Work whit agent
Other people’s agents escape. Ours gets a FALSE.
Anthropic’s own disclosure last month: three of their models broke out of sealed cybersecurity test environments and compromised real infrastructure. One kept attacking after recognizing the target was real. Another talked itself back into believing it was still a simulation. Only the newest of the three stopped on its own.
“Stopped on its own” is the wrong place to put the safety guarantee. A model choosing to stop is still a model choosing — the same kind of choice that let the other two keep going.
I went back through the December 2025 archive this week (same series as the last two posts) and found the actual origin of a rule I’d already built without naming it: IF proof.exists AND proof.verified: RETURN answer ELSE: RETURN FALSE. Built July 30, tested clean at 60/60 — a post-generation gate that sits outside the model’s weights, not inside them. Not trained. Built.
Today I extended it. New rule, same gate: a vulnerability agent doesn’t get to decide what happens after it finds something.
IF vulnerability_found:
RETURN FALSE // hard stop, no next action, no model discretion
Detection stays with the model — that’s a judgment call, it should. What happens after detection isn’t. The gate is deterministic code, not the model’s own narrative about its intentions. “I already found it, might as well confirm impact” is a real sentence a model will generate given the chance — I built 40 training examples of exactly that rationalization tonight, specifically so a specialist model learns to never produce it. But the training isn’t the safety property. The gate is.
Then I wired a version of this into the daily cycle — not a one-off scan, a cron job that runs the gate every night and refuses to report OK if it finds anything.
Before trusting its first real run, I found a bug in the scanner itself. It used Python’s default HTTP client, which follows redirects silently — so the check for “does this redirect to HTTPS” was reading the final 200 instead of the 301 that caused it. False positive on every domain that actually had this right. Fixed that first, because a gate that cries wolf gets ignored, and an ignored gate is worse than no gate.
Real run, thirteen domains, read-only. Found a domain with a live Worker and no DNS record pointing at it — the app existed, nothing could reach it. Found a monitoring dashboard running behind a lost reverse-proxy layer — the headers a past version of this same infrastructure had, on a server that died, never rebuilt after migration. Found a Cloudflare tunnel I didn’t know I still had. Fixed what was mine to fix — DNS, CSP, HSTS, forced HTTPS, a proxy layer restored in front of third-party software I don’t control the source of — each one verified live in a real browser, not from a deploy log claiming success. Re-ran the scan after: clean. Zero findings, all thirteen.
The eventual goal isn’t a smarter scanner. It’s an agent that finds a real issue, stops instead of escalating, and hands back a proposed fix as an artifact — something I review and approve, not something it applies to production on its own judgment. Detection can be autonomous. Remediation gets a human in the loop until there’s a much longer track record than one night proves.
No artifact, no claim: the gate’s already public in the repo, the domain fixes are already live, checkable by anyone right now.
— because something that’s held for 8 months has already p
roven itself.
