I’m facing Xid 56 error - not regularly, but at random and frequently when I resume from suspend.
When I suspend using the gnome-shell option, at random, I will get a blank screen and when I SSH in that machine to check dmesg output, I always get a Xid 56 error and Failed to acquire idle monitor proxy: Timeout was reached.
I did a reboot and then I got the idea to post here so I couldn’t run nvidia-bug-report.sh, but I will post it the next time it occurs. Instead, here is the journalctl output of said boot.
$ nvidia-smi
| NVIDIA-SMI 460.73.01 Driver Version: 460.73.01 CUDA Version: 11.2 |
| | | MIG M. |
| 0 GeForce GT 710 Off | 00000000:09:00.0 N/A | N/A |
| 40% 47C P0 N/A / N/A | 493MiB / 1998MiB | N/A Default |
| | | N/A |
| 1 GeForce RTX 3070 Off | 00000000:0A:00.0 Off | N/A |
| 0% 42C P8 8W / 220W | 10MiB / 7982MiB | 0% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| 1 N/A N/A 2350 G /usr/lib/xorg/Xorg 4MiB |
| 1 N/A N/A 2967 G /usr/lib/xorg/Xorg 4MiB |
$ apt list --installed | grep nvidia
libnvidia-cfg1-460/focal,now 460.73.01-1pop0~1620243177~20.04~5b49ff5 amd64 [installed,automatic]
libnvidia-common-460/focal,focal,now 460.73.01-1pop0~1620243177~20.04~5b49ff5 all [installed,automatic]
libnvidia-compute-460/focal,now 460.73.01-1pop0~1620243177~20.04~5b49ff5 amd64 [installed,automatic]
libnvidia-compute-460/focal,now 460.73.01-1pop0~1620243177~20.04~5b49ff5 i386 [installed,automatic]
libnvidia-decode-460/focal,now 460.73.01-1pop0~1620243177~20.04~5b49ff5 amd64 [installed,automatic]
libnvidia-decode-460/focal,now 460.73.01-1pop0~1620243177~20.04~5b49ff5 i386 [installed,automatic]
libnvidia-encode-460/focal,now 460.73.01-1pop0~1620243177~20.04~5b49ff5 amd64 [installed,automatic]
libnvidia-encode-460/focal,now 460.73.01-1pop0~1620243177~20.04~5b49ff5 i386 [installed,automatic]
libnvidia-extra-460/focal,now 460.73.01-1pop0~1620243177~20.04~5b49ff5 amd64 [installed,automatic]
libnvidia-fbc1-460/focal,now 460.73.01-1pop0~1620243177~20.04~5b49ff5 amd64 [installed,automatic]
libnvidia-fbc1-460/focal,now 460.73.01-1pop0~1620243177~20.04~5b49ff5 i386 [installed,automatic]
libnvidia-gl-460/focal,now 460.73.01-1pop0~1620243177~20.04~5b49ff5 amd64 [installed,automatic]
libnvidia-gl-460/focal,now 460.73.01-1pop0~1620243177~20.04~5b49ff5 i386 [installed,automatic]
libnvidia-ifr1-460/focal,now 460.73.01-1pop0~1620243177~20.04~5b49ff5 amd64 [installed,automatic]
libnvidia-ifr1-460/focal,now 460.73.01-1pop0~1620243177~20.04~5b49ff5 i386 [installed,automatic]
nvidia-compute-utils-460/focal,now 460.73.01-1pop0~1620243177~20.04~5b49ff5 amd64 [installed,automatic]
nvidia-dkms-460/focal,now 460.73.01-1pop0~1620243177~20.04~5b49ff5 amd64 [installed,automatic]
nvidia-driver-460/focal,now 460.73.01-1pop0~1620243177~20.04~5b49ff5 amd64 [installed]
nvidia-kernel-common-460/focal,now 460.73.01-1pop0~1620243177~20.04~5b49ff5 amd64 [installed,automatic]
nvidia-kernel-source-460/focal,now 460.73.01-1pop0~1620243177~20.04~5b49ff5 amd64 [installed,automatic]
nvidia-settings/focal-updates,now 460.73.01-0ubuntu0.20.04.1 amd64 [installed,automatic]
nvidia-utils-460/focal,now 460.73.01-1pop0~1620243177~20.04~5b49ff5 amd64 [installed,automatic]
xserver-xorg-video-nvidia-460/focal,now 460.73.01-1pop0~1620243177~20.04~5b49ff5 amd64 [installed,automatic]
$ uname -a
Linux flameboi 5.11.0-7614-generic #15~1622578982~20.04~383c0a9-Ubuntu SMP Wed Jun 2 00:57:14 UTC 2 x86_64 x86_64 x86_64 GNU/Linux
$ lsb_release -a
Distributor ID: Pop
Description: Pop!_OS 20.04 LTS
Release: 20.04
Codename: focal
$ apt-cache show xserver-xorg | grep Version
Version: 1:7.7+19ubuntu14
Edit: This comment is referring to the problem I have, except with a GT710 instead of a GTX 1060. And to make sure this problem isn’t from the monitor’s end, I switched on the monitor before I wake the computer with either a key-press or with WakeOnLan (and yes, that is turned on in BIOS/UEFI). I also tried un-plugging and re-plugging the HDMI cable but it didn’t seem to work.
