Hi, Our carrier board with L4T 35.2.1 use rtl8211 (rgmii) and disable 10G network.
It seems something wrong. Sometime it can not get ip when booting.
If boot no IP, the network can not work. And then use command “ifconfig” will see RX packets and TX packets is 0. But it always has interrupts on “gpio 39 Level 2310000.ethernet:01”.
nvorin@tegra-ubuntu:~$ ifconfig
eth0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1466
ether 48:b0:2d:94:5e:25 txqueuelen 1000 (Ethernet)
RX packets 0 bytes 0 (0.0 B)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 0 bytes 0 (0.0 B)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
nvorin@tegra-ubuntu:~$ cat /proc/interrupts |grep eth
69: 0 0 0 0 0 0 0 0 GICv3 226 Level eth0.common_irq
70: 0 0 0 0 0 0 0 0 GICv3 218 Level eth0.vm0
71: 0 0 0 0 0 0 0 0 GICv3 219 Level eth0.vm1
72: 0 0 0 0 0 0 0 0 GICv3 220 Level eth0.vm2
73: 0 0 0 0 0 0 0 0 GICv3 221 Level eth0.vm3
310: 508041 0 0 0 0 0 0 0 gpio 39 Level 2310000.ethernet:01
You must use command “sudo ifconfig eth0 down” and “sudo ifconfig eth0 up” to enable network.
Then the RX packets and TX packets has value. Network work normally.
