Jetson AGX orin 32G RGMII RTL8211
Thank you for taking the time to review my inquiry amidst your busy schedule. I am currently using the Jetson AGX orin 32G core board and a customized carrier board. We want to enable both AQR113C and RGMII network interfaces simultaneously, AQR113C can be used now, but the RGMII uses RTL8211F as PHY can not work, and the RGMII’s SCH is shown in the attachment. The board is using L4T 35.4.1. I would like to inquire about the following question: First,Is there any problem with the hardware connection? second, Is there a driver for RTL8211F in L4T35.4.1? Has this device been called in the dtb? third,If L4T 35.4.1 does not have a driver for RTL8211F, or if the dtb does not call this device, how should we modify it to ensure that RGMII works? thanks.
Same PHY was discussed here and eventually worked.
It seems that there is something wrong with the signal connection method of U19, please ask your H/W to confirm.
