The log of tao detectnet_v2 dataset_convert
Converting Tfrecords for COCO trainval dataset
2023-05-03 14:38:46,225 [INFO] root: Registry: ['nvcr.io']
2023-05-03 14:38:46,305 [INFO] tlt.components.instance_handler.local_instance: Running command in container: nvcr.io/nvidia/tao/tao-toolkit:4.0.0-tf1.15.5
2023-05-03 14:38:47,236 [WARNING] tlt.components.docker_handler.docker_handler:
Docker will run the commands as root. If you would like to retain your
local host permissions, please add the "user":"UID:GID" in the
DockerOptions portion of the "/home/shounak/.tao_mounts.json" file. You can obtain your
users UID and GID by using the "id -u" and "id -g" commands on the
terminal.
Using TensorFlow backend.
2023-05-03 18:38:48.758429: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libcudart.so.11.0
WARNING:tensorflow:Deprecation warnings have been disabled. Set TF_ENABLE_DEPRECATION_WARNINGS=1 to re-enable them.
/usr/local/lib/python3.6/dist-packages/requests/__init__.py:91: RequestsDependencyWarning: urllib3 (1.26.5) or chardet (3.0.4) doesn't match a supported version!
RequestsDependencyWarning)
U
2023-05-03 18:38:55,886 [INFO] iva.detectnet_v2.dataio.build_converter: Instantiating a coco converter
2023-05-03 18:38:55,886 [INFO] iva.detectnet_v2.dataio.dataset_converter_lib: Creating output directory /workspace/tao-experiments/data/tfrecords/coco_trainval
loading annotations into memory...
Done (t=0.17s)
creating index...
index created!
Done (t=0.50s)
creating index...
index created!
2023-05-03 18:38:56,629 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 0, shard 0
2023-05-03 18:38:56,645 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 0, shard 1
2023-05-03 18:38:56,660 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 0, shard 2
2023-05-03 18:38:56,675 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 0, shard 3
2023-05-03 18:38:56,691 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 0, shard 4
2023-05-03 18:38:56,707 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 0, shard 5
2023-05-03 18:38:56,723 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 0, shard 6
2023-05-03 18:38:56,739 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 0, shard 7
2023-05-03 18:38:56,754 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 0, shard 8
2023-05-03 18:38:56,770 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 0, shard 9
2023-05-03 18:38:56,787 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 0, shard 10
2023-05-03 18:38:56,803 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 0, shard 11
2023-05-03 18:38:56,820 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 0, shard 12
2023-05-03 18:38:56,837 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 0, shard 13
2023-05-03 18:38:56,853 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 0, shard 14
2023-05-03 18:38:56,870 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 0, shard 15
2023-05-03 18:38:56,887 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 0, shard 16
2023-05-03 18:38:56,904 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 0, shard 17
2023-05-03 18:38:56,920 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 0, shard 18
2023-05-03 18:38:56,937 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 0, shard 19
2023-05-03 18:38:56,956 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 0, shard 20
2023-05-03 18:38:56,975 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 0, shard 21
2023-05-03 18:38:56,995 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 0, shard 22
2023-05-03 18:38:57,016 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 0, shard 23
2023-05-03 18:38:57,036 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 0, shard 24
2023-05-03 18:38:57,057 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 0, shard 25
2023-05-03 18:38:57,080 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 0, shard 26
2023-05-03 18:38:57,100 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 0, shard 27
2023-05-03 18:38:57,119 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 0, shard 28
2023-05-03 18:38:57,139 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 0, shard 29
2023-05-03 18:38:57,158 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 0, shard 30
2023-05-03 18:38:57,178 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 0, shard 31
2023-05-03 18:38:57,207 [INFO] iva.detectnet_v2.dataio.dataset_converter_lib:
Wrote the following numbers of objects:
b'menu': 2826
b'table': 12550
b'check': 1896
b'plate': 4397
b'person': 18264
2023-05-03 18:38:57,207 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 0
2023-05-03 18:38:57,213 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 1
2023-05-03 18:38:57,219 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 2
2023-05-03 18:38:57,224 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 3
2023-05-03 18:38:57,230 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 4
2023-05-03 18:38:57,236 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 5
2023-05-03 18:38:57,242 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 6
2023-05-03 18:38:57,247 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 7
2023-05-03 18:38:57,253 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 8
2023-05-03 18:38:57,259 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 9
2023-05-03 18:38:57,265 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 10
2023-05-03 18:38:57,271 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 11
2023-05-03 18:38:57,276 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 12
2023-05-03 18:38:57,282 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 13
2023-05-03 18:38:57,288 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 14
2023-05-03 18:38:57,294 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 15
2023-05-03 18:38:57,300 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 16
2023-05-03 18:38:57,306 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 17
2023-05-03 18:38:57,312 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 18
2023-05-03 18:38:57,318 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 19
2023-05-03 18:38:57,325 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 20
2023-05-03 18:38:57,331 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 21
2023-05-03 18:38:57,337 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 22
2023-05-03 18:38:57,343 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 23
2023-05-03 18:38:57,349 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 24
2023-05-03 18:38:57,355 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 25
2023-05-03 18:38:57,361 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 26
2023-05-03 18:38:57,367 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 27
2023-05-03 18:38:57,373 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 28
2023-05-03 18:38:57,379 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 29
2023-05-03 18:38:57,386 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 30
2023-05-03 18:38:57,392 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 31
2023-05-03 18:38:57,399 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 32
2023-05-03 18:38:57,405 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 33
2023-05-03 18:38:57,411 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 34
2023-05-03 18:38:57,418 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 35
2023-05-03 18:38:57,424 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 36
2023-05-03 18:38:57,430 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 37
2023-05-03 18:38:57,437 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 38
2023-05-03 18:38:57,443 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 39
2023-05-03 18:38:57,450 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 40
2023-05-03 18:38:57,457 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 41
2023-05-03 18:38:57,463 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 42
2023-05-03 18:38:57,470 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 43
2023-05-03 18:38:57,477 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 44
2023-05-03 18:38:57,483 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 45
2023-05-03 18:38:57,490 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 46
2023-05-03 18:38:57,497 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 47
2023-05-03 18:38:57,503 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 48
2023-05-03 18:38:57,510 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 49
2023-05-03 18:38:57,517 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 50
2023-05-03 18:38:57,524 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 51
2023-05-03 18:38:57,531 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 52
2023-05-03 18:38:57,537 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 53
2023-05-03 18:38:57,544 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 54
2023-05-03 18:38:57,550 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 55
2023-05-03 18:38:57,556 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 56
2023-05-03 18:38:57,563 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 57
2023-05-03 18:38:57,569 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 58
2023-05-03 18:38:57,575 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 59
2023-05-03 18:38:57,581 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 60
2023-05-03 18:38:57,588 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 61
2023-05-03 18:38:57,594 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 62
2023-05-03 18:38:57,600 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 63
2023-05-03 18:38:57,606 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 64
2023-05-03 18:38:57,613 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 65
2023-05-03 18:38:57,619 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 66
2023-05-03 18:38:57,625 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 67
2023-05-03 18:38:57,631 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 68
2023-05-03 18:38:57,637 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 69
2023-05-03 18:38:57,644 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 70
2023-05-03 18:38:57,650 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 71
2023-05-03 18:38:57,656 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 72
2023-05-03 18:38:57,662 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 73
2023-05-03 18:38:57,668 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 74
2023-05-03 18:38:57,675 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 75
2023-05-03 18:38:57,681 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 76
2023-05-03 18:38:57,687 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 77
2023-05-03 18:38:57,693 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 78
2023-05-03 18:38:57,700 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 79
2023-05-03 18:38:57,706 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 80
2023-05-03 18:38:57,712 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 81
2023-05-03 18:38:57,718 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 82
2023-05-03 18:38:57,725 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 83
2023-05-03 18:38:57,731 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 84
2023-05-03 18:38:57,737 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 85
2023-05-03 18:38:57,743 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 86
2023-05-03 18:38:57,750 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 87
2023-05-03 18:38:57,756 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 88
2023-05-03 18:38:57,762 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 89
2023-05-03 18:38:57,768 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 90
2023-05-03 18:38:57,775 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 91
2023-05-03 18:38:57,781 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 92
2023-05-03 18:38:57,787 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 93
2023-05-03 18:38:57,794 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 94
2023-05-03 18:38:57,800 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 95
2023-05-03 18:38:57,806 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 96
2023-05-03 18:38:57,812 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 97
2023-05-03 18:38:57,818 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 98
2023-05-03 18:38:57,825 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 99
2023-05-03 18:38:57,831 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 100
2023-05-03 18:38:57,837 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 101
2023-05-03 18:38:57,843 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 102
2023-05-03 18:38:57,850 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 103
2023-05-03 18:38:57,856 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 104
2023-05-03 18:38:57,862 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 105
2023-05-03 18:38:57,869 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 106
2023-05-03 18:38:57,876 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 107
2023-05-03 18:38:57,882 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 108
2023-05-03 18:38:57,889 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 109
2023-05-03 18:38:57,896 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 110
2023-05-03 18:38:57,903 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 111
2023-05-03 18:38:57,909 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 112
2023-05-03 18:38:57,916 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 113
2023-05-03 18:38:57,923 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 114
2023-05-03 18:38:57,930 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 115
2023-05-03 18:38:57,937 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 116
2023-05-03 18:38:57,943 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 117
2023-05-03 18:38:57,950 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 118
2023-05-03 18:38:57,956 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 119
2023-05-03 18:38:57,962 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 120
2023-05-03 18:38:57,968 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 121
2023-05-03 18:38:57,975 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 122
2023-05-03 18:38:57,981 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 123
2023-05-03 18:38:57,988 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 124
2023-05-03 18:38:57,994 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 125
2023-05-03 18:38:58,000 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 126
2023-05-03 18:38:58,007 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 127
2023-05-03 18:38:58,013 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 128
2023-05-03 18:38:58,019 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 129
2023-05-03 18:38:58,026 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 130
2023-05-03 18:38:58,032 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 131
2023-05-03 18:38:58,039 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 132
2023-05-03 18:38:58,047 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 133
2023-05-03 18:38:58,054 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 134
2023-05-03 18:38:58,061 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 135
2023-05-03 18:38:58,069 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 136
2023-05-03 18:38:58,077 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 137
2023-05-03 18:38:58,084 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 138
2023-05-03 18:38:58,092 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 139
2023-05-03 18:38:58,099 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 140
2023-05-03 18:38:58,107 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 141
2023-05-03 18:38:58,115 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 142
2023-05-03 18:38:58,122 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 143
2023-05-03 18:38:58,130 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 144
2023-05-03 18:38:58,137 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 145
2023-05-03 18:38:58,145 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 146
2023-05-03 18:38:58,152 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 147
2023-05-03 18:38:58,160 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 148
2023-05-03 18:38:58,167 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 149
2023-05-03 18:38:58,178 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 150
2023-05-03 18:38:58,185 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 151
2023-05-03 18:38:58,193 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 152
2023-05-03 18:38:58,200 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 153
2023-05-03 18:38:58,208 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 154
2023-05-03 18:38:58,216 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 155
2023-05-03 18:38:58,223 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 156
2023-05-03 18:38:58,230 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 157
2023-05-03 18:38:58,237 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 158
2023-05-03 18:38:58,244 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 159
2023-05-03 18:38:58,251 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 160
2023-05-03 18:38:58,258 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 161
2023-05-03 18:38:58,264 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 162
2023-05-03 18:38:58,270 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 163
2023-05-03 18:38:58,277 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 164
2023-05-03 18:38:58,284 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 165
2023-05-03 18:38:58,291 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 166
2023-05-03 18:38:58,298 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 167
2023-05-03 18:38:58,305 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 168
2023-05-03 18:38:58,313 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 169
2023-05-03 18:38:58,320 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 170
2023-05-03 18:38:58,328 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 171
2023-05-03 18:38:58,335 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 172
2023-05-03 18:38:58,342 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 173
2023-05-03 18:38:58,349 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 174
2023-05-03 18:38:58,357 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 175
2023-05-03 18:38:58,364 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 176
2023-05-03 18:38:58,371 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 177
2023-05-03 18:38:58,379 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 178
2023-05-03 18:38:58,386 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 179
2023-05-03 18:38:58,393 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 180
2023-05-03 18:38:58,401 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 181
2023-05-03 18:38:58,408 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 182
2023-05-03 18:38:58,415 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 183
2023-05-03 18:38:58,423 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 184
2023-05-03 18:38:58,430 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 185
2023-05-03 18:38:58,437 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 186
2023-05-03 18:38:58,444 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 187
2023-05-03 18:38:58,451 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 188
2023-05-03 18:38:58,458 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 189
2023-05-03 18:38:58,466 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 190
2023-05-03 18:38:58,473 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 191
2023-05-03 18:38:58,480 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 192
2023-05-03 18:38:58,488 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 193
2023-05-03 18:38:58,495 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 194
2023-05-03 18:38:58,502 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 195
2023-05-03 18:38:58,510 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 196
2023-05-03 18:38:58,517 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 197
2023-05-03 18:38:58,525 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 198
2023-05-03 18:38:58,532 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 199
2023-05-03 18:38:58,540 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 200
2023-05-03 18:38:58,548 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 201
2023-05-03 18:38:58,556 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 202
2023-05-03 18:38:58,563 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 203
2023-05-03 18:38:58,571 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 204
2023-05-03 18:38:58,578 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 205
2023-05-03 18:38:58,585 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 206
2023-05-03 18:38:58,593 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 207
2023-05-03 18:38:58,600 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 208
2023-05-03 18:38:58,608 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 209
2023-05-03 18:38:58,615 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 210
2023-05-03 18:38:58,622 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 211
2023-05-03 18:38:58,630 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 212
2023-05-03 18:38:58,637 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 213
2023-05-03 18:38:58,644 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 214
2023-05-03 18:38:58,651 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 215
2023-05-03 18:38:58,659 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 216
2023-05-03 18:38:58,666 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 217
2023-05-03 18:38:58,672 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 218
2023-05-03 18:38:58,678 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 219
2023-05-03 18:38:58,684 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 220
2023-05-03 18:38:58,690 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 221
2023-05-03 18:38:58,697 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 222
2023-05-03 18:38:58,704 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 223
2023-05-03 18:38:58,711 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 224
2023-05-03 18:38:58,718 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 225
2023-05-03 18:38:58,725 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 226
2023-05-03 18:38:58,733 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 227
2023-05-03 18:38:58,740 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 228
2023-05-03 18:38:58,748 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 229
2023-05-03 18:38:58,756 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 230
2023-05-03 18:38:58,763 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 231
2023-05-03 18:38:58,771 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 232
2023-05-03 18:38:58,779 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 233
2023-05-03 18:38:58,787 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 234
2023-05-03 18:38:58,794 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 235
2023-05-03 18:38:58,802 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 236
2023-05-03 18:38:58,810 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 237
2023-05-03 18:38:58,818 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 238
2023-05-03 18:38:58,826 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 239
2023-05-03 18:38:58,834 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 240
2023-05-03 18:38:58,842 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 241
2023-05-03 18:38:58,849 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 242
2023-05-03 18:38:58,856 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 243
2023-05-03 18:38:58,863 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 244
2023-05-03 18:38:58,870 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 245
2023-05-03 18:38:58,877 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 246
2023-05-03 18:38:58,884 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 247
2023-05-03 18:38:58,891 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 248
2023-05-03 18:38:58,898 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 249
2023-05-03 18:38:58,905 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 250
2023-05-03 18:38:58,912 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 251
2023-05-03 18:38:58,919 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 252
2023-05-03 18:38:58,927 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 253
2023-05-03 18:38:58,934 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 254
2023-05-03 18:38:58,942 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Writing partition 1, shard 255
2023-05-03 18:38:58,992 [INFO] iva.detectnet_v2.dataio.dataset_converter_lib:
b'menu': 7717
b'person': 45632
b'check': 6310
b'plate': 15951
b'table': 54083
2023-05-03 18:38:58,992 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Cumulative object statistics
b'menu': 10543
b'table': 66633
b'check': 8206
b'plate': 20348
b'person': 63896
2023-05-03 18:38:58,992 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Class map.
Label in GT: Label in tfrecords file
menu: menu
table: table
check: check
plate: plate
person: person
For the dataset_config in the experiment_spec, please use labels in the tfrecords file, while writing the classmap.
2023-05-03 18:38:58,992 [INFO] iva.detectnet_v2.dataio.coco_converter_lib: Tfrecords generation complete.
Telemetry data couldn't be sent, but the command ran successfully.
[WARNING]: <urlopen error [Errno -2] Name or service not known>
Execution status: PASS
2023-05-03 14:39:00,240 [INFO] tlt.components.docker_handler.docker_handler: Stopping container
The training logs :
2023-05-03 14:46:41,781 [INFO] root: Registry: ['nvcr.io']
2023-05-03 14:46:41,862 [INFO] tlt.components.instance_handler.local_instance: Running command in container: nvcr.io/nvidia/tao/tao-toolkit:4.0.0-tf1.15.5
2023-05-03 14:46:42,353 [WARNING] tlt.components.docker_handler.docker_handler:
terminal.
2023-05-03 18:46:43.101710: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libcudart.so.11.0
[1683139608.764434] [75ec5ecac3ab:230 :f] vfs_fuse.c:281 UCX ERROR inotify_add_watch(/tmp) failed: No space left on device
2023-05-03 18:46:49,910 [INFO] root: Starting DetectNet_v2 Training job
2023-05-03 18:46:49,911 [INFO] __main__: Loading experiment spec at /workspace/tao-experiments/detectnet_v2/specs/detectnet_v2_train_resnet18_coco.txt.
2023-05-03 18:46:49,913 [INFO] iva.detectnet_v2.spec_handler.spec_loader: Merging specification from /workspace/tao-experiments/detectnet_v2/specs/detectnet_v2_train_resnet18_coco.txt
2023-05-03 18:46:49,919 [INFO] root: Training gridbox model.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:153: The name tf.get_default_graph is deprecated. Please use tf.compat.v1.get_default_graph instead.
2023-05-03 18:46:49,919 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:153: The name tf.get_default_graph is deprecated. Please use tf.compat.v1.get_default_graph instead.
2023-05-03 18:46:51,724 [INFO] root: Sampling mode of the dataloader was set to user_defined.
2023-05-03 18:46:51,807 [INFO] root: Building DetectNet V2 model
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:517: The name tf.placeholder is deprecated. Please use tf.compat.v1.placeholder instead.
2023-05-03 18:46:51,807 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:517: The name tf.placeholder is deprecated. Please use tf.compat.v1.placeholder instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:4138: The name tf.random_uniform is deprecated. Please use tf.random.uniform instead.
2023-05-03 18:46:51,808 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:4138: The name tf.random_uniform is deprecated. Please use tf.random.uniform instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:1834: The name tf.nn.fused_batch_norm is deprecated. Please use tf.compat.v1.nn.fused_batch_norm instead.
2023-05-03 18:46:51,823 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:1834: The name tf.nn.fused_batch_norm is deprecated. Please use tf.compat.v1.nn.fused_batch_norm instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/third_party/keras/tensorflow_backend.py:187: The name tf.nn.avg_pool is deprecated. Please use tf.nn.avg_pool2d instead.
2023-05-03 18:46:52,630 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/third_party/keras/tensorflow_backend.py:187: The name tf.nn.avg_pool is deprecated. Please use tf.nn.avg_pool2d instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:174: The name tf.get_default_session is deprecated. Please use tf.compat.v1.get_default_session instead.
2023-05-03 18:46:52,783 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:174: The name tf.get_default_session is deprecated. Please use tf.compat.v1.get_default_session instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:190: The name tf.global_variables is deprecated. Please use tf.compat.v1.global_variables instead.
2023-05-03 18:46:52,783 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:190: The name tf.global_variables is deprecated. Please use tf.compat.v1.global_variables instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:199: The name tf.is_variable_initialized is deprecated. Please use tf.compat.v1.is_variable_initialized instead.
2023-05-03 18:46:52,783 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:199: The name tf.is_variable_initialized is deprecated. Please use tf.compat.v1.is_variable_initialized instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:206: The name tf.variables_initializer is deprecated. Please use tf.compat.v1.variables_initializer instead.
2023-05-03 18:46:53,126 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:206: The name tf.variables_initializer is deprecated. Please use tf.compat.v1.variables_initializer instead.
2023-05-03 18:47:00,738 [INFO] iva.detectnet_v2.objectives.bbox_objective: Default L1 loss function will be used.
__________________________________________________________________________________________________
Layer (type) Output Shape Param # Connected to
input_1 (InputLayer) (None, 3, 544, 960) 0
conv1 (Conv2D) (None, 64, 272, 480) 9472 input_1[0][0]
bn_conv1 (BatchNormalization) (None, 64, 272, 480) 256 conv1[0][0]
activation_1 (Activation) (None, 64, 272, 480) 0 bn_conv1[0][0]
block_1a_conv_1 (Conv2D) (None, 64, 136, 240) 36928 activation_1[0][0]
block_1a_bn_1 (BatchNormalizati (None, 64, 136, 240) 256 block_1a_conv_1[0][0]
block_1a_relu_1 (Activation) (None, 64, 136, 240) 0 block_1a_bn_1[0][0]
block_1a_conv_2 (Conv2D) (None, 64, 136, 240) 36928 block_1a_relu_1[0][0]
block_1a_conv_shortcut (Conv2D) (None, 64, 136, 240) 4160 activation_1[0][0]
block_1a_bn_2 (BatchNormalizati (None, 64, 136, 240) 256 block_1a_conv_2[0][0]
block_1a_bn_shortcut (BatchNorm (None, 64, 136, 240) 256 block_1a_conv_shortcut[0][0]
add_1 (Add) (None, 64, 136, 240) 0 block_1a_bn_2[0][0]
block_1a_bn_shortcut[0][0]
block_1a_relu (Activation) (None, 64, 136, 240) 0 add_1[0][0]
block_1b_conv_1 (Conv2D) (None, 64, 136, 240) 36928 block_1a_relu[0][0]
block_1b_bn_1 (BatchNormalizati (None, 64, 136, 240) 256 block_1b_conv_1[0][0]
block_1b_relu_1 (Activation) (None, 64, 136, 240) 0 block_1b_bn_1[0][0]
block_1b_conv_2 (Conv2D) (None, 64, 136, 240) 36928 block_1b_relu_1[0][0]
block_1b_conv_shortcut (Conv2D) (None, 64, 136, 240) 4160 block_1a_relu[0][0]
block_1b_bn_2 (BatchNormalizati (None, 64, 136, 240) 256 block_1b_conv_2[0][0]
block_1b_bn_shortcut (BatchNorm (None, 64, 136, 240) 256 block_1b_conv_shortcut[0][0]
add_2 (Add) (None, 64, 136, 240) 0 block_1b_bn_2[0][0]
block_1b_bn_shortcut[0][0]
block_1b_relu (Activation) (None, 64, 136, 240) 0 add_2[0][0]
block_2a_conv_1 (Conv2D) (None, 128, 68, 120) 73856 block_1b_relu[0][0]
block_2a_bn_1 (BatchNormalizati (None, 128, 68, 120) 512 block_2a_conv_1[0][0]
block_2a_relu_1 (Activation) (None, 128, 68, 120) 0 block_2a_bn_1[0][0]
block_2a_conv_2 (Conv2D) (None, 128, 68, 120) 147584 block_2a_relu_1[0][0]
block_2a_conv_shortcut (Conv2D) (None, 128, 68, 120) 8320 block_1b_relu[0][0]
block_2a_bn_2 (BatchNormalizati (None, 128, 68, 120) 512 block_2a_conv_2[0][0]
block_2a_bn_shortcut (BatchNorm (None, 128, 68, 120) 512 block_2a_conv_shortcut[0][0]
add_3 (Add) (None, 128, 68, 120) 0 block_2a_bn_2[0][0]
block_2a_bn_shortcut[0][0]
block_2a_relu (Activation) (None, 128, 68, 120) 0 add_3[0][0]
block_2b_conv_1 (Conv2D) (None, 128, 68, 120) 147584 block_2a_relu[0][0]
block_2b_bn_1 (BatchNormalizati (None, 128, 68, 120) 512 block_2b_conv_1[0][0]
block_2b_relu_1 (Activation) (None, 128, 68, 120) 0 block_2b_bn_1[0][0]
block_2b_conv_2 (Conv2D) (None, 128, 68, 120) 147584 block_2b_relu_1[0][0]
block_2b_conv_shortcut (Conv2D) (None, 128, 68, 120) 16512 block_2a_relu[0][0]
block_2b_bn_2 (BatchNormalizati (None, 128, 68, 120) 512 block_2b_conv_2[0][0]
block_2b_bn_shortcut (BatchNorm (None, 128, 68, 120) 512 block_2b_conv_shortcut[0][0]
add_4 (Add) (None, 128, 68, 120) 0 block_2b_bn_2[0][0]
block_2b_bn_shortcut[0][0]
block_2b_relu (Activation) (None, 128, 68, 120) 0 add_4[0][0]
block_3a_conv_1 (Conv2D) (None, 256, 34, 60) 295168 block_2b_relu[0][0]
block_3a_bn_1 (BatchNormalizati (None, 256, 34, 60) 1024 block_3a_conv_1[0][0]
block_3a_relu_1 (Activation) (None, 256, 34, 60) 0 block_3a_bn_1[0][0]
block_3a_conv_2 (Conv2D) (None, 256, 34, 60) 590080 block_3a_relu_1[0][0]
block_3a_conv_shortcut (Conv2D) (None, 256, 34, 60) 33024 block_2b_relu[0][0]
block_3a_bn_2 (BatchNormalizati (None, 256, 34, 60) 1024 block_3a_conv_2[0][0]
block_3a_bn_shortcut (BatchNorm (None, 256, 34, 60) 1024 block_3a_conv_shortcut[0][0]
add_5 (Add) (None, 256, 34, 60) 0 block_3a_bn_2[0][0]
block_3a_bn_shortcut[0][0]
block_3a_relu (Activation) (None, 256, 34, 60) 0 add_5[0][0]
block_3b_conv_1 (Conv2D) (None, 256, 34, 60) 590080 block_3a_relu[0][0]
block_3b_bn_1 (BatchNormalizati (None, 256, 34, 60) 1024 block_3b_conv_1[0][0]
block_3b_relu_1 (Activation) (None, 256, 34, 60) 0 block_3b_bn_1[0][0]
block_3b_conv_2 (Conv2D) (None, 256, 34, 60) 590080 block_3b_relu_1[0][0]
block_3b_conv_shortcut (Conv2D) (None, 256, 34, 60) 65792 block_3a_relu[0][0]
block_3b_bn_2 (BatchNormalizati (None, 256, 34, 60) 1024 block_3b_conv_2[0][0]
block_3b_bn_shortcut (BatchNorm (None, 256, 34, 60) 1024 block_3b_conv_shortcut[0][0]
add_6 (Add) (None, 256, 34, 60) 0 block_3b_bn_2[0][0]
block_3b_bn_shortcut[0][0]
block_3b_relu (Activation) (None, 256, 34, 60) 0 add_6[0][0]
block_4a_conv_1 (Conv2D) (None, 512, 34, 60) 1180160 block_3b_relu[0][0]
block_4a_bn_1 (BatchNormalizati (None, 512, 34, 60) 2048 block_4a_conv_1[0][0]
block_4a_relu_1 (Activation) (None, 512, 34, 60) 0 block_4a_bn_1[0][0]
block_4a_conv_2 (Conv2D) (None, 512, 34, 60) 2359808 block_4a_relu_1[0][0]
block_4a_conv_shortcut (Conv2D) (None, 512, 34, 60) 131584 block_3b_relu[0][0]
block_4a_bn_2 (BatchNormalizati (None, 512, 34, 60) 2048 block_4a_conv_2[0][0]
block_4a_bn_shortcut (BatchNorm (None, 512, 34, 60) 2048 block_4a_conv_shortcut[0][0]
add_7 (Add) (None, 512, 34, 60) 0 block_4a_bn_2[0][0]
block_4a_bn_shortcut[0][0]
block_4a_relu (Activation) (None, 512, 34, 60) 0 add_7[0][0]
block_4b_conv_1 (Conv2D) (None, 512, 34, 60) 2359808 block_4a_relu[0][0]
block_4b_bn_1 (BatchNormalizati (None, 512, 34, 60) 2048 block_4b_conv_1[0][0]
block_4b_relu_1 (Activation) (None, 512, 34, 60) 0 block_4b_bn_1[0][0]
block_4b_conv_2 (Conv2D) (None, 512, 34, 60) 2359808 block_4b_relu_1[0][0]
block_4b_conv_shortcut (Conv2D) (None, 512, 34, 60) 262656 block_4a_relu[0][0]
block_4b_bn_2 (BatchNormalizati (None, 512, 34, 60) 2048 block_4b_conv_2[0][0]
block_4b_bn_shortcut (BatchNorm (None, 512, 34, 60) 2048 block_4b_conv_shortcut[0][0]
add_8 (Add) (None, 512, 34, 60) 0 block_4b_bn_2[0][0]
block_4b_bn_shortcut[0][0]
block_4b_relu (Activation) (None, 512, 34, 60) 0 add_8[0][0]
output_bbox (Conv2D) (None, 20, 34, 60) 10260 block_4b_relu[0][0]
output_cov (Conv2D) (None, 5, 34, 60) 2565 block_4b_relu[0][0]
Total params: 11,561,113
Trainable params: 11,383,961
Non-trainable params: 177,152
2023-05-03 18:47:00,760 [INFO] root: DetectNet V2 model built.
2023-05-03 18:47:00,761 [INFO] root: Building rasterizer.
2023-05-03 18:47:00,761 [INFO] root: Rasterizers built.
2023-05-03 18:47:00,773 [INFO] root: Building training graph.
2023-05-03 18:47:00,774 [INFO] modulus.blocks.data_loaders.multi_source_loader.data_loader: Serial augmentation enabled = False
2023-05-03 18:47:00,774 [INFO] modulus.blocks.data_loaders.multi_source_loader.data_loader: Pseudo sharding enabled = False
2023-05-03 18:47:00,774 [INFO] modulus.blocks.data_loaders.multi_source_loader.data_loader: Max Image Dimensions (all sources): (0, 0)
2023-05-03 18:47:00,774 [INFO] modulus.blocks.data_loaders.multi_source_loader.data_loader: number of cpus: 48, io threads: 96, compute threads: 48, buffered batches: 4
2023-05-03 18:47:00,774 [INFO] modulus.blocks.data_loaders.multi_source_loader.data_loader: total dataset size 5764, number of sources: 1, batch size per gpu: 2, steps: 2882
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/tensorflow_core/python/autograph/converters/directives.py:119: The name tf.set_random_seed is deprecated. Please use tf.compat.v1.set_random_seed instead.
2023-05-03 18:47:00,806 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/tensorflow_core/python/autograph/converters/directives.py:119: The name tf.set_random_seed is deprecated. Please use tf.compat.v1.set_random_seed instead.
WARNING:tensorflow:Entity <bound method DriveNetTFRecordsParser.__call__ of <iva.detectnet_v2.dataloader.drivenet_dataloader.DriveNetTFRecordsParser object at 0x7ff5276b5278>> could not be transformed and will be executed as-is. Please report this to the AutoGraph team. When filing the bug, set the verbosity to 10 (on Linux, `export AUTOGRAPH_VERBOSITY=10`) and attach the full output. Cause: Unable to locate the source code of <bound method DriveNetTFRecordsParser.__call__ of <iva.detectnet_v2.dataloader.drivenet_dataloader.DriveNetTFRecordsParser object at 0x7ff5276b5278>>. Note that functions defined in certain environments, like the interactive Python shell do not expose their source code. If that is the case, you should to define them in a .py source file. If you are certain the code is graph-compatible, wrap the call using @tf.autograph.do_not_convert. Original error: could not get source code
2023-05-03 18:47:00,838 [WARNING] tensorflow: Entity <bound method DriveNetTFRecordsParser.__call__ of <iva.detectnet_v2.dataloader.drivenet_dataloader.DriveNetTFRecordsParser object at 0x7ff5276b5278>> could not be transformed and will be executed as-is. Please report this to the AutoGraph team. When filing the bug, set the verbosity to 10 (on Linux, `export AUTOGRAPH_VERBOSITY=10`) and attach the full output. Cause: Unable to locate the source code of <bound method DriveNetTFRecordsParser.__call__ of <iva.detectnet_v2.dataloader.drivenet_dataloader.DriveNetTFRecordsParser object at 0x7ff5276b5278>>. Note that functions defined in certain environments, like the interactive Python shell do not expose their source code. If that is the case, you should to define them in a .py source file. If you are certain the code is graph-compatible, wrap the call using @tf.autograph.do_not_convert. Original error: could not get source code
2023-05-03 18:47:00,852 [INFO] iva.detectnet_v2.dataloader.default_dataloader: Bounding box coordinates were detected in the input specification! Bboxes will be automatically converted to polygon coordinates.
2023-05-03 18:47:01,017 [INFO] modulus.blocks.data_loaders.multi_source_loader.data_loader: shuffle: True - shard 0 of 1
2023-05-03 18:47:01,022 [INFO] modulus.blocks.data_loaders.multi_source_loader.data_loader: sampling 1 datasets with weights:
2023-05-03 18:47:01,022 [INFO] modulus.blocks.data_loaders.multi_source_loader.data_loader: source: 0 weight: 1.000000
WARNING:tensorflow:Entity <bound method Processor.__call__ of <modulus.blocks.data_loaders.multi_source_loader.processors.asset_loader.AssetLoader object at 0x7ff44c7ddfd0>> could not be transformed and will be executed as-is. Please report this to the AutoGraph team. When filing the bug, set the verbosity to 10 (on Linux, `export AUTOGRAPH_VERBOSITY=10`) and attach the full output. Cause: Unable to locate the source code of <bound method Processor.__call__ of <modulus.blocks.data_loaders.multi_source_loader.processors.asset_loader.AssetLoader object at 0x7ff44c7ddfd0>>. Note that functions defined in certain environments, like the interactive Python shell do not expose their source code. If that is the case, you should to define them in a .py source file. If you are certain the code is graph-compatible, wrap the call using @tf.autograph.do_not_convert. Original error: could not get source code
2023-05-03 18:47:01,032 [WARNING] tensorflow: Entity <bound method Processor.__call__ of <modulus.blocks.data_loaders.multi_source_loader.processors.asset_loader.AssetLoader object at 0x7ff44c7ddfd0>> could not be transformed and will be executed as-is. Please report this to the AutoGraph team. When filing the bug, set the verbosity to 10 (on Linux, `export AUTOGRAPH_VERBOSITY=10`) and attach the full output. Cause: Unable to locate the source code of <bound method Processor.__call__ of <modulus.blocks.data_loaders.multi_source_loader.processors.asset_loader.AssetLoader object at 0x7ff44c7ddfd0>>. Note that functions defined in certain environments, like the interactive Python shell do not expose their source code. If that is the case, you should to define them in a .py source file. If you are certain the code is graph-compatible, wrap the call using @tf.autograph.do_not_convert. Original error: could not get source code
2023-05-03 18:47:01,277 [INFO] __main__: Found 5764 samples in training set
2023-05-03 18:47:01,281 [INFO] root: Rasterizing tensors.
2023-05-03 18:47:01,476 [INFO] root: Tensors rasterized.
2023-05-03 18:47:03,772 [INFO] root: Training graph built.
2023-05-03 18:47:03,772 [INFO] root: Building validation graph.
2023-05-03 18:47:03,773 [INFO] modulus.blocks.data_loaders.multi_source_loader.data_loader: Serial augmentation enabled = False
2023-05-03 18:47:03,773 [INFO] modulus.blocks.data_loaders.multi_source_loader.data_loader: Pseudo sharding enabled = False
2023-05-03 18:47:03,773 [INFO] modulus.blocks.data_loaders.multi_source_loader.data_loader: Max Image Dimensions (all sources): (0, 0)
2023-05-03 18:47:03,773 [INFO] modulus.blocks.data_loaders.multi_source_loader.data_loader: number of cpus: 48, io threads: 96, compute threads: 48, buffered batches: 4
2023-05-03 18:47:03,773 [INFO] modulus.blocks.data_loaders.multi_source_loader.data_loader: total dataset size 1982, number of sources: 1, batch size per gpu: 2, steps: 991
WARNING:tensorflow:Entity <bound method DriveNetTFRecordsParser.__call__ of <iva.detectnet_v2.dataloader.drivenet_dataloader.DriveNetTFRecordsParser object at 0x7ff527698940>> could not be transformed and will be executed as-is. Please report this to the AutoGraph team. When filing the bug, set the verbosity to 10 (on Linux, `export AUTOGRAPH_VERBOSITY=10`) and attach the full output. Cause: Unable to locate the source code of <bound method DriveNetTFRecordsParser.__call__ of <iva.detectnet_v2.dataloader.drivenet_dataloader.DriveNetTFRecordsParser object at 0x7ff527698940>>. Note that functions defined in certain environments, like the interactive Python shell do not expose their source code. If that is the case, you should to define them in a .py source file. If you are certain the code is graph-compatible, wrap the call using @tf.autograph.do_not_convert. Original error: could not get source code
2023-05-03 18:47:03,781 [WARNING] tensorflow: Entity <bound method DriveNetTFRecordsParser.__call__ of <iva.detectnet_v2.dataloader.drivenet_dataloader.DriveNetTFRecordsParser object at 0x7ff527698940>> could not be transformed and will be executed as-is. Please report this to the AutoGraph team. When filing the bug, set the verbosity to 10 (on Linux, `export AUTOGRAPH_VERBOSITY=10`) and attach the full output. Cause: Unable to locate the source code of <bound method DriveNetTFRecordsParser.__call__ of <iva.detectnet_v2.dataloader.drivenet_dataloader.DriveNetTFRecordsParser object at 0x7ff527698940>>. Note that functions defined in certain environments, like the interactive Python shell do not expose their source code. If that is the case, you should to define them in a .py source file. If you are certain the code is graph-compatible, wrap the call using @tf.autograph.do_not_convert. Original error: could not get source code
2023-05-03 18:47:03,794 [INFO] iva.detectnet_v2.dataloader.default_dataloader: Bounding box coordinates were detected in the input specification! Bboxes will be automatically converted to polygon coordinates.
2023-05-03 18:47:03,946 [INFO] modulus.blocks.data_loaders.multi_source_loader.data_loader: shuffle: False - shard 0 of 1
2023-05-03 18:47:03,949 [INFO] modulus.blocks.data_loaders.multi_source_loader.data_loader: sampling 1 datasets with weights:
2023-05-03 18:47:03,949 [INFO] modulus.blocks.data_loaders.multi_source_loader.data_loader: source: 0 weight: 1.000000
WARNING:tensorflow:Entity <bound method Processor.__call__ of <modulus.blocks.data_loaders.multi_source_loader.processors.asset_loader.AssetLoader object at 0x7ff3cc611fd0>> could not be transformed and will be executed as-is. Please report this to the AutoGraph team. When filing the bug, set the verbosity to 10 (on Linux, `export AUTOGRAPH_VERBOSITY=10`) and attach the full output. Cause: Unable to locate the source code of <bound method Processor.__call__ of <modulus.blocks.data_loaders.multi_source_loader.processors.asset_loader.AssetLoader object at 0x7ff3cc611fd0>>. Note that functions defined in certain environments, like the interactive Python shell do not expose their source code. If that is the case, you should to define them in a .py source file. If you are certain the code is graph-compatible, wrap the call using @tf.autograph.do_not_convert. Original error: could not get source code
2023-05-03 18:47:03,960 [WARNING] tensorflow: Entity <bound method Processor.__call__ of <modulus.blocks.data_loaders.multi_source_loader.processors.asset_loader.AssetLoader object at 0x7ff3cc611fd0>> could not be transformed and will be executed as-is. Please report this to the AutoGraph team. When filing the bug, set the verbosity to 10 (on Linux, `export AUTOGRAPH_VERBOSITY=10`) and attach the full output. Cause: Unable to locate the source code of <bound method Processor.__call__ of <modulus.blocks.data_loaders.multi_source_loader.processors.asset_loader.AssetLoader object at 0x7ff3cc611fd0>>. Note that functions defined in certain environments, like the interactive Python shell do not expose their source code. If that is the case, you should to define them in a .py source file. If you are certain the code is graph-compatible, wrap the call using @tf.autograph.do_not_convert. Original error: could not get source code
2023-05-03 18:47:04,112 [INFO] __main__: Found 1982 samples in validation set
2023-05-03 18:47:04,112 [INFO] root: Rasterizing tensors.
2023-05-03 18:47:04,269 [INFO] root: Tensors rasterized.
2023-05-03 18:47:04,550 [INFO] root: Validation graph built.
2023-05-03 18:47:06,102 [INFO] root: Running training loop.
2023-05-03 18:47:06,102 [INFO] __main__: Checkpoint interval: 10
2023-05-03 18:47:06,103 [INFO] __main__: Scalars logged at every 288 steps
2023-05-03 18:47:06,103 [INFO] __main__: Images logged at every 2882 steps
INFO:tensorflow:Create CheckpointSaverHook.
2023-05-03 18:47:06,105 [INFO] tensorflow: Create CheckpointSaverHook.
INFO:tensorflow:Graph was finalized.
2023-05-03 18:47:08,009 [INFO] tensorflow: Graph was finalized.
INFO:tensorflow:Running local_init_op.
2023-05-03 18:47:10,066 [INFO] tensorflow: Running local_init_op.
INFO:tensorflow:Done running local_init_op.
2023-05-03 18:47:10,653 [INFO] tensorflow: Done running local_init_op.
INFO:tensorflow:Saving checkpoints for step-0.
2023-05-03 18:47:17,599 [INFO] tensorflow: Saving checkpoints for step-0.
INFO:tensorflow:epoch = 0.0, learning_rate = 4.9999994e-06, loss = 0.098450065, step = 0
2023-05-03 18:48:03,569 [INFO] tensorflow: epoch = 0.0, learning_rate = 4.9999994e-06, loss = 0.098450065, step = 0
2023-05-03 18:48:03,576 [INFO] root: None
2023-05-03 18:48:03,594 [INFO] iva.detectnet_v2.tfhooks.task_progress_monitor_hook: Epoch 0/120: loss: 0.09845 learning rate: 0.00000 Time taken: 0:00:00 ETA: 0:00:00
2023-05-03 18:48:03,594 [INFO] modulus.hooks.sample_counter_hook: Train Samples / sec: 0.071
2023-05-03 18:48:06,263 [INFO] modulus.hooks.sample_counter_hook: Train Samples / sec: 1.623
2023-05-03 18:48:07,220 [INFO] modulus.hooks.sample_counter_hook: Train Samples / sec: 52.261
2023-05-03 18:48:08,186 [INFO] modulus.hooks.sample_counter_hook: Train Samples / sec: 51.776
INFO:tensorflow:epoch = 0.029493407356002775, learning_rate = 5.0569115e-06, loss = 0.06569926, step = 85 (5.038 sec)
2023-05-03 18:48:08,608 [INFO] tensorflow: epoch = 0.029493407356002775, learning_rate = 5.0569115e-06, loss = 0.06569926, step = 85 (5.038 sec)
2023-05-03 18:48:09,150 [INFO] modulus.hooks.sample_counter_hook: Train Samples / sec: 51.913
2023-05-03 18:48:10,111 [INFO] modulus.hooks.sample_counter_hook: Train Samples / sec: 52.055
2023-05-03 18:48:11,071 [INFO] modulus.hooks.sample_counter_hook: Train Samples / sec: 52.052
2023-05-03 18:48:12,027 [INFO] modulus.hooks.sample_counter_hook: Train Samples / sec: 52.321
2023-05-03 18:48:12,978 [INFO] modulus.hooks.sample_counter_hook: Train Samples / sec: 52.576
INFO:tensorflow:epoch = 0.07529493407356003, learning_rate = 5.1465836e-06, loss = 0.03726593, step = 217 (5.064 sec)
2023-05-03 18:48:13,671 [INFO] tensorflow: epoch = 0.07529493407356003, learning_rate = 5.1465836e-06, loss = 0.03726593, step = 217 (5.064 sec)
2023-05-03 18:48:13,939 [INFO] modulus.hooks.sample_counter_hook: Train Samples / sec: 52.071
2023-05-03 18:48:14,895 [INFO] modulus.hooks.sample_counter_hook: Train Samples / sec: 52.320
2023-05-03 18:48:15,855 [INFO] modulus.hooks.sample_counter_hook: Train Samples / sec: 52.092
INFO:tensorflow:global_step/sec: 19.788
2023-05-03 18:48:18,125 [INFO] tensorflow: global_step/sec: 19.788
2023-05-03 18:48:18,553 [INFO] modulus.hooks.sample_counter_hook: Train Samples / sec: 18.532
INFO:tensorflow:epoch = 0.10548230395558639, learning_rate = 5.2065548e-06, loss = 0.022609862, step = 304 (5.076 sec)
2023-05-03 18:48:18,747 [INFO] tensorflow: epoch = 0.10548230395558639, learning_rate = 5.2065548e-06, loss = 0.022609862, step = 304 (5.076 sec)
2023-05-03 18:48:19,519 [INFO] modulus.hooks.sample_counter_hook: Train Samples / sec: 51.770
2023-05-03 18:48:20,480 [INFO] modulus.hooks.sample_counter_hook: Train Samples / sec: 52.070
2023-05-03 18:48:21,435 [INFO] modulus.hooks.sample_counter_hook: Train Samples / sec: 52.338
2023-05-03 18:48:22,398 [INFO] modulus.hooks.sample_counter_hook: Train Samples / sec: 51.962
2023-05-03 18:48:23,360 [INFO] modulus.hooks.sample_counter_hook: Train Samples / sec: 52.013
INFO:tensorflow:epoch = 0.15128383067314363, learning_rate = 5.2988803e-06, loss = 0.014012933, step = 436 (5.071 sec)
2023-05-03 18:48:23,818 [INFO] tensorflow: epoch = 0.15128383067314363, learning_rate = 5.2988803e-06, loss = 0.014012933, step = 436 (5.071 sec)
2023-05-03 18:48:24,323 [INFO] modulus.hooks.sample_counter_hook: Train Samples / sec: 51.922
2023-05-03 18:48:25,289 [INFO] modulus.hooks.sample_counter_hook: Train Samples / sec: 51.750
2023-05-03 18:48:26,251 [INFO] modulus.hooks.sample_counter_hook: Train Samples / sec: 52.009
2023-05-03 18:48:27,207 [INFO] modulus.hooks.sample_counter_hook: Train Samples / sec: 52.325
2023-05-03 18:48:28,167 [INFO] modulus.hooks.sample_counter_hook: Train Samples / sec: 52.106
INFO:tensorflow:epoch = 0.1967383761276891, learning_rate = 5.3921226e-06, loss = 0.00902343, step = 567 (5.042 sec)
2023-05-03 18:48:28,861 [INFO] tensorflow: epoch = 0.1967383761276891, learning_rate = 5.3921226e-06, loss = 0.00902343, step = 567 (5.042 sec)
2023-05-03 18:48:29,131 [INFO] modulus.hooks.sample_counter_hook: Train Samples / sec: 51.869
INFO:tensorflow:global_step/sec: 25.9738
2023-05-03 18:48:29,213 [INFO] tensorflow: global_step/sec: 25.9738
2023-05-03 18:48:30,096 [INFO] modulus.hooks.sample_counter_hook: Train Samples / sec: 51.844
2023-05-03 18:48:31,065 [INFO] modulus.hooks.sample_counter_hook: Train Samples / sec: 51.619
2023-05-03 18:48:32,028 [INFO] modulus.hooks.sample_counter_hook: Train Samples / sec: 51.934
2023-05-03 18:48:32,988 [INFO] modulus.hooks.sample_counter_hook: Train Samples / sec: 52.087
INFO:tensorflow:epoch = 0.24219292158223454, learning_rate = 5.4870065e-06, loss = 0.007546805, step = 698 (5.047 sec)
I have also added super categories in the json.
