Yin Yan appled to code
Receipts, not hype: yin-yang applied to code
I don’t have an IT background. I got here through pain, millions of files, copies, templates, and everyday work — yesterday included. When I say code carries vulnerability at the moment of creation, I’m not theorizing. I’m reporting from the logs.
Here’s the mechanism, not just the slogan: the same thing that makes code useful is what makes it exploitable. Generalize a function so it handles more cases, and you’ve also generalized the cases where it breaks. Write a check, and the check’s own logic can be wrong in exactly the way the thing it checks is wrong. Vulnerability isn’t a separate ingredient added later by an attacker — it’s the same material as the function, from the same line of code. That’s the Tao part: not two things in conflict, one thing with two faces.
Receipts, from my own repo, not abstraction: in a 5-day window (Aug 6–10), 10 separate commits in sipa-os-governance are titled “Correct EXP-0XX” — each one an experiment result I’d published, then found wrong, then fixed in public, not quietly. Separately: a daily_receipt.yml heredoc-quoting bug sat unnoticed for 7 months because the broken file kept behaving exactly like a working one. And a regex missing one optional group silently lost 14 of 15 ablation runs in one night, passing exit 0 every time.
Today’s own result makes the same point live: I trained and merged 6 LoRA specialists into a vulnerability-gate model, then ran it against 120 held-out and 120 adversarial test cases. 117/120 and 116/120. Not 120/120. The gate that’s supposed to catch vulnerabilities has 3–7 of its own, still there, after the fix, after the merge, after the eval. That’s not a failure of the method — that’s the method telling the truth about itself.
I’m not trying to eliminate vulnerability or stop building new models. That’s a fantasy — the numbers above prove even a working gate can’t get there. The point is narrower: as long as there’s code, there’s vulnerability, in the same file, from the same cause. Not a bug to close once. A constant to keep checking, indefinitely — improve, or replace with something new, and expect the next layer under that
too.
