It is well know that earlier SDK examples would produce compilation errors with gcc 4.4. About two days I downloaded the 3.1 beta SDK and compiled it without encountering a single error - OpenSuSE 11.2 with gcc 4.4.1. So CUDA now works with gcc 4.4.x?
Too early to tell. I would say yes, if you and someone else using another distribution(preferably ubuntu LTS) can successfully run ALL of the SDK examples without any problems.
I can confirm that the 3.1 beta SDK compiles without errors on ubuntu 10.04.
All code examples seem to be working.
N.
N.
Nico, in another post, you said
yep, used gcc4.3 for compiling the SDK.
examples are running just fine
N.
I’m curious about gcc4.4 (as in default install)
have you tested both gcc4.4 and 4.3?
Indeed, I posted that one for the 3.0 toolkit.
Only tried gcc 4.4.3 with the 3.1 beta though. Worked like a charm so I didn’t try 4.3.
N.
