Hi there,
Could anyone clarify whether the Nvidia Linux driver supports the following HDMI output modes:
3840x2160p30 8-bit YUV 4:2:2
3840x2160p30 10-bit YUV 4:2:2 (with Quadro)
Thank you,
adev99
Hi there,
Thank you,
adev99
| Driver forces 10-bit output even though I selected 8-bit in nvidia-settings | 0 | 378 | August 30, 2024 | |
| 30-bit depth with Linux driver does not produce 30-bit output on monitor | 20 | 25838 | May 25, 2018 | |
| AGX Xavier HDMI output 10bit yuv422, DP output 10bit RGB | 6 | 1390 | November 17, 2021 | |
| GTX 1060 375.26 not output 10-bit color | 8 | 20765 | October 14, 2021 | |
| Does XavierNX HDMI output support YUV420 8-bit output? | 9 | 533 | December 12, 2023 | |
| True 10bit display nvidia driver for linux | 2 | 907 | December 4, 2023 | |
| YUV 4:4:4 10/12 bit over HDMI on Jetson TX1 | 2 | 542 | October 18, 2021 | |
| HDMI YUV422 output | 19 | 4249 | December 29, 2021 | |
| Render YUV422 10bit to 10 bits monitor on Orin NX | 9 | 844 | May 8, 2024 | |
| Question: Linux driver 10-bit color depth support | 6 | 6514 | April 17, 2024 |
