We are using a custom carrier board for a Jetson Nano, with a Yocto custom firmware based on L4T 32.7.4, with the patch for tegra210-porg-p3448-emc-a00.dtsi from 32.7.5 for the new memory chips as mentioned in PCN PCN211181.
The Jetson Nano module is a 4GiB module with part number 900-13448-0020-000. Modules with the older memory chips running our firmware boot normally, and report memory as 4GiB. Jetson modules with the new memory chips also boot OK, but report memory as 2GiB. How do I persuade module with the new memory chips to find all 4 GiB of memory?
The serial port output on boot is below:
[0000.271] [L4T TegraBoot] (version 00.00.2018.01-l4t-b1625959)
[0000.277] Processing in cold boot mode Bootloader 2
[0000.281] A02 Bootrom Patch rev = 1023
[0000.285] Power-up reason: pmc por
[0000.288] No Battery Present
[0000.291] pmic max77620 reset reason
[0000.294] pmic max77620 NVERC : 0x50
[0000.297] RamCode = 1
[0000.300] Platform has DDR4 type RAM
[0000.303] max77620 disabling SD1 Remote Sense
[0000.307] Setting DDR voltage to 1125mv
[0000.311] Serial Number of Pmic Max77663: 0xc1269
[0000.319] Entering ramdump check
[0000.322] Get RamDumpCarveOut = 0x0
[0000.325] RamDumpCarveOut=0x0, RamDumperFlag=0xe59ff3f8
[0000.330] Last reboot was clean, booting normally!
[0000.335] Sdram initialization is successful
[0000.339] SecureOs Carveout Base=0x00000000ff800000 Size=0x0080000
0
[0000.345] Lp0 Carveout Base=0x00000000ff780000 Size=0x00001000
[0000.351] BpmpFw Carveout Base=0x00000000ff700000 Size=0x00080000
[0000.357] GSC1 Carveout Base=0x00000000ff600000 Size=0x00100000
[0000.363] GSC2 Carveout Base=0x00000000ff500000 Size=0x00100000
[0000.368] GSC4 Carveout Base=0x00000000ff400000 Size=0x00100000
[0000.374] GSC5 Carveout Base=0x00000000ff300000 Size=0x00100000
[0000.380] GSC3 Carveout Base=0x00000000bf300000 Size=0x00d00000
[0000.396] RamDump Carveout Base=0x00000000ff280000 Size=0x00080000
[0000.402] Platform-DebugCarveout: 0
[0000.406] Nck Carveout Base=0x00000000ff080000 Size=0x00200000
[0000.411] Non secure mode, and RB not enabled.
[0000.416] *** Booting BFS0.
[0000.418] Initialize FailControl
[0000.421] Read PT from (0:3)
[0000.436] Csd NumOfBlocks=0
[0000.445] Skip crc32 and magic check
[0000.449] Using BFS PT to query partitions
[0000.453] PT: Partition LNX NOT found !
[0000.457] *** Booting KFS0.
[0000.459] NvTbootFailControlDoFailover: No failover; Continuing ..
[0000.465] BoardID = 3448, SKU = 0x2
[0000.468] Not Nano-SD or !QSPI-ONLY, check GPT table first …
[0000.474] Read GPT from (0:3)
[0000.486] Using GPT Primary to query partitions
[0000.491] NvTbootFailControlDoFailover: No failover; Continuing ..
[0000.497] Loading Tboot-CPU binary
[0000.503] Verifying TBC in OdmNonSecureSBK mode
[0000.514] Bootloader load address is 0xa0000000, entry address is
0xa0000258
[0000.521] Bootloader downloaded successfully.
[0000.525] Downloaded Tboot-CPU binary to 0xa0000258
[0000.530] MAX77620_GPIO5 configured
[0000.533] CPU power rail is up
[0000.536] CPU clock enabled
[0000.540] Performing RAM repair
[0000.543] Updating A64 Warmreset Address to 0xa00002e9
[0000.548] BoardID = 3448, SKU = 0x2
[0000.551] Not Nano-SD or !QSPI-ONLY, check GPT table first …
[0000.557] NvTbootFailControlDoFailover: No failover; Continuing ..
[0000.563] Loading NvTbootBootloaderDTB
[0000.580] Verifying NvTbootBootloaderDTB in OdmNonSecureSBK mode
[0000.654] Bootloader DTB Load Address: 0x83000000
[0000.659] BoardID = 3448, SKU = 0x2
[0000.662] Not Nano-SD or !QSPI-ONLY, check GPT table first …
[0000.668] Loading NvTbootKernelDTB
[0000.685] Verifying NvTbootKernelDTB in OdmNonSecureSBK mode
[0000.758] Kernel DTB Load Address: 0x83100000
[0000.762] BoardID = 3448, SKU = 0x2
[0000.766] Not Nano-SD or !QSPI-ONLY, check GPT table first …
[0000.772] NvTbootFailControlDoFailover: No failover; Continuing ..
[0000.779] Loading cboot binary
[0000.790] Verifying EBT in OdmNonSecureSBK mode
[0000.831] Bootloader load address is 0x92c00000, entry address is
0x92c00258
[0000.838] Bootloader downloaded successfully.
[0000.843] BoardID = 3448, SKU = 0x2
[0000.846] Not Nano-SD or !QSPI-ONLY, check GPT table first …
[0000.852] NvTbootFailControlDoFailover: No failover; Continuing ..
[0000.858] PT: Partition NCT NOT found !
[0000.862] Warning: Find Partition via PT Failed
[0000.866] Next binary entry address: 0x92c00258
[0000.871] BoardId: 3448
[0000.875] Overriding pmu board id with proc board id
[0000.880] Display board id is not available
[0000.884] BoardID = 3448, SKU = 0x2
[0000.888] Not Nano-SD or !QSPI-ONLY, check GPT table first …
[0000.893] NvTbootFailControlDoFailover: No failover; Continuing ..
[0000.907] Verifying SC7EntryFw in OdmNonSecureSBK mode
[0000.997] /bpmp deleted
[0001.000] SC7EntryFw header found loaded at 0xff700000
[0001.408] OVR2 PMIC
[0001.410] Bpmp FW successfully loaded
[0001.414] BoardID = 3448, SKU = 0x2
[0001.417] Not Nano-SD or !QSPI-ONLY, check GPT table first …
[0001.423] NvTbootFailControlDoFailover: No failover; Continuing ..
[0001.430] WB0 init successfully at 0xff780000
[0001.434] Verifying NvTbootWb0 in OdmNonSecureSBK mode
[0001.439] Set NvDecSticky Bits
[0001.443] GSC2 address ff53fffc value c0edbbcc
[0001.449] GSC MC Settings done
[0001.452] BoardID = 3448, SKU = 0x2
[0001.455] Not Nano-SD or !QSPI-ONLY, check GPT table first …
[0001.462] TOS Image length 53680
[0001.465] Monitor size 53680
[0001.468] OS size 0
[0001.473] Secure Os AES-CMAC Verification Success!
[0001.478] TOS image cipher info: plaintext
[0001.482] Loading and Validation of Secure OS Successful
[0001.498] SC7 Entry Firmware - 0xff700000, 0x4000
[0001.502] NvTbootPackSdramParams: start.
[0001.507] NvTbootPackSdramParams: done.
[0001.511] Tegraboot started after 201972 us
[0001.515] Basic modules init took 719748 us
[0001.519] Sec Bootdevice Read Time = 58 ms, Read Size = 3682 KB
[0001.525] Sec Bootdevice Write Time = 0 ms, Write Size = 0 KB
[0001.530] Next stage binary read took 7401 us
[0001.535] Carveout took -34801 us
[0001.538] CPU initialization took 653482 us
[0001.542] Total time taken by TegraBoot 1345830 us
[0001.546] Starting CPU & Halting co-processor
64NOTICE: BL31: v1.3(release):f9bf1e1
NOTICE: BL31: Built : 21:16:40, Jun 8 2023
ERROR: Error initializing runtime service trusty_fast
[0001.669] RamCode = 1
[0001.678] LPDDR4 Training: found 4 entries (2 nominal, 2 derated)
[0001.684] EMC Training (SRC-freq: 204000; DST-freq: 1600000)
[0001.696] EMC Training Successful
[0001.699] EMC Training (SRC-freq: 204000; DST-freq: 1600000)
[0001.712] EMC Training Successful
[0001.715] 408000 not found in DVFS table
[0001.755] RamCode = 1
[0001.761] DT Write: emc-table@204000 succeeded
[0001.769] DT Write: emc-table@1600000 succeeded
[0001.776] DT Write: emc-table-derated@204000 succeeded
[0001.785] DT Write: emc-table-derated@1600000 succeeded
[0001.790] LPDDR4 Training: Write DT: Number of tables = 4
[0001.842]
[0001.843] Debug Init done
[0001.845] Marked DTB cacheable
[0001.848] Bootloader DTB loaded at 0x83000000
[0001.853] Marked DTB cacheable
[0001.856] Kernel DTB loaded at 0x83100000
[0001.860] DeviceTree Init done
[0001.866] param is not found for property nvidia,io-hv !
[0001.871] param is not found for property nvidia,io-hv !
[0001.876] param is not found for property nvidia,io-hv !
[0001.882] param is not found for property nvidia,io-hv !
[0001.887] param is not found for property nvidia,io-hv !
[0001.893] param is not found for property nvidia,io-hv !
[0001.898] param is not found for property nvidia,io-hv !
[0001.904] param is not found for property nvidia,io-hv !
[0001.909] param is not found for property nvidia,io-hv !
[0001.914] param is not found for property nvidia,io-hv !
[0001.920] param is not found for property nvidia,io-hv !
[0001.925] param is not found for property nvidia,io-hv !
[0001.931] param is not found for property nvidia,io-hv !
[0001.937] param is not found for property nvidia,io-hv !
[0001.942] param is not found for property nvidia,io-hv !
[0001.948] param is not found for property nvidia,io-hv !
[0001.953] param is not found for property nvidia,io-hv !
[0001.958] param is not found for property nvidia,io-hv !
[0001.964] param is not found for property nvidia,io-hv !
[0001.969] param is not found for property nvidia,io-hv !
[0001.981] Pinmux applied successfully
[0001.985] gicd_base: 0x50041000
[0001.989] gicc_base: 0x50042000
[0001.992] Interrupts Init done
[0001.996] Using base:0x60005090 & irq:208 for tick-timer
[0002.002] Using base:0x60005098 for delay-timer
[0002.006] platform_init_timer: DONE
[0002.010] Timer(tick) Init done
[0002.013] osc freq = 38400 khz
[0002.018]
[0002.019] Welcome to L4T Cboot
[0002.022]
[0002.023] Cboot Version: 00.00.2018.01-t210-acb23272
[0002.028] calling constructors
[0002.031] initializing heap
[0002.033] initializing threads
[0002.036] initializing timers
[0002.039] creating bootstrap completion thread
[0002.044] top of bootstrap2()
[0002.046] CPU: ARM Cortex A57
[0002.049] CPU: MIDR: 0x411FD071, MPIDR: 0x80000000
[0002.054] initializing platform
[0002.109] Config for emmc ddr50 mode completed
[0002.113] sdmmc bdev is already initialized
[0002.117] Enable APE clock
[0002.120] Un-powergate APE partition
[0002.123] of_register: registering tegra_udc to of_hal
[0002.128] of_register: registering inv20628-driver to of_hal
[0002.134] of_register: registering ads1015-driver to of_hal
[0002.140] of_register: registering lp8557-bl-driver to of_hal
[0002.145] of_register: registering bq2419x_charger to of_hal
[0002.151] of_register: registering bq27441_fuel_gauge to of_hal
[0002.164] gpio framework initialized
[0002.167] of_register: registering tca9539_gpio to of_hal
[0002.173] of_register: registering tca9539_gpio to of_hal
[0002.178] of_register: registering i2c_bus_driver to of_hal
[0002.183] of_register: registering i2c_bus_driver to of_hal
[0002.189] of_register: registering i2c_bus_driver to of_hal
[0002.195] pmic framework initialized
[0002.198] of_register: registering max77620_pmic to of_hal
[0002.204] regulator framework initialized
[0002.208] of_register: registering tps65132_bl_driver to of_hal
[0002.213] initializing target
[0002.220] gpio_driver_register: register ‘tegra_gpio_driver’ drive
r
[0002.229] board ID = D78, board SKU = 2
[0002.236] fixed regulator driver initialized
[0002.257] initializing OF layer
[0002.260] NCK carveout not present
[0002.264] Skipping dts_overrides
[0002.268] of_children_init: Ops found for compatible string nvidia
,tegra210-i2c
[0002.286] I2C Bus Init done
[0002.289] of_children_init: Ops found for compatible string nvidia
,tegra210-i2c
[0002.300] I2C Bus Init done
[0002.303] of_children_init: Ops found for compatible string nvidia
,tegra210-i2c
[0002.314] I2C Bus Init done
[0002.316] of_children_init: Ops found for compatible string nvidia
,tegra210-i2c
[0002.327] I2C Bus Init done
[0002.330] of_children_init: Ops found for compatible string nvidia
,tegra210-i2c
[0002.341] I2C Bus Init done
[0002.344] of_children_init: Ops found for compatible string maxim,
max77620
[0002.355] max77620_init using irq 118
[0002.359] register ‘maxim,max77620’ pmic
[0002.364] gpio_driver_register: register ‘max77620-gpio’ driver
[0002.370] of_children_init: Ops found for compatible string nvidia
,tegra210-i2c
[0002.381] I2C Bus Init done
[0002.385] NCK carveout not present
[0002.396] Find /i2c@7000c000’s alias i2c0
[0002.400] get eeprom at 1-a0, size 256, type 0
[0002.410] Find /i2c@7000c500’s alias i2c2
[0002.414] get eeprom at 3-a0, size 256, type 0
[0002.418] get eeprom at 3-ae, size 256, type 0
[0002.423] pm_ids_update: Updating 1,a0, size 256, type 0
[0002.428] I2C slave not started
[0002.431] I2C write failed
[0002.434] Writing offset failed
[0002.437] eeprom_init: EEPROM read failed
[0002.441] pm_ids_update: eeprom init failed
[0002.445] pm_ids_update: Updating 3,a0, size 256, type 0
[0002.475] pm_ids_update: The pm board id is 3448-0002-402
[0002.482] Adding plugin-manager/ids/3448-0002-402=/i2c@7000c500:mo
dule@0x50
[0002.491] pm_ids_update: pm id update successful
[0002.495] pm_ids_update: Updating 3,ae, size 256, type 0
[0002.525] eeprom_init: EEPROM incompatible version found
[0002.531] pm_ids_update: eeprom init failed
[0002.561] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0002.567] shim_eeprom_update_mac:267: Failed to update 0 MAC addre
ss in DTB
[0002.575] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0002.581] shim_eeprom_update_mac:267: Failed to update 1 MAC addre
ss in DTB
[0002.589] updating /chosen/nvidia,ethernet-mac node 3c:6d:66:15:02
:01
[0002.596] Plugin Manager: Parse ODM data 0x000a4000
[0002.609] shim_cmdline_install: /chosen/bootargs: console=ttyS0,11
5200 fbcon=map:0 net.ifnames=0 sdhci_tegra.en_boot_part_access=1 qu
iet loglevel=1
[0002.630] Find /i2c@7000c000’s alias i2c0
[0002.634] get eeprom at 1-a0, size 256, type 0
[0002.644] Find /i2c@7000c500’s alias i2c2
[0002.648] get eeprom at 3-a0, size 256, type 0
[0002.652] get eeprom at 3-ae, size 256, type 0
[0002.657] pm_ids_update: Updating 1,a0, size 256, type 0
[0002.662] I2C slave not started
[0002.665] I2C write failed
[0002.667] Writing offset failed
[0002.671] eeprom_init: EEPROM read failed
[0002.674] pm_ids_update: eeprom init failed
[0002.679] pm_ids_update: Updating 3,a0, size 256, type 0
[0002.709] pm_ids_update: The pm board id is 3448-0002-402
[0002.715] Adding plugin-manager/ids/3448-0002-402=/i2c@7000c500:mo
dule@0x50
[0002.722] pm_ids_update: pm id update successful
[0002.727] pm_ids_update: Updating 3,ae, size 256, type 0
[0002.757] eeprom_init: EEPROM incompatible version found
[0002.762] pm_ids_update: eeprom init failed
[0002.792] Add serial number:1424624334816 as DT property
[0002.800] Applying platform configs
[0002.807] platform-init is not present. Skipping
[0002.812] calling apps_init()
[0002.833] Found 16 GPT partitions in “sdmmc3_user”
[0002.838] Proceeding to Cold Boot
[0002.841] starting app android_boot_app
[0002.845] Device state: unlocked
[0002.848] display console init
[0002.858] could not find regulator
[0002.881] hdmi cable not connected
[0002.884] is_hdmi_needed: HDMI not connected, returniDT entry for
leds-pwm not found
n[0002.896] g false
[0002.898] hdmi is not connected
[0002.901] sor0 is not supported
[0002.904] display_console_init: no valid display out_type
[0002.912] subnode volume_up is not found !
[0002.916] subnode back is not found !
[0002.920] subnode volume_down is not found !
[0002.924] subnode menu is not found !
[0002.928] Gpio keyboard init success
[0002.975] found decompressor handler: lz4-legacy
[0002.989] decompressing blob (type 1)…
[0003.029] display_resolution: No display init
[0003.033] Failed to retrieve display resolution
[0003.037] Could not load/initialize BMP blob…ignoring
[0003.043] -------> se_aes_verify_sbk_clear: 747
[0003.047] se_aes_verify_sbk_clear: Error
[0003.051] SE operation failed
[0003.054] bl_battery_charging: connected to external power supply
[0003.064] display_console_ioctl: No display init
[0003.068] switch_backlight failed
[0003.078] device_query_partition_size: failed to open partition sd
mmc3_user:MSC !
[0003.085] MSC Partition not found
[0003.095] device_query_partition_size: failed to open partition sd
mmc3_user:USP !
[0003.102] USP partition read failed!
[0003.106] blob_init: blob-partition USP header read failed
[0003.111] android_boot Unable to update recovery partition
[0003.117] kfs_getpartname: name = LNX
[0003.120] Loading kernel from LNX
[0003.216] load kernel from storage
[0003.225] decompressor handler not found
[0003.255] Successfully loaded kernel and ramdisk images
[0003.260] board ID = D78, board SKU = 2
[0003.265] display_resolution: No display init
[0003.270] Failed to retrieve display resolution
[0003.274] bmp blob is not loaded and initialized
[0003.279] Failed to display boot-logo
[0003.282] NCK carveout not present
[0003.286] Skipping dts_overrides
[0003.289] NCK carveout not present
[0003.300] Find /i2c@7000c000’s alias i2c0
[0003.304] get eeprom at 1-a0, size 256, type 0
[0003.314] Find /i2c@7000c500’s alias i2c2
[0003.318] get eeprom at 3-a0, size 256, type 0
[0003.322] get eeprom at 3-ae, size 256, type 0
[0003.327] pm_ids_update: Updating 1,a0, size 256, type 0
[0003.332] I2C slave not started
[0003.335] I2C write failed
[0003.338] Writing offset failed
[0003.341] eeprom_init: EEPROM read failed
[0003.345] pm_ids_update: eeprom init failed
[0003.349] pm_ids_update: Updating 3,a0, size 256, type 0
[0003.379] pm_ids_update: The pm board id is 3448-0002-402
[0003.386] Adding plugin-manager/ids/3448-0002-402=/i2c@7000c500:mo
dule@0x50
[0003.394] pm_ids_update: pm id update successful
[0003.399] pm_ids_update: Updating 3,ae, size 256, type 0
[0003.429] eeprom_init: EEPROM incompatible version found
[0003.434] pm_ids_update: eeprom init failed
[0003.464] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0003.470] shim_eeprom_update_mac:267: Failed to update 0 MAC addre
ss in DTB
[0003.478] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0003.484] shim_eeprom_update_mac:267: Failed to update 1 MAC addre
ss in DTB
[0003.493] updating /chosen/nvidia,ethernet-mac node 3c:6d:66:15:02
:01
[0003.499] Plugin Manager: Parse ODM data 0x000a4000
[0003.512] shim_cmdline_install: /chosen/bootargs: console=ttyS0,11
iet loglevel=1
[0003.526] Add serial number:1424624334816 as DT property
[0003.535] “bpmp” doesn’t exist, creating
[0003.541] Updated bpmp info to DTB
[0003.546] Updated initrd info to DTB
[0003.550] “proc-board” doesn’t exist, creating
[0003.556] Updated board info to DTB
[0003.559] “pmu-board” doesn’t exist, creating
[0003.565] Updated board info to DTB
[0003.568] “display-board” doesn’t exist, creating
[0003.574] Updated board info to DTB
[0003.578] “reset” doesn’t exist, creating
[0003.582] Updated reset info to DTB
[0003.586] display_console_ioctl: No display init
[0003.590] display_console_ioctl: No display init
[0003.595] display_console_ioctl: No display init
[0003.599] Cmdline: tegraid=21.1.2.0.0 ddr_die=2048M@2048M section=
256M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 e
mc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 cons
ole=ttyS0,115200n8 debug_uartport=lsport,4 earlyprintk=uart8250-32b
it,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0
xff780000 core_edp_mv=1125 core_edp_ma=4000 gpt
[0003.634] DTB cmdline: console=ttyS0,115200 fbcon=map:0 net.ifname
s=0 sdhci_tegra.en_boot_part_access=1 quiet loglevel=1
[0003.646] Updated bootarg info to DTB
[0003.649] Adding uuid 00000001644147c404000000190480c0 to DT
[0003.655] Adding eks info 0 to DT
[0003.661] WARNING: Failed to pass NS DRAM ranges to TOS, err: -7
[0003.667] Updated memory info to DTB
[0003.676] set vdd_core voltage to 1125 mv
[0003.680] setting ‘vdd-core’ regulator to 1125000 micro volts
[0003.686] Found secure-pmc; disable BPMP
U-Boot 2020.04 (Mar 31 2022 - 18:26:30 +0000)
SoC: tegra210
Model: NVIDIA Jetson Nano Developer Kit
Board: NVIDIA P3450-0002 Imetrum
DRAM: 2 GiB
MMC: sdhci@700b0000: 1, sdhci@700b0600: 0
Loading Environment from MMC… *** Warning - bad CRC, using default environment
In: serial
Out: serial
Err: serial
Net: No ethernet found.
Hit any key to stop autoboot: 0
Normal or update boot
ustate = 0
Loading FIT from 0:0x1
18395483 bytes read in 426 ms (41.2 MiB/s)
Loaded OK
Loading kernel from FIT Image at 90000000 …
Using ‘conf-_ddot___ddot___ddot___ddot__nvidia_platform_t210_por
g_kernel-dts_tegra210-p3448-0002-imetrum-vc-mipi.dtb’ configuration
Verifying Hash Integrity … sha256,rsa2048:vector+ OK
Trying ‘kernel-1’ kernel subimage
Description: Linux kernel
Type: Kernel Image
Compression: gzip compressed
Data Start: 0x90000104
Data Size: 18138672 Bytes = 17.3 MiB
Architecture: AArch64
OS: Linux
Load Address: 0x80080000
Entry Point: 0x80080000
Hash algo: sha256
Hash value: 7d73fe03e02dfa70e18c2442f831a4284d57e82e0aae4625
01ba476285227f0d
Verifying Hash Integrity … sha256+ OK
Decrypting Data … OK
Loading fdt from FIT Image at 90000000 …
Trying ‘fdt-_ddot___ddot___ddot___ddot__nvidia_platform_t210_por
g_kernel-dts_tegra210-p3448-0002-imetrum-vc-mipi.dtb’ fdt subimage
Description: Flattened Device Tree blob
Type: Flat Device Tree
Compression: uncompressed
Data Start: 0x9114c908
Data Size: 254270 Bytes = 248.3 KiB
Load Address: 0x83180000
Hash algo: sha256
Hash value: fbb59e21bcee4024e85b8f1315494ca8423ef63f0ce9a278c110982613d73349
Loading fdt from 0x9114c908 to 0x83180000
Booting using the fdt blob at 0x83180000
Uncompressing Kernel Image
ERROR: reserving fdt memory region failed (addr=0 size=0)
Using Device Tree in place at 0000000083180000, end 00000000831c
113d
copying carveout for /host1x@50000000/dc@54200000…
copying carveout for /host1x@50000000/dc@54240000…
DT property /chosen/nvidia,bluetooth-mac missing in source; can’t c
opy
DT property /chosen/nvidia,wifi-mac missing in source; can’t copy
DT property /psci/nvidia,system-lp0-disable missing in source; can’
t copy
Starting kernel …
