Hello! I’m using Yolov3 from Darknet (Installing Darknet) with OpenCV v.4.1.0 (https://create.botmation.net/p/this-is-quick-guide-to-get-you-started.html), but when I run the command on Terminal it don’t recognize OpenCV:
$ ./darknet detector demo cfg/coco.data cfg/yolov3.cfg yolov3.weights video.mp4
Demo needs OpenCV for webcam images.
And a have a RPi Camera connected to Jetson Nano, and still can’t detect it :(
I’ve already tried this options:
1. Change Makefile:
GPU=1
CUDNN=1
OPENCV=1
OPENMP=0
DEBUG=0
ARCH= -gencode arch=compute_53,code=[sm_53,compute_53]
Then I run make on darknet folder and have this:
$ make
g++ -Iinclude/ -Isrc/ -DOPENCV `pkg-config --cflags opencv` -DGPU -I/usr/local/cuda/include/ -DCUDNN -Wall -Wno-unused-result -Wno-unknown-pragmas -Wfatal-errors -fPIC -Ofast -DOPENCV -DGPU -DCUDNN -c ./src/image_opencv.cpp -o obj/image_opencv.o
Package opencv was not found in the pkg-config search path.
Perhaps you should add the directory containing `opencv.pc'
to the PKG_CONFIG_PATH environment variable
No package 'opencv' found
./src/image_opencv.cpp:5:10: fatal error: opencv2/opencv.hpp: No such file or directory
#include "opencv2/opencv.hpp"
compilation terminated.
Makefile:86: recipe for target 'obj/image_opencv.o' failed
make: *** [obj/image_opencv.o] Error 1
- So, I checked the cmake command on OpenCV installer (opencv-4.1.0 folder) and add -D OPENCV_GENERATE_PKGCONFIG=ON and install again.
$ cmake -D WITH_CUDA=ON -D CUDA_ARCH_BIN="5.3" -D CUDA_ARCH_PTX="" -D OPENCV_EXTRA_MODULES_PATH=../../opencv_contrib-4.1.0/modules -D WITH_GSTREAMER=ON -D WITH_LIBV4L=ON -D BUILD_opencv_python2=OFF -D BUILD_opencv_python3=ON -D BUILD_TESTS=OFF -D BUILD_PERF_TESTS=OFF -D BUILD_EXAMPLES=OFF -D CMAKE_BUILD_TYPE=RELEASE -D OPENCV_GENERATE_PKGCONFIG=ON -D OPENCV_PC_FILE_NAME=opencv.pc CMAKE_INSTALL_PREFIX=/usr/local ..
But when I come back to darknet folder on terminal, I run make and have the same result.
3. Finally, I tried making a opencv.pc file in /usr/local/lib/ with this:
prefix=/usr/local
exec_prefix=${prefix}
libdir=${exec_prefix}/lib
includedir_old=${prefix}/include/opencv4/opencv
includedir_new=${prefix}/include/opencv4
Description: Open Source Computer Vision Library
Version: 4.1.0
Libs: -L${exec_prefix}/lib -lopencv_gapi -lopencv_stitching -lopencv_aruco -lopencv_bgsegm -lopencv_bioinspired -lopencv_ccalib -lopencv_dnn_objdetect -lopencv_dpm -lopencv_face -lopencv_freetype -lopencv_fuzzy -lopencv_hfs -lopencv_img_hash -lopencv_line_descriptor -lopencv_quality -lopencv_reg -lopencv_rgbd -lopencv_saliency -lopencv_stereo -lopencv_structured_light -lopencv_phase_unwrapping -lopencv_superres -lopencv_optflow -lopencv_surface_matching -lopencv_tracking -lopencv_datasets -lopencv_text -lopencv_dnn -lopencv_plot -lopencv_videostab -lopencv_video -lopencv_xfeatures2d -lopencv_shape -lopencv_ml -lopencv_ximgproc -lopencv_xobjdetect -lopencv_objdetect -lopencv_calib3d -lopencv_features2d -lopencv_highgui -lopencv_videoio -lopencv_imgcodecs -lopencv_flann -lopencv_xphoto -lopencv_photo -lopencv_imgproc -lopencv_core
Libs.private: -ldl -lm -lpthread -lrt
Cflags: -I${includedir_old} -I${includedir_new}
And guess What? Still nothing haha
Well, that’s all.
Please give me a hint :c
PD: The reason that I choose OpenCV 4.1.0 is because that I can’t use RPi Camera without GStreamer on Jetson Nano.
PD2: It’s the same with Yolov3-Tiny.
