Orin rgmii can not work
Hi, all:
we are debuging our custom board. In our costom board, the MGBE USXGMII port and the RGMII port is directly connnct to our switch. The MGBE ethrnet is ok, but RGMII port ethernet can not work with Orin and L4T 35.4.1.
We have modified the rgmii related pinmux and device tree according to the development manual,But when I enabled the rgmii network port, an error occurred.
Attached are our device tree, pimux profile, and boot log.
tegra234-trunk-atom-ethernet.dtsi.txt (1.3 KB)
tegra234-mb1-bct-pinmux-p3701-0000-a04.dtsi.txt (65.7 KB)
dmesg.log (79.4 KB)
so any suggestion about this issue, thx
I have same problem, and I get register:
D3 0x02445000:
0x00002400
TD2 0x02445008:
0x00002400
TD1 0x02445010:
0x00002400
TD0 0x02445018:
0x00002400
RD3 0x02445020:
0x00002458
RD2 0x02445028:
0x00002458
RD1 0x02445030:
0x00002458
MDC 0x02445038:
0x00002440
RD0 0x02445040:
0x00002458
MDC 0x02445048:
0x00002400
COMP 0x02445050:
0x00002000
TXC 0x02445058:
0x00002400
RXC 0x02445060:
0x00002458
TX CTL 0x02445068:
0x00002400
RX CTL 0x02445070:
0x00002458
Can you disclose used PHY ?
Connects directly to the rgmii port of the switch without phy
Sorry for the late response.
The switch rgmii port configuration problem, the problem has been resolved. thank you
