Writing partition APP with system.img *** Error: Flashing the device failed. ] 031%
I am trying to do mass flashing, here are the steps I followed:
  • Install all the necessary softwares on first xavier nx production module
  • Went to Jetson Xavier NX flashing directory
    cd ~/nvidia/nvidia_sdk/JetPack_4.4.1_Linux_JETSON_XAVIER_NX/Linux_for_Tegra
  • Connected first xavier nx device with all necessary software installed, and put it into RCM mode.
    sudo ./nvmassflashgen.sh jetson-xavier-nx-devkit-emmc mmcblk0p1
  • Untar the generated file
    tar xvjf mfi_jetson-xavier-nx-devkit-emmc.tbz2
  • Went to extracted file directory
    cd mfi_jetson-xavier-nx-devkit-emmc
  • Disconnected first xavier nx production module
  • Connected second xavier nx production module and put it into RCM mode
    sudo ./nvmflash.sh --showlogs
Here is the log output:
*** Boot Rom communication
/home/nitin/nvidia/nvidia_sdk/JetPack_4.4.1_Linux_JETSON_XAVIER_NX/Linux_for_Tegra/mfi_jetson-xavier-nx-devkit-emmc/tegrarcm_v2 --instance 1-9.1 --chip 0x19 0 --rcm rcm_list_signed.xml
BR_CID: 0x88021911646cf5c924000000130501c0
RCM version 0X190001
Boot Rom communication completed
*** Boot Rom communication succeeded.
*** Checking applet
/home/nitin/nvidia/nvidia_sdk/JetPack_4.4.1_Linux_JETSON_XAVIER_NX/Linux_for_Tegra/mfi_jetson-xavier-nx-devkit-emmc/tegrarcm_v2 --instance 1-9.1 --isapplet
Applet version 01.00.0000
*** Checking applet succeeded.
*** Sending BCTs
/home/nitin/nvidia/nvidia_sdk/JetPack_4.4.1_Linux_JETSON_XAVIER_NX/Linux_for_Tegra/mfi_jetson-xavier-nx-devkit-emmc/tegrarcm_v2 --instance 1-9.1 --download bct_bootrom br_bct_BR.bct --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt --download bct_mem mem_rcm_sigheader.bct.encrypt
Sending bct_bootrom
[................................................] 100%
Sending bct_mb1
Sending bct_mem
*** Sending BCTs succeeded.
*** Sending bootloader and pre-requisite binaries
/home/nitin/nvidia/nvidia_sdk/JetPack_4.4.1_Linux_JETSON_XAVIER_NX/Linux_for_Tegra/mfi_jetson-xavier-nx-devkit-emmc/tegrarcm_v2 --instance 1-9.1 --download blob blob.bin
Sending blob
*** Sending bootloader and pre-requisite binaries succeeded.
*** Booting Recovery
/home/nitin/nvidia/nvidia_sdk/JetPack_4.4.1_Linux_JETSON_XAVIER_NX/Linux_for_Tegra/mfi_jetson-xavier-nx-devkit-emmc/tegrarcm_v2 --instance 1-9.1 --boot recovery
*** Booting Recovery succeeded.
*** Checking applet
*** Checking CPU bootloader
/home/nitin/nvidia/nvidia_sdk/JetPack_4.4.1_Linux_JETSON_XAVIER_NX/Linux_for_Tegra/mfi_jetson-xavier-nx-devkit-emmc/tegradevflash_v2 --instance 1-9.1 --iscpubl
Bootloader version 01.00.0000
*** Checking CPU bootloader succeeded.
ls: cannot access 'mbr_*': No such file or directory
ls: cannot access 'gpt_*': No such file or directory
*** Retrieving storage infomation
/home/nitin/nvidia/nvidia_sdk/JetPack_4.4.1_Linux_JETSON_XAVIER_NX/Linux_for_Tegra/mfi_jetson-xavier-nx-devkit-emmc/tegradevflash_v2 --instance 1-9.1 --oem platformdetails storage storage_info.bin
Saved platform info in storage_info.bin
*** Retrieving storage infomation succeeded.
*** Generating GPT
/home/nitin/nvidia/nvidia_sdk/JetPack_4.4.1_Linux_JETSON_XAVIER_NX/Linux_for_Tegra/mfi_jetson-xavier-nx-devkit-emmc/tegraparser_v2 --storageinfo storage_info.bin --generategpt --pt flash.xml.bin
*** Generating GPT succeeded.
*** Flashing the device
/home/nitin/nvidia/nvidia_sdk/JetPack_4.4.1_Linux_JETSON_XAVIER_NX/Linux_for_Tegra/mfi_jetson-xavier-nx-devkit-emmc/tegradevflash_v2 --instance 1-9.1 --pt flash.xml.bin --create
Erasing spi: 0 ......... [Done]
Writing partition secondary_gpt with gpt_secondary_3_0.bin
Erasing sdmmc_user: 3 ......... [Done]
Writing partition master_boot_record with mbr_1_3.bin
Writing partition primary_gpt with gpt_primary_1_3.bin
Writing partition secondary_gpt with gpt_secondary_1_3.bin
Writing partition mb1 with mb1_t194_prod_sigheader.bin.encrypt
Writing partition mb1_b with mb1_t194_prod_sigheader.bin.encrypt
Writing partition spe-fw with spe_t194_sigheader.bin.encrypt
Writing partition spe-fw_b with spe_t194_sigheader.bin.encrypt
Writing partition mb2 with nvtboot_t194_sigheader.bin.encrypt
Writing partition mb2_b with nvtboot_t194_sigheader.bin.encrypt
Writing partition mts-preboot with preboot_c10_prod_cr_sigheader.bin.encrypt
Writing partition mts-preboot_b with preboot_c10_prod_cr_sigheader.bin.encrypt
Writing partition mts-mce with mce_c10_prod_cr_sigheader.bin.encrypt
Writing partition mts-mce_b with mce_c10_prod_cr_sigheader.bin.encrypt
Writing partition mts-proper with mts_c10_prod_cr_sigheader.bin.encrypt
Writing partition mts-proper_b with mts_c10_prod_cr_sigheader.bin.encrypt
Writing partition sc7 with warmboot_t194_prod_sigheader.bin.encrypt
Writing partition sc7_b with warmboot_t194_prod_sigheader.bin.encrypt
Writing partition SMD with slot_metadata.bin
Writing partition SMD_b with slot_metadata.bin
Writing partition xusb-fw with xusb_sil_rel_fw
Writing partition xusb-fw_b with xusb_sil_rel_fw
Writing partition cpu-bootloader with cboot_t194_sigheader.bin.encrypt
Writing partition cpu-bootloader_b with cboot_t194_sigheader.bin.encrypt
Writing partition bootloader-dtb with tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt
Writing partition bootloader-dtb_b with tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt
Writing partition BMP with bmp.blob
Writing partition BMP_b with bmp.blob
Writing partition secure-os with tos-trusty_t194_sigheader.img.encrypt
Writing partition secure-os_b with tos-trusty_t194_sigheader.img.encrypt
Writing partition eks with eks_sigheader.img.encrypt
Writing partition eks_b with eks_sigheader.img.encrypt
Writing partition adsp-fw with adsp-fw_sigheader.bin.encrypt
Writing partition adsp-fw_b with adsp-fw_sigheader.bin.encrypt
Writing partition rce-fw with camera-rtcpu-rce_sigheader.img.encrypt
Writing partition rce-fw_b with camera-rtcpu-rce_sigheader.img.encrypt
Writing partition bpmp-fw with bpmp_t194_sigheader.bin.encrypt
Writing partition bpmp-fw_b with bpmp_t194_sigheader.bin.encrypt
Writing partition bpmp-fw-dtb with tegra194-a02-bpmp-p3668-a00_sigheader.dtb.encrypt
Writing partition bpmp-fw-dtb_b with tegra194-a02-bpmp-p3668-a00_sigheader.dtb.encrypt
Writing partition VER with qspi_bootblob_ver.txt
Writing partition VER_b with qspi_bootblob_ver.txt
Please give some pointers on what could be wrong.
hello NitinRai,
are you having customization to replace the default system.img?
it yes, the size might be differ, you may probably need to use the “-S size” option to specify the partition size.
please check Flash Script Usage and doing so with flash.sh to have verification.
thanks
@JerryChang
I am creating a massflash blob from one of our Xavier NX production module which has custom softwares installed.
I found the system.img at two places:
  1. ~/nvidia/nvidia_sdk/JetPack_4.4.1_Linux_JETSON_XAVIER_NX/Linux_for_Tegra/bootloader/system.img
  2. ~/nvidia/nvidia_sdk/JetPack_4.4.1_Linux_JETSON_XAVIER_NX/Linux_for_Tegra/mfi_jetson-xavier-nx-devkit-emmc/system.img
Please confirm which one you are referring to.
As per the README_Massflash.txt the system.img created inside mfi_jetson-xavier-nx-devkit-emmc dir should just work without replacing any files manually.
it yes, the size might be differ, you may probably need to use the “ -S size ” option to specify the partition size.
At which step do I need to use this -S size option and what should be the value of size?
hello NitinRai,
/bootloader/system.img: this is the default system image generated by flash commands,
/mfi_jetson-xavier-nx-devkit-emmc/system.img : this is generated by nvmassflashgen.sh script.
could you please have an offline approach to execute nvmassflashgen?
for example,
BOARDID=3668 BOARDSKU=0000 FAB=100 FUSELEVEL=fuselevel_production ./nvmassflashgen.sh jetson-xavier-nx-devkit mmcblk0p1
BTW, suggest you should also check Massflash and JetPack 4.4 issue - #8 by DaneLLL as see-also.
thanks
I need to have custom softwares installed on all the devices which will be flashed, If i follow offline method how do i make sure it has those customizations done ?
hello NitinRai,
please check Topic 173555 for the steps to modify the files in system.img, then flash to board again. thanks
Thanks for the reference links, I have seen those topics before creating a new one. I have a system.img file with me I don’t want to modify it.
Where do I use this flag -S size neither nvmassflashgen.sh accepts this nor nvmflash.sh
My query is:
  • I flashed a jetson nx then installed some libraries and softwares
  • I created a mass flash blob image using online method (because I wan’t to flash more device which contains same softwares as the first one)
  • I suppose the blob I created contains all the changes I made in the first nx
  • Once I have this customized blob, I want to flash more Jetson NX devices having same customization that I did in the first one
All the topics I visited has discussion about flash.sh script which only allow to flash one device at once.
I hope you understand what I am trying to do
hello NitinRai,
this is not correct.
it’ll generate a new system.img from your local host machine when you execute nvmassflashgen.sh.
however,
you may include -r switch to skip building and reuse existing system.img.
for example, $ sudo ./nvmassflashgen.sh -r jetson-xavier-nx mmcblk0p1
you should have a cloned image to replace with the default image, then deployment it to other platforms.
BTW,
mostly flash options works for the nvmassflashgen.sh, (since I only check several options.)
you may use the flag -S size into command line for generating mass-flash image tarball, thanks
Hey @JerryChang Thanks for the valuable information. I am able to massflash with custom system.img
I followed all the steps as mentioned in the previous replies to generate mfi_jetson-xavier-nx-devkit-emmc directory and then create a clone of the device using command :
sudo ./flash.sh -r -k APP -G backup.img jetson-xavier-nx-devkit-emmc mmcblk0p1
After which I replaced the system.img with the backup.img in the ``mfi_jetson-xavier-nx-devkit-emmc` directory using command:
cp backup.img mfi_jetson-xavier-nx-devkit-emmc/system.img
and finally connected two Xavier NX put them into RCM and ran sudo ./nvmflash.sh --showlogs It worked out without any errors and flashe both of the two devices in parallel.
@NitinRai
Thank you for sharing your success!
You may also like to use Jetpack 4.5.1 instead of Jetpack 4.4.1
@JerryChang non production nx devkit version is not supported by nvmassflash script? is it?
The readme only lists these
                                 BOARDID  BOARDSKU  FAB  BOARDREV
     jetson-xavier-nx-devkit-emmc     3668     0001      100  N/A
     jetson-nano-devkit-emmc          3448     0002      200  N/A
     jetson-agx-xavier-devkit (16GB)  2888     0001      400  H.0
     jetson-agx-xavier-devkit (32GB)  2888     0004      400  K.0
     jetson-agx-xavier-devkit-8gb     2888     0006      400  B.0
     jetson-tx2-devkit                3310     1000      B02  N/A
     jetson-tx2-devkit-tx2i           3489     0000      300  A.0
     jetson-tx2-devkit-4gb            3489     0888      300  F.0
     jetson-tx1-devkit                2180     0000      400  N/A
hello Andrey1984,
yes, massflash only support with eMMC modules.
however,
there’s tool to support that if you’re working Jetson Xavier NX with external storage, (i.e. NVMe)
please check below for more details.
$OUT/JetPack-4.5.1/Linux_for_Tegra/tools/kernel_flash/README.txt
@JerryChang Using production nx/agx, having a cloned APP partition created from one device, can we use this nvmflash method to get rid of remnants of the mac addresses from the original unit from that the APP image was cloned?
I don’t know if this applies for your case, but there are times when network device information is set up in udev. You might want to check if there is anything related to your MAC address in a subdirectory of “/etc/udev”.
@JerryChang
In which exactly location the cloned image should reside?
Given I have the cloned image in the folder /home/nvidia/backup
However running the nvmassflashgen from /home/nvidia/generate_flash
Where the pre-existing image shoudl reside before running the nvmassflash command? Just executing nvmflash.sh after creating the mfi folder with nvmassflashgen script doesn’t appear to result in the unit booting.
did you mean you’ve extract the mfi_* package, running the nvmflash.sh to flash the target to repo the failure?
since this topic has been solved, could you please initial another new topic and share the steps; we would also like to reproduce the issue locally for investigation.
thanks!
Exactly, from a woking unit, I get the mfi package by executing
./nvmassflashgen.sh jetson-xavier mmcblk0p1
then after connecting a new unit after unpacking the package after processing the ./nvmflash.sh the jetson won’t boot
posted new thread to Nvmassflashgen cloned partition won't boot on other units
thank you, let’s follow-up with Topic 189508.
@JerryChang Thank you for following up, but
could you extend if the reuse of existing system.ing reffers to reuse of the APP partition from the source device or it refers to the particular PATH with particular system.img file that is pressumed to be present at the Host PC somewhere? If yes where excatly?
Here the question that requires a clarification also is either the ./nvmassflash.gen generates system.img using a conencted device which is in recovery mode so it loads all the partitions from it or if the nvmassflashgen.sh generates system.img from Linux_for_Tegra folder
Could you extend on particular details, please? Does the generator use both linux_for_tegra, but also the device as ta source?
