U-Boot tegra-l4t-r32.7.6_good detects new module as 2GB:
U-Boot 2020.04-00005-ge5ea88b0bc (Dec 14 2024 - 18:46:43 +0800)
SoC: tegra210
Model: OKdo Nano C100
Board: NVIDIA P3450-0000
DRAM: 2 GiB
MMC: sdhci@700b0400: 1, sdhci@700b0600: 0
Loading Environment from MMC... *** Warning - bad CRC, using default environment
Checking the hardware-nvidia-platform-t210-porg.patch patch provided in 32.7.5 overlay, tegra210-porg-p3448-emc-a00.dtsi in 32.7.6 is still missing the table for nvidia,ram-code = <1>. I need to load an overlay to include that section to boot the kernel:
Deleting existing nvidia,tegra210-sdhci node at 700B0400...
Deleting existing nvidia,tegra210-emc node at 7001B000...
Retrieving file: /boot/tegra210-p3448-common-sdmmc3.dtbo
4202 bytes read in 27 ms (151.4 KiB/s)
Retrieving file: /boot/tegra210-porg-p3448-emc-a00.dtbo
73917 bytes read in 29 ms (2.4 MiB/s)
## Flattened Device Tree blob at 83100000
Booting using the fdt blob at 0x83100000
ERROR: reserving fdt memory region failed (addr=0 size=0)
Using Device Tree in place at 0000000083100000, end 0000000083149fff
copying carveout for /host1x@50000000/dc@54200000...
copying carveout for /host1x@50000000/dc@54240000...
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.337-tegra (buildbrain@mobile-u64-5499-d7000) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #1 SMP PREEMPT Mon Nov 4 23:41:41 PST 2024
[ 0.000000] Boot CPU: AArch64 Processor [411fd071]
[ 0.000000] OF: fdt:memory scan node memory@80000000, reg size 32,
[ 0.000000] OF: fdt: - 80000000 , 3f200000
[ 0.000000] OF: fdt: - c0000000 , 3ee00000
[ 0.000000] Found tegra_fbmem: 00800000@92cb4000
[ 0.000000] earlycon: uart8250 at MMIO32 0x0000000070006000 (options '')
[ 0.000000] bootconsole [uart8250] enabled
[ 0.397553] Node override does not have targer node
[ 0.700061] OF: /thermal-zones/PLL-therm/cooling-maps/map-tegra-dram: could not find phandle
[ 0.700094] missing cooling_device property
[ 0.700109] failed to build thermal zone PLL-therm: -22
[ 1.221534] tegradc tegradc.1: dpd enable lookup fail:-19
[ 1.391513] imx219 7-0010: imx219_board_setup: error during i2c read probe (-121)
[ 1.391636] imx219 7-0010: board setup failed
[ 1.415824] imx219 8-0010: imx219_board_setup: error during i2c read probe (-121)
[ 1.415911] imx219 8-0010: board setup failed
