Detectnetv2 will not train if the peoplenet model specified as the pretrained config in the trainspec file.
If the pretrained_model_file: line is commented out in the trainspec file model training will successfully begin. But then there is no transfer learning.
This is the pretrained model:
Any help would be appreciated.
Command being run within the docker container (haved tried multiple versions):
detectnet_v2 train -e /home/xxx/dev/AI_tools/object_detector/tao/trainspec_detectnetv2_v0.txt -r /home/xxx/xxx/new_model/backup -k xxx --gpus 2 --use_amp
Trainspec file:
random_seed: 42
dataset_config {
data_sources {
tfrecords_path: "/home/xxx/xxx/new_model/tf/train/*"
image_directory_path: "/home/xxx/xxx/new_model/kitti/"
image_extension: "jpg"
target_class_mapping {
key: "crane"
value: "crane"
key: "forklift"
value: "forklift"
key: "hat"
value: "hat"
key: "hi_vis"
value: "hi_vis"
key: "person"
value: "person"
validation_data_source {
tfrecords_path: "/home/xxx/xxx/new_model/tf/test/*"
augmentation_config {
preprocessing {
output_image_width: 1280
output_image_height: 720
#crop_right: 400
#crop_bottom: 304
min_bbox_width: 1.0
min_bbox_height: 1.0
output_image_channel: 3
spatial_augmentation {
hflip_probability: 0.5
zoom_min: 1.0
zoom_max: 1.0
translate_max_x: 8.0
translate_max_y: 8.0
color_augmentation {
hue_rotation_max: 25.0
saturation_shift_max: 0.20000000298
contrast_scale_max: 0.10000000149
contrast_center: 0.5
postprocessing_config {
target_class_config {
key: "crane"
value {
clustering_config {
coverage_threshold: 0.004999999888241291
minimum_bounding_box_height: 20
dbscan_eps: 0.15000000596046448
dbscan_min_samples: 0.05000000074505806
key: "forklift"
value {
clustering_config {
key: "hat"
value {
clustering_config {
key: "hi_vis"
value {
clustering_config {
key: "person"
value {
clustering_config {
dbscan_eps: 0.20000000298023224
model_config {
pretrained_model_file: "/home/xxx/dev/AI_tools/object_detector/tao/pretrained_models/resnet34_peoplenet.tlt"
num_layers: 34
use_batch_norm: true
activation {
activation_type: "relu"
objective_set {
bbox {
scale: 35.0
offset: 0.5
cov {
training_precision {
backend_floatx: FLOAT32
arch: "resnet"
evaluation_config {
validation_period_during_training: 2
first_validation_epoch: 1
minimum_detection_ground_truth_overlap {
key: "crane"
value: 0.25
key: "forklift"
value: 0.25
key: "hat"
value: 0.25
key: "hi_vis"
value: 0.25
key: "person"
value: 0.25
evaluation_box_config {
key: "crane"
value {
minimum_height: 4
maximum_height: 9999
minimum_width: 4
maximum_width: 9999
key: "forklift"
value {
minimum_height: 4
minimum_width: 4
maximum_width: 9999
key: "hat"
value {
minimum_height: 4
minimum_width: 4
maximum_width: 9999
key: "hi_vis"
value {
minimum_height: 4
minimum_width: 4
maximum_width: 9999
key: "person"
value {
minimum_height: 4
minimum_width: 4
maximum_width: 9999
average_precision_mode: INTEGRATE
cost_function_config {
target_classes {
class_weight: 1.0
coverage_foreground_weight: 0.05000000074505806
objectives {
initial_weight: 1.0
weight_target: 1.0
objectives {
initial_weight: 10.0
weight_target: 10.0
target_classes {
class_weight: 1.0
objectives {
initial_weight: 1.0
weight_target: 1.0
objectives {
weight_target: 1.0
target_classes {
class_weight: 1.0
objectives {
initial_weight: 1.0
weight_target: 1.0
objectives {
weight_target: 10.0
target_classes {
class_weight: 1.0
objectives {
initial_weight: 1.0
weight_target: 1.0
objectives {
weight_target: 10.0
target_classes {
class_weight: 1.0
objectives {
initial_weight: 1.0
weight_target: 1.0
objectives {
weight_target: 10.0
enable_autoweighting: true
max_objective_weight: 0.9998999834060669
min_objective_weight: 9.999999747378752e-05
training_config {
batch_size_per_gpu: 8
num_epochs: 100
learning_rate {
soft_start_annealing_schedule {
min_learning_rate: 5e-06
max_learning_rate: 5e-05
soft_start: 0.0
annealing: 0.3
regularizer {
type: L1
weight: 3.00000002618e-09
optimizer {
adam {
epsilon: 9.99999993923e-09
beta1: 0.899999976158
beta2: 0.999000012875
cost_scaling {
initial_exponent: 20.0
increment: 0.005
decrement: 1.0
checkpoint_interval: 10
bbox_rasterizer_config {
key: "crane"
value {
cov_center_x: 0.5
cov_center_y: 0.5
cov_radius_x: 0.4000000059604645
cov_radius_y: 0.4000000059604645
bbox_min_radius: 1.0
key: "forklift"
value {
cov_center_x: 0.5
cov_center_y: 0.5
key: "hat"
value {
cov_center_x: 0.5
cov_center_y: 0.5
key: "hi_vis"
value {
cov_center_x: 0.5
cov_center_y: 0.5
key: "person"
value {
cov_center_x: 0.5
cov_center_y: 0.5
deadzone_radius: 0.4000000059604645
Docker output:
root@28a41a7ce399:/workspace# detectnet_v2 train -e /home/xxx/dev/AI_tools/object_detector/tao/trainspec_detectnetv2_v0.txt -r /home/inviol/inviol/new_model/backup -k inviol --gpus 2 --use_amp
Using TensorFlow backend.
WARNING:tensorflow:Deprecation warnings have been disabled. Set TF_ENABLE_DEPRECATION_WARNINGS=1 to re-enable them.
WARNING:tensorflow:From /opt/tlt/.cache/dazel/_dazel_tlt/75913d2aee35770fa76c4a63d877f3aa/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/cost_function/cost_auto_weight_hook.py:43: The name tf.train.SessionRunHook is deprecated. Please use tf.estimator.SessionRunHook instead.
2021-12-07 04:40:15,365 [WARNING] tensorflow: From /opt/tlt/.cache/dazel/_dazel_tlt/75913d2aee35770fa76c4a63d877f3aa/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/cost_function/cost_auto_weight_hook.py:43: The name tf.train.SessionRunHook is deprecated. Please use tf.estimator.SessionRunHook instead.
2021-12-07 04:40:15,373 [WARNING] tensorflow: From /opt/tlt/.cache/dazel/_dazel_tlt/75913d2aee35770fa76c4a63d877f3aa/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/cost_function/cost_auto_weight_hook.py:43: The name tf.train.SessionRunHook is deprecated. Please use tf.estimator.SessionRunHook instead.
WARNING:tensorflow:From /opt/tlt/.cache/dazel/_dazel_tlt/75913d2aee35770fa76c4a63d877f3aa/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/tfhooks/checkpoint_saver_hook.py:25: The name tf.train.CheckpointSaverHook is deprecated. Please use tf.estimator.CheckpointSaverHook instead.
2021-12-07 04:40:15,444 [WARNING] tensorflow: From /opt/tlt/.cache/dazel/_dazel_tlt/75913d2aee35770fa76c4a63d877f3aa/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/tfhooks/checkpoint_saver_hook.py:25: The name tf.train.CheckpointSaverHook is deprecated. Please use tf.estimator.CheckpointSaverHook instead.
WARNING:tensorflow:From /opt/tlt/.cache/dazel/_dazel_tlt/75913d2aee35770fa76c4a63d877f3aa/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/scripts/train.py:69: The name tf.logging.set_verbosity is deprecated. Please use tf.compat.v1.logging.set_verbosity instead.
2021-12-07 04:40:15,445 [WARNING] tensorflow: From /opt/tlt/.cache/dazel/_dazel_tlt/75913d2aee35770fa76c4a63d877f3aa/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/scripts/train.py:69: The name tf.logging.set_verbosity is deprecated. Please use tf.compat.v1.logging.set_verbosity instead.
WARNING:tensorflow:From /opt/tlt/.cache/dazel/_dazel_tlt/75913d2aee35770fa76c4a63d877f3aa/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/scripts/train.py:69: The name tf.logging.INFO is deprecated. Please use tf.compat.v1.logging.INFO instead.
2021-12-07 04:40:15,445 [WARNING] tensorflow: From /opt/tlt/.cache/dazel/_dazel_tlt/75913d2aee35770fa76c4a63d877f3aa/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/scripts/train.py:69: The name tf.logging.INFO is deprecated. Please use tf.compat.v1.logging.INFO instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/horovod/tensorflow/__init__.py:117: The name tf.global_variables is deprecated. Please use tf.compat.v1.global_variables instead.
2021-12-07 04:40:15,451 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/horovod/tensorflow/__init__.py:117: The name tf.global_variables is deprecated. Please use tf.compat.v1.global_variables instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/horovod/tensorflow/__init__.py:143: The name tf.get_default_graph is deprecated. Please use tf.compat.v1.get_default_graph instead.
2021-12-07 04:40:15,451 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/horovod/tensorflow/__init__.py:143: The name tf.get_default_graph is deprecated. Please use tf.compat.v1.get_default_graph instead.
2021-12-07 04:40:15,462 [WARNING] tensorflow: From /opt/tlt/.cache/dazel/_dazel_tlt/75913d2aee35770fa76c4a63d877f3aa/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/tfhooks/checkpoint_saver_hook.py:25: The name tf.train.CheckpointSaverHook is deprecated. Please use tf.estimator.CheckpointSaverHook instead.
2021-12-07 04:40:15,464 [WARNING] tensorflow: From /opt/tlt/.cache/dazel/_dazel_tlt/75913d2aee35770fa76c4a63d877f3aa/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/scripts/train.py:69: The name tf.logging.set_verbosity is deprecated. Please use tf.compat.v1.logging.set_verbosity instead.
2021-12-07 04:40:15,464 [WARNING] tensorflow: From /opt/tlt/.cache/dazel/_dazel_tlt/75913d2aee35770fa76c4a63d877f3aa/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/scripts/train.py:69: The name tf.logging.INFO is deprecated. Please use tf.compat.v1.logging.INFO instead.
2021-12-07 04:40:15,469 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/horovod/tensorflow/__init__.py:117: The name tf.global_variables is deprecated. Please use tf.compat.v1.global_variables instead.
2021-12-07 04:40:15,469 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/horovod/tensorflow/__init__.py:143: The name tf.get_default_graph is deprecated. Please use tf.compat.v1.get_default_graph instead.
2021-12-07 04:40:15,851 [INFO] __main__: Loading experiment spec at /home/inviol/dev/AI_tools/object_detector/tao/trainspec_detectnetv2_v0.txt.
2021-12-07 04:40:15,852 [INFO] iva.detectnet_v2.spec_handler.spec_loader: Merging specification from /home/inviol/dev/AI_tools/object_detector/tao/trainspec_detectnetv2_v0.txt
2021-12-07 04:40:15,859 [INFO] __main__: Loading experiment spec at /home/inviol/dev/AI_tools/object_detector/tao/trainspec_detectnetv2_v0.txt.
2021-12-07 04:40:15,860 [INFO] iva.detectnet_v2.spec_handler.spec_loader: Merging specification from /home/inviol/dev/AI_tools/object_detector/tao/trainspec_detectnetv2_v0.txt
2021-12-07 04:40:18,327 [INFO] __main__: Cannot iterate over exactly 47705 samples with a batch size of 32; each epoch will therefore take one extra step.
2021-12-07 04:40:18,327 [INFO] __main__: Cannot iterate over exactly 745 steps per epoch with 32 processors; each processor will therefore take one extra step per epoch.
WARNING:tensorflow:From /opt/tlt/.cache/dazel/_dazel_tlt/75913d2aee35770fa76c4a63d877f3aa/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/cost_function/cost_auto_weight_hook.py:107: The name tf.variable_scope is deprecated. Please use tf.compat.v1.variable_scope instead.
2021-12-07 04:40:18,329 [WARNING] tensorflow: From /opt/tlt/.cache/dazel/_dazel_tlt/75913d2aee35770fa76c4a63d877f3aa/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/cost_function/cost_auto_weight_hook.py:107: The name tf.variable_scope is deprecated. Please use tf.compat.v1.variable_scope instead.
WARNING:tensorflow:From /opt/tlt/.cache/dazel/_dazel_tlt/75913d2aee35770fa76c4a63d877f3aa/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/cost_function/cost_auto_weight_hook.py:110: The name tf.get_variable is deprecated. Please use tf.compat.v1.get_variable instead.
2021-12-07 04:40:18,329 [WARNING] tensorflow: From /opt/tlt/.cache/dazel/_dazel_tlt/75913d2aee35770fa76c4a63d877f3aa/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/cost_function/cost_auto_weight_hook.py:110: The name tf.get_variable is deprecated. Please use tf.compat.v1.get_variable instead.
WARNING:tensorflow:From /opt/tlt/.cache/dazel/_dazel_tlt/75913d2aee35770fa76c4a63d877f3aa/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/cost_function/cost_auto_weight_hook.py:113: The name tf.assign is deprecated. Please use tf.compat.v1.assign instead.
2021-12-07 04:40:18,331 [WARNING] tensorflow: From /opt/tlt/.cache/dazel/_dazel_tlt/75913d2aee35770fa76c4a63d877f3aa/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/cost_function/cost_auto_weight_hook.py:113: The name tf.assign is deprecated. Please use tf.compat.v1.assign instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:517: The name tf.placeholder is deprecated. Please use tf.compat.v1.placeholder instead.
2021-12-07 04:40:18,404 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:517: The name tf.placeholder is deprecated. Please use tf.compat.v1.placeholder instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:4138: The name tf.random_uniform is deprecated. Please use tf.random.uniform instead.
2021-12-07 04:40:18,405 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:4138: The name tf.random_uniform is deprecated. Please use tf.random.uniform instead.
2021-12-07 04:40:18,410 [INFO] __main__: Cannot iterate over exactly 47705 samples with a batch size of 32; each epoch will therefore take one extra step.
2021-12-07 04:40:18,410 [INFO] __main__: Cannot iterate over exactly 745 steps per epoch with 32 processors; each processor will therefore take one extra step per epoch.
2021-12-07 04:40:18,412 [WARNING] tensorflow: From /opt/tlt/.cache/dazel/_dazel_tlt/75913d2aee35770fa76c4a63d877f3aa/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/cost_function/cost_auto_weight_hook.py:107: The name tf.variable_scope is deprecated. Please use tf.compat.v1.variable_scope instead.
2021-12-07 04:40:18,413 [WARNING] tensorflow: From /opt/tlt/.cache/dazel/_dazel_tlt/75913d2aee35770fa76c4a63d877f3aa/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/cost_function/cost_auto_weight_hook.py:110: The name tf.get_variable is deprecated. Please use tf.compat.v1.get_variable instead.
2021-12-07 04:40:18,414 [WARNING] tensorflow: From /opt/tlt/.cache/dazel/_dazel_tlt/75913d2aee35770fa76c4a63d877f3aa/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/cost_function/cost_auto_weight_hook.py:113: The name tf.assign is deprecated. Please use tf.compat.v1.assign instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:1834: The name tf.nn.fused_batch_norm is deprecated. Please use tf.compat.v1.nn.fused_batch_norm instead.
2021-12-07 04:40:18,418 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:1834: The name tf.nn.fused_batch_norm is deprecated. Please use tf.compat.v1.nn.fused_batch_norm instead.
2021-12-07 04:40:18,488 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:517: The name tf.placeholder is deprecated. Please use tf.compat.v1.placeholder instead.
2021-12-07 04:40:18,488 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:4138: The name tf.random_uniform is deprecated. Please use tf.random.uniform instead.
2021-12-07 04:40:18,501 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:1834: The name tf.nn.fused_batch_norm is deprecated. Please use tf.compat.v1.nn.fused_batch_norm instead.
2021-12-07 04:40:19,513 [INFO] __main__: Training was interrupted.
Time taken to run __main__:main: 0:00:04.067285.
2021-12-07 04:40:19,614 [INFO] __main__: Training was interrupted.
Time taken to run __main__:main: 0:00:04.150614.
Other info:
• Training Hardware: 2 x RTX A6000 GPU
• Network Type: DetectnetV2
• TLT Version: tao/tao-toolkit-tf: v3.21.11-tf1.15.5-py3 (also tried v3.21.08-py3)
