Yolov3 not working
To run with multigpu, please change --gpus based on the number of available GPUs in your machine.
Using TensorFlow backend.
WARNING:tensorflow:Deprecation warnings have been disabled. Set TF_ENABLE_DEPRECATION_WARNINGS=1 to re-enable them.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/horovod/tensorflow/init.py:117: The name tf.global_variables is deprecated. Please use tf.compat.v1.global_variables instead.
2021-06-11 08:13:55,018 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/horovod/tensorflow/init.py:117: The name tf.global_variables is deprecated. Please use tf.compat.v1.global_variables instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/horovod/tensorflow/init.py:143: The name tf.get_default_graph is deprecated. Please use tf.compat.v1.get_default_graph instead.
2021-06-11 08:13:55,018 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/horovod/tensorflow/init.py:143: The name tf.get_default_graph is deprecated. Please use tf.compat.v1.get_default_graph instead.
WARNING:tensorflow:From /home/vpraveen/.cache/dazel/_dazel_vpraveen/216c8b41e526c3295d3b802489ac2034/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/yolo_v3/scripts/train.py:49: The name tf.ConfigProto is deprecated. Please use tf.compat.v1.ConfigProto instead.
2021-06-11 08:13:55,462 [WARNING] tensorflow: From /home/vpraveen/.cache/dazel/_dazel_vpraveen/216c8b41e526c3295d3b802489ac2034/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/yolo_v3/scripts/train.py:49: The name tf.ConfigProto is deprecated. Please use tf.compat.v1.ConfigProto instead.
WARNING:tensorflow:From /home/vpraveen/.cache/dazel/_dazel_vpraveen/216c8b41e526c3295d3b802489ac2034/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/yolo_v3/scripts/train.py:52: The name tf.Session is deprecated. Please use tf.compat.v1.Session instead.
2021-06-11 08:13:55,462 [WARNING] tensorflow: From /home/vpraveen/.cache/dazel/_dazel_vpraveen/216c8b41e526c3295d3b802489ac2034/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/yolo_v3/scripts/train.py:52: The name tf.Session is deprecated. Please use tf.compat.v1.Session instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:517: The name tf.placeholder is deprecated. Please use tf.compat.v1.placeholder instead.
2021-06-11 08:14:02,010 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:517: The name tf.placeholder is deprecated. Please use tf.compat.v1.placeholder instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:4138: The name tf.random_uniform is deprecated. Please use tf.random.uniform instead.
2021-06-11 08:14:02,034 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:4138: The name tf.random_uniform is deprecated. Please use tf.random.uniform instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:1834: The name tf.nn.fused_batch_norm is deprecated. Please use tf.compat.v1.nn.fused_batch_norm instead.
2021-06-11 08:14:02,086 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:1834: The name tf.nn.fused_batch_norm is deprecated. Please use tf.compat.v1.nn.fused_batch_norm instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:2018: The name tf.image.resize_nearest_neighbor is deprecated. Please use tf.compat.v1.image.resize_nearest_neighbor instead.
2021-06-11 08:14:03,253 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:2018: The name tf.image.resize_nearest_neighbor is deprecated. Please use tf.compat.v1.image.resize_nearest_neighbor instead.
File “/home/vpraveen/.cache/dazel/_dazel_vpraveen/216c8b41e526c3295d3b802489ac2034/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/yolo_v3/scripts/train.py”, line 213, in
File “/home/vpraveen/.cache/dazel/_dazel_vpraveen/216c8b41e526c3295d3b802489ac2034/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/yolo_v3/scripts/train.py”, line 209, in main
File “/home/vpraveen/.cache/dazel/_dazel_vpraveen/216c8b41e526c3295d3b802489ac2034/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/yolo_v3/scripts/train.py”, line 84, in run_experiment
File “/home/vpraveen/.cache/dazel/_dazel_vpraveen/216c8b41e526c3295d3b802489ac2034/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/yolo_v3/builders/model_builder.py”, line 181, in build_data_and_model
File “/home/vpraveen/.cache/dazel/_dazel_vpraveen/216c8b41e526c3295d3b802489ac2034/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/yolo_v3/utils/model_io.py”, line 48, in load_model
File “/usr/local/lib/python3.6/dist-packages/keras/engine/saving.py”, line 417, in load_model
f = h5dict(filepath, ‘r’)
File “/usr/local/lib/python3.6/dist-packages/keras/utils/io_utils.py”, line 186, in init
self.data = h5py.File(path, mode=mode)
File “/usr/local/lib/python3.6/dist-packages/h5py/_hl/files.py”, line 312, in init
fid = make_fid(name, mode, userblock_size, fapl, swmr=swmr)
File “/usr/local/lib/python3.6/dist-packages/h5py/_hl/files.py”, line 142, in make_fid
fid = h5f.open(name, flags, fapl=fapl)
File “h5py/_objects.pyx”, line 54, in h5py._objects.with_phil.wrapper
File “h5py/_objects.pyx”, line 55, in h5py._objects.with_phil.wrapper
File “h5py/h5f.pyx”, line 78, in h5py.h5f.open
OSError: Unable to open file (unable to open file: name = ‘EXPERIMENT_DIR/pretrained_resnet18/tlt_pretrained_object_detection_vresnet18/resnet_18.hdf5’, errno = 2, error message = ‘No such file or directory’, flags = 0, o_flags = 0)
File “/usr/local/bin/yolo_v3”, line 8, in
sys.exit(main())
File “/home/vpraveen/.cache/dazel/_dazel_vpraveen/216c8b41e526c3295d3b802489ac2034/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/yolo_v3/entrypoint/yolo_v3.py”, line 12, in main
File “/home/vpraveen/.cache/dazel/_dazel_vpraveen/216c8b41e526c3295d3b802489ac2034/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/common/entrypoint/entrypoint.py”, line 296, in launch_job
AssertionError: Process run failed.
print("To resume from checkpoint, please change pretrain_model_path
Hi @bhargavi.sanadhya,
We recommend you to provide more details of the issue and issue repro scripts/model for better assistance.
Also please share following env details.
TensorRT Version :
GPU Type :
Nvidia Driver Version :
CUDA Version :
CUDNN Version :
Operating System + Version :
Python Version (if applicable) :
TensorFlow Version (if applicable) :
PyTorch Version (if applicable) :
Baremetal or Container (if container which image + tag) :
Thank you.
Could not find tensorRT version so I tried this
root@ef112f939b52:/workspace# dpkg -l | grep nvinfer
ii libnvinfer-dev 7.2.1-1+cuda11.1 amd64 TensorRT development libraries and headers
ii libnvinfer-plugin-dev 7.2.1-1+cuda11.1 amd64 TensorRT plugin libraries
ii libnvinfer-plugin7 7.2.1-1+cuda11.1 amd64 TensorRT plugin libraries
ii libnvinfer7 7.2.1-1+cuda11.1 amd64 TensorRT runtime libraries
root@ef112f939b52:/workspace# nm -D libnvinfer7 | grep tensorrt_version
nm: ‘libnvinfer7’: No such file
root@ef112f939b52:/workspace# ^C
root@ef112f939b52:/workspace# dpkg -l | grep TensorRT
ii libnvonnxparsers-dev 7.2.1-1+cuda11.1 amd64 TensorRT ONNX libraries
ii libnvonnxparsers7 7.2.1-1+cuda11.1 amd64 TensorRT ONNX libraries
ii libnvparsers-dev 7.2.1-1+cuda11.1 amd64 TensorRT parsers libraries
ii libnvparsers7 7.2.1-1+cuda11.1 amd64 TensorRT parsers libraries
For GPU Drivers
root@ef112f939b52:/workspace# nvidia-smi --query-gpu=driver_version --format=csv,noheader
460.39
460.39
460.39
460.39
For CUDA version
root@ef112f939b52:/workspace# nvcc --version
Copyright (c) 2005-2020 NVIDIA Corporation
Built on Mon_Oct_12_20:09:46_PDT_2020
Cuda compilation tools, release 11.1, V11.1.105
Build cuda_11.1.TC455_06.29190527_0
Operating system version
root@ef112f939b52:/workspace# cat /etc/*release
DISTRIB_ID=Ubuntu
DISTRIB_RELEASE=18.04
DISTRIB_CODENAME=bionic
DISTRIB_DESCRIPTION=“Ubuntu 18.04.5 LTS”
NAME=“Ubuntu”
VERSION=“18.04.5 LTS (Bionic Beaver)”
ID=ubuntu
ID_LIKE=debian
PRETTY_NAME=“Ubuntu 18.04.5 LTS”
VERSION_ID=“18.04”
HOME_URL=“https://www.ubuntu.com/
SUPPORT_URL=“https://help.ubuntu.com/
BUG_REPORT_URL=“https://bugs.launchpad.net/ubuntu/
PRIVACY_POLICY_URL=“Data privacy | Ubuntu
VERSION_CODENAME=bionic
UBUNTU_CODENAME=bionic
tensorflow and python3
root@ef112f939b52:/workspace# python3 -c ‘import tensorflow as tf; print(tf.version)’
2021-06-11 11:25:09.070606: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libcudart.so.11.0
1.15.4
CUDNN version
root@ef112f939b52:/workspace# cat /usr/include/cudnn.h | grep CUDNN_MAJOR -A 2
root@ef112f939b52:/workspace# dpkg -l | grep cudnn
hi libcudnn8 8.0.4.30-1+cuda11.1 amd64 cuDNN runtime libraries
ii libcudnn8-dev 8.0.4.30-1+cuda11.1 amd64 cuDNN development libraries and headers
TLT image - docker pull nvcr.io/nvidia/tlt-streamanalytics:v3.0-py3
I am still not sure about TensorRT and CUDNN versions. Is there any command?
Moreover I found the above versions by running the commands inside the Docker container
Based on the information you’ve provided it looks like you are using TLT container. We recommend you to post your query on TLT forum to get better help.
Thank you.
