after doing this, it still can’t work.
when running !tao detectnet_v2 train, it prints:
2022-02-16 15:07:22,015 [INFO] root: Registry: ['nvcr.io']
2022-02-16 15:07:22,180 [INFO] tlt.components.instance_handler.local_instance: Running command in container: nvcr.io/nvidia/tao/tao-toolkit-tf:v3.21.11-tf1.15.4-py3
2022-02-16 15:07:22,822 [WARNING] tlt.components.docker_handler.docker_handler:
Docker will run the commands as root. If you would like to retain your
local host permissions, please add the "user":"UID:GID" in the
DockerOptions portion of the "/root/.tao_mounts.json" file. You can obtain your
users UID and GID by using the "id -u" and "id -g" commands on the
terminal.
Using TensorFlow backend.
WARNING:tensorflow:Deprecation warnings have been disabled. Set TF_ENABLE_DEPRECATION_WARNINGS=1 to re-enable them.
WARNING:tensorflow:From /opt/tlt/.cache/dazel/_dazel_tlt/75913d2aee35770fa76c4a63d877f3aa/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/cost_function/cost_auto_weight_hook.py:43: The name tf.train.SessionRunHook is deprecated. Please use tf.estimator.SessionRunHook instead.
2022-02-16 07:07:31,654 [WARNING] tensorflow: From /opt/tlt/.cache/dazel/_dazel_tlt/75913d2aee35770fa76c4a63d877f3aa/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/cost_function/cost_auto_weight_hook.py:43: The name tf.train.SessionRunHook is deprecated. Please use tf.estimator.SessionRunHook instead.
WARNING:tensorflow:From /opt/tlt/.cache/dazel/_dazel_tlt/75913d2aee35770fa76c4a63d877f3aa/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/tfhooks/checkpoint_saver_hook.py:25: The name tf.train.CheckpointSaverHook is deprecated. Please use tf.estimator.CheckpointSaverHook instead.
2022-02-16 07:07:31,776 [WARNING] tensorflow: From /opt/tlt/.cache/dazel/_dazel_tlt/75913d2aee35770fa76c4a63d877f3aa/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/tfhooks/checkpoint_saver_hook.py:25: The name tf.train.CheckpointSaverHook is deprecated. Please use tf.estimator.CheckpointSaverHook instead.
WARNING:tensorflow:From /opt/tlt/.cache/dazel/_dazel_tlt/75913d2aee35770fa76c4a63d877f3aa/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/scripts/train.py:69: The name tf.logging.set_verbosity is deprecated. Please use tf.compat.v1.logging.set_verbosity instead.
2022-02-16 07:07:31,778 [WARNING] tensorflow: From /opt/tlt/.cache/dazel/_dazel_tlt/75913d2aee35770fa76c4a63d877f3aa/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/scripts/train.py:69: The name tf.logging.set_verbosity is deprecated. Please use tf.compat.v1.logging.set_verbosity instead.
WARNING:tensorflow:From /opt/tlt/.cache/dazel/_dazel_tlt/75913d2aee35770fa76c4a63d877f3aa/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/scripts/train.py:69: The name tf.logging.INFO is deprecated. Please use tf.compat.v1.logging.INFO instead.
2022-02-16 07:07:31,779 [WARNING] tensorflow: From /opt/tlt/.cache/dazel/_dazel_tlt/75913d2aee35770fa76c4a63d877f3aa/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/scripts/train.py:69: The name tf.logging.INFO is deprecated. Please use tf.compat.v1.logging.INFO instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/horovod/tensorflow/__init__.py:117: The name tf.global_variables is deprecated. Please use tf.compat.v1.global_variables instead.
2022-02-16 07:07:31,787 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/horovod/tensorflow/__init__.py:117: The name tf.global_variables is deprecated. Please use tf.compat.v1.global_variables instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/horovod/tensorflow/__init__.py:143: The name tf.get_default_graph is deprecated. Please use tf.compat.v1.get_default_graph instead.
2022-02-16 07:07:31,787 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/horovod/tensorflow/__init__.py:143: The name tf.get_default_graph is deprecated. Please use tf.compat.v1.get_default_graph instead.
2022-02-16 07:07:33,022 [INFO] iva.common.logging.logging: Log file already exists at /workspace/tao-experiments/detectnet_v2/experiment_dir_unpruned/status.json
2022-02-16 07:07:33,023 [INFO] __main__: Loading experiment spec at /workspace/tao-experiments/detectnet_v2/specs/detectnet_v2_train_resnet18_kitti.txt.
2022-02-16 07:07:33,028 [INFO] iva.detectnet_v2.spec_handler.spec_loader: Merging specification from /workspace/tao-experiments/detectnet_v2/specs/detectnet_v2_train_resnet18_kitti.txt
2022-02-16 07:07:33,271 [INFO] __main__: Cannot iterate over exactly 327 samples with a batch size of 4; each epoch will therefore take one extra step.
WARNING:tensorflow:From /opt/tlt/.cache/dazel/_dazel_tlt/75913d2aee35770fa76c4a63d877f3aa/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/cost_function/cost_auto_weight_hook.py:107: The name tf.variable_scope is deprecated. Please use tf.compat.v1.variable_scope instead.
2022-02-16 07:07:33,274 [WARNING] tensorflow: From /opt/tlt/.cache/dazel/_dazel_tlt/75913d2aee35770fa76c4a63d877f3aa/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/cost_function/cost_auto_weight_hook.py:107: The name tf.variable_scope is deprecated. Please use tf.compat.v1.variable_scope instead.
WARNING:tensorflow:From /opt/tlt/.cache/dazel/_dazel_tlt/75913d2aee35770fa76c4a63d877f3aa/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/cost_function/cost_auto_weight_hook.py:110: The name tf.get_variable is deprecated. Please use tf.compat.v1.get_variable instead.
2022-02-16 07:07:33,274 [WARNING] tensorflow: From /opt/tlt/.cache/dazel/_dazel_tlt/75913d2aee35770fa76c4a63d877f3aa/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/cost_function/cost_auto_weight_hook.py:110: The name tf.get_variable is deprecated. Please use tf.compat.v1.get_variable instead.
WARNING:tensorflow:From /opt/tlt/.cache/dazel/_dazel_tlt/75913d2aee35770fa76c4a63d877f3aa/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/cost_function/cost_auto_weight_hook.py:113: The name tf.assign is deprecated. Please use tf.compat.v1.assign instead.
2022-02-16 07:07:33,277 [WARNING] tensorflow: From /opt/tlt/.cache/dazel/_dazel_tlt/75913d2aee35770fa76c4a63d877f3aa/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/cost_function/cost_auto_weight_hook.py:113: The name tf.assign is deprecated. Please use tf.compat.v1.assign instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:517: The name tf.placeholder is deprecated. Please use tf.compat.v1.placeholder instead.
2022-02-16 07:07:33,305 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:517: The name tf.placeholder is deprecated. Please use tf.compat.v1.placeholder instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:4138: The name tf.random_uniform is deprecated. Please use tf.random.uniform instead.
2022-02-16 07:07:33,307 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:4138: The name tf.random_uniform is deprecated. Please use tf.random.uniform instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:1834: The name tf.nn.fused_batch_norm is deprecated. Please use tf.compat.v1.nn.fused_batch_norm instead.
2022-02-16 07:07:33,334 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:1834: The name tf.nn.fused_batch_norm is deprecated. Please use tf.compat.v1.nn.fused_batch_norm instead.
WARNING:tensorflow:From /opt/nvidia/third_party/keras/tensorflow_backend.py:187: The name tf.nn.avg_pool is deprecated. Please use tf.nn.avg_pool2d instead.
2022-02-16 07:07:34,723 [WARNING] tensorflow: From /opt/nvidia/third_party/keras/tensorflow_backend.py:187: The name tf.nn.avg_pool is deprecated. Please use tf.nn.avg_pool2d instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:174: The name tf.get_default_session is deprecated. Please use tf.compat.v1.get_default_session instead.
2022-02-16 07:07:35,039 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:174: The name tf.get_default_session is deprecated. Please use tf.compat.v1.get_default_session instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:199: The name tf.is_variable_initialized is deprecated. Please use tf.compat.v1.is_variable_initialized instead.
2022-02-16 07:07:35,040 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:199: The name tf.is_variable_initialized is deprecated. Please use tf.compat.v1.is_variable_initialized instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:206: The name tf.variables_initializer is deprecated. Please use tf.compat.v1.variables_initializer instead.
2022-02-16 07:07:35,419 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:206: The name tf.variables_initializer is deprecated. Please use tf.compat.v1.variables_initializer instead.
2022-02-16 07:07:44,398 [INFO] iva.detectnet_v2.objectives.bbox_objective: Default L1 loss function will be used.
__________________________________________________________________________________________________
Layer (type) Output Shape Param # Connected to
input_1 (InputLayer) (None, 3, 3024, 4032 0
conv1 (Conv2D) (None, 64, 1512, 201 9472 input_1[0][0]
bn_conv1 (BatchNormalization) (None, 64, 1512, 201 256 conv1[0][0]
activation_1 (Activation) (None, 64, 1512, 201 0 bn_conv1[0][0]
block_1a_conv_1 (Conv2D) (None, 64, 756, 1008 36928 activation_1[0][0]
block_1a_bn_1 (BatchNormalizati (None, 64, 756, 1008 256 block_1a_conv_1[0][0]
block_1a_relu_1 (Activation) (None, 64, 756, 1008 0 block_1a_bn_1[0][0]
block_1a_conv_2 (Conv2D) (None, 64, 756, 1008 36928 block_1a_relu_1[0][0]
block_1a_conv_shortcut (Conv2D) (None, 64, 756, 1008 4160 activation_1[0][0]
block_1a_bn_2 (BatchNormalizati (None, 64, 756, 1008 256 block_1a_conv_2[0][0]
block_1a_bn_shortcut (BatchNorm (None, 64, 756, 1008 256 block_1a_conv_shortcut[0][0]
add_1 (Add) (None, 64, 756, 1008 0 block_1a_bn_2[0][0]
block_1a_bn_shortcut[0][0]
block_1a_relu (Activation) (None, 64, 756, 1008 0 add_1[0][0]
block_1b_conv_1 (Conv2D) (None, 64, 756, 1008 36928 block_1a_relu[0][0]
block_1b_bn_1 (BatchNormalizati (None, 64, 756, 1008 256 block_1b_conv_1[0][0]
block_1b_relu_1 (Activation) (None, 64, 756, 1008 0 block_1b_bn_1[0][0]
block_1b_conv_2 (Conv2D) (None, 64, 756, 1008 36928 block_1b_relu_1[0][0]
block_1b_bn_2 (BatchNormalizati (None, 64, 756, 1008 256 block_1b_conv_2[0][0]
add_2 (Add) (None, 64, 756, 1008 0 block_1b_bn_2[0][0]
block_1a_relu[0][0]
block_1b_relu (Activation) (None, 64, 756, 1008 0 add_2[0][0]
block_2a_conv_1 (Conv2D) (None, 128, 378, 504 73856 block_1b_relu[0][0]
block_2a_bn_1 (BatchNormalizati (None, 128, 378, 504 512 block_2a_conv_1[0][0]
block_2a_relu_1 (Activation) (None, 128, 378, 504 0 block_2a_bn_1[0][0]
block_2a_conv_2 (Conv2D) (None, 128, 378, 504 147584 block_2a_relu_1[0][0]
block_2a_conv_shortcut (Conv2D) (None, 128, 378, 504 8320 block_1b_relu[0][0]
block_2a_bn_2 (BatchNormalizati (None, 128, 378, 504 512 block_2a_conv_2[0][0]
block_2a_bn_shortcut (BatchNorm (None, 128, 378, 504 512 block_2a_conv_shortcut[0][0]
add_3 (Add) (None, 128, 378, 504 0 block_2a_bn_2[0][0]
block_2a_bn_shortcut[0][0]
block_2a_relu (Activation) (None, 128, 378, 504 0 add_3[0][0]
block_2b_conv_1 (Conv2D) (None, 128, 378, 504 147584 block_2a_relu[0][0]
block_2b_bn_1 (BatchNormalizati (None, 128, 378, 504 512 block_2b_conv_1[0][0]
block_2b_relu_1 (Activation) (None, 128, 378, 504 0 block_2b_bn_1[0][0]
block_2b_conv_2 (Conv2D) (None, 128, 378, 504 147584 block_2b_relu_1[0][0]
block_2b_bn_2 (BatchNormalizati (None, 128, 378, 504 512 block_2b_conv_2[0][0]
add_4 (Add) (None, 128, 378, 504 0 block_2b_bn_2[0][0]
block_2a_relu[0][0]
block_2b_relu (Activation) (None, 128, 378, 504 0 add_4[0][0]
block_3a_conv_1 (Conv2D) (None, 256, 189, 252 295168 block_2b_relu[0][0]
block_3a_bn_1 (BatchNormalizati (None, 256, 189, 252 1024 block_3a_conv_1[0][0]
block_3a_relu_1 (Activation) (None, 256, 189, 252 0 block_3a_bn_1[0][0]
block_3a_conv_2 (Conv2D) (None, 256, 189, 252 590080 block_3a_relu_1[0][0]
block_3a_conv_shortcut (Conv2D) (None, 256, 189, 252 33024 block_2b_relu[0][0]
block_3a_bn_2 (BatchNormalizati (None, 256, 189, 252 1024 block_3a_conv_2[0][0]
block_3a_bn_shortcut (BatchNorm (None, 256, 189, 252 1024 block_3a_conv_shortcut[0][0]
add_5 (Add) (None, 256, 189, 252 0 block_3a_bn_2[0][0]
block_3a_bn_shortcut[0][0]
block_3a_relu (Activation) (None, 256, 189, 252 0 add_5[0][0]
block_3b_conv_1 (Conv2D) (None, 256, 189, 252 590080 block_3a_relu[0][0]
block_3b_bn_1 (BatchNormalizati (None, 256, 189, 252 1024 block_3b_conv_1[0][0]
block_3b_relu_1 (Activation) (None, 256, 189, 252 0 block_3b_bn_1[0][0]
block_3b_conv_2 (Conv2D) (None, 256, 189, 252 590080 block_3b_relu_1[0][0]
block_3b_bn_2 (BatchNormalizati (None, 256, 189, 252 1024 block_3b_conv_2[0][0]
add_6 (Add) (None, 256, 189, 252 0 block_3b_bn_2[0][0]
block_3a_relu[0][0]
block_3b_relu (Activation) (None, 256, 189, 252 0 add_6[0][0]
block_4a_conv_1 (Conv2D) (None, 512, 189, 252 1180160 block_3b_relu[0][0]
block_4a_bn_1 (BatchNormalizati (None, 512, 189, 252 2048 block_4a_conv_1[0][0]
block_4a_relu_1 (Activation) (None, 512, 189, 252 0 block_4a_bn_1[0][0]
block_4a_conv_2 (Conv2D) (None, 512, 189, 252 2359808 block_4a_relu_1[0][0]
block_4a_conv_shortcut (Conv2D) (None, 512, 189, 252 131584 block_3b_relu[0][0]
block_4a_bn_2 (BatchNormalizati (None, 512, 189, 252 2048 block_4a_conv_2[0][0]
block_4a_bn_shortcut (BatchNorm (None, 512, 189, 252 2048 block_4a_conv_shortcut[0][0]
add_7 (Add) (None, 512, 189, 252 0 block_4a_bn_2[0][0]
block_4a_bn_shortcut[0][0]
block_4a_relu (Activation) (None, 512, 189, 252 0 add_7[0][0]
block_4b_conv_1 (Conv2D) (None, 512, 189, 252 2359808 block_4a_relu[0][0]
block_4b_bn_1 (BatchNormalizati (None, 512, 189, 252 2048 block_4b_conv_1[0][0]
block_4b_relu_1 (Activation) (None, 512, 189, 252 0 block_4b_bn_1[0][0]
block_4b_conv_2 (Conv2D) (None, 512, 189, 252 2359808 block_4b_relu_1[0][0]
block_4b_bn_2 (BatchNormalizati (None, 512, 189, 252 2048 block_4b_conv_2[0][0]
add_8 (Add) (None, 512, 189, 252 0 block_4b_bn_2[0][0]
block_4a_relu[0][0]
block_4b_relu (Activation) (None, 512, 189, 252 0 add_8[0][0]
output_bbox (Conv2D) (None, 4, 189, 252) 2052 block_4b_relu[0][0]
output_cov (Conv2D) (None, 1, 189, 252) 513 block_4b_relu[0][0]
Total params: 11,197,893
Trainable params: 11,188,165
Non-trainable params: 9,728
2022-02-16 07:07:44,442 [INFO] modulus.blocks.data_loaders.multi_source_loader.data_loader: Serial augmentation enabled = False
2022-02-16 07:07:44,442 [INFO] modulus.blocks.data_loaders.multi_source_loader.data_loader: Pseudo sharding enabled = False
2022-02-16 07:07:44,443 [INFO] modulus.blocks.data_loaders.multi_source_loader.data_loader: Max Image Dimensions (all sources): (0, 0)
2022-02-16 07:07:44,443 [INFO] modulus.blocks.data_loaders.multi_source_loader.data_loader: number of cpus: 48, io threads: 96, compute threads: 48, buffered batches: 4
2022-02-16 07:07:44,443 [INFO] modulus.blocks.data_loaders.multi_source_loader.data_loader: total dataset size 327, number of sources: 1, batch size per gpu: 4, steps: 82
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/tensorflow_core/python/autograph/converters/directives.py:119: The name tf.set_random_seed is deprecated. Please use tf.compat.v1.set_random_seed instead.
2022-02-16 07:07:44,499 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/tensorflow_core/python/autograph/converters/directives.py:119: The name tf.set_random_seed is deprecated. Please use tf.compat.v1.set_random_seed instead.
WARNING:tensorflow:Entity <bound method DriveNetTFRecordsParser.__call__ of <iva.detectnet_v2.dataloader.drivenet_dataloader.DriveNetTFRecordsParser object at 0x7f06e6b72518>> could not be transformed and will be executed as-is. Please report this to the AutoGraph team. When filing the bug, set the verbosity to 10 (on Linux, `export AUTOGRAPH_VERBOSITY=10`) and attach the full output. Cause: Unable to locate the source code of <bound method DriveNetTFRecordsParser.__call__ of <iva.detectnet_v2.dataloader.drivenet_dataloader.DriveNetTFRecordsParser object at 0x7f06e6b72518>>. Note that functions defined in certain environments, like the interactive Python shell do not expose their source code. If that is the case, you should to define them in a .py source file. If you are certain the code is graph-compatible, wrap the call using @tf.autograph.do_not_convert. Original error: could not get source code
2022-02-16 07:07:44,559 [WARNING] tensorflow: Entity <bound method DriveNetTFRecordsParser.__call__ of <iva.detectnet_v2.dataloader.drivenet_dataloader.DriveNetTFRecordsParser object at 0x7f06e6b72518>> could not be transformed and will be executed as-is. Please report this to the AutoGraph team. When filing the bug, set the verbosity to 10 (on Linux, `export AUTOGRAPH_VERBOSITY=10`) and attach the full output. Cause: Unable to locate the source code of <bound method DriveNetTFRecordsParser.__call__ of <iva.detectnet_v2.dataloader.drivenet_dataloader.DriveNetTFRecordsParser object at 0x7f06e6b72518>>. Note that functions defined in certain environments, like the interactive Python shell do not expose their source code. If that is the case, you should to define them in a .py source file. If you are certain the code is graph-compatible, wrap the call using @tf.autograph.do_not_convert. Original error: could not get source code
2022-02-16 07:07:44,584 [INFO] iva.detectnet_v2.dataloader.default_dataloader: Bounding box coordinates were detected in the input specification! Bboxes will be automatically converted to polygon coordinates.
2022-02-16 07:07:44,892 [INFO] modulus.blocks.data_loaders.multi_source_loader.data_loader: shuffle: True - shard 0 of 1
2022-02-16 07:07:44,900 [INFO] modulus.blocks.data_loaders.multi_source_loader.data_loader: sampling 1 datasets with weights:
2022-02-16 07:07:44,900 [INFO] modulus.blocks.data_loaders.multi_source_loader.data_loader: source: 0 weight: 1.000000
WARNING:tensorflow:Entity <bound method Processor.__call__ of <modulus.blocks.data_loaders.multi_source_loader.processors.asset_loader.AssetLoader object at 0x7f07707ec860>> could not be transformed and will be executed as-is. Please report this to the AutoGraph team. When filing the bug, set the verbosity to 10 (on Linux, `export AUTOGRAPH_VERBOSITY=10`) and attach the full output. Cause: Unable to locate the source code of <bound method Processor.__call__ of <modulus.blocks.data_loaders.multi_source_loader.processors.asset_loader.AssetLoader object at 0x7f07707ec860>>. Note that functions defined in certain environments, like the interactive Python shell do not expose their source code. If that is the case, you should to define them in a .py source file. If you are certain the code is graph-compatible, wrap the call using @tf.autograph.do_not_convert. Original error: could not get source code
2022-02-16 07:07:44,918 [WARNING] tensorflow: Entity <bound method Processor.__call__ of <modulus.blocks.data_loaders.multi_source_loader.processors.asset_loader.AssetLoader object at 0x7f07707ec860>> could not be transformed and will be executed as-is. Please report this to the AutoGraph team. When filing the bug, set the verbosity to 10 (on Linux, `export AUTOGRAPH_VERBOSITY=10`) and attach the full output. Cause: Unable to locate the source code of <bound method Processor.__call__ of <modulus.blocks.data_loaders.multi_source_loader.processors.asset_loader.AssetLoader object at 0x7f07707ec860>>. Note that functions defined in certain environments, like the interactive Python shell do not expose their source code. If that is the case, you should to define them in a .py source file. If you are certain the code is graph-compatible, wrap the call using @tf.autograph.do_not_convert. Original error: could not get source code
2022-02-16 07:07:45,357 [INFO] __main__: Found 327 samples in training set
WARNING:tensorflow:From /opt/tlt/.cache/dazel/_dazel_tlt/75913d2aee35770fa76c4a63d877f3aa/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/rasterizers/bbox_rasterizer.py:347: The name tf.bincount is deprecated. Please use tf.math.bincount instead.
2022-02-16 07:07:45,482 [WARNING] tensorflow: From /opt/tlt/.cache/dazel/_dazel_tlt/75913d2aee35770fa76c4a63d877f3aa/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/rasterizers/bbox_rasterizer.py:347: The name tf.bincount is deprecated. Please use tf.math.bincount instead.
WARNING:tensorflow:From /opt/tlt/.cache/dazel/_dazel_tlt/75913d2aee35770fa76c4a63d877f3aa/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/training/training_proto_utilities.py:89: The name tf.train.get_or_create_global_step is deprecated. Please use tf.compat.v1.train.get_or_create_global_step instead.
2022-02-16 07:07:45,608 [WARNING] tensorflow: From /opt/tlt/.cache/dazel/_dazel_tlt/75913d2aee35770fa76c4a63d877f3aa/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/training/training_proto_utilities.py:89: The name tf.train.get_or_create_global_step is deprecated. Please use tf.compat.v1.train.get_or_create_global_step instead.
WARNING:tensorflow:From /opt/tlt/.cache/dazel/_dazel_tlt/75913d2aee35770fa76c4a63d877f3aa/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/training/training_proto_utilities.py:36: The name tf.train.AdamOptimizer is deprecated. Please use tf.compat.v1.train.AdamOptimizer instead.
2022-02-16 07:07:45,626 [WARNING] tensorflow: From /opt/tlt/.cache/dazel/_dazel_tlt/75913d2aee35770fa76c4a63d877f3aa/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/training/training_proto_utilities.py:36: The name tf.train.AdamOptimizer is deprecated. Please use tf.compat.v1.train.AdamOptimizer instead.
WARNING:tensorflow:From /opt/tlt/.cache/dazel/_dazel_tlt/75913d2aee35770fa76c4a63d877f3aa/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/cost_function/cost_functions.py:17: The name tf.log is deprecated. Please use tf.math.log instead.
2022-02-16 07:07:45,803 [WARNING] tensorflow: From /opt/tlt/.cache/dazel/_dazel_tlt/75913d2aee35770fa76c4a63d877f3aa/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/cost_function/cost_functions.py:17: The name tf.log is deprecated. Please use tf.math.log instead.
WARNING:tensorflow:From /opt/tlt/.cache/dazel/_dazel_tlt/75913d2aee35770fa76c4a63d877f3aa/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/cost_function/cost_auto_weight_hook.py:235: The name tf.assign_add is deprecated. Please use tf.compat.v1.assign_add instead.
2022-02-16 07:07:45,814 [WARNING] tensorflow: From /opt/tlt/.cache/dazel/_dazel_tlt/75913d2aee35770fa76c4a63d877f3aa/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/cost_function/cost_auto_weight_hook.py:235: The name tf.assign_add is deprecated. Please use tf.compat.v1.assign_add instead.
WARNING:tensorflow:From /opt/tlt/.cache/dazel/_dazel_tlt/75913d2aee35770fa76c4a63d877f3aa/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/model/detectnet_model.py:591: The name tf.summary.scalar is deprecated. Please use tf.compat.v1.summary.scalar instead.
2022-02-16 07:07:45,818 [WARNING] tensorflow: From /opt/tlt/.cache/dazel/_dazel_tlt/75913d2aee35770fa76c4a63d877f3aa/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/model/detectnet_model.py:591: The name tf.summary.scalar is deprecated. Please use tf.compat.v1.summary.scalar instead.
2022-02-16 07:07:47,480 [INFO] modulus.blocks.data_loaders.multi_source_loader.data_loader: Serial augmentation enabled = False
2022-02-16 07:07:47,481 [INFO] modulus.blocks.data_loaders.multi_source_loader.data_loader: Pseudo sharding enabled = False
2022-02-16 07:07:47,481 [INFO] modulus.blocks.data_loaders.multi_source_loader.data_loader: Max Image Dimensions (all sources): (0, 0)
2022-02-16 07:07:47,481 [INFO] modulus.blocks.data_loaders.multi_source_loader.data_loader: number of cpus: 48, io threads: 96, compute threads: 48, buffered batches: 4
2022-02-16 07:07:47,481 [INFO] modulus.blocks.data_loaders.multi_source_loader.data_loader: total dataset size 53, number of sources: 1, batch size per gpu: 4, steps: 14
WARNING:tensorflow:Entity <bound method DriveNetTFRecordsParser.__call__ of <iva.detectnet_v2.dataloader.drivenet_dataloader.DriveNetTFRecordsParser object at 0x7f06e6b724a8>> could not be transformed and will be executed as-is. Please report this to the AutoGraph team. When filing the bug, set the verbosity to 10 (on Linux, `export AUTOGRAPH_VERBOSITY=10`) and attach the full output. Cause: Unable to locate the source code of <bound method DriveNetTFRecordsParser.__call__ of <iva.detectnet_v2.dataloader.drivenet_dataloader.DriveNetTFRecordsParser object at 0x7f06e6b724a8>>. Note that functions defined in certain environments, like the interactive Python shell do not expose their source code. If that is the case, you should to define them in a .py source file. If you are certain the code is graph-compatible, wrap the call using @tf.autograph.do_not_convert. Original error: could not get source code
2022-02-16 07:07:47,498 [WARNING] tensorflow: Entity <bound method DriveNetTFRecordsParser.__call__ of <iva.detectnet_v2.dataloader.drivenet_dataloader.DriveNetTFRecordsParser object at 0x7f06e6b724a8>> could not be transformed and will be executed as-is. Please report this to the AutoGraph team. When filing the bug, set the verbosity to 10 (on Linux, `export AUTOGRAPH_VERBOSITY=10`) and attach the full output. Cause: Unable to locate the source code of <bound method DriveNetTFRecordsParser.__call__ of <iva.detectnet_v2.dataloader.drivenet_dataloader.DriveNetTFRecordsParser object at 0x7f06e6b724a8>>. Note that functions defined in certain environments, like the interactive Python shell do not expose their source code. If that is the case, you should to define them in a .py source file. If you are certain the code is graph-compatible, wrap the call using @tf.autograph.do_not_convert. Original error: could not get source code
2022-02-16 07:07:47,539 [INFO] iva.detectnet_v2.dataloader.default_dataloader: Bounding box coordinates were detected in the input specification! Bboxes will be automatically converted to polygon coordinates.
2022-02-16 07:07:47,992 [INFO] modulus.blocks.data_loaders.multi_source_loader.data_loader: shuffle: False - shard 0 of 1
2022-02-16 07:07:47,998 [INFO] modulus.blocks.data_loaders.multi_source_loader.data_loader: sampling 1 datasets with weights:
2022-02-16 07:07:47,998 [INFO] modulus.blocks.data_loaders.multi_source_loader.data_loader: source: 0 weight: 1.000000
WARNING:tensorflow:Entity <bound method Processor.__call__ of <modulus.blocks.data_loaders.multi_source_loader.processors.asset_loader.AssetLoader object at 0x7f0754308278>> could not be transformed and will be executed as-is. Please report this to the AutoGraph team. When filing the bug, set the verbosity to 10 (on Linux, `export AUTOGRAPH_VERBOSITY=10`) and attach the full output. Cause: Unable to locate the source code of <bound method Processor.__call__ of <modulus.blocks.data_loaders.multi_source_loader.processors.asset_loader.AssetLoader object at 0x7f0754308278>>. Note that functions defined in certain environments, like the interactive Python shell do not expose their source code. If that is the case, you should to define them in a .py source file. If you are certain the code is graph-compatible, wrap the call using @tf.autograph.do_not_convert. Original error: could not get source code
2022-02-16 07:07:48,016 [WARNING] tensorflow: Entity <bound method Processor.__call__ of <modulus.blocks.data_loaders.multi_source_loader.processors.asset_loader.AssetLoader object at 0x7f0754308278>> could not be transformed and will be executed as-is. Please report this to the AutoGraph team. When filing the bug, set the verbosity to 10 (on Linux, `export AUTOGRAPH_VERBOSITY=10`) and attach the full output. Cause: Unable to locate the source code of <bound method Processor.__call__ of <modulus.blocks.data_loaders.multi_source_loader.processors.asset_loader.AssetLoader object at 0x7f0754308278>>. Note that functions defined in certain environments, like the interactive Python shell do not expose their source code. If that is the case, you should to define them in a .py source file. If you are certain the code is graph-compatible, wrap the call using @tf.autograph.do_not_convert. Original error: could not get source code
2022-02-16 07:07:48,289 [INFO] __main__: Found 53 samples in validation set
WARNING:tensorflow:From /opt/tlt/.cache/dazel/_dazel_tlt/75913d2aee35770fa76c4a63d877f3aa/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/tfhooks/validation_hook.py:40: The name tf.summary.FileWriterCache is deprecated. Please use tf.compat.v1.summary.FileWriterCache instead.
2022-02-16 07:07:48,900 [WARNING] tensorflow: From /opt/tlt/.cache/dazel/_dazel_tlt/75913d2aee35770fa76c4a63d877f3aa/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/tfhooks/validation_hook.py:40: The name tf.summary.FileWriterCache is deprecated. Please use tf.compat.v1.summary.FileWriterCache instead.
2022-02-16 07:07:50,232 [INFO] __main__: Checkpoint interval: 10
WARNING:tensorflow:From /opt/tlt/.cache/dazel/_dazel_tlt/75913d2aee35770fa76c4a63d877f3aa/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/scripts/train.py:109: The name tf.train.Scaffold is deprecated. Please use tf.compat.v1.train.Scaffold instead.
2022-02-16 07:07:50,233 [WARNING] tensorflow: From /opt/tlt/.cache/dazel/_dazel_tlt/75913d2aee35770fa76c4a63d877f3aa/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/scripts/train.py:109: The name tf.train.Scaffold is deprecated. Please use tf.compat.v1.train.Scaffold instead.
WARNING:tensorflow:From /opt/tlt/.cache/dazel/_dazel_tlt/75913d2aee35770fa76c4a63d877f3aa/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/common/graph/initializers.py:14: The name tf.local_variables_initializer is deprecated. Please use tf.compat.v1.local_variables_initializer instead.
2022-02-16 07:07:50,233 [WARNING] tensorflow: From /opt/tlt/.cache/dazel/_dazel_tlt/75913d2aee35770fa76c4a63d877f3aa/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/common/graph/initializers.py:14: The name tf.local_variables_initializer is deprecated. Please use tf.compat.v1.local_variables_initializer instead.
WARNING:tensorflow:From /opt/tlt/.cache/dazel/_dazel_tlt/75913d2aee35770fa76c4a63d877f3aa/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/common/graph/initializers.py:15: The name tf.tables_initializer is deprecated. Please use tf.compat.v1.tables_initializer instead.
2022-02-16 07:07:50,234 [WARNING] tensorflow: From /opt/tlt/.cache/dazel/_dazel_tlt/75913d2aee35770fa76c4a63d877f3aa/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/common/graph/initializers.py:15: The name tf.tables_initializer is deprecated. Please use tf.compat.v1.tables_initializer instead.
WARNING:tensorflow:From /opt/tlt/.cache/dazel/_dazel_tlt/75913d2aee35770fa76c4a63d877f3aa/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/common/graph/initializers.py:16: The name tf.get_collection is deprecated. Please use tf.compat.v1.get_collection instead.
2022-02-16 07:07:50,235 [WARNING] tensorflow: From /opt/tlt/.cache/dazel/_dazel_tlt/75913d2aee35770fa76c4a63d877f3aa/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/common/graph/initializers.py:16: The name tf.get_collection is deprecated. Please use tf.compat.v1.get_collection instead.
WARNING:tensorflow:From /opt/tlt/.cache/dazel/_dazel_tlt/75913d2aee35770fa76c4a63d877f3aa/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/tfhooks/utils.py:59: The name tf.train.LoggingTensorHook is deprecated. Please use tf.estimator.LoggingTensorHook instead.
2022-02-16 07:07:50,238 [WARNING] tensorflow: From /opt/tlt/.cache/dazel/_dazel_tlt/75913d2aee35770fa76c4a63d877f3aa/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/tfhooks/utils.py:59: The name tf.train.LoggingTensorHook is deprecated. Please use tf.estimator.LoggingTensorHook instead.
WARNING:tensorflow:From /opt/tlt/.cache/dazel/_dazel_tlt/75913d2aee35770fa76c4a63d877f3aa/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/tfhooks/utils.py:60: The name tf.train.StopAtStepHook is deprecated. Please use tf.estimator.StopAtStepHook instead.
2022-02-16 07:07:50,238 [WARNING] tensorflow: From /opt/tlt/.cache/dazel/_dazel_tlt/75913d2aee35770fa76c4a63d877f3aa/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/tfhooks/utils.py:60: The name tf.train.StopAtStepHook is deprecated. Please use tf.estimator.StopAtStepHook instead.
WARNING:tensorflow:From /opt/tlt/.cache/dazel/_dazel_tlt/75913d2aee35770fa76c4a63d877f3aa/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/tfhooks/utils.py:73: The name tf.train.StepCounterHook is deprecated. Please use tf.estimator.StepCounterHook instead.
2022-02-16 07:07:50,238 [WARNING] tensorflow: From /opt/tlt/.cache/dazel/_dazel_tlt/75913d2aee35770fa76c4a63d877f3aa/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/tfhooks/utils.py:73: The name tf.train.StepCounterHook is deprecated. Please use tf.estimator.StepCounterHook instead.
INFO:tensorflow:Create CheckpointSaverHook.
2022-02-16 07:07:50,238 [INFO] tensorflow: Create CheckpointSaverHook.
WARNING:tensorflow:From /opt/tlt/.cache/dazel/_dazel_tlt/75913d2aee35770fa76c4a63d877f3aa/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/tfhooks/utils.py:99: The name tf.train.SummarySaverHook is deprecated. Please use tf.estimator.SummarySaverHook instead.
2022-02-16 07:07:50,238 [WARNING] tensorflow: From /opt/tlt/.cache/dazel/_dazel_tlt/75913d2aee35770fa76c4a63d877f3aa/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/tfhooks/utils.py:99: The name tf.train.SummarySaverHook is deprecated. Please use tf.estimator.SummarySaverHook instead.
WARNING:tensorflow:From /opt/tlt/.cache/dazel/_dazel_tlt/75913d2aee35770fa76c4a63d877f3aa/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/training/utilities.py:140: The name tf.train.SingularMonitoredSession is deprecated. Please use tf.compat.v1.train.SingularMonitoredSession instead.
2022-02-16 07:07:52,780 [WARNING] tensorflow: From /opt/tlt/.cache/dazel/_dazel_tlt/75913d2aee35770fa76c4a63d877f3aa/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/training/utilities.py:140: The name tf.train.SingularMonitoredSession is deprecated. Please use tf.compat.v1.train.SingularMonitoredSession instead.
INFO:tensorflow:Graph was finalized.
2022-02-16 07:07:53,764 [INFO] tensorflow: Graph was finalized.
INFO:tensorflow:Restoring parameters from /tmp/tmpe9rr80sp/model.ckpt-0
2022-02-16 07:07:54,389 [INFO] tensorflow: Restoring parameters from /tmp/tmpe9rr80sp/model.ckpt-0
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/client/session.py", line 1365, in _do_call
return fn(*args)
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/client/session.py", line 1350, in _run_fn
target_list, run_metadata)
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/client/session.py", line 1443, in _call_tf_sessionrun
run_metadata)
tensorflow.python.framework.errors_impl.NotFoundError: 2 root error(s) found.
(0) Not found: Key cost_sums/city-bbox not found in checkpoint
[[{{node save/RestoreV2}}]]
(1) Not found: Key cost_sums/city-bbox not found in checkpoint
[[save/RestoreV2/_637]]
0 successful operations.
0 derived errors ignored.
During handling of the above exception, another exception occurred:
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/training/saver.py", line 1290, in restore
{self.saver_def.filename_tensor_name: save_path})
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/client/session.py", line 956, in run
run_metadata_ptr)
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/client/session.py", line 1180, in _run
feed_dict_tensor, options, run_metadata)
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/client/session.py", line 1359, in _do_run
run_metadata)
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/client/session.py", line 1384, in _do_call
raise type(e)(node_def, op, message)
[[node save/RestoreV2 (defined at /usr/local/lib/python3.6/dist-packages/tensorflow_core/python/framework/ops.py:1748) ]]
Original stack trace for 'save/RestoreV2':
File "/opt/tlt/.cache/dazel/_dazel_tlt/75913d2aee35770fa76c4a63d877f3aa/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/scripts/train.py", line 838, in <module>
File "<decorator-gen-2>", line 2, in main
File "/opt/tlt/.cache/dazel/_dazel_tlt/75913d2aee35770fa76c4a63d877f3aa/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/utilities/timer.py", line 46, in wrapped_fn
File "/opt/tlt/.cache/dazel/_dazel_tlt/75913d2aee35770fa76c4a63d877f3aa/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/scripts/train.py", line 827, in main
File "/opt/tlt/.cache/dazel/_dazel_tlt/75913d2aee35770fa76c4a63d877f3aa/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/scripts/train.py", line 708, in run_experiment
File "/opt/tlt/.cache/dazel/_dazel_tlt/75913d2aee35770fa76c4a63d877f3aa/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/scripts/train.py", line 644, in train_gridbox
File "/opt/tlt/.cache/dazel/_dazel_tlt/75913d2aee35770fa76c4a63d877f3aa/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/scripts/train.py", line 153, in run_training_loop
File "/opt/tlt/.cache/dazel/_dazel_tlt/75913d2aee35770fa76c4a63d877f3aa/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/training/utilities.py", line 143, in get_singular_monitored_session
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/training/monitored_session.py", line 1104, in __init__
stop_grace_period_secs=stop_grace_period_secs)
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/training/monitored_session.py", line 727, in __init__
self._sess = self._coordinated_creator.create_session()
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/training/monitored_session.py", line 878, in create_session
self.tf_sess = self._session_creator.create_session()
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/training/monitored_session.py", line 638, in create_session
self._scaffold.finalize()
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/training/monitored_session.py", line 229, in finalize
self._saver = training_saver._get_saver_or_default() # pylint: disable=protected-access
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/training/saver.py", line 599, in _get_saver_or_default
saver = Saver(sharded=True, allow_empty=True)
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/training/saver.py", line 828, in __init__
self.build()
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/training/saver.py", line 840, in build
self._build(self._filename, build_save=True, build_restore=True)
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/training/saver.py", line 878, in _build
build_restore=build_restore)
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/training/saver.py", line 502, in _build_internal
restore_sequentially, reshape)
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/training/saver.py", line 381, in _AddShardedRestoreOps
name="restore_shard"))
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/training/saver.py", line 328, in _AddRestoreOps
restore_sequentially)
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/training/saver.py", line 575, in bulk_restore
return io_ops.restore_v2(filename_tensor, names, slices, dtypes)
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/ops/gen_io_ops.py", line 1696, in restore_v2
name=name)
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/framework/op_def_library.py", line 794, in _apply_op_helper
op_def=op_def)
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/util/deprecation.py", line 513, in new_func
return func(*args, **kwargs)
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/framework/ops.py", line 3357, in create_op
attrs, op_def, compute_device)
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/framework/ops.py", line 3426, in _create_op_internal
op_def=op_def)
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/framework/ops.py", line 1748, in __init__
self._traceback = tf_stack.extract_stack()
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/training/saver.py", line 1300, in restore
names_to_keys = object_graph_key_mapping(save_path)
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/training/saver.py", line 1618, in object_graph_key_mapping
object_graph_string = reader.get_tensor(trackable.OBJECT_GRAPH_PROTO_KEY)
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/pywrap_tensorflow_internal.py", line 915, in get_tensor
return CheckpointReader_GetTensor(self, compat.as_bytes(tensor_str))
tensorflow.python.framework.errors_impl.NotFoundError: Key _CHECKPOINTABLE_OBJECT_GRAPH not found in checkpoint
File "/opt/tlt/.cache/dazel/_dazel_tlt/75913d2aee35770fa76c4a63d877f3aa/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/scripts/train.py", line 849, in <module>
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/training/monitored_session.py", line 647, in create_session
init_fn=self._scaffold.init_fn)
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/training/session_manager.py", line 290, in prepare_session
config=config)
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/training/session_manager.py", line 204, in _restore_checkpoint
saver.restore(sess, checkpoint_filename_with_path)
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/training/saver.py", line 1306, in restore
err, "a Variable name or other graph key that is missing")
tensorflow.python.framework.errors_impl.NotFoundError: Restoring from checkpoint failed. This is most likely due to a Variable name or other graph key that is missing from the checkpoint. Please ensure that you have not altered the graph expected based on the checkpoint. Original error:
self.build()
name=name)
op_def=op_def)
op_def=op_def)
ERROR:tensorflow:==================================
Object was never used (type <class 'tensorflow.python.framework.ops.Tensor'>):
<tf.Tensor 'IsVariableInitialized_411:0' shape=() dtype=bool>
If you want to mark it as used call its "mark_used()" method.
It was originally created here:
File "/opt/tlt/.cache/dazel/_dazel_tlt/75913d2aee35770fa76c4a63d877f3aa/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/training/utilities.py", line 143, in get_singular_monitored_session File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/training/monitored_session.py", line 1104, in __init__
stop_grace_period_secs=stop_grace_period_secs) File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/training/monitored_session.py", line 727, in __init__
self._sess = self._coordinated_creator.create_session() File "/opt/tlt/.cache/dazel/_dazel_tlt/75913d2aee35770fa76c4a63d877f3aa/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/core/build_wheel.runfiles/ai_infra/moduluspy/modulus/hooks/hooks.py", line 285, in begin File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/util/tf_should_use.py", line 198, in wrapped
return _add_should_use_warning(fn(*args, **kwargs))
2022-02-16 07:07:55,622 [ERROR] tensorflow: ==================================
2022-02-16 15:07:57,849 [INFO] tlt.components.docker_handler.docker_handler: Stopping container.
