Hello board,
I am working on a complex Qt/OpenGL Application.
Xorg starts leaking in VRAM when i’m using the application and never release the memory, until I restart X of course.
$ nvidia-smi
| NVIDIA-SMI 390.48 Driver Version: 390.48 |
| 0 GeForce GTX 105... Off | 00000000:01:00.0 Off | N/A |
| N/A 46C P8 4W / N/A | 50MiB / 4040MiB | 0% Default |
| Processes: GPU Memory |
| GPU PID Type Process name Usage |
| 0 29628 G /usr/lib/xorg-server/Xorg 47MiB |
$ ./myOpenGLQtBasedApp ... doing graphic stuff then exiting
$ nvidia-smi
| N/A 46C P8 4W / N/A | 110MiB / 4040MiB | 0% Default |
| 0 29628 G /usr/lib/xorg-server/Xorg 107MiB |
The version of Xorg does not matter, tested a few.
The version of the driver does not matter, as long as it’s nvidia, tested 340, 384, 390
The linux distribution does not matter, tested Ubuntu 16.04, 18.04, fedora
The de does not matter, tested Unity, Gnome-shell, Xfce, Lxde + Compton, Openbox + compton
The compositor used does not matter, but the leak disappear without a compositor.
I did not test Wayland.
Do you know what could cause this behavior ?
Could this be a nvidia driver bug ?
If not, what could, in our code create this behavior ?
