X-output problems Error: glXCreateContext failed
I just installed the sdk on a kubuntu system with two GTX295 (sli) cards and two displays with twinview. KDE works fine, but running sdk samples with x-output results in:
[ CUDA Mandelbrot/Julia Set ]
Initializing GLUT…
freeglut (./Mandelbrot): Unable to create direct context rendering for window ‘./Mandelbrot’
This may hurt performance.
X Error of failed request: BadMatch (invalid parameter attributes)
Major opcode of failed request: 156 (GLX)
Minor opcode of failed request: 5 (X_GLXMakeCurrent)
Serial number of failed request: 42
Current serial number in output stream: 42
Samples like sorting work. Then I started glxdemo, which shows the errormessage:
I guess the problem is located in my xorg.conf, so I post it here:
[b]
Section “ServerLayout”
Identifier “Layout0”
Screen 0 “Screen0” 0 0
Screen 1 “Screen1” RightOf “Screen0”
Screen 2 “Screen2” RightOf “Screen1”
Screen 3 “Screen3” RightOf “Screen2”
InputDevice “Keyboard0” “CoreKeyboard”
InputDevice “Mouse0” “CorePointer”
EndSection
Section “Files”
EndSection
Section “InputDevice”
# generated from default
Identifier     "Mouse0"
Driver         "mouse"
Option         "Protocol" "auto"
Option         "Device" "/dev/psaux"
Option         "Emulate3Buttons" "no"
Option         "ZAxisMapping" "4 5"
EndSection
Identifier     "Keyboard0"
Driver         "kbd"
EndSection
Section “Monitor”
Identifier “Monitor0”
VendorName “Unknown”
ModelName “Unknown”
HorizSync 28.0 - 33.0
VertRefresh 43.0 - 72.0
Option “DPMS”
EndSection
Section “Monitor”
Identifier “Monitor1”
ModelName “Unknown”
Option “DPMS”
EndSection
Section “Monitor”
Identifier “Monitor2”
ModelName “Unknown”
Option “DPMS”
EndSection
Section “Monitor”
Identifier “Monitor3”
ModelName “Unknown”
Option “DPMS”
EndSection
Section “Device”
Identifier “Device0”
Driver “nvidia”
VendorName “NVIDIA Corporation”
BoardName “GeForce GTX 295”
BusID “PCI:15:0:0”
EndSection
Section “Device”
Identifier “Device1”
Driver “nvidia”
BusID “PCI:14:0:0”
EndSection
Section “Device”
Identifier “Device2”
Driver “nvidia”
BusID “PCI:11:0:0”
EndSection
Section “Device”
Identifier “Device3”
Driver “nvidia”
BusID “PCI:10:0:0”
EndSection
Section “Screen”
Identifier “Screen0”
Device “Device0”
Monitor “Monitor0”
DefaultDepth 24
Option “TwinView” “True”
Option “MetaModes” “nvidia-auto-select, nvidia-auto-select”
Option “TwinViewOrientation” “LeftOf”
SubSection “Display”
Depth 24
EndSubSection
EndSection
Section “Screen”
Identifier “Screen1”
Device “Device1”
Monitor “Monitor1”
DefaultDepth 24
Depth 24
EndSubSection
EndSection
Section “Screen”
Identifier “Screen2”
Device “Device2”
Monitor “Monitor2”
DefaultDepth 24
Depth 24
EndSubSection
EndSection
Section “Screen”
Identifier “Screen3”
Device “Device3”
Monitor “Monitor3”
DefaultDepth 24
Depth 24
EndSubSection
EndSection
[/b]
Any help is wellcome…
Philipp.
Ok, I solved it.
Deinstalling all nvidia* packages with apt-get and reinstalling the nvidia driver worked!
I am facing the same issue with NVIDIA GeForce RTX 4060 Laptop GPU/PCIe/SSE2
OpenGL ES profile version string: OpenGL ES 3.2 NVIDIA 545.23.08
OpenGL ES profile shading language version string: OpenGL ES GLSL ES 3.20
when using NVIDIA shipped drivers, glXCreateContext() does not work. The rendering window automatically gets closed.
I tried remove/re-install of drivers. But the same issue.
When I use OS provided Nouveau drivers, it works.
