YOLO-POSE Demo Accelerated with Deepstream and TensorRT(Pose Estimation with DeepStream Python Binding)
Hello everyone
I deployed customized pose estimation models (YOLO-Pose with Yolov8-Pose cose) on Jetson and accelerated it with Deepstream + TensorRT , feel free to refer to it and feedback better acceleration suggestions!
Environment
TensorRT Version : 8.5.2
GPU Type : J etson AGX Xavier / AGX Orin
Nvidia Driver Version :
CUDA Version : 11.4.315
CUDNN Version : 8.6.0.166
Operating System + Version : 35.2.1 ( Jetpack: 5.1)
Python Version (if applicable) : Python 3.8.10
TensorFlow Version (if applicable) :
PyTorch Version (if applicable) : 1.12.0a0+2c916ef.nv22.3
Baremetal or Container (if container which image + tag) :
Relevant Files
https://github.com/YunghuiHsu/deepstream-yolo-pose
Steps To Reproduce
Environment Setting plz refer https://github.com/YunghuiHsu/deepstream-yolo-pose
Download Ripository
git clone https://github.com/YunghuiHsu/deepstream-yolo-pose.git
To run the app with default settings:
  • NVInfer with rtsp inputs
    python3 deepstream_YOLOv8-Pose_rtsp.py \
       -i  rtsp://sample_1.mp4 \
           rtsp://sample_2.mp4 \
           rtsp://sample_N.mp4  \
  • eg: loop with local file inputs
        -i file:///home/ubuntu/video1.mp4 file:///home/ubuntu/video2.mp4 \
        --file-loop
  • Default RTSP streaming location:
Note:
  1. if -g/--pgie : uses nvinfer as default. ([‘nvinfer’, ‘nvinferserver’]).
  2. -config/--config-file : need to be provided for custom models.
  3. --file-loop : option can be used to loop input files after EOS.
  4. --conf-thres : Objec Confidence Threshold
  5. --iou-thres : IOU Threshold for NMS
This sample app is derived from NVIDIA-AI-IOT/deepstream_python_apps/apps and adds customization features
  • Includes following :
    • Accepts multiple sources
    • Dynamic batch model(YOLO-POSE)
    • Accepts RTSP stream as input and gives out inference as RTSP stream
    • NVInfer GPU inference engine
    • NVInferserver GPU inference engine(Not yet tested)
    • MultiObjectTracker(NVTracker)
    • Automatically adjusts the tensor shape of the loaded input and output (NvDsInferTensorMeta)
    • Extract the stream metadata, image data from the batched buffer of Gst-nvinfer
      source : deepstream-imagedata-multistream
Thanks for your sharing to the community!
On the Orin AGX 64 Gbyte with JetPack 6.0 DP and Deepstream 6.4, the engine conversion fails with
sudo /usr/src/tensorrt/bin/trtexec --verbose     --onnx=yolov8s-pose.onnx     --fp16     --workspace=4096     --minShapes=images:1x3x640x640     --optShapes=images:12x3x640x640     --maxShapes=images:16x3x640x640     --saveEngine=yolov8s-pose-dy-sim-640.engine
Could not find any implementation for node /model.22/Range_2.
[E] Error[10]: [optimizer.cpp::computeCosts::3869] Error Code 10: Internal Error (Could not find any implementation for node /model.22/Range_2.)
Any ideas what might be going on there?
