[WSL2 + Ubuntu 24.04 LTS] NVIDIA GPU detected but WSLg not working (OpenGL = llvmpipe)
Tags: #WSL2 #Ubuntu2404 #WSLg #NVIDIA #OpenGL #CUDA
🧩 Context
I’m using Windows 11 with WSL2 and Ubuntu 24.04 LTS, trying to run Gazebo / RViz / OpenGL apps with NVIDIA GPU acceleration through WSLg.
CUDA works, but OpenGL still falls back to software rendering (llvmpipe).
⚙️ Environment
Component Version / Info
Windows 11 Pro – build 26100.6725
WSL 2.6.1.0
Kernel 6.6.87.2-microsoft-standard-WSL2
WSLg 1.0.66
Ubuntu 24.04.3 LTS
GPU NVIDIA GeForce RTX 2050
Driver (Windows) 581.42
CUDA 13.0
🧪 What I have tested
  1. GPU detected
    nvidia-smi
    → Works fine, GPU and driver visible.
  2. No WSLg detected
    echo $WSLG
    → Empty output.
  3. OpenGL renderer = software
    glxinfo | grep "OpenGL renderer"
    → Output: llvmpipe (LLVM 20.1.2, 256 bits) (CPU rendering only).
  4. Fix attempts
    • Removed manual DISPLAY and LIBGL_ALWAYS_INDIRECT from .bashrc
    • Ran:
      wsl --update
      wsl --shutdown
    • Tried reinstalling WSLg manually:
      Add-AppxPackage -Register "C:\Program Files\WindowsApps\MicrosoftCorporationII.WindowsSubsystemForLinux_1.0.66.0_x64__8wekyb3d8bbwe\AppxManifest.xml"
      → Path not found (new WSL integrates WSLg).
  5. Alternative (VcXsrv)
    • xeyes works, but still software rendering.
    • OpenGL fallback remains llvmpipe.
  6. ⚙️ NVIDIA bug report
    sudo nvidia-bug-report.sh
    → Report generated, but /proc/driver/nvidia/version missing (expected in WSL2).
🚫 Current status
  • nvidia-smi ✅ Works
  • CUDA ✅ Works
  • OpenGL ❌ Software rendering (no GPU acceleration)
  • WSLg ❌ Seems inactive on Ubuntu 24.04
❓ Question
Is there a known incompatibility between WSLg and Ubuntu 24.04 LTS?
If so, should I switch back to Ubuntu 22.04 LTS to get NVIDIA OpenGL hardware acceleration?
Or is there a way to force-enable WSLg on Ubuntu 24.04 under Windows 11?
📎 Logs available
here is my nvidia-bug-report
nvidia-bug-report.log.gz (191.9 KB)
The same problem! Did anyone solve that?
In WSL the HW graphics driver is not “native”, but using a DirectX 12 translation layer.
Similar to XBOX: OpenGL® on DX12 enables STEEL ASSAULT to launch on Xbox - DirectX Developer Blog
Get latest driver from https://launchpad.net/\~kisak/+archive/ubuntu/kisak-mesa
export MESA_D3D12_DEFAULT_ADAPTER_NAME=NVIDIA
export GALLIUM_DRIVER=d3d12
export LIBGL_ALWAYS_SOFTWARE=false
Thanks Man, till now I didn’t know my WSL has direct GPU access, when Tried to launch electron based app it took eternity to open, now that GPU is exposed it is opening in a flash.
