and here is the re-train log:
2021-12-03 15:10:40,194 [INFO] root: Registry: [‘nvcr.io’]
2021-12-03 15:10:40,257 [INFO] tlt.components.instance_handler.local_instance: Running command in container: nvcr.io/nvidia/tao/tao-toolkit-tf:v3.21.11-tf1.15.5-py3
2021-12-03 15:10:40,270 [WARNING] tlt.components.docker_handler.docker_handler:
Docker will run the commands as root. If you would like to retain your
local host permissions, please add the “user”:“UID:GID” in the
DockerOptions portion of the “/home/buhund/.tao_mounts.json” file. You can obtain your
users UID and GID by using the “id -u” and “id -g” commands on the
terminal.
Using TensorFlow backend.
WARNING:tensorflow:Deprecation warnings have been disabled. Set TF_ENABLE_DEPRECATION_WARNINGS=1 to re-enable them.
WARNING:tensorflow:From /root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/yolo_v4/scripts/train.py:40: The name tf.ConfigProto is deprecated. Please use tf.compat.v1.ConfigProto instead.
2021-12-03 13:10:47,181 [WARNING] tensorflow: From /root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/yolo_v4/scripts/train.py:40: The name tf.ConfigProto is deprecated. Please use tf.compat.v1.ConfigProto instead.
WARNING:tensorflow:From /root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/yolo_v4/scripts/train.py:43: The name tf.Session is deprecated. Please use tf.compat.v1.Session instead.
2021-12-03 13:10:47,181 [WARNING] tensorflow: From /root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/yolo_v4/scripts/train.py:43: The name tf.Session is deprecated. Please use tf.compat.v1.Session instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:153: The name tf.get_default_graph is deprecated. Please use tf.compat.v1.get_default_graph instead.
2021-12-03 13:10:47,522 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:153: The name tf.get_default_graph is deprecated. Please use tf.compat.v1.get_default_graph instead.
WARNING:tensorflow:From /root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/yolo_v3/data_loader/generate_shape_tensors.py:8: The name tf.variable_scope is deprecated. Please use tf.compat.v1.variable_scope instead.
2021-12-03 13:10:47,542 [WARNING] tensorflow: From /root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/yolo_v3/data_loader/generate_shape_tensors.py:8: The name tf.variable_scope is deprecated. Please use tf.compat.v1.variable_scope instead.
WARNING:tensorflow:From /root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/yolo_v3/data_loader/generate_shape_tensors.py:8: The name tf.AUTO_REUSE is deprecated. Please use tf.compat.v1.AUTO_REUSE instead.
2021-12-03 13:10:47,542 [WARNING] tensorflow: From /root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/yolo_v3/data_loader/generate_shape_tensors.py:8: The name tf.AUTO_REUSE is deprecated. Please use tf.compat.v1.AUTO_REUSE instead.
WARNING:tensorflow:From /root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/yolo_v3/data_loader/generate_shape_tensors.py:9: The name tf.get_variable is deprecated. Please use tf.compat.v1.get_variable instead.
2021-12-03 13:10:47,543 [WARNING] tensorflow: From /root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/yolo_v3/data_loader/generate_shape_tensors.py:9: The name tf.get_variable is deprecated. Please use tf.compat.v1.get_variable instead.
WARNING:tensorflow:From /root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/yolo_v3/data_loader/generate_shape_tensors.py:55: The name tf.assign is deprecated. Please use tf.compat.v1.assign instead.
2021-12-03 13:10:47,547 [WARNING] tensorflow: From /root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/yolo_v3/data_loader/generate_shape_tensors.py:55: The name tf.assign is deprecated. Please use tf.compat.v1.assign instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:517: The name tf.placeholder is deprecated. Please use tf.compat.v1.placeholder instead.
2021-12-03 13:10:47,571 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:517: The name tf.placeholder is deprecated. Please use tf.compat.v1.placeholder instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:4138: The name tf.random_uniform is deprecated. Please use tf.random.uniform instead.
2021-12-03 13:10:47,573 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:4138: The name tf.random_uniform is deprecated. Please use tf.random.uniform instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:1834: The name tf.nn.fused_batch_norm is deprecated. Please use tf.compat.v1.nn.fused_batch_norm instead.
2021-12-03 13:10:47,589 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:1834: The name tf.nn.fused_batch_norm is deprecated. Please use tf.compat.v1.nn.fused_batch_norm instead.
WARNING:tensorflow:From /opt/nvidia/third_party/keras/tensorflow_backend.py:183: The name tf.nn.max_pool is deprecated. Please use tf.nn.max_pool2d instead.
2021-12-03 13:10:47,731 [WARNING] tensorflow: From /opt/nvidia/third_party/keras/tensorflow_backend.py:183: The name tf.nn.max_pool is deprecated. Please use tf.nn.max_pool2d instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:2018: The name tf.image.resize_nearest_neighbor is deprecated. Please use tf.compat.v1.image.resize_nearest_neighbor instead.
2021-12-03 13:10:48,036 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:2018: The name tf.image.resize_nearest_neighbor is deprecated. Please use tf.compat.v1.image.resize_nearest_neighbor instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:174: The name tf.get_default_session is deprecated. Please use tf.compat.v1.get_default_session instead.
2021-12-03 13:10:49,293 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:174: The name tf.get_default_session is deprecated. Please use tf.compat.v1.get_default_session instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:190: The name tf.global_variables is deprecated. Please use tf.compat.v1.global_variables instead.
2021-12-03 13:10:49,293 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:190: The name tf.global_variables is deprecated. Please use tf.compat.v1.global_variables instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:199: The name tf.is_variable_initialized is deprecated. Please use tf.compat.v1.is_variable_initialized instead.
2021-12-03 13:10:49,293 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:199: The name tf.is_variable_initialized is deprecated. Please use tf.compat.v1.is_variable_initialized instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:206: The name tf.variables_initializer is deprecated. Please use tf.compat.v1.variables_initializer instead.
2021-12-03 13:10:49,568 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:206: The name tf.variables_initializer is deprecated. Please use tf.compat.v1.variables_initializer instead.
/usr/local/lib/python3.6/dist-packages/keras/engine/saving.py:292: UserWarning: No training configuration found in save file: the model was not compiled. Compile it manually.
warnings.warn('No training configuration found in save file: ’
WARNING:tensorflow:From /root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/common/losses/base_loss.py:40: The name tf.log is deprecated. Please use tf.math.log instead.
2021-12-03 13:10:55,211 [WARNING] tensorflow: From /root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/common/losses/base_loss.py:40: The name tf.log is deprecated. Please use tf.math.log instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/keras/optimizers.py:790: The name tf.train.Optimizer is deprecated. Please use tf.compat.v1.train.Optimizer instead.
2021-12-03 13:10:55,354 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/optimizers.py:790: The name tf.train.Optimizer is deprecated. Please use tf.compat.v1.train.Optimizer instead.
Layer (type) Output Shape Param # Connected to
Input (InputLayer) (None, 3, 480, 640) 0
conv_0 (Conv2D) (None, 32, 240, 320) 864 Input[0][0]
conv_0_bn (BatchNormalization) (None, 32, 240, 320) 128 conv_0[0][0]
conv_0_mish (LeakyReLU) (None, 32, 240, 320) 0 conv_0_bn[0][0]
conv_1 (Conv2D) (None, 64, 120, 160) 18432 conv_0_mish[0][0]
conv_1_bn (BatchNormalization) (None, 64, 120, 160) 256 conv_1[0][0]
conv_1_mish (LeakyReLU) (None, 64, 120, 160) 0 conv_1_bn[0][0]
conv_2_conv_0 (Conv2D) (None, 64, 120, 160) 36864 conv_1_mish[0][0]
conv_2_conv_0_bn (BatchNormaliz (None, 64, 120, 160) 256 conv_2_conv_0[0][0]
conv_2_conv_0_mish (LeakyReLU) (None, 64, 120, 160) 0 conv_2_conv_0_bn[0][0]
conv_2_split_0 (Split) (None, 32, 120, 160) 0 conv_2_conv_0_mish[0][0]
conv_2_conv_1 (Conv2D) (None, 32, 120, 160) 9216 conv_2_split_0[0][0]
conv_2_conv_1_bn (BatchNormaliz (None, 32, 120, 160) 128 conv_2_conv_1[0][0]
conv_2_conv_1_mish (LeakyReLU) (None, 32, 120, 160) 0 conv_2_conv_1_bn[0][0]
conv_2_conv_2 (Conv2D) (None, 32, 120, 160) 9216 conv_2_conv_1_mish[0][0]
conv_2_conv_2_bn (BatchNormaliz (None, 32, 120, 160) 128 conv_2_conv_2[0][0]
conv_2_conv_2_mish (LeakyReLU) (None, 32, 120, 160) 0 conv_2_conv_2_bn[0][0]
conv_2_concat_0 (Concatenate) (None, 64, 120, 160) 0 conv_2_conv_2_mish[0][0]
conv_2_conv_3 (Conv2D) (None, 64, 120, 160) 4096 conv_2_concat_0[0][0]
conv_2_conv_3_bn (BatchNormaliz (None, 64, 120, 160) 256 conv_2_conv_3[0][0]
conv_2_conv_3_mish (LeakyReLU) (None, 64, 120, 160) 0 conv_2_conv_3_bn[0][0]
conv_2_concat_1 (Concatenate) (None, 128, 120, 160 0 conv_2_conv_0_mish[0][0]
conv_2_conv_3_mish[0][0]
conv_2_pool_0 (MaxPooling2D) (None, 128, 60, 80) 0 conv_2_concat_1[0][0]
conv_3_conv_0 (Conv2D) (None, 128, 60, 80) 147456 conv_2_pool_0[0][0]
conv_3_conv_0_bn (BatchNormaliz (None, 128, 60, 80) 512 conv_3_conv_0[0][0]
conv_3_conv_0_mish (LeakyReLU) (None, 128, 60, 80) 0 conv_3_conv_0_bn[0][0]
conv_3_split_0 (Split) (None, 64, 60, 80) 0 conv_3_conv_0_mish[0][0]
conv_3_conv_1 (Conv2D) (None, 64, 60, 80) 36864 conv_3_split_0[0][0]
conv_3_conv_1_bn (BatchNormaliz (None, 64, 60, 80) 256 conv_3_conv_1[0][0]
conv_3_conv_1_mish (LeakyReLU) (None, 64, 60, 80) 0 conv_3_conv_1_bn[0][0]
conv_3_conv_2 (Conv2D) (None, 64, 60, 80) 36864 conv_3_conv_1_mish[0][0]
conv_3_conv_2_bn (BatchNormaliz (None, 64, 60, 80) 256 conv_3_conv_2[0][0]
conv_3_conv_2_mish (LeakyReLU) (None, 64, 60, 80) 0 conv_3_conv_2_bn[0][0]
conv_3_concat_0 (Concatenate) (None, 128, 60, 80) 0 conv_3_conv_2_mish[0][0]
conv_3_conv_3 (Conv2D) (None, 128, 60, 80) 16384 conv_3_concat_0[0][0]
conv_3_conv_3_bn (BatchNormaliz (None, 128, 60, 80) 512 conv_3_conv_3[0][0]
conv_3_conv_3_mish (LeakyReLU) (None, 128, 60, 80) 0 conv_3_conv_3_bn[0][0]
conv_3_concat_1 (Concatenate) (None, 256, 60, 80) 0 conv_3_conv_0_mish[0][0]
conv_3_conv_3_mish[0][0]
conv_3_pool_0 (MaxPooling2D) (None, 256, 30, 40) 0 conv_3_concat_1[0][0]
conv_4_conv_0 (Conv2D) (None, 256, 30, 40) 589824 conv_3_pool_0[0][0]
conv_4_conv_0_bn (BatchNormaliz (None, 256, 30, 40) 1024 conv_4_conv_0[0][0]
conv_4_conv_0_mish (LeakyReLU) (None, 256, 30, 40) 0 conv_4_conv_0_bn[0][0]
conv_4_split_0 (Split) (None, 128, 30, 40) 0 conv_4_conv_0_mish[0][0]
conv_4_conv_1 (Conv2D) (None, 128, 30, 40) 147456 conv_4_split_0[0][0]
conv_4_conv_1_bn (BatchNormaliz (None, 128, 30, 40) 512 conv_4_conv_1[0][0]
conv_4_conv_1_mish (LeakyReLU) (None, 128, 30, 40) 0 conv_4_conv_1_bn[0][0]
conv_4_conv_2 (Conv2D) (None, 128, 30, 40) 147456 conv_4_conv_1_mish[0][0]
conv_4_conv_2_bn (BatchNormaliz (None, 128, 30, 40) 512 conv_4_conv_2[0][0]
conv_4_conv_2_mish (LeakyReLU) (None, 128, 30, 40) 0 conv_4_conv_2_bn[0][0]
conv_4_concat_0 (Concatenate) (None, 256, 30, 40) 0 conv_4_conv_2_mish[0][0]
conv_4_conv_3 (Conv2D) (None, 256, 30, 40) 65536 conv_4_concat_0[0][0]
conv_4_conv_3_bn (BatchNormaliz (None, 256, 30, 40) 1024 conv_4_conv_3[0][0]
conv_4_conv_3_mish (LeakyReLU) (None, 256, 30, 40) 0 conv_4_conv_3_bn[0][0]
conv_4_concat_1 (Concatenate) (None, 512, 30, 40) 0 conv_4_conv_0_mish[0][0]
conv_4_conv_3_mish[0][0]
conv_4_pool_0 (MaxPooling2D) (None, 512, 15, 20) 0 conv_4_concat_1[0][0]
conv_5 (Conv2D) (None, 512, 15, 20) 2359296 conv_4_pool_0[0][0]
conv_5_bn (BatchNormalization) (None, 512, 15, 20) 2048 conv_5[0][0]
conv_5_mish (LeakyReLU) (None, 512, 15, 20) 0 conv_5_bn[0][0]
yolo_conv1_1 (Conv2D) (None, 256, 15, 20) 131072 conv_5_mish[0][0]
yolo_conv1_1_bn (BatchNormaliza (None, 256, 15, 20) 1024 yolo_conv1_1[0][0]
yolo_conv1_1_lrelu (LeakyReLU) (None, 256, 15, 20) 0 yolo_conv1_1_bn[0][0]
yolo_conv2 (Conv2D) (None, 128, 15, 20) 32768 yolo_conv1_1_lrelu[0][0]
yolo_conv2_bn (BatchNormalizati (None, 128, 15, 20) 512 yolo_conv2[0][0]
yolo_conv2_lrelu (LeakyReLU) (None, 128, 15, 20) 0 yolo_conv2_bn[0][0]
upsample0 (UpSampling2D) (None, 128, 30, 40) 0 yolo_conv2_lrelu[0][0]
concatenate_2 (Concatenate) (None, 384, 30, 40) 0 upsample0[0][0]
yolo_conv1_6 (Conv2D) (None, 512, 15, 20) 1179648 yolo_conv1_1_lrelu[0][0]
yolo_conv3_6 (Conv2D) (None, 256, 30, 40) 884736 concatenate_2[0][0]
yolo_conv1_6_bn (BatchNormaliza (None, 512, 15, 20) 2048 yolo_conv1_6[0][0]
yolo_conv3_6_bn (BatchNormaliza (None, 256, 30, 40) 1024 yolo_conv3_6[0][0]
yolo_conv1_6_lrelu (LeakyReLU) (None, 512, 15, 20) 0 yolo_conv1_6_bn[0][0]
yolo_conv3_6_lrelu (LeakyReLU) (None, 256, 30, 40) 0 yolo_conv3_6_bn[0][0]
conv_big_object (Conv2D) (None, 24, 15, 20) 12312 yolo_conv1_6_lrelu[0][0]
conv_mid_object (Conv2D) (None, 24, 30, 40) 6168 yolo_conv3_6_lrelu[0][0]
bg_permute (Permute) (None, 15, 20, 24) 0 conv_big_object[0][0]
md_permute (Permute) (None, 30, 40, 24) 0 conv_mid_object[0][0]
bg_reshape (Reshape) (None, 900, 8) 0 bg_permute[0][0]
md_reshape (Reshape) (None, 3600, 8) 0 md_permute[0][0]
bg_anchor (YOLOAnchorBox) (None, 900, 6) 0 conv_big_object[0][0]
bg_bbox_processor (BBoxPostProc (None, 900, 8) 0 bg_reshape[0][0]
md_anchor (YOLOAnchorBox) (None, 3600, 6) 0 conv_mid_object[0][0]
md_bbox_processor (BBoxPostProc (None, 3600, 8) 0 md_reshape[0][0]
encoded_bg (Concatenate) (None, 900, 14) 0 bg_anchor[0][0]
bg_bbox_processor[0][0]
encoded_md (Concatenate) (None, 3600, 14) 0 md_anchor[0][0]
md_bbox_processor[0][0]
encoded_detections (Concatenate (None, 4500, 14) 0 encoded_bg[0][0]
encoded_md[0][0]
Total params: 5,884,944
Trainable params: 5,878,736
Non-trainable params: 6,208
WARNING:tensorflow:From /root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/yolo_v3/utils/tensor_utils.py:7: The name tf.local_variables_initializer is deprecated. Please use tf.compat.v1.local_variables_initializer instead.
2021-12-03 13:10:55,560 [WARNING] tensorflow: From /root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/yolo_v3/utils/tensor_utils.py:7: The name tf.local_variables_initializer is deprecated. Please use tf.compat.v1.local_variables_initializer instead.
WARNING:tensorflow:From /root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/yolo_v3/utils/tensor_utils.py:8: The name tf.tables_initializer is deprecated. Please use tf.compat.v1.tables_initializer instead.
2021-12-03 13:10:55,560 [WARNING] tensorflow: From /root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/yolo_v3/utils/tensor_utils.py:8: The name tf.tables_initializer is deprecated. Please use tf.compat.v1.tables_initializer instead.
WARNING:tensorflow:From /root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/yolo_v3/utils/tensor_utils.py:9: The name tf.get_collection is deprecated. Please use tf.compat.v1.get_collection instead.
2021-12-03 13:10:55,560 [WARNING] tensorflow: From /root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/yolo_v3/utils/tensor_utils.py:9: The name tf.get_collection is deprecated. Please use tf.compat.v1.get_collection instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:986: The name tf.assign_add is deprecated. Please use tf.compat.v1.assign_add instead.
2021-12-03 13:10:57,052 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:986: The name tf.assign_add is deprecated. Please use tf.compat.v1.assign_add instead.
Epoch 1/100
File “/root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/yolo_v4/scripts/train.py”, line 110, in
File “/root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/common/utils.py”, line 528, in return_func
File “/root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/common/utils.py”, line 516, in return_func
File “/root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/yolo_v4/scripts/train.py”, line 106, in main
File “/root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/yolo_v4/scripts/train.py”, line 63, in run_experiment
File “/root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/yolo_v4/models/yolov4_model.py”, line 644, in train
File “/usr/local/lib/python3.6/dist-packages/keras/legacy/interfaces.py”, line 91, in wrapper
return func(*args, **kwargs)
File “/usr/local/lib/python3.6/dist-packages/keras/engine/training.py”, line 1418, in fit_generator
initial_epoch=initial_epoch)
File “/usr/local/lib/python3.6/dist-packages/keras/engine/training_generator.py”, line 217, in fit_generator
class_weight=class_weight)
File “/usr/local/lib/python3.6/dist-packages/keras/engine/training.py”, line 1211, in train_on_batch
File “/usr/local/lib/python3.6/dist-packages/keras/engine/training.py”, line 751, in _standardize_user_data
exception_prefix=‘input’)
File “/usr/local/lib/python3.6/dist-packages/keras/engine/training_utils.py”, line 138, in standardize_input_data
str(data_shape))
ValueError: Error when checking input: expected Input to have shape (3, 480, 640) but got array with shape (3, 736, 896)
terminate called without an active exception
[6fba8a984de0:00049] *** Process received signal ***
[6fba8a984de0:00049] Signal: Aborted (6)
[6fba8a984de0:00049] Signal code: (-6)
[6fba8a984de0:00049] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x3f040)[0x7fde798dc040]
[6fba8a984de0:00049] [ 1] /lib/x86_64-linux-gnu/libc.so.6(gsignal+0xc7)[0x7fde798dbfb7]
[6fba8a984de0:00049] [ 2] /lib/x86_64-linux-gnu/libc.so.6(abort+0x141)[0x7fde798dd921]
[6fba8a984de0:00049] [ 3] /usr/lib/x86_64-linux-gnu/libstdc++.so.6(+0x8c957)[0x7fde02680957]
[6fba8a984de0:00049] [ 4] /usr/lib/x86_64-linux-gnu/libstdc++.so.6(+0x92ae6)[0x7fde02686ae6]
[6fba8a984de0:00049] [ 5] /usr/lib/x86_64-linux-gnu/libstdc++.so.6(+0x92b21)[0x7fde02686b21]
[6fba8a984de0:00049] [ 6] /usr/lib/x86_64-linux-gnu/libstdc++.so.6(__gxx_personality_v0+0x2da)[0x7fde026864ea]
[6fba8a984de0:00049] [ 7] /lib/x86_64-linux-gnu/libgcc_s.so.1(+0x10668)[0x7fde758a6668]
[6fba8a984de0:00049] [ 8] /lib/x86_64-linux-gnu/libgcc_s.so.1(_Unwind_ForcedUnwind+0x12c)[0x7fde758a6c5c]
[6fba8a984de0:00049] [ 9] /lib/x86_64-linux-gnu/libpthread.so.0(__pthread_unwind+0x40)[0x7fde7968f000]
[6fba8a984de0:00049] [10] /lib/x86_64-linux-gnu/libpthread.so.0(+0x8ae5)[0x7fde79686ae5]
[6fba8a984de0:00049] [11] /lib/x86_64-linux-gnu/libc.so.6(pthread_exit+0x24)[0x7fde799cd394]
[6fba8a984de0:00049] [12] python3.6[0x632045]
[6fba8a984de0:00049] [13] python3.6[0x50baf7]
[6fba8a984de0:00049] [14] python3.6(PyGILState_Ensure+0x47)[0x637e87]
[6fba8a984de0:00049] [15] /usr/local/lib/python3.6/dist-packages/cv2/cv2.cpython-36m-x86_64-linux-gnu.so(+0x12f835)[0x7fddce3a5835]
[6fba8a984de0:00049] [16] /usr/local/lib/python3.6/dist-packages/cv2/cv2.cpython-36m-x86_64-linux-gnu.so(+0x14bb35)[0x7fddce3c1b35]
[6fba8a984de0:00049] [17] /usr/local/lib/python3.6/dist-packages/cv2/cv2.cpython-36m-x86_64-linux-gnu.so(+0x1c54e6)[0x7fddce43b4e6]
[6fba8a984de0:00049] [18] python3.6[0x50a5a5]
[6fba8a984de0:00049] [19] python3.6(_PyEval_EvalFrameDefault+0x444)[0x50bf44]
[6fba8a984de0:00049] [20] python3.6[0x507cd4]
[6fba8a984de0:00049] [21] python3.6[0x509a00]
[6fba8a984de0:00049] [22] python3.6[0x50a3fd]
[6fba8a984de0:00049] [23] python3.6(_PyEval_EvalFrameDefault+0x444)[0x50bf44]
[6fba8a984de0:00049] [24] python3.6[0x5096c8]
[6fba8a984de0:00049] [25] python3.6[0x50a3fd]
[6fba8a984de0:00049] [26] python3.6(_PyEval_EvalFrameDefault+0x444)[0x50bf44]
[6fba8a984de0:00049] [27] python3.6[0x5096c8]
[6fba8a984de0:00049] [28] python3.6[0x50a3fd]
[6fba8a984de0:00049] [29] python3.6(_PyEval_EvalFrameDefault+0x444)[0x50bf44]
[6fba8a984de0:00049] *** End of error message ***
Aborted (core dumped)
2021-12-03 15:11:04,408 [INFO] tlt.components.docker_handler.docker_handler: Stopping container.
