• Network Type bpnet
• TLT Version 3.22.05
I got an error when I pruned again. Does TAO support multiple pruning?
Yes, after pruning and retraining, can prune again.
I got an error when pruning again, my command:
!tao bpnet prune -m $USER_EXPERIMENT_DIR/models/exp_m1_retrain/bpnet_model.tlt \
-o $USER_EXPERIMENT_DIR/models/exp_m1_pruned/bpnet_model.pruned-0.05-1.tlt \
-eq union \
-pth 0.05 \
-k $KEY
error:
022-11-09 08:05:14,838 [INFO] modulus.pruning.pruning: Exploring graph for retainable indices
2022-11-09 08:05:14,838 [INFO] modulus.pruning.pruning: Pruning model and appending pruned nodes to new graph
2022-11-09 08:05:14,841 [INFO] modulus.pruning.pruning: Exploring graph for retainable indices
2022-11-09 08:05:15,240 [INFO] modulus.pruning.pruning: Pruning model and appending pruned nodes to new graph
File "/root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/driveix/build_wheel.runfiles/ai_infra/driveix/bpnet/scripts/prune.py", line 160, in <module>
File "/root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/driveix/build_wheel.runfiles/ai_infra/driveix/bpnet/scripts/prune.py", line 156, in main
File "/root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/driveix/build_wheel.runfiles/ai_infra/driveix/bpnet/scripts/prune.py", line 137, in run_pruning
File "/root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/core/build_wheel.runfiles/ai_infra/moduluspy/modulus/pruning/pruning.py", line 1613, in prune
File "/root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/core/build_wheel.runfiles/ai_infra/moduluspy/modulus/pruning/pruning.py", line 1411, in prune
File "/usr/local/lib/python3.6/dist-packages/keras/engine/network.py", line 1049, in from_config
return cls(inputs=input_tensors, outputs=output_tensors, name=name)
File "/usr/local/lib/python3.6/dist-packages/keras/legacy/interfaces.py", line 91, in wrapper
return func(*args, **kwargs)
File "/usr/local/lib/python3.6/dist-packages/keras/engine/network.py", line 93, in __init__
self._init_graph_network(*args, **kwargs)
File "/usr/local/lib/python3.6/dist-packages/keras/engine/network.py", line 231, in _init_graph_network
self.inputs, self.outputs)
File "/usr/local/lib/python3.6/dist-packages/keras/engine/network.py", line 1443, in _map_graph_network
str(layers_with_complete_input))
ValueError: Graph disconnected: cannot obtain value for tensor Tensor("input_1_2:0", shape=(?, ?, ?, 3), dtype=float32) at layer "input_1". The following previous layers were accessed without issue: []
File "/usr/local/bin/bpnet", line 8, in <module>
sys.exit(main())
File "/root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/driveix/build_wheel.runfiles/ai_infra/driveix/bpnet/entrypoint/bpnet.py", line 12, in main
File "/root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/driveix/build_wheel.runfiles/ai_infra/driveix/common/entrypoint/entrypoint.py", line 300, in launch_job
AssertionError: Process run failed.
Is bpnet_model.tlt a tlt model from retraining?
Can it run evaluation well?
Yes, bpnet_model.tlt is a tlt model from retraining.
It runs evaluation well, but can not prune again.
Could you share your retraining spec file? Thanks.
Of course.
bpnet_retrain_m1_coco.yaml (2.8 KB)
Could you run a quick(for example, 2 epochs) retraining by turning regularization off and then try to prune again?
From Body Pose Estimation — TAO Toolkit 3.22.05 documentation
After pruning, when retraining the networks, we recommend turning regularization off by setting the kernel_regularization_factor
to 0.0.
I set kernel_regularization_factor
to 0.0 and retraining again, it looks like the same error:
2022-11-09 09:12:24,802 [INFO] modulus.pruning.pruning: Exploring graph for retainable indices
2022-11-09 09:12:24,802 [INFO] modulus.pruning.pruning: Pruning model and appending pruned nodes to new graph
2022-11-09 09:12:24,805 [INFO] modulus.pruning.pruning: Exploring graph for retainable indices
2022-11-09 09:12:25,210 [INFO] modulus.pruning.pruning: Pruning model and appending pruned nodes to new graph
sys.exit(main())
I’m sure the path to the retrain model is correct and can be seen inside docker.
Why does pruning report an error?
!tao bpnet run ls /workspace/tao-experiments/bpnet/models/exp_m1_retrain
!tao bpnet prune -m /workspace/tao-experiments/bpnet/models/exp_m1_retrain/bpnet_model.tlt \
-o $USER_EXPERIMENT_DIR/models/exp_m1_pruned/bpnet_model.pruned-0.07.tlt \
-eq union \
-pth 0.07 \
-k $KEY
2022-11-10 14:38:52,536 [INFO] root: Registry: ['nvcr.io']
2022-11-10 14:38:52,577 [INFO] tlt.components.instance_handler.local_instance: Running command in container: nvcr.io/nvidia/tao/tao-toolkit-tf:v3.22.05-tf1.15.5-py3
2022-11-10 14:38:52,638 [WARNING] tlt.components.docker_handler.docker_handler:
Docker will run the commands as root. If you would like to retain your
local host permissions, please add the "user":"UID:GID" in the
DockerOptions portion of the "/home/nxin/.tao_mounts.json" file. You can obtain your
users UID and GID by using the "id -u" and "id -g" commands on the
terminal.
bpnet_model.tlt model.step-0.ckzip
events model.step-0.tlt
events.out.tfevents.1668057219.17180a130fd5 model.step-922.ckzip
experiment_spec.yaml model.step-922.tlt
graph.pbtxt
2022-11-10 14:38:53,072 [INFO] tlt.components.docker_handler.docker_handler: Stopping container.
2022-11-10 14:38:53,498 [INFO] root: Registry: ['nvcr.io']
2022-11-10 14:38:53,538 [INFO] tlt.components.instance_handler.local_instance: Running command in container: nvcr.io/nvidia/tao/tao-toolkit-tf:v3.22.05-tf1.15.5-py3
2022-11-10 14:38:53,600 [WARNING] tlt.components.docker_handler.docker_handler:
terminal.
2022-11-10 06:38:54.182489: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libcudart.so.11.0
WARNING:tensorflow:Deprecation warnings have been disabled. Set TF_ENABLE_DEPRECATION_WARNINGS=1 to re-enable them.
/usr/local/lib/python3.6/dist-packages/requests/__init__.py:91: RequestsDependencyWarning: urllib3 (1.26.5) or chardet (3.0.4) doesn't match a supported version!
RequestsDependencyWarning)
Using TensorFlow backend.
WARNING:tensorflow:From /root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/tfhooks/checkpoint_saver_hook.py:25: The name tf.train.CheckpointSaverHook is deprecated. Please use tf.estimator.CheckpointSaverHook instead.
2022-11-10 06:38:55,977 [WARNING] tensorflow: From /root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/tfhooks/checkpoint_saver_hook.py:25: The name tf.train.CheckpointSaverHook is deprecated. Please use tf.estimator.CheckpointSaverHook instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:517: The name tf.placeholder is deprecated. Please use tf.compat.v1.placeholder instead.
2022-11-10 06:38:58,553 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:517: The name tf.placeholder is deprecated. Please use tf.compat.v1.placeholder instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:4138: The name tf.random_uniform is deprecated. Please use tf.random.uniform instead.
2022-11-10 06:38:58,559 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:4138: The name tf.random_uniform is deprecated. Please use tf.random.uniform instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:245: The name tf.get_default_graph is deprecated. Please use tf.compat.v1.get_default_graph instead.
2022-11-10 06:38:58,565 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:245: The name tf.get_default_graph is deprecated. Please use tf.compat.v1.get_default_graph instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:1834: The name tf.nn.fused_batch_norm is deprecated. Please use tf.compat.v1.nn.fused_batch_norm instead.
2022-11-10 06:38:58,571 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:1834: The name tf.nn.fused_batch_norm is deprecated. Please use tf.compat.v1.nn.fused_batch_norm instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:133: The name tf.placeholder_with_default is deprecated. Please use tf.compat.v1.placeholder_with_default instead.
2022-11-10 06:38:58,575 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:133: The name tf.placeholder_with_default is deprecated. Please use tf.compat.v1.placeholder_with_default instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:4115: The name tf.random_normal is deprecated. Please use tf.random.normal instead.
2022-11-10 06:38:58,768 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:4115: The name tf.random_normal is deprecated. Please use tf.random.normal instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:174: The name tf.get_default_session is deprecated. Please use tf.compat.v1.get_default_session instead.
2022-11-10 06:38:59,184 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:174: The name tf.get_default_session is deprecated. Please use tf.compat.v1.get_default_session instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:181: The name tf.ConfigProto is deprecated. Please use tf.compat.v1.ConfigProto instead.
2022-11-10 06:38:59,184 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:181: The name tf.ConfigProto is deprecated. Please use tf.compat.v1.ConfigProto instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:186: The name tf.Session is deprecated. Please use tf.compat.v1.Session instead.
2022-11-10 06:38:59,184 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:186: The name tf.Session is deprecated. Please use tf.compat.v1.Session instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:190: The name tf.global_variables is deprecated. Please use tf.compat.v1.global_variables instead.
2022-11-10 06:38:59,450 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:190: The name tf.global_variables is deprecated. Please use tf.compat.v1.global_variables instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:199: The name tf.is_variable_initialized is deprecated. Please use tf.compat.v1.is_variable_initialized instead.
2022-11-10 06:38:59,451 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:199: The name tf.is_variable_initialized is deprecated. Please use tf.compat.v1.is_variable_initialized instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:206: The name tf.variables_initializer is deprecated. Please use tf.compat.v1.variables_initializer instead.
2022-11-10 06:38:59,724 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:206: The name tf.variables_initializer is deprecated. Please use tf.compat.v1.variables_initializer instead.
/usr/local/lib/python3.6/dist-packages/keras/engine/saving.py:292: UserWarning: No training configuration found in save file: the model was *not* compiled. Compile it manually.
warnings.warn('No training configuration found in save file: '
2022-11-10 06:38:59,997 [INFO] modulus.pruning.pruning: Exploring graph for retainable indices
2022-11-10 06:38:59,997 [INFO] modulus.pruning.pruning: Pruning model and appending pruned nodes to new graph
2022-11-10 06:39:00,000 [INFO] modulus.pruning.pruning: Exploring graph for retainable indices
2022-11-10 06:39:00,521 [INFO] modulus.pruning.pruning: Pruning model and appending pruned nodes to new graph
sys.exit(main())
Higher pth gives you smaller model. Could you retry with a lower pth ?
For example,
-pth 0.01
-pth 0.001
Yes, the same error is reported.
-o $USER_EXPERIMENT_DIR/models/exp_m1_pruned/bpnet_model.pruned-0.0007.tlt \
-eq union \
-pth 0.0007 \
-k $KEY
2022-11-10 07:50:16,251 [INFO] modulus.pruning.pruning: Exploring graph for retainable indices
2022-11-10 07:50:16,251 [INFO] modulus.pruning.pruning: Pruning model and appending pruned nodes to new graph
2022-11-10 07:50:16,254 [INFO] modulus.pruning.pruning: Exploring graph for retainable indices
2022-11-10 07:50:16,741 [INFO] modulus.pruning.pruning: Pruning model and appending pruned nodes to new graph
sys.exit(main())
I download the bpnet model from ngc and prune it directly for several times. But I cannot reproduce the error.
Did you ever try that official model? Or if you run official notebook previously, after retraining, did you ever prune it successfully?
Failure to succeed, I found that pruning will report this error as long as the load_graph
setting to True in the training spec file. If I set load_graph
to False pruning will succeed.
But I see that the documentation requires load_graph
to be set to True when retraining. What is the reason for this?
My retraining model:
bpnet_model.tlt (63.7 MB)
key:nvidia_tlt
I will check further.
Just an update. We can reproduce this error. Will check further internally and update to you if any.
Thank you.
We will fix this issue in next release. It is expected to be soon.
I look forward to using the next release, thank you for the reply.
