We are working with a custom board that uses Marvell 1G Ethernet. The Ethernet interface works fine on one board but is not functioning on another, despite both boards being flashed with the same code. We are trying to understand the root cause of this issue. Below are the error messages we have observed.
Yes, it’s the industrial version of AGX Orin. The ping works fine, but we are unable to access the internet. Browsing and package updates are not working.
Any suggestions on how to resolve this would be appreciated.
Actually I am not quite sure about what do you mean ping works fine but not able to access Internet. Such description seems not an issue on the PHY or Orin itself but the setting in your network environment.
However, when I try to browse the internet or run system updates, it doesn’t work. Below is the error message we encountered.
Err:1
http://ports.ubuntu.com/ubuntu-ports
focal InRelease
Could not connect to ports.ubuntu.com:80 (2620:2d:4000:1::16). - connect (101: Network is unreachable) Could not connect to ports.ubuntu.com:80 (2620:2d:4000:1::19). - connect (101: Network is unreacht
Err:2
focal-updates InRelease
Unable to connect to ports.ubuntu.com:http:
Err:3
focal-backports InRelease
Err:4
focal-security InRelease
Reading package lists... Done
W: Failed to fetch
http://ports.ubuntu.com/ubuntu-ports/dists/focal/InRelease
Could not connect to ports.ubuntu.com:80 (2620:2d:4000:1::16). - connect (101: Network is unreachable) Could not connect tot
W: Failed to fetch
http://ports.ubuntu.com/ubuntu-ports/dists/focal-updates/InRelease
W: Failed to fetch
http://ports.ubuntu.com/ubuntu-ports/dists/focal-backports/InRelease
W: Failed to fetch
http://ports.ubuntu.com/ubuntu-ports/dists/focal-security/InRelease
W: Some index files failed to download. They have been ignored, or old ones used instead.
We tested the same RJ45 network connection with another system, and the internet works, so it doesn’t seem to be an issue on the network side.
What kind of issue could this be? It’s quite unusual for us. Could you please advise on what settings or files we should check to troubleshoot this further? Any guidance on the specific paths or configurations that may need adjustment would be helpful.
We have gone through the wiki and followed the steps, but the issue is still persisting. Could you provide some insight into which components might be causing this issue? Any hints or guidance on potential failures would be greatly appreciated.
Sorry for the late response.
