I’m running Arch Linux on a MacBook Pro (4,1; Early 2008). The newest 340 drivers contain a memory leak that causes X to hang requiring a restart of Xorg/greeter.
I’m running Enlightenment as a window manager, with compiz disabled and opengl used as the rendering engine. This was working previously on nvidia-334, -337, and early versions of 340 (.24 and .32 does not seem to exhibit this issue).
Here are the current package versions:
$pacman -Q | egrep "xorg-server|enlightenment|nvidia-340|vlc|linux"
archlinux-keyring 20140908-1
enlightenment 0.19.0-1
lib32-util-linux 2.25.2-1
libutil-linux 2.25.2-1
linux 3.17.1-1
linux-api-headers 3.16.2-1
linux-firmware 20141009.0e5f637-1
linux-headers 3.17.1-1
linuxtv-dvb-apps 1504-1
nvidia-340xx 340.46-4
nvidia-340xx-libgl 340.46-3
nvidia-340xx-utils 340.46-3
util-linux 2.25.2-1
vlc 2.1.5-4
xorg-server 1.16.1-1
xorg-server-common 1.16.1-1
xorg-server-xvfb 1.16.1-1
nvidia-settings reports that 98% (254MB) of the dedicated video memory is used (256MB) while running only simple 2D applications (chrome, xterm, nvidia-settings) only the built-in display (LVDS, 1440x900). Trying to play video with VLC results in the driver crashing as it cannot allocate the required VRAM.
Xorg.0.log:
[ 46478.670]
X.Org X Server 1.16.1
Release Date: 2014-09-21
[ 46478.670] X Protocol Version 11, Revision 0
[ 46478.670] Build Operating System: Linux 3.16.1-1-ARCH x86_64
[ 46478.671] Current Operating System: Linux ulm 3.17.1-1-ARCH #1 SMP PREEMPT Wed Oct 15 15:04:35 CEST 2014 x86_64
[ 46478.671] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-linux root=/dev/mapper/mbp-arch rw nomodeset nointremap pciehp.pciehp_force=1 i8042.nopnp=1
[ 46478.671] Build Date: 21 September 2014 10:53:13AM
[ 46478.671]
[ 46478.671] Current version of pixman: 0.32.6
[ 46478.672] Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
[ 46478.672] Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 46478.673] (==) Log file: "/var/log/Xorg.0.log", Time: Fri Oct 31 17:40:46 2014
[ 46478.686] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 46478.686] (==) No Layout section. Using the first Screen section.
[ 46478.686] (==) No screen section available. Using defaults.
[ 46478.686] (**) |-->Screen "Default Screen Section" (0)
[ 46478.686] (**) | |-->Monitor "<default monitor>"
[ 46478.687] (==) No monitor specified for screen "Default Screen Section".
Using a default monitor configuration.
[ 46478.687] (==) Automatically adding devices
[ 46478.687] (==) Automatically enabling devices
[ 46478.687] (==) Automatically adding GPU devices
[ 46478.687] (WW) The directory "/usr/share/fonts/OTF/" does not exist.
[ 46478.687] Entry deleted from font path.
[ 46478.687] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/100dpi/".
[ 46478.687] (Run 'mkfontdir' on "/usr/share/fonts/100dpi/").
[ 46478.687] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/75dpi/".
[ 46478.687] (Run 'mkfontdir' on "/usr/share/fonts/75dpi/").
[ 46478.687] (==) FontPath set to:
/usr/share/fonts/misc/,
/usr/share/fonts/TTF/,
/usr/share/fonts/Type1/
[ 46478.687] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 46478.687] (II) The server relies on udev to provide the list of input devices.
If no devices become available, reconfigure udev or disable AutoAddDevices.
[ 46478.687] (II) Loader magic: 0x818d80
[ 46478.687] (II) Module ABI versions:
[ 46478.687] X.Org ANSI C Emulation: 0.4
[ 46478.687] X.Org Video Driver: 18.0
[ 46478.687] X.Org XInput driver : 21.0
[ 46478.687] X.Org Server Extension : 8.0
[ 46478.688] (EE) systemd-logind: failed to get session: PID 26984 does not belong to any known session
[ 46478.689] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 46478.691] (--) PCI:*(0:1:0:0) 10de:0407:106b:00a3 rev 161, Mem @ 0xd2000000/16777216, 0xc0000000/268435456, 0xd0000000/33554432, I/O @ 0x00007000/128, BIOS @ 0x????????/131072
[ 46478.691] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[ 46478.691] (II) LoadModule: "glx"
[ 46478.692] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 46478.711] (II) Module glx: vendor="NVIDIA Corporation"
[ 46478.711] compiled for 4.0.2, module version = 1.0.0
[ 46478.711] Module class: X.Org Server Extension
[ 46478.711] (II) NVIDIA GLX Module 340.46 Wed Sep 24 13:54:14 PDT 2014
[ 46478.711] (II) Applying OutputClass "nvidia" to /dev/dri/card0
[ 46478.711] loading driver: nvidia
[ 46478.711] (==) Matched nvidia as autoconfigured driver 0
[ 46478.711] (==) Matched nouveau as autoconfigured driver 1
[ 46478.711] (==) Matched nvidia as autoconfigured driver 2
[ 46478.711] (==) Matched nv as autoconfigured driver 3
[ 46478.711] (==) Matched nouveau as autoconfigured driver 4
[ 46478.711] (==) Matched nvidia as autoconfigured driver 5
[ 46478.711] (==) Matched nv as autoconfigured driver 6
[ 46478.711] (==) Matched modesetting as autoconfigured driver 7
[ 46478.711] (==) Matched fbdev as autoconfigured driver 8
[ 46478.711] (==) Matched vesa as autoconfigured driver 9
[ 46478.711] (==) Assigned the driver to the xf86ConfigLayout
[ 46478.711] (II) LoadModule: "nvidia"
[ 46478.711] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[ 46478.712] (II) Module nvidia: vendor="NVIDIA Corporation"
[ 46478.712] compiled for 4.0.2, module version = 1.0.0
[ 46478.712] Module class: X.Org Video Driver
[ 46478.712] (II) LoadModule: "nouveau"
[ 46478.712] (WW) Warning, couldn't open module nouveau
[ 46478.712] (II) UnloadModule: "nouveau"
[ 46478.712] (II) Unloading nouveau
[ 46478.712] (EE) Failed to load module "nouveau" (module does not exist, 0)
[ 46478.712] (II) LoadModule: "nv"
[ 46478.712] (WW) Warning, couldn't open module nv
[ 46478.712] (II) UnloadModule: "nv"
[ 46478.712] (II) Unloading nv
[ 46478.713] (EE) Failed to load module "nv" (module does not exist, 0)
[ 46478.713] (II) LoadModule: "modesetting"
[ 46478.713] (WW) Warning, couldn't open module modesetting
[ 46478.713] (II) UnloadModule: "modesetting"
[ 46478.713] (II) Unloading modesetting
[ 46478.713] (EE) Failed to load module "modesetting" (module does not exist, 0)
[ 46478.713] (II) LoadModule: "fbdev"
[ 46478.713] (WW) Warning, couldn't open module fbdev
[ 46478.713] (II) UnloadModule: "fbdev"
[ 46478.713] (II) Unloading fbdev
[ 46478.713] (EE) Failed to load module "fbdev" (module does not exist, 0)
[ 46478.713] (II) LoadModule: "vesa"
[ 46478.713] (WW) Warning, couldn't open module vesa
[ 46478.713] (II) UnloadModule: "vesa"
[ 46478.713] (II) Unloading vesa
[ 46478.713] (EE) Failed to load module "vesa" (module does not exist, 0)
[ 46478.713] (II) NVIDIA dlloader X Driver 340.46 Wed Sep 24 13:34:03 PDT 2014
[ 46478.713] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 46478.713] (++) using VT number 7
[ 46478.720] (II) Loading sub module "fb"
[ 46478.720] (II) LoadModule: "fb"
[ 46478.720] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 46478.732] (II) Module fb: vendor="X.Org Foundation"
[ 46478.732] compiled for 1.16.1, module version = 1.0.0
[ 46478.732] ABI class: X.Org ANSI C Emulation, version 0.4
[ 46478.732] (WW) Unresolved symbol: fbGetGCPrivateKey
[ 46478.732] (II) Loading sub module "wfb"
[ 46478.732] (II) LoadModule: "wfb"
[ 46478.732] (II) Loading /usr/lib/xorg/modules/libwfb.so
[ 46478.732] (II) Module wfb: vendor="X.Org Foundation"
[ 46478.732] (II) Loading sub module "ramdac"
[ 46478.732] (II) LoadModule: "ramdac"
[ 46478.732] (II) Module "ramdac" already built-in
[ 46478.733] (II) NVIDIA(0): Creating default Display subsection in Screen section
"Default Screen Section" for depth/fbbpp 24/32
[ 46478.733] (==) NVIDIA(0): Depth 24, (==) framebuffer bpp 32
[ 46478.733] (==) NVIDIA(0): RGB weight 888
[ 46478.733] (==) NVIDIA(0): Default visual is TrueColor
[ 46478.733] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[ 46478.733] (**) NVIDIA(0): Enabling 2D acceleration
[ 46478.778] (II) NVIDIA(0): Display (Apple Color LCD (DFP-0)) does not support NVIDIA 3D
[ 46478.778] (II) NVIDIA(0): Vision stereo.
[ 46478.778] (II) NVIDIA(GPU-0): Found DRM driver nvidia-drm (20130102)
[ 46478.781] (II) NVIDIA(0): NVIDIA GPU GeForce 8600M GT (G84) at PCI:1:0:0 (GPU-0)
[ 46478.781] (--) NVIDIA(0): Memory: 262144 kBytes
[ 46478.781] (--) NVIDIA(0): VideoBIOS: 60.84.49.03.00
[ 46478.781] (II) NVIDIA(0): Detected PCI Express Link width: 16X
[ 46478.787] (--) NVIDIA(0): Valid display device(s) on GeForce 8600M GT at PCI:1:0:0
[ 46478.787] (--) NVIDIA(0): CRT-0
[ 46478.787] (--) NVIDIA(0): TV-0
[ 46478.787] (--) NVIDIA(0): Apple Color LCD (DFP-0) (boot, connected)
[ 46478.787] (--) NVIDIA(0): DFP-1
[ 46478.787] (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
[ 46478.787] (--) NVIDIA(GPU-0): TV-0: 400.0 MHz maximum pixel clock
[ 46478.787] (--) NVIDIA(0): Apple Color LCD (DFP-0): Internal LVDS
[ 46478.787] (--) NVIDIA(GPU-0): Apple Color LCD (DFP-0): 330.0 MHz maximum pixel clock
[ 46478.787] (--) NVIDIA(0): DFP-1: Internal TMDS
[ 46478.787] (--) NVIDIA(GPU-0): DFP-1: 330.0 MHz maximum pixel clock
[ 46478.787] (**) NVIDIA(0): Using HorizSync/VertRefresh ranges from the EDID for display
[ 46478.787] (**) NVIDIA(0): device Apple Color LCD (DFP-0) (Using EDID frequencies has
[ 46478.787] (**) NVIDIA(0): been enabled on all display devices.)
[ 46478.787] (==) NVIDIA(0):
[ 46478.787] (==) NVIDIA(0): No modes were requested; the default mode "nvidia-auto-select"
[ 46478.787] (==) NVIDIA(0): will be used as the requested mode.
[ 46478.787] (II) NVIDIA(0): Validated MetaModes:
[ 46478.787] (II) NVIDIA(0): "DFP-0:nvidia-auto-select"
[ 46478.787] (II) NVIDIA(0): Virtual screen size determined to be 1440 x 900
[ 46479.803] (--) NVIDIA(0): DPI set to (107, 103); computed from "UseEdidDpi" X config
[ 46479.803] (--) NVIDIA(0): option
[ 46479.803] (--) Depth 24 pixmap format is 32 bpp
[ 46479.803] (II) NVIDIA: Using 768.00 MB of virtual memory for indirect memory access.
[ 46479.810] (II) NVIDIA(0): ACPI: failed to connect to the ACPI event daemon; the daemon
[ 46479.810] (II) NVIDIA(0): may not be running or the "AcpidSocketPath" X
[ 46479.810] (II) NVIDIA(0): configuration option may not be set correctly. When the
[ 46479.810] (II) NVIDIA(0): ACPI event daemon is available, the NVIDIA X driver will
[ 46479.810] (II) NVIDIA(0): try to use it to receive ACPI event notifications. For
[ 46479.810] (II) NVIDIA(0): details, please see the "ConnectToAcpid" and
[ 46479.810] (II) NVIDIA(0): "AcpidSocketPath" X configuration options in Appendix B: X
[ 46479.810] (II) NVIDIA(0): Config Options in the README.
[ 46479.815] (II) NVIDIA(0): Setting mode "DFP-0:nvidia-auto-select"
[ 46480.199] (==) NVIDIA(0): Disabling shared memory pixmaps
[ 46480.199] (==) NVIDIA(0): Backing store enabled
[ 46480.199] (==) NVIDIA(0): Silken mouse enabled
[ 46480.200] (==) NVIDIA(0): DPMS enabled
[ 46480.200] (II) Loading sub module "dri2"
[ 46480.200] (II) LoadModule: "dri2"
[ 46480.200] (II) Module "dri2" already built-in
[ 46480.200] (II) NVIDIA(0): [DRI2] Setup complete
[ 46480.200] (II) NVIDIA(0): [DRI2] VDPAU driver: nvidia
[ 46480.200] (--) RandR disabled
[ 46480.206] (II) Initializing extension GLX
[ 46480.306] (II) config/udev: Adding input device Power Button (/dev/input/event6)
[ 46480.306] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 46480.306] (II) LoadModule: "evdev"
[ 46480.306] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[ 46480.307] (II) Module evdev: vendor="X.Org Foundation"
[ 46480.307] compiled for 1.16.0, module version = 2.9.0
[ 46480.307] Module class: X.Org XInput Driver
[ 46480.307] ABI class: X.Org XInput driver, version 21.0
[ 46480.307] (II) Using input driver 'evdev' for 'Power Button'
[ 46480.307] (**) Power Button: always reports core events
[ 46480.307] (**) evdev: Power Button: Device: "/dev/input/event6"
[ 46480.307] (--) evdev: Power Button: Vendor 0 Product 0x1
[ 46480.307] (--) evdev: Power Button: Found keys
[ 46480.307] (II) evdev: Power Button: Configuring as keyboard
[ 46480.307] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input6/event6"
[ 46480.307] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[ 46480.307] (**) Option "xkb_rules" "evdev"
[ 46480.307] (**) Option "xkb_model" "pc104"
[ 46480.307] (**) Option "xkb_layout" "us"
[ 46480.332] (II) config/udev: Adding input device Video Bus (/dev/input/event7)
[ 46480.333] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[ 46480.333] (II) Using input driver 'evdev' for 'Video Bus'
[ 46480.333] (**) Video Bus: always reports core events
[ 46480.333] (**) evdev: Video Bus: Device: "/dev/input/event7"
[ 46480.333] (--) evdev: Video Bus: Vendor 0 Product 0x6
[ 46480.333] (--) evdev: Video Bus: Found keys
[ 46480.333] (II) evdev: Video Bus: Configuring as keyboard
[ 46480.333] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:01/LNXVIDEO:00/input/input7/event7"
[ 46480.333] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 7)
[ 46480.333] (**) Option "xkb_rules" "evdev"
[ 46480.333] (**) Option "xkb_model" "pc104"
[ 46480.333] (**) Option "xkb_layout" "us"
[ 46480.333] (II) config/udev: Adding input device Power Button (/dev/input/event4)
[ 46480.333] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 46480.333] (II) Using input driver 'evdev' for 'Power Button'
[ 46480.333] (**) Power Button: always reports core events
[ 46480.333] (**) evdev: Power Button: Device: "/dev/input/event4"
[ 46480.333] (--) evdev: Power Button: Vendor 0 Product 0x1
[ 46480.333] (--) evdev: Power Button: Found keys
[ 46480.333] (II) evdev: Power Button: Configuring as keyboard
[ 46480.333] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input4/event4"
[ 46480.333] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 8)
[ 46480.334] (II) config/udev: Adding input device Lid Switch (/dev/input/event3)
[ 46480.334] (II) No input driver specified, ignoring this device.
[ 46480.334] (II) This device may have been added with another device file.
[ 46480.334] (II) config/udev: Adding input device Sleep Button (/dev/input/event5)
[ 46480.334] (**) Sleep Button: Applying InputClass "evdev keyboard catchall"
[ 46480.334] (II) Using input driver 'evdev' for 'Sleep Button'
[ 46480.334] (**) Sleep Button: always reports core events
[ 46480.334] (**) evdev: Sleep Button: Device: "/dev/input/event5"
[ 46480.334] (--) evdev: Sleep Button: Vendor 0 Product 0x3
[ 46480.334] (--) evdev: Sleep Button: Found keys
[ 46480.334] (II) evdev: Sleep Button: Configuring as keyboard
[ 46480.334] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input5/event5"
[ 46480.334] (II) XINPUT: Adding extended input device "Sleep Button" (type: KEYBOARD, id 9)
[ 46480.334] (**) Option "xkb_rules" "evdev"
[ 46480.334] (**) Option "xkb_model" "pc104"
[ 46480.334] (**) Option "xkb_layout" "us"
[ 46480.335] (II) config/udev: Adding input device HDA Digital PCBeep (/dev/input/event9)
[ 46480.335] (II) No input driver specified, ignoring this device.
[ 46480.335] (II) This device may have been added with another device file.
[ 46480.335] (II) config/udev: Adding input device HDA Intel Line (/dev/input/event10)
[ 46480.335] (II) config/udev: Adding input device HDA Intel Headphone (/dev/input/event11)
[ 46480.336] (II) config/udev: Adding input device Apple Computer, Inc. IR Receiver (/dev/input/event1)
[ 46480.336] (**) Apple Computer, Inc. IR Receiver: Applying InputClass "evdev keyboard catchall"
[ 46480.336] (II) Using input driver 'evdev' for 'Apple Computer, Inc. IR Receiver'
[ 46480.336] (**) Apple Computer, Inc. IR Receiver: always reports core events
[ 46480.336] (**) evdev: Apple Computer, Inc. IR Receiver: Device: "/dev/input/event1"
[ 46480.336] (--) evdev: Apple Computer, Inc. IR Receiver: Vendor 0x5ac Product 0x8242
[ 46480.336] (--) evdev: Apple Computer, Inc. IR Receiver: Found keys
[ 46480.336] (II) evdev: Apple Computer, Inc. IR Receiver: Configuring as keyboard
[ 46480.336] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1d.2/usb5/5-1/5-1:1.0/0003:05AC:8242.0001/input/input1/event1"
[ 46480.336] (II) XINPUT: Adding extended input device "Apple Computer, Inc. IR Receiver" (type: KEYBOARD, id 10)
[ 46480.336] (**) Option "xkb_rules" "evdev"
[ 46480.336] (**) Option "xkb_model" "pc104"
[ 46480.336] (**) Option "xkb_layout" "us"
[ 46480.336] (II) config/udev: Adding input device Apple, Inc. Apple Internal Keyboard / Trackpad (/dev/input/event2)
[ 46480.336] (**) Apple, Inc. Apple Internal Keyboard / Trackpad: Applying InputClass "evdev keyboard catchall"
[ 46480.336] (II) Using input driver 'evdev' for 'Apple, Inc. Apple Internal Keyboard / Trackpad'
[ 46480.336] (**) Apple, Inc. Apple Internal Keyboard / Trackpad: always reports core events
[ 46480.336] (**) evdev: Apple, Inc. Apple Internal Keyboard / Trackpad: Device: "/dev/input/event2"
[ 46480.337] (--) evdev: Apple, Inc. Apple Internal Keyboard / Trackpad: Vendor 0x5ac Product 0x230
[ 46480.337] (--) evdev: Apple, Inc. Apple Internal Keyboard / Trackpad: Found keys
[ 46480.337] (II) evdev: Apple, Inc. Apple Internal Keyboard / Trackpad: Configuring as keyboard
[ 46480.337] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1d.2/usb5/5-2/5-2:1.0/0003:05AC:0230.0002/input/input2/event2"
[ 46480.337] (II) XINPUT: Adding extended input device "Apple, Inc. Apple Internal Keyboard / Trackpad" (type: KEYBOARD, id 11)
[ 46480.337] (**) Option "xkb_rules" "evdev"
[ 46480.337] (**) Option "xkb_model" "pc104"
[ 46480.337] (**) Option "xkb_layout" "us"
[ 46480.337] (II) config/udev: Adding input device bcm5974 (/dev/input/event12)
[ 46480.337] (**) bcm5974: Applying InputClass "evdev touchpad catchall"
[ 46480.337] (**) bcm5974: Applying InputClass "touchpad catchall"
[ 46480.337] (**) bcm5974: Applying InputClass "Default clickpad buttons"
[ 46480.337] (**) bcm5974: Applying InputClass "Disable clickpad buttons on Apple touchpads"
[ 46480.337] (II) LoadModule: "synaptics"
[ 46480.337] (II) Loading /usr/lib/xorg/modules/input/synaptics_drv.so
[ 46480.337] (II) Module synaptics: vendor="X.Org Foundation"
[ 46480.337] compiled for 1.16.0, module version = 1.8.1
[ 46480.338] Module class: X.Org XInput Driver
[ 46480.338] ABI class: X.Org XInput driver, version 21.0
[ 46480.338] (II) Using input driver 'synaptics' for 'bcm5974'
[ 46480.338] (**) bcm5974: always reports core events
[ 46480.338] (**) Option "Device" "/dev/input/event12"
[ 46480.428] (--) synaptics: bcm5974: x-axis range -4824 - 4824 (res 0)
[ 46480.428] (--) synaptics: bcm5974: y-axis range -172 - 4290 (res 0)
[ 46480.428] (--) synaptics: bcm5974: pressure range 0 - 256
[ 46480.428] (--) synaptics: bcm5974: finger width range 0 - 16
[ 46480.428] (--) synaptics: bcm5974: buttons: left double triple
[ 46480.428] (--) synaptics: bcm5974: Vendor 0x5ac Product 0x230
[ 46480.428] (**) Option "TapButton1" "1"
[ 46480.428] (**) Option "TapButton2" "2"
[ 46480.428] (**) Option "TapButton3" "3"
[ 46480.428] (--) synaptics: bcm5974: touchpad found
[ 46480.428] (**) bcm5974: always reports core events
[ 46480.475] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1d.2/usb5/5-2/5-2:1.2/input/input21/event12"
[ 46480.475] (II) XINPUT: Adding extended input device "bcm5974" (type: TOUCHPAD, id 12)
[ 46480.475] (**) synaptics: bcm5974: (accel) MinSpeed is now constant deceleration 2.5
[ 46480.475] (**) synaptics: bcm5974: (accel) MaxSpeed is now 1.75
[ 46480.475] (**) synaptics: bcm5974: (accel) AccelFactor is now 0.019
[ 46480.475] (**) bcm5974: (accel) keeping acceleration scheme 1
[ 46480.475] (**) bcm5974: (accel) acceleration profile 1
[ 46480.475] (**) bcm5974: (accel) acceleration factor: 2.000
[ 46480.475] (**) bcm5974: (accel) acceleration threshold: 4
[ 46480.478] (--) synaptics: bcm5974: touchpad found
[ 46480.478] (II) config/udev: Adding input device bcm5974 (/dev/input/mouse0)
[ 46480.478] (**) bcm5974: Ignoring device from InputClass "touchpad ignore duplicates"
[ 46480.479] (II) config/udev: Adding input device Built-in iSight (/dev/input/event13)
[ 46480.479] (**) Built-in iSight: Applying InputClass "evdev keyboard catchall"
[ 46480.479] (II) Using input driver 'evdev' for 'Built-in iSight'
[ 46480.479] (**) Built-in iSight: always reports core events
[ 46480.479] (**) evdev: Built-in iSight: Device: "/dev/input/event13"
[ 46480.479] (--) evdev: Built-in iSight: Vendor 0x5ac Product 0x8502
[ 46480.479] (--) evdev: Built-in iSight: Found keys
[ 46480.479] (II) evdev: Built-in iSight: Configuring as keyboard
[ 46480.479] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1d.7/usb7/7-4/7-4:1.0/input/input13/event13"
[ 46480.479] (II) XINPUT: Adding extended input device "Built-in iSight" (type: KEYBOARD, id 13)
[ 46480.479] (**) Option "xkb_rules" "evdev"
[ 46480.479] (**) Option "xkb_model" "pc104"
[ 46480.479] (**) Option "xkb_layout" "us"
[ 46480.479] (II) config/udev: Adding input device applesmc (/dev/input/event0)
[ 46480.479] (II) No input driver specified, ignoring this device.
[ 46480.479] (II) This device may have been added with another device file.
[ 46480.480] (II) config/udev: Adding input device applesmc (/dev/input/js0)
[ 46480.480] (II) No input driver specified, ignoring this device.
[ 46480.480] (II) This device may have been added with another device file.
[ 46480.480] (II) config/udev: Adding input device PC Speaker (/dev/input/event8)
[ 46484.680] (II) NVIDIA(GPU-0): Display (Apple Color LCD (DFP-0)) does not support NVIDIA 3D
[ 46484.680] (II) NVIDIA(GPU-0): Vision stereo.
[ 46484.709] (II) NVIDIA(0): Setting mode "LVDS-0: nvidia-auto-select @1440x900 +0+0 {ViewPortIn=1440x900, ViewPortOut=1440x900+0+0}"
[ 46736.852] (II) NVIDIA(0): Setting mode "LVDS-0: nvidia-auto-select @1440x900 +0+0 {ViewPortIn=1440x900, ViewPortOut=1440x900+0+0}"
[ 46738.211] (II) NVIDIA(0): ACPI: failed to connect to the ACPI event daemon; the daemon
[ 46738.211] (II) NVIDIA(0): may not be running or the "AcpidSocketPath" X
[ 46738.211] (II) NVIDIA(0): configuration option may not be set correctly. When the
[ 46738.211] (II) NVIDIA(0): ACPI event daemon is available, the NVIDIA X driver will
[ 46738.211] (II) NVIDIA(0): try to use it to receive ACPI event notifications. For
[ 46738.211] (II) NVIDIA(0): details, please see the "ConnectToAcpid" and
[ 46738.211] (II) NVIDIA(0): "AcpidSocketPath" X configuration options in Appendix B: X
[ 46738.211] (II) NVIDIA(0): Config Options in the README.
[ 46738.231] (II) NVIDIA(GPU-0): Display (Apple Color LCD (DFP-0)) does not support NVIDIA 3D
[ 46738.231] (II) NVIDIA(GPU-0): Vision stereo.
[ 46738.250] (--) synaptics: bcm5974: touchpad found
[ 49740.109] (II) NVIDIA(0): Setting mode "LVDS-0: nvidia-auto-select @1440x900 +0+0 {ViewPortIn=1440x900, ViewPortOut=1440x900+0+0}"
[ 49741.438] (EE) NVIDIA(0): Failed to allocate primary buffer: out of memory.
[ 49741.438] (EE) NVIDIA(0): *** Aborting ***
[ 49741.439] (II) NVIDIA(0): ACPI: failed to connect to the ACPI event daemon; the daemon
[ 49741.439] (II) NVIDIA(0): may not be running or the "AcpidSocketPath" X
[ 49741.439] (II) NVIDIA(0): configuration option may not be set correctly. When the
[ 49741.439] (II) NVIDIA(0): ACPI event daemon is available, the NVIDIA X driver will
[ 49741.439] (II) NVIDIA(0): try to use it to receive ACPI event notifications. For
[ 49741.439] (II) NVIDIA(0): details, please see the "ConnectToAcpid" and
[ 49741.439] (II) NVIDIA(0): "AcpidSocketPath" X configuration options in Appendix B: X
[ 49741.439] (II) NVIDIA(0): Config Options in the README.
[ 49741.459] (II) NVIDIA(GPU-0): Display (Apple Color LCD (DFP-0)) does not support NVIDIA 3D
[ 49741.459] (II) NVIDIA(GPU-0): Vision stereo.
[ 49741.460] (EE)
[ 49741.460] (EE) Backtrace:
[ 49741.460] (EE) 0: /usr/bin/Xorg.bin (xorg_backtrace+0x56) [0x593a46]
[ 49741.460] (EE) 1: /usr/bin/Xorg.bin (0x400000+0x197b99) [0x597b99]
[ 49741.460] (EE) 2: /usr/lib/libc.so.6 (0x7fc9c0303000+0x339f0) [0x7fc9c03369f0]
[ 49741.460] (EE) 3: /usr/lib/xorg/modules/drivers/nvidia_drv.so (0x7fc9b9ce0000+0x84cbd) [0x7fc9b9d64cbd]
[ 49741.460] (EE) 4: /usr/lib/xorg/modules/drivers/nvidia_drv.so (0x7fc9b9ce0000+0x5937d9) [0x7fc9ba2737d9]
[ 49741.460] (EE) 5: /usr/lib/xorg/modules/drivers/nvidia_drv.so (0x7fc9b9ce0000+0x597f24) [0x7fc9ba277f24]
[ 49741.460] (EE) 6: /usr/lib/xorg/modules/drivers/nvidia_drv.so (0x7fc9b9ce0000+0x5a7b42) [0x7fc9ba287b42]
[ 49741.460] (EE) 7: /usr/lib/xorg/modules/drivers/nvidia_drv.so (0x7fc9b9ce0000+0x59f3e1) [0x7fc9ba27f3e1]
[ 49741.460] (EE) 8: /usr/bin/Xorg.bin (xf86VTEnter+0x12b) [0x4765eb]
[ 49741.460] (EE) 9: /usr/bin/Xorg.bin (WakeupHandler+0x6b) [0x43c3ab]
[ 49741.460] (EE) 10: /usr/bin/Xorg.bin (WaitForSomething+0x1c7) [0x590e77]
[ 49741.461] (EE) 11: /usr/bin/Xorg.bin (0x400000+0x374f1) [0x4374f1]
[ 49741.461] (EE) 12: /usr/bin/Xorg.bin (0x400000+0x3b866) [0x43b866]
[ 49741.461] (EE) 13: /usr/lib/libc.so.6 (__libc_start_main+0xf0) [0x7fc9c0323040]
[ 49741.461] (EE) 14: /usr/bin/Xorg.bin (0x400000+0x25d0e) [0x425d0e]
[ 49741.461] (EE)
[ 49741.461] (EE) Segmentation fault at address 0x30
[ 49741.461] (EE)
Fatal server error:
[ 49741.461] (EE) Caught signal 11 (Segmentation fault). Server aborting
[ 49741.461] (EE)
[ 49741.461] (EE)
Please consult the The X.Org Foundation support
at http://wiki.x.org
for help.
[ 49741.461] (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
[ 49741.461] (EE)
[ 49743.147] (EE) Server terminated with error (1). Closing log file.
It would be great if NVidia could look into a possible regression in the 340 branch as this bug affects usability quite severely.
