If anyone is interested, I sent CSI camera to PC: video-viewer --bitrate=8000000 csi://0 rtp://10.199.1.13:5000 --output-codec=h265 --input-width=1920 --input-height=1080 --input-rate=60 (but it doesn’t give output 60fps, only 30 if checked)
And on PC ran detectnet: detectnet rtp://@:5000 file://tere.mp4 --headless --input-codec=h265 --batch-size=8 --model=ssd-mobilnet-v2.onnx --output-cvg=scores --output-bbox=boxes --labels=labels.txt
Results: on 1070 8GB network time lowered about 2 times, but preprocess (because of video stream i think) took about 2,5ms, so in total its actually the same as on Jetson Xavier NX 16.
Both models has input size 512.
GST_ARGUS: Available Sensor modes :
GST_ARGUS: 3840 x 2160 FR = 29.999999 fps Duration = 33333334 ; Analog Gain range min 1.000000, max 22.250000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1920 x 1080 FR = 59.999999 fps Duration = 16666667 ; Analog Gain range min 1.000000, max 22.250000; Exposure Range min 13000, max 683709000;
GST_ARGUS: Running with following settings:
Camera index = 1
Camera mode = 1
Output Stream W = 1920 H = 1080
seconds to Run = 0
Frame Rate = 59.999999
GST_ARGUS: Setup Complete, Starting captures for 0 seconds
GST_ARGUS: Starting repeat capture requests.
CONSUMER: Producer has connected; continuing.
[gstreamer] gstCamera – onPreroll
[gstreamer] gstBufferManager – map buffer size was less than max size (3110400 vs 3110407)
[gstreamer] gstBufferManager recieve caps: video/x-raw, width=(int)1920, height=(int)1080, framerate=(fraction)60/1, format=(string)NV12
[gstreamer] gstBufferManager – recieved first frame, codec=raw format=nv12 width=1920 height=1080 size=3110407
[cuda] allocated 4 ring buffers (3110407 bytes each, 12441628 bytes total)
[cuda] allocated 4 ring buffers (8 bytes each, 32 bytes total)
[gstreamer] gstreamer changed state from READY to PAUSED ==> mysink
[gstreamer] gstreamer message async-done ==> pipeline0
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> mysink
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> pipeline0
[cuda] allocated 4 ring buffers (6220800 bytes each, 24883200 bytes total)
video-viewer: captured 0 frames (1920x1080)
[cuda] allocated 2 ring buffers (3110400 bytes each, 6220800 bytes total)
[gstreamer] gstEncoder – starting pipeline, transitioning to GST_STATE_PLAYING
Opening in BLOCKING MODE
[gstreamer] gstreamer changed state from NULL to READY ==> udpsink0
[gstreamer] gstreamer changed state from NULL to READY ==> rtph265pay0
[gstreamer] gstreamer changed state from NULL to READY ==> capsfilter3
[gstreamer] gstreamer changed state from NULL to READY ==> encoder
[gstreamer] gstreamer changed state from NULL to READY ==> capsfilter2
[gstreamer] gstreamer changed state from NULL to READY ==> vidconv
[gstreamer] gstreamer changed state from NULL to READY ==> mysource
[gstreamer] gstreamer changed state from NULL to READY ==> pipeline1
[gstreamer] gstreamer changed state from READY to PAUSED ==> rtph265pay0
[gstreamer] gstreamer changed state from READY to PAUSED ==> capsfilter3
[gstreamer] gstreamer changed state from READY to PAUSED ==> encoder
[gstreamer] gstreamer changed state from READY to PAUSED ==> capsfilter2
[gstreamer] gstreamer changed state from READY to PAUSED ==> vidconv
[gstreamer] gstreamer stream status CREATE ==> src
[gstreamer] gstreamer changed state from READY to PAUSED ==> mysource
[gstreamer] gstreamer changed state from READY to PAUSED ==> pipeline1
[gstreamer] gstreamer message new-clock ==> pipeline1
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> rtph265pay0
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> capsfilter3
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> encoder
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> capsfilter2
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> vidconv
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> mysource
[gstreamer] gstreamer stream status ENTER ==> src
[gstreamer] gstEncoder – new caps: video/x-raw, width=1920, height=1080, format=(string)I420, framerate=30/1
video-viewer: captured 1 frames (1920x1080)
