2d matrix passing values help with this code
// example1.cpp : Defines the entry point for the console application.
#include “stdafx.h”
#include <assert.h>
#include <cuda.h>
#include<stdio.h>
void matmul(float **a,float **b,float **c,int N);
int i,j,k;
 for(i=0;i<N;i++)
for(j=0;j<N;j++)
for(k=0;k<N;k++)
c[i][j] += a[i][k]*b[k][j];
 for(i=0;i<N;i++)
           for(j=0;j<N;j++)
               printf("%f\t",a[i][j]);
        printf("\n");
 for(i=0;i<N;i++)
for(j=0;j<N;j++)
printf(“%f\t”,b[i][j]);
   printf("\n");
  for(i=0;i<N;i++)
    for(j=0;j<N;j++)
        printf("%f\t",c[i][j]);
    printf("\n");
global void matmulondevice(float **a,float **b,float **c)
int i = threadIdx.x;
int j = threadIdx.y;
c[i][j]= a[i][j]+b[i][j];
int main(void)
float **a,**b,**c;
float **a_d,**b_d,**c_d;
int N = 2;
a = (float**)malloc(sizeof(float *)*N);
b = (float**)malloc(sizeof(float *)*N);
c = (float**)malloc(sizeof(float *)*N);
cudaMalloc((void **) &a_d, sizeof(float*)*N);
cudaMalloc((void **) &b_d, sizeof(float*)*N);
cudaMalloc((void **) &c_d, sizeof(float*)*N);
int i;
int j;
for(i=0;i<N;i++)
                a[i] = (float*)malloc(sizeof(float)*N);
                b[i] = (float*)malloc(sizeof(float)*N);
                c[i] = (float*)malloc(sizeof(float)*N);
for(i=0;i<N;i++)
cudaMalloc((void **) &a_d[i], sizeof(float)*N);
cudaMalloc((void **) &b_d[i], sizeof(float)*N);
cudaMalloc((void **) &c_d[i], sizeof(float)*N);
for(i=0;i<N;i++)
for(j=0;j<N;j++)
printf(“Enter the %d,%d element”,i,j);
scanf(“%f”,&a[i][j]);
scanf(“%f”,&b[i][j]);
c[i][j]=0;
matmul(a,b,c,N);
for(i=0;i<N;i++)
for(j=0;j<N;j++)
c[i][j]=0;
dim3 dimBlock(2,2);
matmulondevice<<<1,dimBlock>>>(a_d,b_d,c_d);
for(i=0;i<N;i++)
cudaMemcpy(c[i], c_d[i], sizeof(float)*N, cudaMemcpyDeviceToHost);
for(i=0;i<N;i++)
for(j=0;j<N;j++)
printf(“%f\t”,c[i][j]);
    printf("\n");
free(a);free(B);free©;
cudaFree(a_d);cudaFree(b_d);cudaFree(c_d);
The C function works fine,
The kernel however is the problem, it gives 0 for all values.After the values are retrieved from the device and printed with the loop statement.
My guess is i am not accessing the thredid’s in the right way or i am not passing the values correctly to the kernel.
please help me
  1. your host code, matrix multiplication must be corrected as
[codebox]void matmul(float **a,float **b,float **c,int N)
int i,j,k;
for(i=0; i<N;i++){
	for(j=0;j<N;j++){
		c[i][j] = 0.0 ;  // you miss this
		for(k=0; k<N;k++){
}[/codebox]
  1. you original code to allocate pointer array in device is wrong
your original code
[codebox] cutilSafeCall( cudaMalloc((void *) &a_d, sizeof(float)*N) ) ;
cutilSafeCall( cudaMalloc((void **) &b_d, sizeof(float*)*N) ) ;
cutilSafeCall( cudaMalloc((void **) &c_d, sizeof(float*)*N) ) ;
for(i=0; i < N ; i++){
	cutilSafeCall( cudaMalloc((void **) &a_d[i], sizeof(float)*N) );
	cutilSafeCall( cudaMalloc((void **) &b_d[i], sizeof(float)*N) );
	cutilSafeCall( cudaMalloc((void **) &c_d[i], sizeof(float)*N) );
}[/codebox]
Question: why does your original code fail?
ans: when you do “cudaMalloc((void *) &a_d, sizeof(float)*N)”, then a_d is a pointer pointing
to memory in device, so float* a_d[i] is an address in device, you cannot access this address
in host code. However “cudaMalloc((void **) &a_d[i], sizeof(float)*N)” means that you want to
allocate a device memory with size “sizeof(float)*N” and put the address into
device variable a_d[i]
this is the problem because a_d[i] cannot be access by host code.
you can use following code
float **a_d_host,**b_d_host,**c_d_host;
a_d_host = (float**)malloc(sizeof(float *)*N);
b_d_host = (float**)malloc(sizeof(float *)*N);
c_d_host = (float**)malloc(sizeof(float *)*N);
	cutilSafeCall( cudaMalloc((void **) &a_d_host[i], sizeof(float)*N) );
	cutilSafeCall( cudaMalloc((void **) &b_d_host[i], sizeof(float)*N) );
	cutilSafeCall( cudaMalloc((void **) &c_d_host[i], sizeof(float)*N) );
for(i=0;i < N;i++){
	CUDA_SAFE_CALL(cudaMemcpy(a_d, a_d_host, sizeof(float*)*N , cudaMemcpyHostToDevice) );
	CUDA_SAFE_CALL(cudaMemcpy(b_d, b_d_host, sizeof(float*)*N , cudaMemcpyHostToDevice) );
	CUDA_SAFE_CALL(cudaMemcpy(c_d, c_d_host, sizeof(float*)*N , cudaMemcpyHostToDevice) );
} [/codebox]
now you put all address of device memory into host pointer array a_d_host, b_d_host and c_d_host
and then copy whole pointer array into device memory pointing by a_d, b_d, c_d
  1. copy data from host to device
[codebox] for(i=0;i < N;i++){
	CUDA_SAFE_CALL(cudaMemcpy(a_d_host[i], a[i], sizeof(float)*N , cudaMemcpyHostToDevice) );
	CUDA_SAFE_CALL(cudaMemcpy(b_d_host[i], b[i], sizeof(float)*N , cudaMemcpyHostToDevice) );
} [/codebox]
  1. copy data from device to host
[codebox] for(i=0;i<N;i++){
	cudaMemcpy(c[i], c_d_host[i], sizeof(float)*N, cudaMemcpyDeviceToHost);
}[/codebox]
  1. your kernel function do “matrix addition”, not “matrix multiplication”
  2. you can use 1-D array with 2-D logical index, this is more simple
Thank you Lung Sheng Chien. Using a 1D format is easier inface i implemented it after i made the post here . But i really wanted to use this 2D addressing format. I’ll implement your code and get it working soon.
well, i just found this one and had to dig up this old threads …i have a very similar problem…
please take a look at my code…
i wonder whats wrong with my for loop in the middle of the code.
for(i=0; i<X; i++)
CUDA_SAFE_CALL( cudaMemcpy(c_d[i], c_d_host[i], Ysizeof(int), cudaMemcpyHostToDevice) );
would you please help? Thanks in advance.
int main(int argc, char *argv)
int i, j;
int **crray2d;
int **c_d;
int **c_d_host;
crray2d = (int**)malloc(Xsizeof(int));
for(i=0; i<X; i++)
crray2d[i] = (int*)malloc(Y*sizeof(int));
CUDA_SAFE_CALL( cudaMalloc((void **) &c_d, Xsizeof(int)) );
c_d_host = (int**)malloc(Xsizeof(int));
for(i=0; i<X; i++)
CUDA_SAFE_CALL( cudaMalloc((void **) &c_d_host[i], Y*sizeof(int)) );
for(i=0; i<X; i++)
/* at this point i can not pass this point so the followings are not important now */
//dim3 dimBlock(X,Y);
//MatAdd<<<1,dimBlock>>>(c_d);
//for(i=0;i < X;i++){
// cudaMemcpy(crray2d, c_d, Ysizeof(int), cudaMemcpyDeviceToHost) ;
for(i=0; i<X; i++)
int i, j;
int **crray2d;
int **c_d;
int **c_d_host;
for(i=0; i<X; i++)
for(i=0; i<X; i++)
for(i=0; i<X; i++)
