Yolov2 weights not working on deepstream plugin on jetson tx2
We are creating sample for object detection from deepstream-yolo on jetson tx2, when i try to make build it works fine. We are using Jetson tX2 with JetPack 3.3 and deepstream plugin has only detect tiny-yolo. Can you please give me more suggestion or where we change for yolov2 weights/ yolov3.weights but its not works. Here are the commands i have try;
For tegra,
$cd sources/plugins/gst-yoloplugin-tegra
make && sudo make install
$ nvgstiva-app -c config/nvgstiva-app_yolo_config.txt
Please remember to update the source with the model you used:
[url]https://github.com/vat-nvidia/deepstream-plugins#building-nvyolo-plugin[/url]
