Workbench-example-hybrid-rag Microservice error
I’m using Ubuntu 22.04. I’ve tried running Microservice locally, but I get the same error as I get on Local and Cloud
*** ERR: Unable to process query. ***
Message: Response ended prematurely
For cloud and local microservice responses, I’ve pushed a fix this morning that addresses an issue. See here.
On local, you may need to provide the logs you see in Output > Chat to get more info into what is happening
EDIT: I see you got the local to work here, let me know if you still need help
