Seems like caffe is not downloaded/built. Do you do the below step?
b) Download Caffe source package from the following website:
https://github.com/BVLC/caffe
And copy the package to `$HOME` directory on the target board
with the following command:
$ mkdir -pv $HOME/Work/caffe
$ cp caffe-master.zip $HOME/Work/caffe/
$ cd $HOME/Work/caffe/ && unzip caffe-master.zip
I get the same error while compiling the OpenCV consumer library for 11_camera_object_identification sample.
Caffe is downloaded and built. I have also verified it by running the tests for Caffe.
so i have the same error code, with only one small difference included from opencv_consumer.cpp:41:0:.
so how do i check to see if caffe is properly downloaded or built?, i followed all the instructions in the tutorial, so i’m not sure where i’ve messed up.
i also tried to redo the first step where i unzip caffe-master.zip, but it prompted me asking if i wished to replace the files, having this pop up i assume this means that caffe was installed?
Hi lawrencl,
We suggest use TensorRT and refer to below samples:
tegra_multimedia_api\samples\04_video_dec_trt
tegra_multimedia_api\samples\backend
tegra_multimedia_api\samples\frontend
