hi:
I would like to ask two questions. One is that the Primary_Detector_Nano model in deepstream is poorly identified at night. Is this just a model use case? Do not provide accurate vehicle tracking, we need to develop it ourselves? There is another problem, we use the yolov3_tiny model to track and detect the vehicle, the source stream is 1080p, I am modifying the streammux wight=1280 height=720 in the configuration file deepstream_app_config_yolov3_tiny.txt, when using deepstream-app, Error:
root@uu-desktop:/opt/nvidia/deepstream/deepstream-4.0/sources/objectDetector_Yolo# deepstream-app -c deepstream_app_config_yoloV3_tiny.txt
** WARN: <parse_gie:940>: Unknown key 'raw_output_directory' for group [primary-gie]
Using winsys: x11
Opening in BLOCKING MODE
Creating LL OSD context new
0:00:00.671765941 9241 0x10ac3520 INFO nvinfer gstnvinfer.cpp:519:gst_nvinfer_logger:<primary_gie_classifier> NvDsInferContext[UID 1]:initialize(): Trying to create engine from model files
Loading pre-trained weights...
Loading complete!
Total Number of weights read : 8858734
layer inp_size out_size weightPtr
(1) conv-bn-leaky 3 x 416 x 416 16 x 416 x 416 496
(2) maxpool 16 x 416 x 416 16 x 208 x 208 496
(3) conv-bn-leaky 16 x 208 x 208 32 x 208 x 208 5232
(4) maxpool 32 x 208 x 208 32 x 104 x 104 5232
(5) conv-bn-leaky 32 x 104 x 104 64 x 104 x 104 23920
(6) maxpool 64 x 104 x 104 64 x 52 x 52 23920
(7) conv-bn-leaky 64 x 52 x 52 128 x 52 x 52 98160
(8) maxpool 128 x 52 x 52 128 x 26 x 26 98160
(9) conv-bn-leaky 128 x 26 x 26 256 x 26 x 26 394096
(10) maxpool 256 x 26 x 26 256 x 13 x 13 394096
(11) conv-bn-leaky 256 x 13 x 13 512 x 13 x 13 1575792
(12) maxpool 512 x 13 x 13 512 x 13 x 13 1575792
(13) conv-bn-leaky 512 x 13 x 13 1024 x 13 x 13 6298480
(14) conv-bn-leaky 1024 x 13 x 13 256 x 13 x 13 6561648
(15) conv-bn-leaky 256 x 13 x 13 512 x 13 x 13 7743344
(16) conv-linear 512 x 13 x 13 255 x 13 x 13 7874159
(17) yolo 255 x 13 x 13 255 x 13 x 13 7874159
(18) route - 256 x 13 x 13 7874159
(19) conv-bn-leaky 256 x 13 x 13 128 x 13 x 13 7907439
(20) upsample 128 x 13 x 13 128 x 26 x 26 -
(21) route - 384 x 26 x 26 7907439
(22) conv-bn-leaky 384 x 26 x 26 256 x 26 x 26 8793199
(23) conv-linear 256 x 26 x 26 255 x 26 x 26 8858734
(24) yolo 255 x 26 x 26 255 x 26 x 26 8858734
Output blob names :
yolo_17
yolo_24
Total number of layers: 50
Total number of layers on DLA: 0
Building the TensorRT Engine...
Building complete!
0:00:32.850000647 9241 0x10ac3520 INFO nvinfer gstnvinfer.cpp:519:gst_nvinfer_logger:<primary_gie_classifier> NvDsInferContext[UID 1]:generateTRTModel(): Storing the serialized cuda engine to file at /opt/nvidia/deepstream/deepstream-4.0/sources/objectDetector_Yolo/model_b1_fp32.engine
Deserialize yoloLayerV3 plugin: yolo_17
Deserialize yoloLayerV3 plugin: yolo_24
Runtime commands:
h: Print this help
q: Quit
p: Pause
r: Resume
**PERF: FPS 0 (Avg) FPS 1 (Avg)
**PERF: 0.00 (0.00) 0.00 (0.00)
** INFO: <bus_callback:163>: Pipeline ready
NvMMLiteOpen : Block : BlockType = 261
NVMEDIA: Reading vendor.tegra.display-size : status: 6
NvMMLiteBlockCreate : Block : BlockType = 261
** INFO: <bus_callback:149>: Pipeline running
NvMMLiteOpen : Block : BlockType = 4
===== NVMEDIA: NVENC =====
NvMMLiteBlockCreate : Block : BlockType = 4
H264: Profile = 66, Level = 0
ERROR from sink_sub_bin_mux1: Could not multiplex stream.
Debug info: gstqtmux.c(4561): gst_qt_mux_add_buffer (): /GstPipeline:pipeline/GstBin:processing_bin_0/GstBin:sink_bin/GstBin:sink_sub_bin1/GstQTMux:sink_sub_bin_mux1:
Buffer has no PTS.
Quitting
App run failed
配置文件:
# Copyright (c) 2019, NVIDIA CORPORATION. All rights reserved.
# Permission is hereby granted, free of charge, to any person obtaining a
# copy of this software and associated documentation files (the "Software"),
# to deal in the Software without restriction, including without limitation
# the rights to use, copy, modify, merge, publish, distribute, sublicense,
# and/or sell copies of the Software, and to permit persons to whom the
# Software is furnished to do so, subject to the following conditions:
# The above copyright notice and this permission notice shall be included in
# all copies or substantial portions of the Software.
# THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
# IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
# FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL
# THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
# LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
# FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
# DEALINGS IN THE SOFTWARE.
[application]
enable-perf-measurement=1
perf-measurement-interval-sec=5
#gie-kitti-output-dir=streamscl
[tiled-display]
enable=0
rows=1
columns=2
width=1920
height=1080
gpu-id=1
#(0): nvbuf-mem-default - Default memory allocated, specific to particular platform
#(1): nvbuf-mem-cuda-pinned - Allocate Pinned/Host cuda memory, applicable for Tesla
#(2): nvbuf-mem-cuda-device - Allocate Device cuda memory, applicable for Tesla
#(3): nvbuf-mem-cuda-unified - Allocate Unified cuda memory, applicable for Tesla
#(4): nvbuf-mem-surface-array - Allocate Surface Array memory, applicable for Jetson
nvbuf-memory-type=0
[source0]
enable=1
#Type - 1=CameraV4L2 2=URI 3=MultiURI
type=3
uri=file://../../samples/streams/test.mp4
num-sources=1
gpu-id=1
# (0): memtype_device - Memory type Device
# (1): memtype_pinned - Memory type Host Pinned
# (2): memtype_unified - Memory type Unified
cudadec-memtype=0
[source1]
enable=0
type=3
num-sources=1
gpu-id=0
cudadec-memtype=0
[source2]
enable=0
type=3
num-sources=1
gpu-id=0
cudadec-memtype=0
[source3]
enable=1
type=3
#uri=file://../../samples/streams/test.mp4
uri=file://20191010111000.mp4
num-sources=1
gpu-id=1
cudadec-memtype=0
[sink0]
enable=1
#Type - 1=FakeSink 2=EglSink 3=File
type=3
container=1
codec=1
sync=0
source-id=0
gpu-id=0
qos=0
nvbuf-memory-type=0
overlay-id=1
output-file=out.mp4
#[sink0]
#enable=0
##Type - 1=FakeSink 2=EglSink 3=File
#type=3
#sync=0
#source-id=1
#gpu-id=1
#nvbuf-memory-type=0
[sink1]
enable=1
type=2
sync=0
source-id=1
gpu-id=1
nvbuf-memory-type=0
[sink2]
enable=0
type=2
sync=0
source-id=2
gpu-id=0
nvbuf-memory-type=0
[sink3]
enable=0
type=2
sync=0
source-id=3
gpu-id=0
nvbuf-memory-type=0
[osd]
enable=1
gpu-id=0
border-width=1
text-size=15
text-color=1;1;1;1;
text-bg-color=0.3;0.3;0.3;1
font=Serif
show-clock=0
clock-x-offset=800
clock-y-offset=820
clock-text-size=12
clock-color=1;0;0;0
nvbuf-memory-type=0
[streammux]
gpu-id=0
##Boolean property to inform muxer that sources are live
live-source=0
batch-size=1
##time out in usec, to wait after the first buffer is available
##to push the batch even if the complete batch is not formed
batched-push-timeout=40000
## Set muxer output width and height
width=1280
height=720
##Enable to maintain aspect ratio wrt source, and allow black borders, works
##along with width, height properties
enable-padding=0
nvbuf-memory-type=0
# config-file property is mandatory for any gie section.
# Other properties are optional and if set will override the properties set in
# the infer config file.
[primary-gie]
enable=1
gpu-id=0
#model-engine-file=model_b1_fp32.engine
labelfile-path=labels.txt
batch-size=1
#bbox-border-color0=1;0;0;1
#bbox-border-color1=0;1;1;1
#bbox-border-color2=0;0;1;1
#bbox-border-color3=0;1;0;1
gie-unique-id=1
nvbuf-memory-type=0
config-file=config_infer_primary_yoloV3_tiny.txt
raw_output_directory=1234
[tests]
file-loop=0
