Hi Nvidia Support Team,
I am trying to convert our Custom model from ONNX to tensorrt Model in Jetson Nano. The conversion is happening without errors, but after the Conversion, the size and type of the TRT Model being generated in Jetson Nano are completely different when I am converting in my Local System.
-> Size of the ONNX Model= 251 MB
->Size of the TRT Model being generated in Jetson Nano= 605 MB[Type: STL 3D Model(binary)]
-> Size of the TRT model being generated in my Local System= 250MB[Type: binary]
Code used for ONNX to TRT Conversion:
`import tensorrt as trt
TRT_LOGGER = trt.Logger(trt.Logger.WARNING)
trt_runtime = trt.Runtime(TRT_LOGGER)
def build_engine(onnx_path, shape = [1,1,224,224]):
with trt.Builder(TRT_LOGGER) as builder, builder.create_network(1) as network, trt.OnnxParser(network, TRT_LOGGER) as parser:
builder.max_workspace_size = (1<<30)
with open(onnx_path, 'rb') as model:
parser.parse(model.read())
network.get_input(0).shape = shape
engine = builder.build_cuda_engine(network)
return engine
def save_engine(engine, file_name):
buf = engine.serialize()def load_engine(trt_runtime, plan_path):
with open(engine_path, 'rb') as f:
engine_data = f.read()
engine = trt_runtime.deserialize_cuda_engine(engine_data)
return engine
from onnx import ModelProto
engine_name = "xyz.plan"
onnx_path = "xyz.onnx"
model = ModelProto()
with open(onnx_path, "rb") as f:
model.ParseFromString(f.read())
batch_size = 1
d0 = model.graph.input[0].type.tensor_type.shape.dim[1].dim_value
d1 = model.graph.input[0].type.tensor_type.shape.dim[2].dim_value
d2 = model.graph.input[0].type.tensor_type.shape.dim[3].dim_value
shape = [batch_size , d0, d1 ,d2]
engine = build_engine(onnx_path)
save_engine(engine, engine_name)
Is there any way for reducing the size of the Tensorrt Model?
What is the Workspace size for jetson Nano?
