I am working on Xavier and I try to use Opencv tracking algorithms with python2.7. But I faced with this error when I call tracking algorithms.
"csrt": cv2.TrackerCSRT_create,
AttributeError: 'module' object has no attribute 'TrackerCSRT_create'
Then I tried to install opencv and opencv-contrib lib to Xavier. I followed this topic ‘How to install Opencv-contrib-python on Xavier’[0] topic.
Here is what I did step by step:
1 - Downloaded script[1] that mentioned in topic, to ‘/home/nvidia/’ path.
2 - Changed all opencv and opencv_contrib versions to ‘3.4.0.’. Also I changed file name to ‘install_opencv3.4.0_Xaiver.sh’. After this step script file look like this[2].
3 - Run sh file with the command ‘sudo ./install_opencv3.4.0_Xaiver.sh ~/’
Installation was successful. But after installation I still face with same error when I called tracking algorithms. Console print while script file runing[3].
I don’t understand why it did not work after installation finished successfully.
[0]:https://devtalk.nvidia.com/default/topic/1055742/jetson-agx-xavier/how-to-install-opencv-contrib-python-on-xavier-/
[1]:https://github.com/AastaNV/JEP/blob/master/script/install_opencv4.0.0_Xavier.sh
[2]:https://paste.ubuntu.com/p/dZDQMyrQ4k/
[3]:https://pasteboard.co/Iu7MnZx.png
