Yolov5s run on jetson nx probloms
hello all,now i want to port yolov5s to jetson nx。
1,convert yolov5s.pt to yolov5s.onnx
(yolov5s.pt download from here https://github.com/ultralytics/yolov5/releases/download/v6.1/yolov5s.pt)
(convert to onnx command:python3 export.py --weights yolov5s.pt --include onnx --simplify)
2,convert to tersorrt engine use the command: ./trtexec --onnx=yolov5s.onnx --saveEngine=yolov5s.trt
the output is,note the int64 to int32 warning
&&&& RUNNING TensorRT.trtexec # ./trtexec --onnx=yolov5s.onnx --saveEngine=yolov5s.trt
[07/06/2022-11:51:37] [I] === Model Options ===
[07/06/2022-11:51:37] [I] Format: ONNX
[07/06/2022-11:51:37] [I] Model: yolov5s.onnx
[07/06/2022-11:51:37] [I] Output:
[07/06/2022-11:51:37] [I] === Build Options ===
[07/06/2022-11:51:37] [I] Max batch: 1
[07/06/2022-11:51:37] [I] Workspace: 16 MB
[07/06/2022-11:51:37] [I] minTiming: 1
[07/06/2022-11:51:37] [I] avgTiming: 8
[07/06/2022-11:51:37] [I] Precision: FP32
[07/06/2022-11:51:37] [I] Calibration:
[07/06/2022-11:51:37] [I] Safe mode: Disabled
[07/06/2022-11:51:37] [I] Save engine: yolov5s.trt
[07/06/2022-11:51:37] [I] Load engine:
[07/06/2022-11:51:37] [I] Builder Cache: Enabled
[07/06/2022-11:51:37] [I] NVTX verbosity: 0
[07/06/2022-11:51:37] [I] Inputs format: fp32:CHW
[07/06/2022-11:51:37] [I] Outputs format: fp32:CHW
[07/06/2022-11:51:37] [I] Input build shapes: model
[07/06/2022-11:51:37] [I] Input calibration shapes: model
[07/06/2022-11:51:37] [I] === System Options ===
[07/06/2022-11:51:37] [I] Device: 0
[07/06/2022-11:51:37] [I] DLACore:
[07/06/2022-11:51:37] [I] Plugins:
[07/06/2022-11:51:37] [I] === Inference Options ===
[07/06/2022-11:51:37] [I] Batch: 1
[07/06/2022-11:51:37] [I] Input inference shapes: model
[07/06/2022-11:51:37] [I] Iterations: 10
[07/06/2022-11:51:37] [I] Duration: 3s (+ 200ms warm up)
[07/06/2022-11:51:37] [I] Sleep time: 0ms
[07/06/2022-11:51:37] [I] Streams: 1
[07/06/2022-11:51:37] [I] ExposeDMA: Disabled
[07/06/2022-11:51:37] [I] Spin-wait: Disabled
[07/06/2022-11:51:37] [I] Multithreading: Disabled
[07/06/2022-11:51:37] [I] CUDA Graph: Disabled
[07/06/2022-11:51:37] [I] Skip inference: Disabled
[07/06/2022-11:51:37] [I] Inputs:
[07/06/2022-11:51:37] [I] === Reporting Options ===
[07/06/2022-11:51:37] [I] Verbose: Disabled
[07/06/2022-11:51:37] [I] Averages: 10 inferences
[07/06/2022-11:51:37] [I] Percentile: 99
[07/06/2022-11:51:37] [I] Dump output: Disabled
[07/06/2022-11:51:37] [I] Profile: Disabled
[07/06/2022-11:51:37] [I] Export timing to JSON file:
[07/06/2022-11:51:37] [I] Export output to JSON file:
[07/06/2022-11:51:37] [I] Export profile to JSON file:
Input filename: yolov5s.onnx
ONNX IR version: 0.0.6
Opset version: 12
Producer name: pytorch
Producer version: 1.8
Domain:
Model version: 0
Doc string:
[07/06/2022-11:51:40] [W] [TRT] onnx2trt_utils.cpp:220: Your ONNX model has been generated with INT64 weights, while TensorRT does not natively support INT64. Attempting to cast down to INT32.
[07/06/2022-11:51:40] [W] [TRT] onnx2trt_utils.cpp:246: One or more weights outside the range of INT32 was clamped
[07/06/2022-11:51:41] [I] [TRT]
[07/06/2022-11:51:41] [I] [TRT] --------------- Layers running on DLA:
[07/06/2022-11:51:41] [I] [TRT] --------------- Layers running on GPU:
[07/06/2022-11:51:41] [I] [TRT] Slice_4, Slice_9, Slice_14, Slice_19, Slice_24, Slice_29, Slice_34, Slice_39, Conv_41, PWN(PWN((Unnamed Layer* 14) [Constant] + (Unnamed Layer* 15) [Shuffle], PWN(PWN((Unnamed Layer* 10) [Constant] + (Unnamed Layer* 11) [Shuffle] + Add_43, Clip_46), Div_48)), Mul_49), Conv_50, PWN(PWN((Unnamed Layer* 23) [Constant] + (Unnamed Layer* 24) [Shuffle], PWN(PWN((Unnamed Layer* 19) [Constant] + (Unnamed Layer* 20) [Shuffle] + Add_52, Clip_55), Div_57)), Mul_58), Conv_88 || Conv_59, PWN(PWN((Unnamed Layer* 32) [Constant] + (Unnamed Layer* 33) [Shuffle], PWN(PWN((Unnamed Layer* 28) [Constant] + (Unnamed Layer* 29) [Shuffle] + Add_61, Clip_64), Div_66)), Mul_67), Conv_68, PWN(PWN((Unnamed Layer* 41) [Constant] + (Unnamed Layer* 42) [Shuffle], PWN(PWN((Unnamed Layer* 37) [Constant] + (Unnamed Layer* 38) [Shuffle] + Add_70, Clip_73), Div_75)), Mul_76), Conv_77, PWN(PWN(PWN((Unnamed Layer* 50) [Constant] + (Unnamed Layer* 51) [Shuffle], PWN(PWN((Unnamed Layer* 46) [Constant] + (Unnamed Layer* 47) [Shuffle] + Add_79, Clip_82), Div_84)), Mul_85), Add_86), Conv_87, 254 copy, BatchNormalization_90, LeakyRelu_91, Conv_92, PWN(PWN((Unnamed Layer* 65) [Constant] + (Unnamed Layer* 66) [Shuffle], PWN(PWN((Unnamed Layer* 61) [Constant] + (Unnamed Layer* 62) [Shuffle] + Add_94, Clip_97), Div_99)), Mul_100), Conv_101, PWN(PWN((Unnamed Layer* 74) [Constant] + (Unnamed Layer* 75) [Shuffle], PWN(PWN((Unnamed Layer* 70) [Constant] + (Unnamed Layer* 71) [Shuffle] + Add_103, Clip_106), Div_108)), Mul_109), Conv_177 || Conv_110, PWN(PWN((Unnamed Layer* 83) [Constant] + (Unnamed Layer* 84) [Shuffle], PWN(PWN((Unnamed Layer* 79) [Constant] + (Unnamed Layer* 80) [Shuffle] + Add_112, Clip_115), Div_117)), Mul_118), Conv_119, PWN(PWN((Unnamed Layer* 92) [Constant] + (Unnamed Layer* 93) [Shuffle], PWN(PWN((Unnamed Layer* 88) [Constant] + (Unnamed Layer* 89) [Shuffle] + Add_121, Clip_124), Div_126)), Mul_127), Conv_128, PWN(PWN(PWN((Unnamed Layer* 101) [Constant] + (Unnamed Layer* 102) [Shuffle], PWN(PWN((Unnamed Layer* 97) [Constant] + (Unnamed Layer* 98) [Shuffle] + Add_130, Clip_133), Div_135)), Mul_136), Add_137), Conv_138, PWN(PWN((Unnamed Layer* 111) [Constant] + (Unnamed Layer* 112) [Shuffle], PWN(PWN((Unnamed Layer* 107) [Constant] + (Unnamed Layer* 108) [Shuffle] + Add_140, Clip_143), Div_145)), Mul_146), Conv_147, PWN(PWN(PWN((Unnamed Layer* 120) [Constant] + (Unnamed Layer* 121) [Shuffle], PWN(PWN((Unnamed Layer* 116) [Constant] + (Unnamed Layer* 117) [Shuffle] + Add_149, Clip_152), Div_154)), Mul_155), Add_156), Conv_157, PWN(PWN((Unnamed Layer* 130) [Constant] + (Unnamed Layer* 131) [Shuffle], PWN(PWN((Unnamed Layer* 126) [Constant] + (Unnamed Layer* 127) [Shuffle] + Add_159, Clip_162), Div_164)), Mul_165), Conv_166, PWN(PWN(PWN((Unnamed Layer* 139) [Constant] + (Unnamed Layer* 140) [Shuffle], PWN(PWN((Unnamed Layer* 135) [Constant] + (Unnamed Layer* 136) [Shuffle] + Add_168, Clip_171), Div_173)), Mul_174), Add_175), Conv_176, 343 copy, BatchNormalization_179, LeakyRelu_180, Conv_181, PWN(PWN((Unnamed Layer* 154) [Constant] + (Unnamed Layer* 155) [Shuffle], PWN(PWN((Unnamed Layer* 150) [Constant] + (Unnamed Layer* 151) [Shuffle] + Add_183, Clip_186), Div_188)), Mul_189), Conv_190, PWN(PWN((Unnamed Layer* 163) [Constant] + (Unnamed Layer* 164) [Shuffle], PWN(PWN((Unnamed Layer* 159) [Constant] + (Unnamed Layer* 160) [Shuffle] + Add_192, Clip_195), Div_197)), Mul_198), Conv_266 || Conv_199, PWN(PWN((Unnamed Layer* 172) [Constant] + (Unnamed Layer* 173) [Shuffle], PWN(PWN((Unnamed Layer* 168) [Constant] + (Unnamed Layer* 169) [Shuffle] + Add_201, Clip_204), Div_206)), Mul_207), Conv_208, PWN(PWN((Unnamed Layer* 181) [Constant] + (Unnamed Layer* 182) [Shuffle], PWN(PWN((Unnamed Layer* 177) [Constant] + (Unnamed Layer* 178) [Shuffle] + Add_210, Clip_213), Div_215)), Mul_216), Conv_217, PWN(PWN(PWN((Unnamed Layer* 190) [Constant] + (Unnamed Layer* 191) [Shuffle], PWN(PWN((Unnamed Layer* 186) [Constant] + (Unnamed Layer* 187) [Shuffle] + Add_219, Clip_222), Div_224)), Mul_225), Add_226), Conv_227, PWN(PWN((Unnamed Layer* 200) [Constant] + (Unnamed Layer* 201) [Shuffle], PWN(PWN((Unnamed Layer* 196) [Constant] + (Unnamed Layer* 197) [Shuffle] + Add_229, Clip_232), Div_234)), Mul_235), Conv_236, PWN(PWN(PWN((Unnamed Layer* 209) [Constant] + (Unnamed Layer* 210) [Shuffle], PWN(PWN((Unnamed Layer* 205) [Constant] + (Unnamed Layer* 206) [Shuffle] + Add_238, Clip_241), Div_243)), Mul_244), Add_245), Conv_246, PWN(PWN((Unnamed Layer* 219) [Constant] + (Unnamed Layer* 220) [Shuffle], PWN(PWN((Unnamed Layer* 215) [Constant] + (Unnamed Layer* 216) [Shuffle] + Add_248, Clip_251), Div_253)), Mul_254), Conv_255, PWN(PWN(PWN((Unnamed Layer* 228) [Constant] + (Unnamed Layer* 229) [Shuffle], PWN(PWN((Unnamed Layer* 224) [Constant] + (Unnamed Layer* 225) [Shuffle] + Add_257, Clip_260), Div_262)), Mul_263), Add_264), Conv_265, 432 copy, BatchNormalization_268, LeakyRelu_269, Conv_270, PWN(PWN((Unnamed Layer* 243) [Constant] + (Unnamed Layer* 244) [Shuffle], PWN(PWN((Unnamed Layer* 239) [Constant] + (Unnamed Layer* 240) [Shuffle] + Add_272, Clip_275), Div_277)), Mul_278), Conv_279, PWN(PWN((Unnamed Layer* 252) [Constant] + (Unnamed Layer* 253) [Shuffle], PWN(PWN((Unnamed Layer* 248) [Constant] + (Unnamed Layer* 249) [Shuffle] + Add_281, Clip_284), Div_286)), Mul_287), Conv_288, PWN(PWN((Unnamed Layer* 261) [Constant] + (Unnamed Layer* 262) [Shuffle], PWN(PWN((Unnamed Layer* 257) [Constant] + (Unnamed Layer* 258) [Shuffle] + Add_290, Clip_293), Div_295)), Mul_296), MaxPool_299, MaxPool_298, MaxPool_297, 462 copy, Conv_301, PWN(PWN((Unnamed Layer* 274) [Constant] + (Unnamed Layer* 275) [Shuffle], PWN(PWN((Unnamed Layer* 270) [Constant] + (Unnamed Layer* 271) [Shuffle] + Add_303, Clip_306), Div_308)), Mul_309), Conv_338 || Conv_310, PWN(PWN((Unnamed Layer* 283) [Constant] + (Unnamed Layer* 284) [Shuffle], PWN(PWN((Unnamed Layer* 279) [Constant] + (Unnamed Layer* 280) [Shuffle] + Add_312, Clip_315), Div_317)), Mul_318), Conv_319, PWN(PWN((Unnamed Layer* 292) [Constant] + (Unnamed Layer* 293) [Shuffle], PWN(PWN((Unnamed Layer* 288) [Constant] + (Unnamed Layer* 289) [Shuffle] + Add_321, Clip_324), Div_326)), Mul_327), Conv_328, PWN(PWN((Unnamed Layer* 301) [Constant] + (Unnamed Layer* 302) [Shuffle], PWN(PWN((Unnamed Layer* 297) [Constant] + (Unnamed Layer* 298) [Shuffle] + Add_330, Clip_333), Div_335)), Mul_336), Conv_337, 504 copy, BatchNormalization_340, LeakyRelu_341, Conv_342, PWN(PWN((Unnamed Layer* 315) [Constant] + (Unnamed Layer* 316) [Shuffle], PWN(PWN((Unnamed Layer* 311) [Constant] + (Unnamed Layer* 312) [Shuffle] + Add_344, Clip_347), Div_349)), Mul_350), Conv_351, PWN(PWN((Unnamed Layer* 324) [Constant] + (Unnamed Layer* 325) [Shuffle], PWN(PWN((Unnamed Layer* 320) [Constant] + (Unnamed Layer* 321) [Shuffle] + Add_353, Clip_356), Div_358)), Mul_359), Resize_361, 530 copy, Conv_391 || Conv_363, PWN(PWN((Unnamed Layer* 335) [Constant] + (Unnamed Layer* 336) [Shuffle], PWN(PWN((Unnamed Layer* 331) [Constant] + (Unnamed Layer* 332) [Shuffle] + Add_365, Clip_368), Div_370)), Mul_371), Conv_372, PWN(PWN((Unnamed Layer* 344) [Constant] + (Unnamed Layer* 345) [Shuffle], PWN(PWN((Unnamed Layer* 340) [Constant] + (Unnamed Layer* 341) [Shuffle] + Add_374, Clip_377), Div_379)), Mul_380), Conv_381, PWN(PWN((Unnamed Layer* 353) [Constant] + (Unnamed Layer* 354) [Shuffle], PWN(PWN((Unnamed Layer* 349) [Constant] + (Unnamed Layer* 350) [Shuffle] + Add_383, Clip_386), Div_388)), Mul_389), Conv_390, 560 copy, BatchNormalization_393, LeakyRelu_394, Conv_395, PWN(PWN((Unnamed Layer* 367) [Constant] + (Unnamed Layer* 368) [Shuffle], PWN(PWN((Unnamed Layer* 363) [Constant] + (Unnamed Layer* 364) [Shuffle] + Add_397, Clip_400), Div_402)), Mul_403), Conv_404, PWN(PWN((Unnamed Layer* 376) [Constant] + (Unnamed Layer* 377) [Shuffle], PWN(PWN((Unnamed Layer* 372) [Constant] + (Unnamed Layer* 373) [Shuffle] + Add_406, Clip_409), Div_411)), Mul_412), Resize_414, 586 copy, Conv_444 || Conv_416, PWN(PWN((Unnamed Layer* 387) [Constant] + (Unnamed Layer* 388) [Shuffle], PWN(PWN((Unnamed Layer* 383) [Constant] + (Unnamed Layer* 384) [Shuffle] + Add_418, Clip_421), Div_423)), Mul_424), Conv_425, PWN(PWN((Unnamed Layer* 396) [Constant] + (Unnamed Layer* 397) [Shuffle], PWN(PWN((Unnamed Layer* 392) [Constant] + (Unnamed Layer* 393) [Shuffle] + Add_427, Clip_430), Div_432)), Mul_433), Conv_434, PWN(PWN((Unnamed Layer* 405) [Constant] + (Unnamed Layer* 406) [Shuffle], PWN(PWN((Unnamed Layer* 401) [Constant] + (Unnamed Layer* 402) [Shuffle] + Add_436, Clip_439), Div_441)), Mul_442), Conv_443, 616 copy, BatchNormalization_446, LeakyRelu_447, Conv_448, PWN(PWN((Unnamed Layer* 419) [Constant] + (Unnamed Layer* 420) [Shuffle], PWN(PWN((Unnamed Layer* 415) [Constant] + (Unnamed Layer* 416) [Shuffle] + Add_450, Clip_453), Div_455)), Mul_456), Conv_559, Reshape_573 + Transpose_574, Sigmoid_575, Split_576_2, Split_576_1, Split_576, Conv_457, PWN(PWN((Unnamed Layer* 428) [Constant] + (Unnamed Layer* 429) [Shuffle], PWN(PWN((Unnamed Layer* 424) [Constant] + (Unnamed Layer* 425) [Shuffle] + Add_459, Clip_462), Div_464)), Mul_465), 581 copy, (Unnamed Layer* 532) [Constant] + (Unnamed Layer* 533) [Shuffle] + Mul_578, Conv_495 || Conv_467, PWN(PWN((Unnamed Layer* 438) [Constant] + (Unnamed Layer* 439) [Shuffle], PWN(PWN((Unnamed Layer* 434) [Constant] + (Unnamed Layer* 435) [Shuffle] + Add_469, Clip_472), Div_474)), Mul_475), PWN((Unnamed Layer* 543) [Constant] + (Unnamed Layer* 544) [Shuffle], PWN((Unnamed Layer* 540) [Constant] + (Unnamed Layer* 541) [Shuffle] + Mul_584, Pow_586)), (Unnamed Layer* 535) [Constant] + Add_580, Conv_476, PWN(PWN((Unnamed Layer* 447) [Constant] + (Unnamed Layer* 448) [Shuffle], PWN(PWN((Unnamed Layer* 443) [Constant] + (Unnamed Layer* 444) [Shuffle] + Add_478, Clip_481), Div_483)), Mul_484), (Unnamed Layer* 546) [Constant] + Mul_588, (Unnamed Layer* 537) [Constant] + (Unnamed Layer* 538) [Shuffle] + Mul_582, 760 copy, 766 copy, 754 copy, Reshape_592, Conv_485, PWN(PWN((Unnamed Layer* 456) [Constant] + (Unnamed Layer* 457) [Shuffle], PWN(PWN((Unnamed Layer* 452) [Constant] + (Unnamed Layer* 453) [Shuffle] + Add_487, Clip_490), Div_492)), Mul_493), Conv_494, 666 copy, 667 copy, BatchNormalization_497, LeakyRelu_498, Conv_499, PWN(PWN((Unnamed Layer* 470) [Constant] + (Unnamed Layer* 471) [Shuffle], PWN(PWN((Unnamed Layer* 466) [Constant] + (Unnamed Layer* 467) [Shuffle] + Add_501, Clip_504), Div_506)), Mul_507), Conv_593, Reshape_607 + Transpose_608, Sigmoid_609, Split_610_2, Split_610_1, Split_610, Conv_508, PWN(PWN((Unnamed Layer* 479) [Constant] + (Unnamed Layer* 480) [Shuffle], PWN(PWN((Unnamed Layer* 475) [Constant] + (Unnamed Layer* 476) [Shuffle] + Add_510, Clip_513), Div_515)), Mul_516), 688 copy, 525 copy, (Unnamed Layer* 557) [Constant] + (Unnamed Layer* 558) [Shuffle] + Mul_612, Conv_546 || Conv_518, PWN(PWN((Unnamed Layer* 489) [Constant] + (Unnamed Layer* 490) [Shuffle], PWN(PWN((Unnamed Layer* 485) [Constant] + (Unnamed Layer* 486) [Shuffle] + Add_520, Clip_523), Div_525)), Mul_526), PWN((Unnamed Layer* 568) [Constant] + (Unnamed Layer* 569) [Shuffle], PWN((Unnamed Layer* 565) [Constant] + (Unnamed Layer* 566) [Shuffle] + Mul_618, Pow_620)), (Unnamed Layer* 560) [Constant] + Add_614, Conv_527, PWN(PWN((Unnamed Layer* 498) [Constant] + (Unnamed Layer* 499) [Shuffle], PWN(PWN((Unnamed Layer* 494) [Constant] + (Unnamed Layer* 495) [Shuffle] + Add_529, Clip_532), Div_534)), Mul_535), (Unnamed Layer* 571) [Constant] + Mul_622, (Unnamed Layer* 562) [Constant] + (Unnamed Layer* 563) [Shuffle] + Mul_616, 804 copy, 810 copy, 798 copy, Reshape_626, Conv_536, PWN(PWN((Unnamed Layer* 507) [Constant] + (Unnamed Layer* 508) [Shuffle], PWN(PWN((Unnamed Layer* 503) [Constant] + (Unnamed Layer* 504) [Shuffle] + Add_538, Clip_541), Div_543)), Mul_544), Conv_545, 717 copy, 718 copy, BatchNormalization_548, LeakyRelu_549, Conv_550, PWN(PWN((Unnamed Layer* 521) [Constant] + (Unnamed Layer* 522) [Shuffle], PWN(PWN((Unnamed Layer* 517) [Constant] + (Unnamed Layer* 518) [Shuffle] + Add_552, Clip_555), Div_557)), Mul_558), Conv_627, Reshape_641 + Transpose_642, Sigmoid_643, Split_644_2, Split_644_1, Split_644, (Unnamed Layer* 582) [Constant] + (Unnamed Layer* 583) [Shuffle] + Mul_646, PWN((Unnamed Layer* 593) [Constant] + (Unnamed Layer* 594) [Shuffle], PWN((Unnamed Layer* 590) [Constant] + (Unnamed Layer* 591) [Shuffle] + Mul_652, Pow_654)), (Unnamed Layer* 585) [Constant] + Add_648, (Unnamed Layer* 596) [Constant] + Mul_656, (Unnamed Layer* 587) [Constant] + (Unnamed Layer* 588) [Shuffle] + Mul_650, 848 copy, 854 copy, 842 copy, Reshape_660, 774 copy, 818 copy, 862 copy,
[07/06/2022-11:51:50] [I] [TRT] Some tactics do not have sufficient workspace memory to run. Increasing workspace size may increase performance, please check verbose output.
[07/06/2022-11:55:43] [I] [TRT] Detected 1 inputs and 4 output network tensors.
[07/06/2022-11:55:44] [I] Starting inference threads
[07/06/2022-11:55:47] [I] Warmup completed 5 queries over 200 ms
[07/06/2022-11:55:47] [I] Timing trace has 43 queries over 3.15354 s
[07/06/2022-11:55:47] [I] Trace averages of 10 runs:
[07/06/2022-11:55:47] [I] Average on 10 runs - GPU latency: 58.0234 ms - Host latency: 58.8179 ms (end to end 58.889 ms, enqueue 7.25994 ms)
[07/06/2022-11:55:47] [I] Average on 10 runs - GPU latency: 77.7581 ms - Host latency: 78.5935 ms (end to end 78.6058 ms, enqueue 5.8263 ms)
[07/06/2022-11:55:47] [I] Average on 10 runs - GPU latency: 82.3244 ms - Host latency: 83.1825 ms (end to end 83.3682 ms, enqueue 5.49225 ms)
[07/06/2022-11:55:47] [I] Average on 10 runs - GPU latency: 70.3519 ms - Host latency: 71.1755 ms (end to end 71.2973 ms, enqueue 4.90483 ms)
[07/06/2022-11:55:47] [I] Host Latency
[07/06/2022-11:55:47] [I] min: 46.4056 ms (end to end 46.4195 ms)
[07/06/2022-11:55:47] [I] max: 113.098 ms (end to end 113.105 ms)
[07/06/2022-11:55:47] [I] mean: 73.2449 ms (end to end 73.3366 ms)
[07/06/2022-11:55:47] [I] median: 60.6202 ms (end to end 60.627 ms)
[07/06/2022-11:55:47] [I] percentile: 113.098 ms at 99% (end to end 113.105 ms at 99%)
[07/06/2022-11:55:47] [I] throughput: 13.6355 qps
[07/06/2022-11:55:47] [I] walltime: 3.15354 s
[07/06/2022-11:55:47] [I] Enqueue Time
[07/06/2022-11:55:47] [I] min: 4.31714 ms
[07/06/2022-11:55:47] [I] max: 10.6324 ms
[07/06/2022-11:55:47] [I] median: 5.27222 ms
[07/06/2022-11:55:47] [I] GPU Compute
[07/06/2022-11:55:47] [I] min: 45.7134 ms
[07/06/2022-11:55:47] [I] max: 112.401 ms
[07/06/2022-11:55:47] [I] mean: 72.4188 ms
[07/06/2022-11:55:47] [I] median: 59.8231 ms
[07/06/2022-11:55:47] [I] percentile: 112.401 ms at 99%
[07/06/2022-11:55:47] [I] total compute time: 3.11401 s
&&&& PASSED TensorRT.trtexec # ./trtexec --onnx=yolov5s.onnx --saveEngine=yolov5s.trt
3,convert to tensorrt engine seems ok excepts the warning,but when I user tensorrt to infer,the output is Partial correct。I compare the tensorrt engine with the onnx output which run on cpu,214200(25200*85) floats,33607 is not equal,the other is equal.
4,my jetson info is
  • NVIDIA Jetson Xavier NX (Developer Kit Version)
    • Jetpack 4.4.1 [L4T 32.4.4]
    • NV Power Mode: MODE_15W_6CORE - Type: 2
    • jetson_stats.service: active
  • Libraries:
    • CUDA: 10.2.89
    • cuDNN: 8.0.0.180
    • TensorRT: 7.1.3.0
    • Visionworks: NOT_INSTALLED
    • OpenCV: 4.1.1 compiled CUDA: NO
    • VPI: NOT_INSTALLED
    • Vulkan: 1.2.70
      Please correct me if I am wrong. thanyou very much
I am moving your topic to the Jetson Xavier NX category so our support team has visibility.
We have several newer releases already.
Could you upgrade your environment to JetPack 4.6.2 or 5.0.1 DP and try it again?
how can i upgrade the jetpack version?
For JetPack 4.6.x, you can find the SD card image:
For JetPack 5.0, please reflash your device with SDK manager.
