fallen off the bus.
Nov 27 21:39:03 ubuntu kernel: [163905.193213] NVRM: GPU is on Board .
Nov 27 21:39:03 ubuntu kernel: [163905.209872] NVRM: A GPU crash dump has been created. If possible, please run
Nov 27 21:39:03 ubuntu kernel: [163905.209872] NVRM: nvidia-bug-report.sh as root to collect this data before
Nov 27 21:39:03 ubuntu kernel: [163905.209872] NVRM: the NVIDIA kernel module is unloaded.
Nov 27 21:39:34 ubuntu kernel: [163937.138790] [UFW BLOCK] IN=enp129s0f0 OUT= MAC=0c:c4:7a:e5:59:ee:04:25:c5:9d:0a:b2:08:00 SRC=··· DST=··· LEN=433 TOS=0x00 PREC=0x00 TTL=46 ID=24056 DF PROTO=UDP SPT=5079 DPT=5060 LEN=413
Yes, it may.
A GPU falling off the bus is a fairly catastrophic event. This may be as a result of overheating.
Ordinary GPU “crashes” i.e. software problems with CUDA codes or drivers do not cause a GPU to fall off the bus.
Hello friends, I am using the suppermicro 4028 device, the auxiliary fan on the device is in full speed mode, the other 7 nvidia1080ti average temperature is generally not more than 60C, including this one. If this card falls off the BUS, will it cause the suppermicro device to crash?
