I’m running an issue with my Jetson Xavier NX developer kit on a jetbot.
I have it connected with an ultrasonic sensor, a adafruit TB6612 ECS controller which then connected to 2 DC motors. I had 4 batteries powering up the motor and an adapter to power up the board. Everything works all good until yesterady I was when I plugged in the power source and access the board using VNC, nothing shows up. I then plugged in the hdmi cable to screen and the screens shows no signal.
I then unplugged all the connections and tried multiple times but the screen still shows no signal input.
Before that I did a soldering work that allows the battery to both power up the motor and the board, and when I plug in the power the board works all fine. I’m pretty sure that when I was doing soldering, the power was off.
I also tried to use another SD card with new os file and the board still won’t work. I tried to use SDKmanager to flash the system but it shows the board cannot be detected.
Any ideas to such situation? Did I accidently burn something on the board?
