Hi ,
i have developed a Convolutional Autoencoder model in Pytorch and converted it with onnx. Everything is working fine i am able to run inference but the output of the model of tensorrt is very different from the output obtained from the model in Pytorch.
Both inference code are developed in python.
To avoid image problem type conversion i load the same input to both model. Load the data from the same file.
def do_inference(context, h_input, d_input, h_output, d_output, stream):
# Transfer input data to the GPU.
cuda.memcpy_htod_async(d_input, h_input, stream)
# Run inference.
context.execute_async(bindings=[int(d_input), int(d_output)], stream_handle=stream.handle)
# Transfer predictions back from the GPU.
cuda.memcpy_dtoh_async(h_output, d_output, stream)
# Synchronize the stream
stream.synchronize()
#tensorrt Inference
array = np.loadtxt("/home/velab/Desktop/model_input.txt")
image_arr = array.ravel()
np.copyto(pagelocked_buffer, image_arr)
h_output = torch.from_numpy(h_output).float().cuda()
imagePIL= transforms.ToPILImage()(h_output.cpu().view(-1, 64, 64)
imagePIL.show()
# Pytorch Script
tensor_image_in = torch.from_numpy(array).float().cuda()
tensor_image_in=tensor_image_in.view(1,1,64,64)
output=model_inference(tensor_image_in.cuda())
imagePIL=transforms.ToPILImage()(output.detach().cpu().view(-1,64,64))
image_inputPIL = transforms.ToPILImage()(tensor_image_in.cpu().view(-1, 64, 64))
image_inputPIL.show()
imagePIL.show()
The output image from Pytorch Script is correct but the Output image from tensorrt is not correct.
Could someone provide me any feedback why is not working?
