您好,我们的模块采用AGX Orin,是搭载我们自己的底板,网络是采用x1的pcie扩展出来的i210,目前有出现概率性掉网络的情况,有时在大流量的情况下,跑大概一天会掉。掉网后ifconfig会出现error信息,如下:
此时换到其它网络接口是正常的,就只有掉的那个网口无法使用,重启能恢复,目前不清楚是什么原因导致,想了解官方这边是否有相关的思路或建议呢?
A user has shared a patch for i210:
[35.3.1] Intel I210 throughput issue on Jetson Orin Nano Devkit - #12 by sgidel
Please apply it and give it a try.
你好,这边现象可能不太一样呢。
想再咨询一下ethernet@2310000这个具体是什么作用呢?如果关掉会影响哪些功能吗?
麻烦了。
There is RGMII interface in AGX Orin module. If you don’t use it, you can disable it.
Please check Chapter 8 in product design guide:
https://developer.nvidia.com/downloads/embedded/secure/jetson/agx_orin/jetson_agx_orin_design_guide/
For your reference, the throughput of Xavier developer kit + i210:
[35.2.1] I210 throughput slow on Xavier NX - #6 by DaneLLL
