3.3 Where is Foundation.lib ?
I’m new to Physx (and also to this forum) and i’d like to use SPH with physx. I’m having trouble creating the PxFoundation :
#include <extensions/PxDefaultErrorCallback.h>
#include <extensions/PxDefaultAllocator.h>
#include <foundation/PxFoundation.h>
#include <PxPhysicsAPI.h>
#include <iostream>
using namespace physx;
#pragma comment(lib, "PhysX3_x64.lib")
#pragma comment(lib, "Foundation.lib")
#pragma comment(lib, "PhysX3Extensions.lib")
#pragma comment(lib, "PhysX3Cooking_x64.lib")
#pragma comment(lib, "PxTask.lib")
int main(int argc, char *argv[])
	bool recordMemoryAllocations = true;
	PxDefaultErrorCallback gDefaultErrorCallback;
	PxDefaultAllocator gDefaultAllocatorCallback;
	PxFoundation *mFoundation = PxCreateFoundation(PX_PHYSICS_VERSION, gDefaultAllocatorCallback, gDefaultErrorCallback);
	if(!mFoundation)
		std::cout<<"PxCreateFoundation failed!"<<std::endl;
	return 0;
Compilation seems to work fine, but at the execution here is what i get :
1>------ Début de la génération : Projet : physxFluid, Configuration : Debug Win32 ------
1>main.obj : error LNK2019: symbole externe non résolu "public: __thiscall physx::PxDefaultErrorCallback::PxDefaultErrorCallback(void)" (??0PxDefaultErrorCallback@physx@@QAE@XZ) référencé dans la fonction _main
1>main.obj : error LNK2019: symbole externe non résolu "public: virtual __thiscall physx::PxDefaultErrorCallback::~PxDefaultErrorCallback(void)" (??1PxDefaultErrorCallback@physx@@UAE@XZ) référencé dans la fonction _main
1>main.obj : error LNK2019: symbole externe non résolu __imp__PxCreateFoundation référencé dans la fonction _main
1>G:\projects\physxFluid\Debug\physxFluid.exe : fatal error LNK1120: 3 externes non résolus
========== Génération : 0 a réussi, 1 a échoué, 0 mis à jour, 0 a été ignoré ==========
I don’t have any Foundation.lib in my physx installation. Any idea ? (i’m using visual studio 2012 professional)
Thanks !
Muska17
Include in your project properties -> Linker-> Input-> Additional dependencies:
Doing so should not give you that linker error.
Greetings.
Thanks for your answer. I thought the pragma comment directives would do the job.
However i still have a problem. At the compilation :
fatal error C1189: #error :  Exactly one of NDEBUG and _DEBUG needs to be defined by preprocessor
I also tried to compile the same code with gcc on linux, and i have the same message ! :(
Here is my Makefile :
COMPILER=g++
OPTIONS=-std=gnu++0x
LIBS=./Lib/linux64/
HEADERS=./Include/
SRC=*.cpp
LINKS=-lPhysX3CharacterKinematic_x64 -lPhysX3Common_x64 -lPhysX3Cooking_x64 -lPhysX3Extensions -lPhysX3Vehicle -lPhysX3_x64 -lPhysXProfileSDK -lPhysXVisualDebuggerSDK -lPxTask
all:
	$(COMPILER) $(OPTIONS) -I$(HEADERS) -L$(LIBS) $(SRC)
clean:
	rm -f *.out *.o *~
My code :
#include <iostream>
	if(!mFoundation)
	return 0;
And the tree of my project :
Include
  vehicle
  particles
Lib
  linux32
  linux64
main.cpp
Makefile
Solved adding :
OPTIONS=-std=gnu++0x -DNDEBUG
pthread required on linux :
LINKS= [...] -lpthread
